8Dio CAGE Strings KONTAKT | 13.9 Gb
»¶ÓÀ´µ½CAGE ¡ª¡ªÓÐÊ·ÒÔÀ´×îÈ«ÃæµÄ¹ÜÏÒÀÖϵÁС£¿ÆæÏµÁвúÆ·ÊÇÓɰÂ˹¿¨½ðÏñ½±¡¢¿Æ¼¼¹«Ë¾ºÍͨÓÃÆû³µ¹«Ë¾³öÆ·G½±»ñ½±×÷Çú¼Ò£¬Troels FolmannºÍ°¬ÃÀ½±ÌáÃû×÷Çú¼ÒºÍ¹ÜÏÒÀÖÑÝ×à¼Ò£¬Colin O ' malley¡£¿ÆæÓÐÈý¾íרÓõÄÏÒ£¬»ÆÍºÍľ¹Ü£¬Ã¿¾í°üº¬9¸öÂó¿Ë·çλÖá£Âó¿Ë·ç·ÖΪÁ½¸öºËÐÄ×é:ºÏ×à×é(close£¬»ìºÏ£¬Ì¨¿¨£¬Ô¶£¬¿í)ºÍdi×à(µãÂó¿Ë·ç1,2,3ºÍ4)£¬Òò´ËÄãÊÇ·ñÏëÒªÍêÕûµÄÕûÌå»ò¸ü¶àµÄ·¿¼ä(di×à)µ¼ÏòµÄFX -ËüµÄËùÓÐÔÚÄãµÄÖ¸¼â¡£
CAGEÏÒÀÖ°æ±¾°üº¬ÁËÒ»¸öÇåÎúµÄÁÐ±í£¬Æä´ÎÊǸ߽âÎö¶ÈµÄwave¡£wav / 24λ/ 96khz¸ñʽ¡£ÎÒÃÇÏëÒª´´Ôì³öÒ»ÖÖÎÞ¿ÉÆ¥µÐµÄȨÍþ¡£½ö×Ö·û´®°æ±¾¾Í°üº¬1100¶à¸ö·¢Òô£¬¼¸ºõ²»¿ÉÄÜ·¢ÏÖûÓи²¸ÇµÄЧ¹û¡£ÎÒÃǶ¨ÖƵÄÁýʽ»ìãçÒýÇæÖ§³ÖÁîÈËÄÑÒÔÖÃÐŵÄÉî¶È£¬Ëü°üº¬³¬¹ý80.000ÐеĴúÂë¡£Áýʽ»ìãçÒýÇæÔÊÐíÄãÍêÈ«¿ØÖÆÑù±¾£¬Äã¿ÉÒÔͨ¹ýÒ»´Îµã»÷¿ØÖƳ¬¹ý1500¸öÑù±¾²ÎÊý¡£´ËÍ⣬Äú»¹¿ÉÒÔËæ»ú»¯ËùÓеÄrack- fx(ex. trance - gate¡¢¹ýÂËÆ÷¡¢EQ)¡£
ËùÒÔÏëÏóһϣ¬ÓÐÒ»×é×îÉî¿ÌµÄ·¢Éù£¬ÓÐÒ»¸ö·Ç³£Ö±¹ÛºÍÇ¿´óµÄ»ìãçÒýÇæ¡£ÎÞÇî¶àµÄ¿ÉÄÜÐÔ¡£Õû¸öÓû§½çÃæ(UI)¶¼ÊÇÓûªÀöµÄ3D¸ñʽÉè¼ÆµÄ£¬¶øÇÒÔÚÒ»ÖÖÔÊÐíÐÂÈ˺Íר¼ÒÔÚ¼¸ÃëÖÓÄÚ¹ö¶¯µÄ·½Ê½¡£¿ÆæÊ¹ÓÃÁËÎÒÃÇרÓеÄV8PϵÁеĸ÷ÖÖ×é¼þ£¬°üº¬³¬¹ý80.000ÐеĴúÂ룬¸øÄú×î´óµÄÁé»îÐԺͿÉÍæÐÔ¡£Ò»¸öÀý×ÓÊÇÔÚ²»Í¬µÄ¹Ø½ÚÖ®¼ä½¨Á¢Ñ»·Á´µÄÄÜÁ¦£¬ÕâÑùÄã¾Í¿ÉÒÔ½¨Á¢×Ô¼ºµÄÍâ»ãÁ´¡£
µ«×îÖØÒªµÄÊÇ£¬CAGEÊǹÜÏÒÀÖFXµÄ×îÈ«ÃæµÄÊղء£ÄÃһЩ¼òµ¥µÄ¡°ÏÒÀÖÁ¢¹Ü¡±¡£ÊÇ·ñÏëÒªÒ»¸öÉÏÉýµÄÏÒÀÖÉùÒô²»ÔÙÖØÒª¡£ÕâÊÇÒ»¸öÎÊÌ⣬ÄãÊÇ·ñÏëÒªËüÔÚÕý³£µÄlegato glissando»òÕß¿ÉÄÜÓë²üÒôµÄ¶¯×÷ - Ò²ÐíÄãÏëÒª¸ü¶àµÄ»ùÓÚtrillµÄglissando»òÕßÒ²ÐíÄãÖ»ÊÇÏëÒªÒ»¸ö¿ÉŵÄÄ¥Ï÷ÏÒÀֱ仯¡£ CAGEÓµÓÐÕâÒ»ÇУ¬ÊǹÜÏÒÀÖFXµÄ×îÖÕÊղء£
ÔÎÄ
Welcome to CAGE ¨C the most comprehensive collection of Orchestral Effects ever done. CAGE (Custom Aleatoric Group Effects) series is produced by Academy Award, TEC and G.A.N.G Award Winning Composer, Troels Folmann and Emmy nominated composer and orchestrator, Colin O¡¯Malley. CAGE comes in three dedicated volumes for Strings, Brass and Woodwinds and each volume contains 9 microphone positions. The microphones are divided into two core groups: Ensemble (Close, Mixed, Decca, Far, Wide) and Divisi (Spot Mic 1, 2, 3 and 4). So whether you want full ensemble or more chamber (divisi) oriented FX ¨C its all there at your finger tips.
The CAGE Strings Edition contains an articulation list second to none and comes in high-resolution wave (.wav / 24 bit / 96khz format). We wanted to create something definitive and unrivaled. The String Edition alone contains over 1100 articulations and it is near impossible to find an effect not covered. The incredible depth of articulations is supported by our custom CAGE Chaos Engine, which contains over 80.000 lines of code. The CAGE Chaos Engine allows you to take complete control of the samples and you can control over 1.500 sample parameters with a single click. In addition you can also randomize all the rack-fx (ex. trance-gate, filters, EQ).
So imagine having the deepest set of articulations with an incredibly intuitive and powerful Chaos Engine. An infinity of possibilities. The entire user-interface (UI) was designed in gorgeous 3D and in a way that allows both newcomers and experts to get rolling in a matter of seconds. CAGE is using a variety of components from our exclusive V8P series and contains over 80.000 lines of code giving you the ultimate flexibility and playability. One example is the ability to make round robin chains between different articulations, so you can build your own sets of FX chains.
But most importantly CAGE is the most comprehensive collection of orchestral FX ever done. Take something as simple a ¡°string riser¡±. It¡¯s no longer matter of whether you want a rising string sound. It is a matter of whether you want it in normal legato glissando or perhaps with tremolo motion to it ¨C maybe you want more of a trill based glissando or maybe you just want a horrific grinding string variation. CAGE has it all and is the definitive collection of orchestral FX.
ÔÎÄ
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´
