ÃÀ¹úJBL¹¤³Ìʦ̸AVÏä°Úλ
×î½ü×°ÐÞ·¿×Ó£¬ÒòΪϲ¼ºóÃæÊÇÉÈ´óµÄÂäµØÆ®´°£¬ÒôÏäµÄ°ÚλºÜÊÇÍ·Í´¡£ÓÚÊǸøÃÀ¹úJBLµÄAV¹¤³ÌʦдÐÅѯÎÊ£¬¿´¿´±ðÈËר¼ÒµÄ´ð¸´£¬ÎÒ¾õµÃºÜÓеÀÀí¡£´ó¼Ò¿ÉÒÔ×÷Ϊ²Î¿¼£¬±¾ÈËÓ¢ÓïˮƽÓÐÏÞ£¬Ò²Ï£ÍûÄÄλӢÓï´ïÈ˸ø³ö¸ü׼ȷµÄ·Òë¡£
˳±ã˵һÏ£¬ÀÏÍâÔðÈÎÐÄÕæµÄºÜÔÞ£¬Ö®Ç°¸øÎһظ´¹ýÒ»·âÖ»ÊǼòµ¥µØ´ð¸´£¬²¢ËµÒª¸ú½øÎÒµÄÎÊÌâ¡£ºóÀ´±ðÈ˾ÍÓëÆäËû¹¤³ÌʦÉÌÁ¿£¬ÕæµÄ¸øÁËÎÒºÜÏêϸµÄ´ð¸´¡£
1.The optimum height for the LCR is determined by the relative height of the listener to the speaker (as a side note¡the face of the actors is usually about 2/3 UP from the bottom of the screen, so it makes sense to have the tweeters on the 2/3 line from the bottom in this respect). If the speaker is mounted above the screen, and so would be above the listener, then the tweeter should be pointed at (angled down) the middle of the seating area. This is true for both the Vertical and the horizontal speakers. The statement ¡°no more then 2 feet higher¡± refers to the Tweeter to Tweeter distance. If you CAN angle the speaker down to be aimed at the center of the listening area, then place the L+R higher will be better. If you CANNOT angle the speaker down then place the speakers no more then 300 (thirty degrees) above the ear height.
2.The P52OWS can go on the ceiling (careful to mount it securely), 8 feet is not too high. Alternatively you can mount the REAR speakers on the SIDE WALL but BEHIND the listener locations. The SIDE speakers should be on the side wall NEXT to or slightly AHEAD of the listener locations.
°´ÕÕÎÒÀí½âµÄÒâ˼¾ÍÊÇ£º
1¡¢×óÖÐÓÒÒôÏäµÄ×î¼Ñ¸ß¶ÈÈ¡¾öÓÚÌýÕßÓëÒôÏäµÄ¸ß¶È¹ØÏµ£¨¸½×¢£ºÍ¨³£ÑÝÔ±µÄÃæ²¿Î»ÓÚÆÁÄ»µ×²¿µ½¶¥²¿µÄ2/3λÖã¬ËùÒÔÔڴ˹æÔòÏÂÓ¦¸Ã½«¸ßÒôµ¥ÔªÎ»Ö÷ÅÓÚÆÁÄ»µÄÉÏ2/3ˮƽÏߣ©¡£Èç¹ûÒôÏäÊÇ·ÅÓÚÆÁÄ»¶¥²¿µÄ£¬Í¬ÑùҲλÓÚÌýÕßÉϲ¿£¬ÄÇô¸ßÒôµ¥ÔªÓ¦¸ÃÂÔÏòÏÂÐýת£¬Ö¸Ïò×ùÎ»ÇøÓòµÄÖмäλÖá£ÕâͬÑùÊÊÓÃÓÚ´¹Ö±»òˮƽ·ÅÖõÄÒôÏä¡£¡°ÖÐÖò»Ó¦¸ßÓÚÖ÷Ïä2Ó¢³ß£¨Ô¼60ÀåÃ×£©¡±µÄ³ÂÊö£¨ËµÃ÷ÊéÉÏдµÄ³ÂÊö£©Ö¸µÄÊǸßÒôµ½¸ßÒôµÄ¾àÀë¡£Èç¹ûÄãÄܹ»½«¸ßÒôµ¥ÔªÏòÏÂÐýת£¬Ö¸ÏòÖмä×ùÎ»ÇøÓò£¬È»ºó½«Ö÷Ïä¹Ò¸ßÒ»µã½«»á¸üºÃ¡£Èç¹û²»ÄÜÏòÏÂÐýת£¬ÄÇôÒôÏä²»Ó¦¸Ã¸ßÓÚ¶ú¶ä¸ß¶È30¶È¡£
2¡¢P52OWS£¨JBLµÄż¼«»·ÈÆ£©¿ÉÒÔ¹ÒÔÚÌ컨°åÉÏ£¨×¢ÒâÐü¹Ò°²È«¡£PS£ºÕæÌùÐÄ£©£¬8Ó¢³ß£¨Ô¼2.4Ã×£©²»Ëã¸ß¡££¨ÒòΪÎҵĿÍÌüºóÃæÊÇ·¹Ìü£¬Ã»ÓкóǽֻÄܹÒÌ컨°åÉÏ£©ÁíÍâÄã¿ÉÒÔ½«ºó»·ÈƹÒÔÚ²àǽÉÏ£¬µ«ÊÇÒªÔÚÌýÕßλÖõĺóÃæ¡£²à»·ÈÆÓ¦¸ÃÔÚ¿¿½ü»òÕßÂÔ³¬Ç°ÓÚÌýÕߵIJàǽÉÏ¡£
