Chandler Limited LTD-1 EQ/Pre Amp ¾ùºâ/»°·Å
É豸
Chandler LimitedµÄLTD-1ÊÇÒ»¸öÊÖ¹¤ÖÆÔìµÄǰÖ÷ŴóÆ÷ºÍ¾ùºâÆ÷£¬Æä²¿¼þºÍ¼¼ÊõÀ´×ÔÓÚÀÏÅÆ¾­µäÉ豸¡£½ÓµØºÍÅäÏß¼¼Êõ¡¢Ô­°æ±äѹÆ÷¡¢¾§Ìå¹Ü¡¢µç¸ÐÆ÷µÈµÈºÜ¶à²úÉúÔ­À´É豸ÄÇÖÖÌØ±ðÉùÒôµÄ²¿¼þºÍ¼¼Êõ¶¼±»²»ÒÅÓàÁ¦µØÖØÐÂÖÆÔì¡£
³ýÁËÄܲúÉú¾­µäµÄÉùÒôÖ®Í⣬¸ÃÉ豸»¹Ìí¼ÓÁ˸÷ÖÖÏÖ´ú¹¦ÄÜ£¬°üÀ¨¸ß×迹ÊäÈë¡¢48V¿ª¹Ø¡¢Êä³ö¿ØÖÆ£¨Ï൱ÓÚÍÆ×Ó£©¡¢¾ùºâÊäÈëÊä³ö¡¢·´Ïࡢƽºâ»°Í²ÊäÈ롢ƽºâÏß·ÊäÈëµÈ£¬³ä×ãµÄ¹©µçÒÔ±£Ö¤µÄ¶¯Ì¬ÓàÁ¿£¬»¹ÓÐ9¸öÔö¼ÓµÄ¾ùºâµã¡£
Ãæ°åÉϸ÷²¿·Ö¼òÒª½éÉÜÈçÏ£º
48V»ÃÏ󹩵翪¹Ø¡£
DIÊäÈëÊä³ö£ºÒ²¿ÉÒÔ×÷Ϊ»°Í²ÊäÈëµÄ¾²Òô°´Å¥¡£
¾ùºâÆ÷ÊäÈëÊä³ö°´Å¥¡£
·´Ïà°´Å¥¡£
Â˲¨Æ÷£ºÕâÊÇÒ»¸ö¸ßͨÂ˲¨£¬ÆµÂÊÊÇ300hz¡¢160hz¡¢80hzºÍ50hz¡£ÕâЩÉèÖúÍÄÇЩ¹ÅµäÉ豸ÊÇÒ»ÑùµÄ¡£
µÍƵ¾ùºâ£ºÕâÀïÊÇµÍÆµÖãÐξùºâ£¬Ëĸö¾ùºâµã·Ö±ðÊÇ220hz¡¢110hz¡¢60hzºÍ35hz¡£ÕâЩÉèÖú;­µäµÄ1073sÊÇÒ»ÑùµÄ¡£
ÖÐÆµ¾ùºâ£ºÕâÀïÊÇÖÐÆµÖÓÐξùºâ£¬Ê®¸ö¾ùºâµã·Ö±ðÊÇ270hz¡¢390hz¡¢560hz¡¢820hz¡¢1k2¡¢1k8¡¢2k7¡¢3k9¡¢5k6ºÍ8k2¡£
¸ßƵ¾ùºâ£ºÕâÀïÊÇ¸ßÆµÖãÐξùºâ£¬Îå¸ö¾ùºâµã·Ö±ðÊÇ16k¡¢12k¡¢6k8¡¢4k7ºÍ3k3¡£
»°Í²ºÍÏß·ÊäÈëÔöÒæ£º»°Í²ÊäÈëÔöÒæ´Ó£­20µ½80db£¬Ïß·ÊäÈëÔöÒæ´Ó£­10µ½£«20db¡£
Êä³ö¿ØÖÆ£ºÏ൱ÓÚµ÷Òǫ̂ÉϵÄÍÆ×Ó¡£¿ÉÒÔ¶ÔÊäÈë¿ØÖÆÐýťÿ¸ñ5dbµÄ·¶Î§ÄÚ½øÐÐ΢µ÷£¬Ò²¿ÉÒÔÔö´óÊäÈëÐźŶø²»²úÉú¼Òô»úµÄÊ§Õæ¡£
×¢£ºµçÔ´µ¥Åä Chandler Limited PSU-1 MKIIµçÔ´¡£
A New Take on a Classic Preamp!
The Chandler Limited LTD-1 is a hand-wired, handcrafted 10-series preamp/equalizer utilizing parts and build techniques from the original manufacturer (that would be Neve). The Neve 1073, of course, is the stuff of audio legend. In the LTD-1, Chandler Limited has, as usual, obsessed themselves with grounding, wiring techniques, original transformers, transistors, and inductors in their quest to give you the sonic spittin&££39; image of the vintage original. Have they succeeded? We certainly think so. Put one through the paces in your studio and hear for yourself. We bet you&££39;re going to love the Chandler Limited LTD-1.
Chandler Limited LTD-1 Single-channel Preamplifier/Equalizer at a Glance:
Original specs, parts, and wiring techniques give you authentic sonic results
How do you improve upon the most sought-after preamp/EQ of all time?
Vintage goodness - with additional modern flexibility
Like the rest of the famous Chandler Limited hand-wired 10-series, the Chandler Limited LTD-1 equalizer and preamplifier not only gives you the sound of the classic original, it also features the same transformers, transistors, inductors, and wiring techniques used to make it. (That may be your first clue as to how they achieve the jaw-dropping results.)
In addition to classic 10-series sound, Chandler Limited juiced the LTD-1 with all the modern functionality you need. They expanded the EQ section, giving you a much larger palate to choose from. Additional features include a front-panel high-impedance DI, 48v switching, an output fader, EQ in/out, phase reversal, balanced mic in, balanced line in, an overbuilt power supply to ensure max headroom, and the aforementioned nine additional EQ points.
Unlike the original Neve 1073, the Chandler Limited LTD-1 offers a wide variety of frequency settings (nine more total additional EQ points), giving you incredible tonal flexibility and control over your sound. For many of us who have been fortunate enough to record through vintage Neve consoles, that sound is the standard by which all other gear is measured. A little more flexibility would have been nice, though. That wish is reality now, thanks to Chandler Limited. When you factor in the vintage sonics, modern features, and weapons-grade build quality, the Chandler Limited LTD-1 becomes a must-have preamp/equalizer.
Chandler Limited LTD-1 Single-channel Preamplifier/Equalizer Features:
Vintage sonics and modern features - what&££39;s not to love?
20dB to 80dB microphone gain
-10dB to 20dB line-level gain
Locking DI input
+48V phantom power
DI in/out switch mutes the microphone input
Highpass filter
Shelving low frequency EQ control
Peaking mid frequency EQ control
Shelving high frequency equalizer
Note: this unit requires the Chandler Limited Power Supply
Chandler Limited&££39;s LTD-1 gives you classic sound with modern flexibility!
ÆÀÂÛÁÐ±í£¨3£©
minyueren Â¥Ö÷
Tech Specs
Preamp TypeSolid State
Number of Channels1
Phantom PowerYes
EQYes
Analog Inputs1 x 1/4", 2 x XLR
Analog Outputs1 x XLR
Rack Spaces1U
Height1.75"
Depth19"
2010-2-27 09:37:52 »Ø¸´
:victory::):victory:
2010-2-27 09:46:56 »Ø¸´
Chandler Limited LTD-1 EQ/Pre Amp ¾ùºâ/»°·Å !:handshake
2010-3-1 02:13:30 »Ø¸´
