AC-AUDIO H1004 ËÄͨµÀ¶ú»ú·Å´óÆ÷
¶ú»ú
( @. C7 h! h9 E) E7 y2 c' j
# |, d1 J% u4 T7 q4 j1 P" y5 u+ i/ l7 `
AC-AUDIO H1004ÊÇÒ»¿îÆ·ÖÊ׿Խ¡¢¹¦ÄÜÇ¿´óµÄËÄͨµÀ¶ú»ú·ÖÅä·Å´óÆ÷£¬²ÉÓø߾«ÃܶȾ§Ìå¹Ü¼¼Êõ¼°Ã¿¸öͨµÀ¶ÀÁ¢³¬´ó¹¦ÂÊ·Å´ó¼¼Êõ¡£ÓµÓÐÊäÈëLEDµçƽ±í¼°Ã¿¸öͨµÀÓÉ8¸öLEDµÆ×é³ÉµÄµçƽ±í£¬Äܹ»ÇåÎúʵʱÏÔʾÐźŵĴóСºÍ±ä»¯¡£±ê×¼µÄ19Ó¢´ç1U»ú¼Üʽ½ðÊô»úÉíÉè¼Æ£¬ÎªÂ¼ÒôÅÏÖ³¡Ñݳö¼°ÒôÀÖ¹¤×÷ÊÒ¼àÌýÌṩÁ¼ºÃµÄ²Ù¿ØÐÔºÍÓÅÐãµÄÉùÒôÆ·ÖÊ¡£
) G1 ?* t8 ^5 @! P% A& [) |¶à¸öH1004¿ÉÒÔÁ¬½ÓʹÓ㬼´Ê¹ÔÚ´óÐÍÀÖ¶Ó¡¢¶àýÌåÖÆ×÷¡¢½ÌÓý¼°´óÐÍ»áÒéµÈ¾ßÓдóÁ¿ÌýÖڵĴóÐͳ¡ºÏ£¬H1004£¨¶à¸ö£©Ò²ÍêȫӦ¸¶×ÔÈç¡£H1004ÊʺÏËùÓÐÀàÐ͵Ķú»ú¡£3 ?* G8 {2 e0 n  v; H7 `, I0 W
8 m- |8 a' C* Q7 ?
0 l( {/ P+ g# }+ `4 n& h% j# Y" V+ Y! Y, Z6 Q
/ A+ n/ |, C* c2 y! W! [! y0 Y( E: k7 f1 \/ ?& |: z
¼¼ÊõÌØÐÔ:
; P6 L4 V0 t: L: I& d- ËÄͨµÀ´ó¹¦Âʶú»ú·ÖÅä·Å´óÆ÷
, h; T3 w. f9 m# k2 v- Ò»Á÷µÄ·Å´óÆ÷¼¼Êõ¼°¸ß¾«ÃܶȾ§Ìå¹Ü¼¼Êõ9 Y3 B: S) X9 h0 b; u- p" T- k
- ±ê×¼19Ó¢´ç1U»ú¼Üʽ´¿ÂÁ»úÉíÉè¼Æ£¬ÓÐЧɢÈÈ
7 n, `5 P, \# c- x, k1 G# M- Ç°Ãæ°åÖ±½ÓÊäÈë½Ó¿Ú. B# x+ ^% q1 v5 p5 J1 L
- ¾ß±¸Æ½ºâÊäÈë
- y7 Z; t; C# y; i- ºóÃæ°åÁ½¸öÁ¢ÌåÉùÊäÈ룬·Ö±ðÓµÓп¨Å©½Ó¿ÚÊäÈëºÍ´óÈýо½Ó¿ÚÊäÈë+ s: V) U, q1 ~# d# w  o" D
- ÿ¸öͨµÀ¶¼ÓÐ8-digitµÄLEDµÆ£¬¾«È·ÏÔʾÊä³öµçƽÇé¿ö
+ v" v( d# I) u; K: T- ÊäÈëµçƽÓÉ4- digitµÄLEDµÆÏÔʾ£¬·Ö±ðÊÇ£º-30/-12/0dB/CLIP$ l4 M) R+ F( a$ i$ F9 B/ w
" ?+ d# o# T, i* \4 a
) L, O+ U5 s9 w2 F²ÎÊý:
! U+ g! ^/ M* P3 k
. X! f! S4 I9 J# F+ H! y0 I  IÖ÷ÊäÈë:
( }9 f2 r' \. h5 tHF-filtered, servo-balanced XLR- and 1/4" TRS Á¬½Ó
8 u, B& C- b! H. uÊäÈë×迹:
  _4 n* q$ f1 L$ n, J40 k¦¸ ƽºâ, 30 k¦¸ ·Çƽºâ1 G  F6 q, {+ p8 W
×î´óÊäÈëµçƽ:
2 D) f, \" w) {+ b& O5 i: o16 dBu ƽºâºÍ·Çƽºâ
; T& H9 `! _+ H9 M* S* i% [/ @CMRR:
1 I8 N$ k; I$ s6 l. {. `typically 40 dB, >55 dB @ 1 kHz4 q) _' R  U7 k
Ö÷Êä³ö:5 I7 P' `' c6 r' y" y8 C5 Z
XLR- and 1/4" TRS Á¬½Ó, ƽºâ
' x( M. O. }9 L: V$ i: U¿¨Å©Êä³ö:
% i" X1 ^+ R4 z& _4 L/ o+ V1/4" TRS Á¬½Ó£¨Á¢ÌåÉù£©/ @; |2 v& H5 J7 V, S9 o
×î´óÊä³ö¹¦ÂÊ:( w( n. `0 i" t' B) z- g
+24 dBm (¸ºÔØ×迹100 ¦¸)% t  q7 z5 c$ o6 `$ c/ c
ƵÂÊÏìÓ¦:4 b5 B0 k1 ?7 x& X- s: g/ h
10 Hz to 150 kHz, +/-3 dB
# p! Y4 q. n( D1 `+ U2 [ÔëÒô:
: r; [) h( H# ^' I" k6 X- |22 Hz to 22 kHz >90 dB @ 0 dBu
" w0 }& t% a8 U4 _! q( O¶¯Ì¬·¶Î§:
* C' N9 j8 G4 a) r& ?- @$ k" F22 Hz to 22 kHz: 110 dB& w  h  j( C9 t: f9 p  C; a, s
Ê§Õæ (THD):& Q9 i  x2 Y: V7 q1 k. k
0.006 % typ. @ +4 dBu, 1 kHz, Gain 1/ d3 s. [0 Y/ a2 p0 ?/ K' w
ÊäÈëµçƽ:
  e5 c  q/ q4 e4- digit LEDÏÔʾ: -30/-12/0dB/CLIP+ g& ^4 j3 J# o8 w& i. _& R
Êä³öµçƽ:" m/ E3 j: ~2 `; |" n; g' a6 p
8-digit LEDÏÔʾ: -30/-24/-18/-12/-6/-3/0 dB/CLIP
+ T5 R# Q0 w$ H; {/ kµçѹ:
  a/ k' m8 E: \& q! yAU: 240 V~50 Hz, US: 120 V~60 Hz, EC: 220 V~50 Hz, UK: 240 V~50 Hz, JP: 100 V~60 Hz, SA: 240 V~50 Hz+ r$ b. e+ A) [- c  m* C$ l
ÄÜÁ¿ÏûºÄ:! n0 H% @5 `( A$ R: Y' S& e
34 W8 G. q6 X6 ^2 g9 A! g* G: ?, h9 O
±£ÏÕË¿:6 u$ Q+ D. r% [) g& ~
100-120v:T630mAH, 200-240v:T315mAH7 D/ k& m; I. Q6 R
³ß´ç (H x W x D):
( J% A- `1 d8 i+ uÔ¼ 45 mm x 483 mm x 190 mm
( H" o  y/ d4 A) E4 w5 e/ [
ÆÀÂÛÁÐ±í£¨2£©
Ö§³Ö ¶¥Ò»Ï ¹²Ãã
2010-3-10 20:49:49 »Ø¸´
ÐÀÉÍ¡¢Ñ§Ï°¡¢Ö§³Ö~~~~:victory:
2010-3-19 10:01:58 »Ø¸´
