רҵÒôƵ´Ê»ãÖÐÓ¢¶ÔÕÕ
A
AAC automatic ampltiude control ×Ô¶¯·ù¶È¿ØÖÆ
    AB ABÖÆÁ¢ÌåÉù¼Òô·¨
    Abeyancd ÔÝÍ££¬Ç±Ì¬
    A-B repeat A-BÖØ¸´
    ABS absolute ¾ø¶ÔµÄ£¬ÍêÈ«µÄ£¬¾ø¶Ôʱ¼ä
    ABS american bureau of standard ÃÀ¹ú±ê×¼¾Ö
    ABSS auto blank secrion scanning ×Ô¶¯´Å´ø¿Õ°×²¿·ÖɨÃè
    Abstime ¾ø¶ÔÔËÐÐʱ¼ä
    A.DEF audio defeat ÒôƵ½µÔ룬ÔëÉùÒÖÖÆ£¬°éÒô¾²Ôë
    ADJ adjective ¸½ÊôµÄ£¬¸½¼þ
    ADJ Adjust µ÷½Ú
    ADJ acoustic delay line ÉùÑÓ³ÙÏß
    Admission ÔÊÐí½øÈ룬¹©¸ø
    ADP acoustic data processor ÒôÏìÊý¾Ý´¦Àí»ú
    ADP(T) adapter ÑÓÅäÆ÷£¬×ª½ÓÆ÷
    ADRES automatic dynamic range expansion system ¶¯Ì¬·¶Î§À©Õ¹ÏµÍ³
    ADRM analog to digital remaster Ä£Äâ¼Òô¡¢Êý×Ö´¦ÀíÊýÂ볪ÅÌ
    ADS audio distribution system ÒôƵ·ÖÅäϵͳ
    A.DUB audio dubbing ÅäÒô£¬ÒôƵ¸´ÖÆ£¬ºóÆÚ¼Òô
    ADV advance ËÍÈ룬ÌáÉý£¬Ç°ÖÃÁ¿
    ADV adversum ¶Ô¿¹
    ADV advancer Ïàλ³¬Ç°²¹³¥Æ÷
    Adventure ¾ªÏÕЧ¹û
    AE audio erasing ÒôƵ£¨ÉùÒô£©²Á³ý
    AE auxiliary equipment ¸¨ÖúÉ豸
    Aerial ÌìÏß
    AES audio engineering society ÃÀ¹úÉùƵ¹¤³ÌЭ»á
    AF audio fidelity ÒôƵ±£Õæ¶È
    AF audio frequency ÒôƵƵÂÊ
    AFC active field control ×Ô¶¯ÆµÂÊ¿ØÖÆ
    AFC automatic frequency control Éù³¡¿ØÖÆ
    Affricate Èû²ÁÒô
    AFL aside fade listen Ë¥¼õºó£¨ÍÆ×Ӻ󣩼àÌý
    A-fader ÒôƵ˥¼õ
    AFM advance frequency modulation ¸ß¼¶µ÷Ƶ
    AFS acoustic feedback speaker Éù·´À¡ÑïÉùÆ÷
    AFT automatic fine tuning ×Ô¶¯Î¢µ÷
    AFTAAS advanced fast time acoustic analysis system ¸ß¼¶¿ìËÙÒôÏì·ÖÎöϵͳ
    After ×ªÒÆ²¿·ÖÎļþ
    Afterglow Óà»Ô£¬Ï¦ÕÕʱ·ÖÒôÏìЧ¹û
    Against ÒÔ¡­¡­Îª±³¾°
    AGC automatic gain control ×Ô¶¯ÔöÒæ¿ØÖÆ
    AHD audio high density ÒôƵ¸ßÃܶȳªÆ¬ÏµÍ³
   AI advanced integrated Ô¤»ãÁ÷
    AI amplifier input ·Å´óÆ÷ÊäÈë
    AI artificial intelligence È˹¤ÖÇÄÜ
    AI azimuth indicator ·½Î»Ö¸Ê¾Æ÷
    A-IN ÒôƵÊäÈë
    A-INSEL audio input selection ÒôƵÊäÈëÑ¡Ôñ
    Alarm ¾¯±¨Æ÷
    ALC automatic level control ×Ô¶¯µçƽ¿ØÖÆ
    ALC automatic load control×Ô¶¯¸ºÔØ¿ØÖÆ
    Alford loop °®¸£ÌØ»·ÐÎÌìÏß
    Algorithm ÑÝʾ
    Aliasing Á¿»¯ÔëÉù£¬ÆµÆ×»ìµþ
    Aliasing distortion ÕÛµþÊ§Õæ
    Align alignment УÕý£¬²¹³¥£¬Î¢µ÷£¬Æ¥Åä
    Al-Si-Fe alloy head Ìú¹èÂÁºÏ½ð´ÅÍ·
    Allegretto С¿ì°å£¬ÉÔ¿ìµØ
    Allegro ¿ì°å£¬Ñ¸ËÙµØ
    Allocation ÅäÖ㬶¨Î»
    All rating È«£¨Òô£©Óò
    ALM audio level meter ÒôƵµçƽ±í
    ALT alternating Õðµ´£¬½»ÌæµÄ
    ALT alternator ½»Á÷·¢µç»ú
    ALT altertue ת·
    ALT-CH alternate channel ת»»Í¨µÀ£¬½»ÌæÉùµÀ
    Alter ת»»£¬½»Á÷µç£¬±ä»»Æ÷
    AM amperemeter °²Åà¼Æ£¬µçÁ÷±í
    AM amplitude modulation µ÷·ù£¨¹ã²¥£©
    AM auxiliary memory ¸¨Öú´æ´¢Æ÷
    Ambience ÁÙ³¡¸Ð£¬»·ÈƸÐ
    ABTD automatic bulk tape degausser ´Å´ø×Ô¶¯ÕûÌåÈ¥´Åµç·
    Ambient »·¾³µÄ
    Ambiophonic system »·ÈÆÉùϵͳ
    Ambiophony ÏÖ³¡»ìÏ죬»·¾³Á¢ÌåÉù
    AMLS automatic music locate system ×Ô¶¯ÒôÀÖ¶¨Î»ÏµÍ³
    AMP ampere °²Åà
    AMP amplifier ·Å´óÆ÷
    AMPL amplification ·Å´ó
    AMP amplitude ·ù¶È£¬¾àÀë
    Amorphous head ·Ç¾§Ì¬´ÅÍ·
    Abort ÖÕÖ¹£¬Í£Ö¹£¨Â¼ÖÆ»ò²¥·Å£©
    A-B TEST AB±È½ÏÊÔÌý
    Absorber ¼õÕðÆ÷
    Absorption ÉùÒô±»ÎïÌåÎüÊÕ
    ABX acoustic bass extension µÍÒôÀ©Õ¹
  AC accumulator ³äµçµç³Ø
    AC adjustment caliration µ÷½Ú-У׼
    AC alternating current ½»Á÷µç£¬½»Á÷
    AC audio coding ÊýÂëÉù£¬ÒôƵ±àÂë
    AC audio center ÒôƵÖÐÐÄ
    AC azimuth comprator ·½Î»±È½ÏÆ÷
    AC-3 ¶Å±ÈÊýÂë»·ÈÆÉùϵͳ
    AC-3 RF ¶Å±ÈÊýÂë»·ÈÆÉùÊý¾ÝÁ÷£¨½Ó¿Ú£©
    ACC Acceleration ¼ÓËÙ
    Accel ½¥¿ì£¬¼ÓËÙ
    Accent ÖØÒô£¬Éùµ÷
    Accentuator Ô¤¼ÓÖØµç·
    Access ´æÈ¡£¬½øÈ룬Ôö¼Ó£¬Í¨Â·
    Accessory ¸½¼þ£¨½Ó¿Ú£©£¬Åä¼þ
    Acryl ±û»ùõ£»ù
    Accompaniment °é×࣬ºÏ×࣬°éËæ
    Accord ºÍг£¬µ÷ºÍ
    Accordion ÊÖ·çÇÙ
    ACD automatic call distributor ×Ô¶¯ºô½Ð·ÖÅäÆ÷
    ACE audio control erasing ÒôƵ¿ØÖÆÏû´Å
    A-Channel A£¨×ó£©ÉùµÀ
    Acoumeter ²âÌý¼Æ
    Acoustical ÉùµÄ£¬ÉùÒôµÄ
    Acoustic coloring ÉùȾɫ
    Acoustic image ÉùÏñ
    Across ½»²æ£¬²¢ÐУ¬¿ç½Ó
    Across frequency ½»²æÆµÂÊ£¬·ÖƵƵÂÊ
    ACST access time ´æÈ¡Ê±¼ä
    Active Ö÷¶¯µÄ£¬ÓÐÔ´µÄ£¬ÓÐЧµÄ£¬ÔËÐеÄ
    Active crossover Ö÷¶¯·ÖƵ£¬µç×Ó·ÖÆµ£¬ÓÐÔ´·ÖƵ
    Active loudsperker ÓÐÔ´ÒôÏä
    Armstrong MOD °¢Ä·Ë¹ÌØÀʵ÷ÖÆ
    ARP azimuth reference pulse ·½Î»»ù×¼Âö³å
    Arpeggio ÅÃÒô
    Articulation ÉùÒôÇåÎú¶È£¬·¢Òô
    Artificial ·Â¡­¡­µÄ£¬È˹¤µÄ£¬ÊÖ¶¯£¨¿ØÖÆ£©
    AAD active acoustic devide ÓÐÔ´ÉùѧÈí¼þ
    ABC auto base and chord ×Ô¶¯µÍÒôºÏÏÒ
    Architectural acoustics ½¨ÖþÉùѧ
    Arm motor ³ª±Û³ª»ú
    Arpeggio single ÅÃÒôºÍÏÒ£¬·Ö½âºÍÏÒ
    ARL aerial ÌìÏß
    ASC automatic sensitivity control ×Ô¶¯ÁéÃô¶È¿ØÖÆ
    ASGN Assign ·ÖÅ䣬ָ¶¨£¬É趨
   ASP audio signal processing ÒôƵÐźŴ¦Àí
    ASS assembly ×é¼þ£¬×°Å䣬×ܳÉ
    ASSEM assemble »ã±à£¬¼ô¼­
    ASSEM Assembly ×é¼þ£¬×°Å䣬×ܳÉ
    Assign Ö¸¶¨£¬×ª·¢£¬·ÖÅä
    Assist ¸¨Öú£¨×°Öã©
    ASSY accessory ×é¼þ£¬¸½¼þ
    AST active servo techonology ÓÐÔ´ËÅ·þ¼¼Êõ
    A Tempo »Øµ½Ô­ËÙ
    Astigmatism methord ÏóÉ¢·¨
ÆÀÂÛÁÐ±í£¨15£©
hdaudio Â¥Ö÷
C
C cathode Òõ¼«£¬¸º¼«
    C Cell µç³Ø
    C Center ÖÐÐÄ
    C Clear Çå³ý
    C Cold À䣨¶Ë£©
    CA cable µçÀÂ
    Cable µçÀÂ
    Cabinet С²Ù×Ý̨
    CAC coherent acoustic coding Ïà¸ÉÉùѧ±àÂë
    Cache »º³å´æ´¢Æ÷
    Cal calando ¼õСÒôÁ¿
    CAL Calendar ·ÖÀà
    CAL Caliber ¿Ú¾¶
    CAL Calibrate ±ê×¼»¯
    CAL Continuity accept limit Á¬ÐøÐÔ½ÓÊܼ«ÏÞ
    Calibrate У׼£¬¶¨±ê
    Call È¡»Ø£¬¸´³ö£¬ºô³ö
   Can ¼àÌý¶ú»ú£¬´øºÐ
    CANCL cancel ɾ³ý
    CANCL Cancelling Ïû³ý
    Cancel È¡Ïû
    Cannon ¿¨Ù¯½Ó¿Ú
    Canon ¹æÔò
    Cap µçÈÝ
    Capacitance Mic µçÈÝ»°Í²
    Capacity ¹¦ÂÊ£¬µçÈÝÁ¿
    CAR carrier ÔØ²¨£¬Ö§×ù£¬¼¦ÐļÐÍ·
    Card ³ÌÐòµ¥£¬²å¼þ°å
    Cardioid ÐÄÐ͵Ä
    CATV cable television ÓÐÏßµçÊÓ
    Crispness ´àÉù
    Category ÖÖÀ࣬ÀàÐÍ
    Cartridge Èí¼þ¿¨£¬Ê°ÒôÍ·
    Carrkioid ÐÄÐÍ»°Í²
    Carrier ÔØ²¨Æ÷
    Cart תÔË
    Cartridge ºÐʽ´æ´¢Æ÷£¬ºÐʽ´Å´ø
    Cascade ´®Áª
    Cassette ¿¨Ê½µÄ£¬ºÐʽµÄ
    CAV constant angular velocity ºã½ÇËÙ¶È
    Caution ±¨¾¯
    CBR circuit board rack µç·°å¼Ü
    CC contour correction ÂÖÀªÐ£Õý
    CCD charge coupled device µçºÉñîºÏÆ÷¼þ
    CD compact disc ¼¤¹â³ªÆ¬
    CDA current dumping amplifier µçÁ÷·Å´óÆ÷
    CD-E compact disc erasable ¿ÉĨʽ¼¤¹â³ªÆ¬
    CDG compact-disc plus graphic ´øÓо²Ö¹Í¼ÏñµÄCD³ªÅÌ
    CD constant directional horn ºã¶¨Ö¸ÏòºÅ½Ç
    CDV compact disc with video ÃÜÎÆÉùÏñ³ªÆ¬
    CE ceramic ÌÕ´É
    Clock enable ʱÖÓÆô¶¯
    Cell µç³Ø£¬Ôª¼þ£¬µ¥Ôª
    Cellar club µØÏ¾ãÀÖ²¿Ð§¹û
    Cello ´óÌáÇÙ
    CEMA consumer electronics manufacturer'sassociation£¨ÃÀ¹ú£©Ïû·Ñµç×Ó²úÆ·ÖÆÔìÉÌЭ»á
    CENELEC connector Å·ÖÞ±ê×¼21½ÅAVÁ¬½ÓÆ÷
    Cent Òô·Ö
    Central earth ÖÐÐĽӵØ
    CES consumer electronic show £¨ÃÀ¹ú£©Ïû·Ñµç×Ó²úÆ·Õ¹ÀÀ»á
    CF center frequency ÖÐÐÄÆµÂÊ
  Cross fade ÈíÇл»
    CH channel ÉùµÀ£¬Í¨µÀ
    Chain ´«ÊäÁ´£¬ÐŵÀ
    Chain play Á¬ÐøÑÝ×à
    Chamber ÃÜÒôÒôÏìЧ¹û£¬ÏûÉùÊÒ
    CHAN channel ͨµÀ
    Change ½»»»
    Chapter ÇúÄ¿
    Chaper skip Ìø½Ú
    CHAE character ×Ö·û£¬·ûºÅ
    Characteristic curve ÌØÐÔÇúÏß
    Charge ³äµç
    Charger ³äµçÆ÷
    Chase ¸ú×Ù
    Check УÑé
    CHC charge ³äµç
    CH - off ͨµÀÇжÏ
    Choke ºÏ³ª
    Choose Ñ¡Ôñ
    Chromatic É«²Ê£¬°ëÒô
    Church ½ÌÌÃÒôÏìЧ¹û
    CI cut in ÇÐÈë
    CIC cross interleave code ½»²æ¸ôÐбàÂë
    CIRC circulate Ñ­»·
    Circuit µç·
    CL cancel È¡Ïû
    Classic ¹ÅµäµÄ
    Clean ¾»»¯
    CLR clear ¹éÁã
    Click àÖßÕÉù
    Clip Ï÷²¨£¬ÏÞ·ù£¬½ÓÏßÖù
    CLK clock ʱÖÓÐźÅ
    Close ¹Ø±Õ£¬Í£Ö¹
    CLS ¿ØÖÆÊÒ¼àÌý
    Cluster ÒôÏäÕóЧ¹û
    CLV ceiling limit value ÉÏÏÞÖµ
    CMP compact ѹËõ
    CMPT compatibility ¼æÈÝÐÔ
    CMRR common mode rejection ratio ¹²Ä£ÒÖÖÆ±È
    CNT count ¼ÇÊý£¬¼ÇÊýÆ÷
    CNTRL central ÖÐÐÄ£¬ÖÐÑë CO carry out ¶¨Î»Êä³ö
    Coarse ´Öµ÷
    Coax ͬÖáµçÀÂ
    Coaxial ÊýÂëͬÖá½Ó¿Ú
   Code Â룬±àÂë
    Coefficient ϵÊý
    Coincident ¶àÐźÅͬ²½
    Cold ÀäµÄ£¬µ¥±¡µÄ
    Color ȾɫЧ¹û
    COM comb Êá×´£¨Â˲¨£©
    COMB combination ×éºÏÒôÉ«
    COMBI combination ×éºÏ£¬»ìºÏ
    COMBO combination ÅäºÏ£¬×éºÏ
    Combining ¼¯ºÏ£¬½áºÏ
    COMM communication »»ÏòµÄ£¬Çл»×°ÖÃ
    Command Ö¸Á²Ù×÷£¬ÐźÅ
    COMMON ¹«¹²µÄ£¬¹«¹²µØ¶Ë
    Communieation speed ͨѶËÙ¶ÈÑ¡Ôñ
    COMP comparator ±È½ÏÆ÷
    COMP compensate ²¹³¥
    Compact ѹËõ
    Compander ѹËõÀ©Õ¹Æ÷
    Compare ±ÈÄâ
    Compatibility ¼æÈÝ
    Compensate ²¹³¥
    Complex È«Ì×É豸
    Copmoser ´´ÒâÕߣ¬×÷ÇúÕß
    Compressor ѹËõÆ÷
    COMP-EXP ѹÀ©Æ÷
    Compromise £¨ÆµÂÊ£©Æ½ºâ
    Computer ¼ÆËã»ú£¬µçÄÔ
    CON concentric cable ͬÖáµçÀÂ
    CON console ²Ù×Ý̨
    CON controller ¿ØÖÆÆ÷
    Concentric ͬÖáµÄ£¬Í¬ÐĵÄ
    Concert ÒôÀÖÌüЧ¹û
    Condenser Microphone µçÈÝ»°Í²
    Cone type ×¶ÐΣ¨ÑïÉùÆ÷£©
    CONFIG ²¼¾Ö£¬Ïß·½Ó·¨
    Connect Á¬½Ó£¬ÁªÂç
    CORR correct УÕý£¬²¹³¥£¬µÖÏû
    Configuration Ïß·²¼¾Ö
    Confirmation È·ÈÏ
    Consent ÍòÄܲå×ù
    Console µ÷Òǫ̂
    Consonant ¸¨Òô
    Constant ³£Êý
    CONT continuous Á¬ÐøµÄ£¨ÒôÉ«ÌØÐÔ£©
  CONT control ¿ØÖÆ£¬²Ù×Ý
    Contact ½Ó´¥Æ÷
    Content ÄÚÈÝ
    Continue Á¬Ðø£¬¼ÌÐø
    Continue button Á½Â¼Òô¿¨×ùÁ¬Ðø·ÅÒô¼ü
    Contour ÍâÐΣ¬ÂÖÀª£¬±£³Ö
    Contra ´Î°Ë¶È
    Contrast ¶Ô±È¶È
    Contribution ·ÖÅä
    Controlled ¿É¿ØµÄ
    Controller ¿ØÖÆÆ÷
    CONV conventional ³£¹æµÄ
    CONV convert ±ä»»
    CONV convertible ¿Éת»»µÄ
    Copy ¸´ÖÆ
    Correlation meter Ïà¹Ø±í
    Coupler ñîºÏ
    Cover ²¹³¥
    Coverage ÓÐЧ·¶Î§
    CP clock pulse ʱÖÓÂö³å
    CP control program ¿ØÖƳÌÐò
    CPU ÖÐÑë´¦ÀíÆ÷
    CR card reader ¿¨Æ¬ÔĶÁ»ú
    CRC cyclic redundancy check Ñ­»·ÈßÓàУÑé
    Create ½¨Á¢£¬´´Ôì
    Crescendo ½¥Ç¿»ò½¥Èõ
    Crispness Çå´à¸Ð
    CRM control room ¿ØÖÆÊÒ
    CROM control read only memory ¿ØÖÆÖ»¶Á´æ´¢Æ÷
    Crossfader ½»²æ½¥±äÆ÷
    Cross-MOD ½»²æµ÷ÖÆ
    Crossover ·ÖƵÆ÷£¬»»Ïò£¬ÇжÏ
    Cross talk ÉùµÀ´®ÈÅ£¬´®Òô
    Crunch Ħ²ÁÒô
    C/S cycle/second ÖÜ/Ãë
    CSS content scrambling system ÄÚÈݼÓÃÜϵͳ
    CST case style tape ºÐʽ´Å´ø
    CT current µçÁ÷
    CTM close talking microphone ½ü½²»°Í²
    CU counting unit ¼ÆÊýµ¥Ôª
    Cue Ìáʾ£¬Ñ¡Ìý
    Cue clock ¹ÊÕϼÆÊ±ÖÓ
    Cueing Ìáʾ£¬Ö¸³ö
    Cursor ָʾÆ÷£¬¹â±ê
   Curve £¨ÌØÐÔ£©ÇúÏß
    Custom ³£¹æ
    CUT ÇÐÈ¥£¬Ó²Çл»
2009-12-24 19:58:49 »Ø¸´
hdaudio Â¥Ö÷
D
D double Ë«ÖØµÄ£¬¶ÔżµÄ
    D drum ¹Ä£¬´Å¹Ä
    DA delayed action ÑÓ³Ù×÷ÓÃ
    D/Adigital/analog Êý×Ö/Ä£Äâ
    DAB digital audio broadcasting Êý×ÖÒôƵ¹ã²¥
    Damp ×èÄá
    DASH digital audio stationar head Êý×̶ֹ¨´ÅÍ·
    Dashpot »º³åÆ÷£¬¼õÕðÆ÷
    DAT digital audio tape Êý×ÖÒôƵ´Å´ø£¬Êý×Ö¼Òô»ú
    DATA Êý¾Ý
    DATAtron Êý¾Ý´¦Àí»ú
    DATE ÈÕÆÚ
    DB(dB) decibel ·Ö±´
    DB distribution ·ÖÏߺÐ
    DBA decibel asolute ¾ø¶Ô·Ö±´
    DBA decibel adjusted µ÷Õû·Ö±´
    DBB dynamic bass boost ¶¯Ì¬µÍÒôÌáÉý
    DBK decibels referred to one kilowatt ǧÍß·Ö±´
    DBm decibel above one milliwatt in 600 ohms ºÁÍß·Ö±´
    DBS direct broadcast satellite Ö±²¥ÎÀÐÇ
    DBX ѹËõÀ©Õ¹Ê½½µÔëϵͳ
    DC distance controlled Ò£¿ØÆ÷
    DCA digital command assembly Êý×ÖÖ¸Áî×°ÖÃ
    DCE data circuit terminating equipment Êý¾ÝͨѶÏß·ÖÕ¶ËÉ豸
    DCF digital comb filter Êý×ÖÊá×´Â˲¨Æ÷
    DCH decade chorus Ê®Éù²¿ºÏ³ª
    DCP date central processor Êý¾ÝÖÐÐÄ´¦ÀíÆ÷
    DD direct drive Ö±½ÓÇý¶¯
    DD dolby digital Êý×ֶűÈ
    DDC direct digital control Ö±½ÓÊý×Ö¿ØÖÆ
    DDS digital dynamic sound Êý×Ö¶¯Ì¬Éù
    DDT data definition table Êý¾Ý¶¨Òå±í
    Dead ¾ßÓÐÇ¿ÎüÉùÌØÐԵķ¿¼äµÄ¾²¼Å
    DEC decay Ë¥¼õ£¬½¥Èõ£¬ÓàÒôЧ¹û
    Decibel ·Ö±´
    Deck ¿¨×ù£¬Â¼Òô×ù£¬´øÖ§¼ÓµÄ£¬×ß´ø»ú¹¹
    Deemphasis ÊÍ·Å
    Deep reverb ×ÝÉî»ìÏì
    De-esser È¥ßÐÉùÆ÷
  DEF defeat ÏûÒþ£¬¾²Ôë
    Delete ɾ³ý
    Delivery end ÊäÈë¶Ë
    DEMO demodulator ½âµ÷Æ÷
    Demo ×Ô¶¯ÑÝ×à
    Demoder ½âÂëÆ÷
    Density Ãܶȣ¬ÉùÒôÃܶÈЧ¹û
    Detune Òô¸ß΢µ÷£¬È¥Ð³
    DepFin ×ÝÉî΢µ÷
    Depth Éî¶È
    Denoiser ½µÔëÆ÷
    Design Éè¼Æ
    Destroyer ÒÖÖÆÆ÷
    DET detector ¼ì²¨Æ÷
    Deutlichkeit ÇåÎú¶È
    DEV device ×°Öã¬ÒÇÆ÷
    DEX dynamic exciter ¶¯Ì¬¼¤ÀøÆ÷
    DF damping factor ¶¯Ì¬Â˲¨Æ÷
    DFL dynamic filter ¶¯Ì¬Â˲¨
    DFS digital frequency synthesizer Êý×ÖÆµÂÊºÏ³ÉÆ÷
    DI data input Êý¾ÝÊäÈë
    Diagram ͼÐΣ¬Ô­Àíͼ
    Dial µ÷½Ú¶ÈÅÌ
    Difference ²»Í¬£¬²î±ð
    DIFF differential ²î¶¯
    Diffraction ÑÜÉä£¬ÈÆÉä
    Diffuse ´«²¥
    Diffusion À©É¢
    DIG digit Êý×Öʽ
    Digital Êý×ֵģ¬Êý×Öʽ£¬¼ÆÊýµÄ
    Digitalyier Êý×Ö»¯×°ÖÃ
    DIM digital input module Êý×ÖÊäÈëÄ£¿é
    DIM diminished Ë¥¼õ£¬¼õ°ëÒô
    Dimension ·¶Î§£¬Ãܶȣ¬³ß´ç£¬£¨¿Õ¼ä£©Î¬£¬ÉùÏñ¿í¶È
    Din Îåо²å¿Ú£¨µÂ¹ú¹¤Òµ±ê×¼£©
    DIN digital input Êý×ÖÊäÈë
    DIR direct Ö±½ÓµÄ£¬£¨µ÷Òǫ̂£©Ö±½ÓÊä³ö£¬¶¨ÏòµÄ
    Direct box Ö¸ÁîºÐ£¬¿ØÖƺÐ
    Direct sound Ö±´ïÉù
    Directory Ŀ¼
    Direction ÅäÖ÷½Ê½
    Directional ·½Ïò£¬Ö¸ÏòµÄ
    Directivity ·½ÏòÐÔ
    DIS display ÏÔʾÆ÷
   DISC disconnect Çжϣ¬¿ªÂ·
    DISC discriminator ¼øÏàÆ÷
    Disc ³ªÅÌ£¬³ªÆ¬£¬µú
    Disc holder ³ªÆ¬³éÌë
    Disc recorder ÅÌÆ¬Ê½Â¼Òô»ú
    Dischage ÊÍ·Å£¬½â³ý
    Disco µÏ˹¿Æ£¬µÏ˹¿ÆÒôÀÖЧ¹û
    Discord ²»Ð³ºÍÏÒ
    Disk ³ªÅÌ£¬µú
    DISP display ÏÔʾÆ÷£¬ÏÔʾÆÁ
    Dispersion ÆµÉ¢ÌØÐÔ£¬ÉùÒô·Ö²¼
    Displacement ƫת£¬´ú»»
    Distortion Ê§Õæ£¬»û±ä
    DIST distance ¾àÀ룬¼ä¾à
    DIST district Çø¼ä
    Distributer ·ÖÅäÆ÷£¬µ¼Ïò×°ÖÃ
    DITEC digital television camera Êý×ÖµçÊÓÉãÏñ»ú
    Dim ±äÈõ£¬±ä°µ£¬Ë¥¼õ
    DIV divergence ·¢É¢
    DIV division ·Ö¶Î
    DIV divisor ·ÖÅäÆ÷
    Diversity ·Ö¼¯£¨½ÓÊÕ£©
    Divider ·ÖÅäÆ÷
    Divx ÃÀ¹úÊý×ÖÊÓÆµ¿ìµÝ¹«Ë¾¿ª·¢µÄÒ»ÖÖÿ´Î¹Û¿´¸¶·ÑµÄDVD
    DJ Disc Jocker ³ªÆ¬ÆïÊ¿
    DJ dust jacket ·À³¾ÕÖ
    DJ delay ÑÓ³Ù
    DLD dynamic linear drive ¶¯Ì¬ÏßÐÔÇý¶¯
    DLLD direct linear loop detector Ö±½ÓÏßÐÔ»·Â·¼ì²¨Æ÷
    DME digital multiple effector Êý×Ö×ÛºÏЧ¹ûÆ÷
    DMS date multiplexing system Êý¾Ý¶à·´«Êäϵͳ
    DMS digital multiplexing synchronizer
    Êý×Ö¶à·´«Êäͬ²½Æ÷
    DMX data multiplex Êý¾Ý¶à·£¨´«Ê䣩
    DNL dynamic noise limiter ¶¯Ì¬ÔëÉùÒÖÖÆÆ÷
    DNR dynamic noise reduction ¶¯Ì¬½µÔëµç·
    DO dolly out ºóÒÆ
    DO dropout ÐźÅʧÂä
    DOB dolby ¶Å±È
    DOL dynamic optimum loudness ¶¯Ì¬×î¼ÑÏì¶È
    Dolby ¶Å±È£¬¶Å±È¹¦ÄÜ
    Dolby Hx Pro dolby Hx pro headroom extension system ¶Å±ÈHx Pro¶¯Ì¬ÓàÁ¿À©Õ¹ÏµÍ³
    Dolby NR ¶Å±È½µÔë
    Dolby Pro-logic ¶Å±È¶¨ÏòÂß¼­
  Dolby SR-D dolby SR digital ¶Å±ÈÊý×ÖÆµÆ×¼Ç¼
    Dolby Surround ¶Å±È»·ÈÆ
    Dome loudspeaker Çò¶¥ÑïÉùÆ÷
    Dome type Çò¶¥£¨ÑïÉùÆ÷£©
    DOP doppler ¶àÆÕÀÕ£¨ÏìÓ¦£©
    Double ¼Ó±¶£¬Ë«£¬´Î°Ë¶È
    Doubler ±¶ÆµÆ÷£¬¼Ó±¶Æ÷
    Double speed ±¶ËÙ¸´ÖÆ
    D.OUT direct output Ö±½ÓÊä³ö
    Down ÏòÏ£¬Ïòϵ÷Õû£¬ÏÂÒÆ£¬¼õÉÙ
    DPCM differential pulse code modulation ²î¶¯Âö³åµ÷ÖÆ
    DPD direct pure MPX decoder Ö±½Ó´¿¶à·½âµ÷Æ÷
    DPL dolby pro logic ¶Å±È¶¨ÏòÂß¼­
    DPL duplex Ë«¹¤£¬Ë«Áª
    DPLR doppler ¶àÆÕÀÕ£¨ÏµÍ³£©
    D.Poher effect µÂ.²¨°£Ð§Ó¦
    Dr displacement corrector Î»ÒÆÐ£×¼Æ÷£¬Í¬²½»ú
    DR distributor ·ÖÅäÆ÷
    DR drum ´Å¹Ä
    Drain ©µç£¬Â©¼«
    DRAM direct read after write Ò»´ÎÐÔ¶Áд´æ´¢Æ÷
    Drama ¾ç³¡Ð§¹û
    DRAW Ö»¶Á×·ÒäÐ͹âÅÌ
    Dr.Beat È¡×Öʱ¼äУ׼Æ÷
    DRCN dynamic range compression and normalization ¶¯Ì¬·¶Î§Ñ¹ËõºÍ¹éÒ»»¯
    Drive Çý¶¯£¬¼¤Àø
    Dr.Rhythm ½Ú×àͬ²½Ð£×¼Æ÷
    DRPS digital random program selector Êý×Öʽ½ÚÄ¿Ëæ»úÑ¡ÔñÆ÷D
    Drum ¹Ä
    Drum machine ¹Ä»ú
    Dry ¸É£¬ÎÞЧ¹ûÉù£¬Ö±´ïÉù
    DS distortion Ê§Õæ
    DSC digital signal converter Êý×ÖÐźÅת»»Æ÷
    DSL dynamic super loudness µÍÒô¶¯Ì¬³¬Ïì¶È£¬ÖصÍÒô»Ö¸´
    DSM dynamic scan modulation ¶¯Ì¬É¨ÃèËٶȵ÷ÖÆÆ÷
    DSP digital signal processor Êý×ÖÐźŴ¦ÀíÆ÷
    DSP display simulation program ÏÔʾģÄâ³ÌÐò
    DSP digital sound processor Êý×ÖÉùÒô´¦ÀíÆ÷
    DSP digital sound field processor Êý×ÖÉù³¡´¦ÀíÆ÷
    DSP dynamic speaker µç¶¯Ê½ÑïÉùÆ÷
    DSS digital satellite system Êý×ÖÎÀÐÇϵͳ
    DT data terminal Êý¾ÝÖÕ¶Ë
    DT data transmission Êý¾Ý´«Êä
    DTL direct to line Ö±½ÓÈ¥Ïß·
  DTS digital theater system Êý×ÖÓ°¾çԺϵͳ
    DTS digital tuning system Êý×Öµ÷гϵͳ
    DTV digital television Êý×ÖµçÊÓ
    Dual ¶Ôż£¬Ë«ÖØ£¬Ë«
    Dub ¸´ÖÆ£¬ÅäÒô£¬¿½±´£¬×ªÂ¼´Å´ø
    Dubbing mixer »ì¼µ÷Òǫ̂
    Duck °´È룬½øÈë
    Dummyload ¼Ù¸ºÔØ
    DUP Duplicate ¸´ÖÆ£¨Æ·£©
    Duplicator ¸´ÖÆ×°Öã¬Ôö±¶Æ÷
    Duration ³ÖÐøÊ±¼ä£¬¿í¶È
    Duty ¸ºÔØ£¬×÷Ó÷¶Î§£¬¹¦ÂÊ
    Duty cycle Õ¼¿ÕϵÊý£¬Æµ¿í±È
    DUX duplex Ë«¹¤
    DV device ×°Öã¬Æ÷¼þ
    DVC digital video cassette Êý×Ö¼Ïó´ø
    DVD digital video disc Êý×Ö¼¤¹âÊÓÅÌ
    DX ÌìÏßÊÕ·¢¿ª¹Ø£¬Ë«Öصģ¬Ë«ÏòµÄ
    DYN dynamic µç¶¯Ê½µÄ£¬¶¯Ì¬·¶Î§£¬¶¯È¦Ê½µÄ
    Dynamic filter ¶¯Ì¬Â˲¨£¨ÌØÊâЧ¹û´¦Àí£©Æ÷
    Dynamic Microphone ¶¯È¦»°Í²
    Dynamic range ¶¯Ì¬·¶Î§
    Dynode µç×Ó±¶ÔöÆ÷µç¼«
2009-12-24 20:00:16 »Ø¸´
hdaudio Â¥Ö÷
E
    E early warning Ô¤¾¯
    E earth ÕæµØ£¬½ÓµØ
    E error ´íÎ󣬲î´í£¨¹ÊÕÏÏÔʾ£©
    EA earth µØÏߣ¬ÕæµØ
    EAR early ÔçÆÚ£¨·´ÉäÉù£©
    Earphone ¶ú»ú
    Earth terminal ½ÓµØ¶Ë
    EASE electro-acooustic simulators for engineers ¹¤³ÌʦÓõçÉùÄ£ÄâÆ÷£¬¼ÆËã»úµçÉùÓëÉùѧÉè¼ÆÈí¼þ
    Eat ÊÕÈ¡ÐźÅ
    EBU european broadcasting union Å·Ö޹㲥ÁªÃË
    EC error correction Îó²îУÕý
    ECD electrochomeric display µçÖ±äÉ«ÏÔʾÆ÷
    Echo »ØÉù£¬»ØÉùЧ¹û£¬»ìÏì
    ECL extension zcompact limitter À©Õ¹Ñ¹ËõÏÞÖÆÆ÷
    ECM electret condenser microphone פ¼«Ì廰Ͳ
    ECSL equivalent continuous sound level µÈ¼¶Á¬ÐøÉù¼¶
    ECT electronec controlled transmission µç¿Ø´«Êä
    ED edit editor ±à¼­£¬±à¼­Æ÷
    Edit ±à¼­
  Edge tone ±ßÀâÒô
    EDTV enhanced definition television ÔöÇ¿ÇåÎú¶ÈµçÊÓ£¨Ò»ÖֿɼæÈݸßÇåÎú¶ÈµçÊÓ£©
    E-DRAW erasable direct after write ¿É´æ¿ÉĨ¶Áд´æ´¢Æ÷
    EE errors excepted ÔÊÐíÎó²î
    EFF effect efficiency Ч¹û£¬×÷ÓÃ
    Effector ²Ù×Ý×°Öã¬Ð§¹ûÆ÷
    Effects generator Ч¹û·¢ÉúÆ÷
    EFM 8/14λµ÷ÖÆ·¨
    EFX effect Ч¹û
    EG envelope generator °üÂç·¢ÉúÆ÷
    EIA electronec industries association £¨ÃÀ¹ú£©µç×Ó¹¤ÒµÐ­»á
    EIAJ electronic industries association Japan ÈÕ±¾µç×Ó¹¤ÒµÐ­»á
    EIN einstein Á¿×ÓĦ¶û£¨ÄÜÁ¿µ¥Î»£©
    EIN equivalent input noise µÈЧÊäÈëÔëÉù
    EIO error in operation ²Ù×÷Âë´íÎó
    Eject µ¯Æð²ÕÃÅ£¬È¡³ö´Å´ø£¨¹âÅÌ£©£¬³öºÐ
    EL electro luminescence ³¡Ö·¢¹â
    ELAC electroacoustic µçÉù£¨Æ÷¼þ£©
    ELEC electret פ¼«Ìå
    Electret condenser microphone פ¼«Ì廰Ͳ
    ELF extremely low frequency ¼«µÍƵ
    ELEC electronec µç×ÓµÄ
    Electroacoustics µçÉùѧ
    EMI electro magnetic interference µç´Å¸ÉÈÅ
    Emission ·¢Éä
    EMP emphasispo ¼ÓÖØ
    EMP empty ¿ÕÔØ
    Emphasis ¼ÓÖØ
    EMS emergency switch ½ô¼±¿ª¹Ø
    Emulator Ä£ÄâÆ÷£¬·ÂÕæÉ豸
    EN enabling Æô¶¯
    Enable ¸³ÄÜ£¬³·Ïû½ûÖ¹Ö¸Áî
    Encoding ±àÂë
    End Ä©¶Ë£¬½áÊø£¬ÖÕÖ¹
    Ending ÖÕ¶Ë£¬¶Ë½Ó·¨£¬Ïâ±ß
    ENG engineering ¹¤³Ì
    Engine ÔËÐУ¬Ê¹ÓÃ
    ENG land ¹¤³Ì½ÓµØ
    Enhance ÔöÇ¿£¬Ìá¸ß£¬ÌáÉý
    ENS ensemble ºÏ×à
    ENS envelope sensation Ⱥ¸Ð
    Eensemble ºÏ×à
    Eensemble ºÏ×à
    ENT enter ¼Ç¼
Enter ¼ÇÈ룬½øÈ룬»Ø³µ
    Entering ²åÈ룬¼Ç¼
    Entry ÊäÈëÊý¾Ý£¬½øÈë
    ENV envelope °üÂçÏß
    Envelopment »·ÈƸÐ
    EOP electronic overload protection µç×Ó¹ýÔØ±£»¤
    EOP end of program ³ÌÐò½áÊø
    EOP end output Ä©¶ËÊä³ö
    EOT end of tape ´Å´øÎ²¶Ë
    EP extend playing record ¶àÇúÄ¿³ªÆ¬
    EP extended play ³¤Ê±¼ä·Å¼£¬Ãܼ
    EPG edit pulse generator ±à¼­Âö³å·¢ÉúÆ÷
    EPS emergency power supply Ó¦¼±µçÔ´
    EQ equalizer ¾ùºâÆ÷£¬¾ùºâ
    EQ equalization ¾ùºâ
    EQL equalization ¾ùºâ
    Equal-loudness contour µÈÏìÇúÏß
    Equipped ×¼±¸ºÃµÄ£¬ÒÑ×°±¸
    Equitonic È«Òô
    Equivalence µÈЧֵ
    ER erect ÉèÖÃ
    ER error ´íÎó£¬Îó²î
    ERA earphone ¶ú»ú
    Eraser Ĩȥ£¬Ïû³ý
    Erasing ²Á³ý£¬ÇåÏ´
    Erasure ĨÒô
    Erase Ïû³ý£¬Ïû
    Er early ÔçÆÚµÄ
    ERCD extended resolution CD À©Õ¹½âÎö¶ÈCD
    EREQ erect equalizer ¾ùºâÆ÷£¨Æµµã£©Î»Ö㨵ãƵ²¹³¥µç·µÄÖÐµãÆµÂÊ£©µ÷Õû
    ERF early reflection ÔçÆÚ·´É䣨Éù£©
    Ernumber ÔçÆÚ·´ÉäÉùÁ¿
    Error ´íÎ󣬳ö´í£¬²»ÕýÈ·
    ES earth swith ½ÓµØ¿ª¹Ø
    ES electrical stimulation µã¼¤Àø
    Escqpe Í˳ö
    ETER eternity ÎÞÏÞ
    Euroscart Å·ÖÞ±ê×¼21½ÅAVÁ¬½ÓÆ÷
    Event ʼþ
    EVF envelope follower °üÂç¸úËæÆ÷£¨ÒôÏìºÏ³É×°Öù¦Äܵ¥Ôª£©
    EX exciter ¼¤ÀøÆ÷
    EX exchange ½»»»
    EX expanding À©Õ¹
    EXB expanded bass µÍÒôÔöÇ¿
  EXC exciter ¼¤ÀøÆ÷
    EXCH exchange ת»»
    Exclusive רÓõÄ
    Excursion Æ«ÒÆ£¬Æ«×ª£¬Æ¯ÒÆ£¬Õñ·ù
    EXP expender À©Õ¹Æ÷£¬¶¯Ì¬À©Õ¹Æ÷
    EXP export Êä³ö
    Exponential horn tweeter Ö¸ÊýÐ͸ßÒôºÅ½ÇÑïÉùÆ÷
    Expression pedal ±í´ï̤°å£¨ÓÃÓÚ¿ØÖÆÀÖÆ÷»òЧ¹ûÆ÷µÄ½Å̤װÖã©
    EXT extend À©Õ¹
    EXT exterior Íâ½ÓµÄ£¨É豸£©
    EXT external ÍⲿµÄ£¬Íâ½ÓµÄ
    EXT extra ³¬¹ý
    EXTN extension À©Õ¹£¬ÑÓÉ죨³Ì¿Ø×°Öù¦Äܵ¥Ôª£©
    Extract ¹ìµÀÌá³ö
    EXTSN extension À©Õ¹£¬ÑÓÉ죨³Ì¿Ø×°Öù¦Äܵ¥Ôª£©
2009-12-24 20:00:54 »Ø¸´
hdaudio Â¥Ö÷
F
F fast ¿ì£¨ËÙ£©
    F feedback ·´À¡
    F forward Ïòǰ
    F foot ½Å̤£¨×°Öã©
    F frequency ƵÂÊ
    F function ¹¦ÄÜ
    Ffactor Òò×Ó£¬ÒòËØ£¬ÏµÊý£¬ÒòÊý
    Fade Ë¥¼õ£¨ÒôÁ¿¿ØÖƵ¥Ôª£©
    Fade in-out µ­Èëµ­³ö£¬Âýת»»
    Fader Ë¥¼õÆ÷
    Fade up ƽ»¬ÉÏÉý
    Failure ¹ÊÕÏ
    Fall Ë¥Â䣬б¶È
    Faraday shield ·¨À­µÚÆÁ±Î£¬¾²µçÆÁ±Î
    FAS full automatic search È«×Ô¶¯ËÑË÷
    Fast ¿ìËÙ£¨×Ô¶¯ÑÝ×à×°ÖõÄËٶȵ÷ÕûÅ¥£©
    Fastener ½ÓÏßÖù£¬±ÕËø
    Fat »ëºñ£¨ÒôÕùµ÷ÕûÅ¥£©
    Fattens out ƽֱÊä³ö
    Fault ¹ÊÕÏ£¬Ëð»µ
    Fader Ë¥¼õÆ÷£¬µ÷ÒôÌ¨ÍÆÀ­µçλÆ÷£¨ÍÆ×Ó£©
    Fading in ½¥ÏÔ
    Fading out ½¥ÏÔ
    False ´íÎó
    Fancier ÒôÏì·¢ÉÕÓÑ
    Far field Ô¶³¡
    FatEr ·áÂúµÄÔçÆÚ·´Éä
  FB feedback ·´À¡£¬Éù·´À¡
    FB fuse block ÈÛË¿ºÐ
    F.B fiver by ÇåÎú
    FBO feedback outrigger ·´À¡ÑÓÉì
    FCC federal communications commission £¨ÃÀ¹ú£©Áª°îͨÐÅίԱ»á
    FD fade depth Ë¥¼õÉî¶È
    FD feed À¡ÈëÐźÅ
    FDR fader Ë¥¼õÆ÷
    FeCr Ìú¸õ´Å´ø
    Feed À¡¸ø£¬À¡È룬ÊäÈë
    Feeder À¡Ïß
    Feed/Rewind spool ¹©´øÅÌ/µ¹´øÅÌ
    Ferrite head ÌúÑõÌå´ÅÍ·
    F.&B. forward and back ǰºó
    FET field effect technology ³¡Ð§Ó¦¼¼Êõ
    FF flip flop ´¥·¢Æ÷
    FF fast forward ¿ì½ø
    FG flag generator ±êÖ¾Ðźŷ¢ÉúÆ÷
    FI fade in ½¥½ø
    Field Éù³¡
    Field pickup ʵ¿öʰÒô
    File Îļþ£¬´æÈ룬¹éµµ£¬Êý¾Ý¼¯£¬£¨Í⣩´æ´¢Æ÷
    Fill-in ÌîÈë
    FILT filter Â˲¨Æ÷
    Final ÔÏĸ
    Fine ΢µ÷
    Fingered ¶àÖ¸ºÍÏÒ
    Finger ÊÖÖ¸£¬µ¥Ö¸ºÍÏÒ
    FIN GND ½ÓµØÆ¬
    Finish ½áÊø£¬ÐÞÊÎ
    FIP digital frequency display panel Êý×ÖÆµÂÊÏÔʾ°å
    FIR finite-furation impulse response ÓÐÏ޳弤ÏìÓ¦£¨Â˲¨Æ÷£©
    Fire Æô¶¯
    Fix È·¶¨£¬¹Ì¶¨
    Fizz ˻˻Éù
    FL fluorescein Ó«¹âЧ¹û
    Flange ·¨À¼ÒôÏìЧ¹û£¬Ïâ±ßЧ¹û
    Flanger Ïâ±ßÆ÷
    Flanging Ïâ±ß
    Flash ÉÁ¹âÐźÅ
    Flat ƽ̹£¬Æ½Ö±
    Flat noise °×ÔëÉù
    Flat tuning ´Öµ÷
    Flex ¹Õµã
  FLEX flexible cord ÈíÏߣ¬ÈûÉþ
    FLEX frequency level expander ƵÂÊÀ©Õ¹Æ÷
    FLEXWAVE flexible waveguide ¿ÉÍäÇú²¨µ¼¹Ü
    FLG flanger Ïâ±ßÆ÷
    Flip Ìæ»»£¬µ÷»»
    Floating ·Ç¹Ì¶¨µÄ£¬Ðü¸¡Ê½µÄ
    Floppy disc Èí´ÅÅÌ
    FLTR filter Â˲¨Æ÷
    Fluorescent display Ó«¹âÏÔʾÆ÷
    Flute ³¤µÑ
    Flutter Ò»ÖÖ·ÅÒôÊ§Õæ£¬Âö³å¸ÉÈÅ£¬²ü¶¯
    FLW follow ¸ú×Ù£¬Ë涯
    FLY ¾ùºâÆ÷
    FM fade margin Ë¥ÂäÉ豸
    FM frequency modulation µ÷Ƶ¹ã²¥
    FM/SW telescopic rod aerial µ÷Ƶ/¶Ì²¨À­¸ËÌìÏß
    FO fade out ½¥Òþ
    Focus ½¹µã£¬ÖÐÐĵã
    Foldback ·µËÍ£¬¼àÌý
    Foot(board) ½Å̤°å£¨¿ª¹Ø¿ØÖÆ£©
    Fomant ¹²Õñ·å
    Force ¹ýÔØ£¬Ç¿ÐÐÖÃÈë
    Format ¸ñʽ£¬¸ñʽ»¯£¬¹æ¸ñ£¬£¨´¢´æÆ÷Öеģ©ÐÅÏ¢°²ÅÅ
    Forward תËÍ
    FPR floating point routine ¸¡µã³ÌÐò
    FPR full power response È«¹¦ÂÊÏìÓ¦
    FR frequency ƵÂÊ
    FR frequency response ƵÂÊÏìÓ¦
    Frame »­Ã棬£¨µçÊӵģ©Ö¡
    Frames Ö¡Êý
    Free Ê£Ó࣬×ÔÓÉ
    Free echoes ÎÞÏÞ»ØÉù£¨ÑÓʱЧ¹û´¦ÀíµÄÒ»ÖÖ£©
    Free edge ×ÔÓÉÕÛ»·£¨ÑïÉùÆ÷£©
    FREEQ frequency ƵÂÊ
    F.Rew fast rewind ¿ìµ¹
    Freeze Äý¹Ì£¬ÉùÒôÖèÍ££¬¾²Ö¹
    Frequency divider ·ÖƵÆ÷
    Frequency shifter 񮮵Æ÷£¬±äƵÆ÷
    Fricative ²ÁÒô
    Front Ç°ÃæµÄ£¬ÕýÃæµÄ
    Front balance ǰÖÃÆ½ºâ
    Front process ǰÉù³¡´¦Àí
    FRU field replaceable unit ²å¼þ£¬¿É»»²¿¼þ
    FS frequency shift ÆµÒÆ£¬±äµ÷
  FS full short È«¾°
    FT facility terminal É豸£¨Êä³ö£©¶Ë¿Ú
    FT fine tuning ΢µ÷
    FT foot ½Å̤װÖÃ
    FT function tist ¹¦ÄܲâÊÔ
    FT frequency tracke ƵÂʸú×ÙÆ÷
    FTG fitting ½ÓÍ·£¬Åä¼þ
    FTS faverate track selection ×î¼ÑÉù¼£Ñ¡Ôñ
    Full ·áÂú£¬±¥ºÍ
    Full auto È«×Ô¶¯
    Full effect recording ȫЧ¹û¼Òô
    Full range È«ÒôÓò£¬È«Æµ
2009-12-25 19:51:56 »Ø¸´
hdaudio Â¥Ö÷
G
G gate ÃÅ£¨µç·£©
    G ground ½ÓµØ
    GA general average ×ÜÆ½¾ùÖµ
    Gain ÔöÒæ£¬ÌáË¥Á¿
    Game ¿¨À­OKÒôÏìЧ¹û
    Gamut ÒôÓò
    Gap ¼ä¸ô£¬Í¨µÀ
    Gate ÔëÉùÃÅ£¬ÃÅ£¬Ñ¡Í¨
    Gated Rev ѡͨ»ìÏ죨¿ªÃŵÄʱ¼äÄÚÓлìÏìЧ¹û£©
    GB ¼ª×Ö½Ú
    Gear ·ç¸ñ£¬¸ñµ÷
    GEN generator £¨Ðźţ©·¢ÉúÆ÷
    General ×ÛºÏЧ¹û
    Generator Ðźŷ¢ÉúÆ÷
    GEQ graphie equalizier ͼʾ¾ùºâÆ÷
    GD ground ½ÓµØ
    Girth ¼¤ÀøÆ÷µÄµÍÒôÇ¿¶Èµ÷½Ú
    Glide strip »¬×àÌõ£¨ÑÝ×à×°Öã©
    GLLS-sando »¬½µ£¨ÑÝ×àµÄЧ¹û£©
    Global ×ÜÌåÉè¼Æ
    GM genertal MIDI ͨÓÃÀÖÆ÷Êý×Ö½ÓÆ÷
    GND ground µØÏߣ¬½ÓµØ¶Ë GP group ±à×é
    GPR general purpose receiver ͨÓýÓÊÕ»ú
    GPI general purpose interface ͨÓýӿÚÉ豸
    Govern µ÷Õû£¬¿ØÖÆ£¬²Ù×÷£¬ÔËת
    GR group ×éºÏ
    Gramophone ÁôÉù»ú£¬³ª»ú
    Graphic equalizer ͼʾ¾ùºâÆ÷£¬Í¼±í¾ùºâÆ÷
    GRND ground ½ÓµØ
    Groove ¹âÅÌÂÝÐýµÀµÄ²Û
  Group ±à×飨µ÷Òǫ̂£©£¬×é
    Growler ÏßȦ¶Ì·²âÊÔÒÇ
    GT gate ÃÅ£¬ÔëÉùÃÅ
    GT gauge template Ñù°å
    GTE gate ÃÅ£¨µç·£©
    GTR gate reverb ÃÅ»ìÏì
    Guard ±£»¤£¬·À»¤×°ÖÃ
    GUI graphical user interface ͼÐÎÓû§½Ó¿Ú
    Guitar ¼ªËü
    Guy À­Ïß
    Gymnasium ÌåÓý¹ÝЧ¹û
    Gyrator »ØÐýÆ÷
H
    HQAD high quality audio disc ¸ßƷλÒôƵ¹âÅÌ
    HR handing room ²Ù×÷ÊÒ
    HR high resistance ¸ß×迹£¨ÐźŶË×ÓµÄ×è¿¹ÌØÐÔ£©
    HRTF head-related transfer function ÈËÄÔÏà¹Ø×ª»»¹¦ÄÜ
    HS head set Í·´÷ʽ¶ú»ú
    HS hybrid system »ìºÏϵͳ
    HT home theater ¼ÒÍ¥Ó°Ôº£¬¼ÒÍ¥¾ç³¡
    Hubrid »ìºÏÍøÂ磬ÇŽӲí·
    Hum ½»Á÷ºßÉù£¬½»Á÷µÍƵ£¨50Hz£©ÔëÉù
    Hum and Noise ºßÔÓÉù£¬½»Á÷ÔëÉù
    Humidity ʪ¶È£¬ÊªÆø
    HUT homes using TV ¼ÒÓõçÊÓ
    HVDS Hi-visual dramatic sound ¸ß±£ÕæÏÖ³¡¸ÐÒôÏìϵͳ
    HX headroom extension ¶¯Ì¬ÓàÁ¿À©Õ¹£¨ÏµÍ³£©£¨Ò»ÖֶűȽµÔëϵͳ£©£¬¾»¿ÕÑÓÉì
    H horizonal ˮƽ£¨×´Ì¬£©
    H hot ÈÈ£¨Æ½ºâÐźŶ˿ڵġ°Èȶˡ±£©
    Hall ÌüÌÃЧ¹û
    Handle ÊÖ±ú£¬¿ØÖÆ
    HAR harmonec г²¨
    Hard knee Ó²¹Õµã£¨Ñ¹ÏÞÆ÷£©
    Harmonic г²¨
    Harmonic distortion г²¨Ê§Õæ
    Harmonic Generator г²¨·¢ÉúÆ÷
    Harmonize £¨Ê¹£©ºÍг£¬Ð£Òô
    Harmony ºÍг
    Harp ÊúÇÙ
    Hash ÔÓÂÒÂö³å¸ÉÈÅ
    Hass effect ¹þ˹ЧӦ
    HD harmonic distortion г²¨Ê§Õæ
    HDCD high definition compatible digital ¸ß·Ö±æÂʼæÈÝÐÔÊý×Ö¼¼Êõ
  HDTV hight definiton television ¸ßÇåÎú¶ÈµçÊÓ
    Head ¼Òô»ú´ÅÍ·£¬Ç°Öõ쬳ªÍ·
    Head azimuth ´ÅÍ··½Î»½Ç
    Head gap ´ÅÍ··ì϶
    Headroom ¶¯Ì¬ÓàÁ¿£¬¶¯Ì¬·¶Î§ÉÏÏÞ£¬µçƽ´¢±¸
    Headphone Í·´÷ʽ¶ú»ú
    Headset Í·´øÊ½¶ú»ú
    Heavy metel ÖØ½ðÊô
    HeiFin ´¹Ö±Î¢µ÷
    Hearing Ìýµ½£¬Ìý¾õ
    Heat sink É¢ÈȰå
    Help £¨¶Ô³ÌÐòµÄ£©½âÊÍ
    HF high frequency ¸ßƵ£¬¸ßÒô
    Hi hign ¸ßƵ£¬¸ßÒô
    HI band ¸ßƵ´ø
    Hi-end ×î¸ßÆ·ÖÊ£¬¶¥¼¶
    Hi-BLEND ¸ßƵ»ìºÏָʾ
    High cut ¸ßÇÐ
    High pass ¸ßͨ
    Highway ×ÜÏߣ¬ÐÅϢͨµÀ
    Hi-Fi high fidelity ¸ß±£Õ棬¸ß±£ÕæÒôÏì
    Hiss ßÐÉù
    Hi-Z ¸ß×迹
    HL half reverb ´óÌü»ìÏì
    Hoghorn Å×ÎïÃæÀ®°È
    Hoisting ÌáÉý
    Hold ±£³Ö£¬ÎÞÏÞÑÓÐø£¬±£³Öʱ¼ä
    Holder Ö§¼Ü£¬¹Ì¶¨¼Ü
    Hold-off ½â³ý±£³Ö
    Home ¼ÒÍ¥£¬ÊµÓÃ
    Home theatre ¼ÒÍ¥Ó°Ôº
    Horizontal ˮƽµÄ£¬ºáÏòµÄ
    Horn ¸ßÒôºÅ½Ç£¬ºÅͲ£¬Ô²ºÅ
    Hornloaded ºÅ½Ç´¦Àí
    Hot Èȶˣ¬¸ßµçλ¶Ë
    Hour Сʱ
    Howling Ð¥½ÐÉù
    Howlround Ð¥½Ð
    H.P headphone Í·´÷ʽ¶ú»ú
    HPA haas pan allochthonous ¹þ˹ÉùÏñÆ¯ÒÆ
    HPF high pass filter ¸ßͨÂ˲¨Æ÷
    HQ high quality ¸ßÖÊÁ¿£¬¸ßƷλ
    Hyper Condenser ³¬ÐÄÐ͵Ä
    HZ hertz ºÕ×È
  H hard Ó²µÄÒôÏìЧ¹ûÌØÕ÷
2010-3-28 16:40:03 »Ø¸´
hdaudio Â¥Ö÷
I
    IC integrated circuit ¼¯³Éµç·
    ID identification ʶ±ð
    ID identify ±êÖ¾
    Idle ¿ÕÔØµÄ£¬ÎÞЧ¹ûµÄ
    IDTV improved definition television ¸Ä½øÇåÎú¶ÈµçÊÓϵͳ
    IEC international electrical commission ¹ú¼Êµç¹¤Î¯Ô±»á
    IEEE institute of electrical&electronic engineers µçÆø¼°µç×Ó¹¤³Ìʦѧ»á
    IF intermidiate frequency ÖÐÆµµÄ
    I/F interface ½Ó¿Ú
    IHF the institute of high fidelity ¸ß±£ÕæÑ§»á
    IIR infinite-duration impulse response ÎÞÏ޳弤ÏìÓ¦
    IKA Interactive knee adapt »¥µ÷¹ÕµãÊÊÅ䣬Èí¹Õµã
    I/O input/output ÊäÈë/Êä³ö
    IM impulse modulation Âö³åµ÷¼Á
    IM image Ó°Ïó
    IMD intermodulation distortion »¥µ÷Ê§Õæ
    IMP impedance ×迹
    IMP impedence ×迹
    IMP interface message processor ½Ó¿ÚÐÅÏ¢´¦Àí»ú
    Improper ´íÎóµÄ
    IN inductor ¸ÐÓ¦Æ÷
    IN input ÊäÈë
    IN inverter ·´ÑÝÆ÷£¬µ¹ÏàÆ÷
    Inactive ÔÝÍ££¬Ê§Ð§µÄ
    INC incoming ÒýÈëÏß
    INC increase Ôö¸ß
    INCOM intercom ÄÚ²¿Í¨»°£¨ÏµÍ³£©
    In phase ͬÏà
    IND index Ë÷Òý£¬±êÖ¾£¬Ö¸Êý
    IND indicator ָʾÆ÷
    Indicator ÏÔʾÆ÷£¬Ö¸Ê¾Æ÷
    Indirect ¼ä½Ó
    Inductance µç¸Ð
    Induction ¸ÐÓ¦£¬ÒýÈë
    INF infinite ÎÞÏÞ´ó
    Infrared ºìÍâÏßµÄ
    Infra-red remote control ºìÍâÏßÒ£¿Ø
    INH inhibit ÒÖÖÆ£¬½ûÖ¹
    Initial Éùĸ£¬³õʼ»¯
    In/Out ¼ÓÓë²»¼ÓÑ¡Ôñ£¨Ï൱ÓÚÅÔ·£©¿ª¹Ø£¬½Óͨ¿ª¹Ø
    Infinite ÎÞÏ޵쬷ÇÏÞ¶¨µÄ
   Increase Ôö¼Ó
    Initial Delay ÔçÆÚÑÓʱ£¬³õ´ÎÑÓʱ
    Inject ×¢È룬ÖÃÈë Inlead ÒýÈëÏß
    Inlet ÒýÈëÏߣ¬²åÈë In-line ´®ÁªµÄ£¬ÔÚÏßµÄ
    INP input ÊäÈ루¶Ë¿Ú£©
    INV invertor µ¹ÏàÆ÷£¬·­×ªÆ÷£¬·´ÏàÆ÷£¬±ä»»Æ÷
    Inverse µ¹Ïà
    Inverseve Rev µßµ¹Ê½»ìÏìЧ¹û
    Invert ÂÖÁ÷£¬·´×ª
    I/O in/out ÊäÈë/Êä³ö£¨½Ó¿Ú£©£¬ÐźŲåÈë½Ó¿Ú I/O
    instead of Ìæ´ú
    IPE integrated parameter editing ×ۺϲÎÁ¿±à¼­
    IR infrared sensor ºìÍâÏß´«¸ÐÆ÷
    IROA impulse response optimum algorithm Âö³åÏìÓ¦×î¼ÑËã·¨
    IS information separators ÐÅÏ¢·Ö¸ô×Ö·û
    IS in service ²»ÖжϷþÎñ
    ISO International Standardization Organization ¹ú¼Ê±ê×¼»¯×éÖ¯
    Input ÊäÈë
    Indicator ÏÔʾÆ÷£¬Ö¸Ê¾µÆ
    INS insert ²åÈ루Ðźţ©£¬²åÈë½Ó¿Ú
    INSEL input select ÊäÈëÑ¡Ôñ
    INST instant Ö±½ÓµÄ£¬ÊµÊ±
    INST institution ½¨Á¢£¬ÉèÖÃ
    INST instrument ÒÇÆ÷£¬ÀÖÆ÷
    Instrument ÀÖÆ÷
    Insulator ¾øÔµÌå
    INT intake ½øÈ룬Èë¿Ú INT intensity Ç¿¶È£¬ÁÒ¶È
    INT interior ÄÚ²¿
    INT interrupter ¶Ï·Æ÷
    Integrated ×éºÏµÄ
    Integrated amplifier ǰÖÃ-¹¦ÂÊ·Å´óÆ÷£¬×ۺϹ¦ÂÊ·Å´óÆ÷
    Intelligate ÖÇÄÜ»¯ÔëÉùÃÅ
    Intelligibility ¿É¶®¶È
    Interactie Ï໥×÷Óã¬ÈË»ú¶Ô»°£¬Èí¹Õµã
    Interval Òô¸ß²î±ð
    Integrated ¼¯³ÉµÄ£¬ÍêÈ«µÄ
    Intercom ¶Ô½²£¬Í¨»°
    Interconnect »¥ÏàÁªÏµ
    Inter cut ²å²¥
    Interface ½Ó¿Ú£¬¶Ô»°×°ÖÃ
    Interference ¸ÉÈÅ£¬¸ÉÉæ£¬´®ÈÅ
    Interim ÁÙʱµÄ£¬¹ý¶ÉÌØÕ÷
    Intermodulation »¥µ÷£¬ÄÚµ÷ÖÆ
    Intermodulation distortion ½»Ô½Ê§Õæ
  Internal Äڴ棬¶Ô½²»ú
    Internally ÔÚÄÚ²¿£¬ÄÚ´æ
    Inter parameter ÄÚ²¿²ÎÊý
    Interval Òô¸ß²î±ð
    Interplay Ï໥×÷Óã¬ÄÚ²¿²¥·Å
    Interval shifter ÒôÐªÒÆÏàÆ÷
    Intimacy Ç×ÇиÐ
    Intonation Éùµ÷
    INTRO introduction ½éÉÜ£¬ä¯ÀÀ£¬ÒýÈ룬£¨ÀÖÇúµÄ£©Ç°×à
   &n,bsp;  INTRO sacn ÇúÍ·¼ìË÷£¨½ÚÄ¿ËÑË÷£©
    INTRO sensor ÇúÍ·¶Á³öÆ÷£¨½ÚÄ¿²éѯ£©
    Introskip ÄÚÒÆ£¬ÄÚÌø
    ISS insertion test signal ²åÈëÇл»ÐźÅ
    ISS interference suppression switch ¸ÉÈÅÒÖÖÆ¿ª¹Ø
    ITS insertion test signal ²åÈë²âÊÔÐźÅ
    IV interval ¼ä¸ôËÑË÷
    IV inverter µ¹ÏàÆ÷
    IWC interrupted wave ¶ÏÐø²¨
    IX index ±êÅÌ£¬Ö¸Õ룬Ë÷Òý
J
J jack ²å¿×£¬²å×ù£¬´«¶¯×°ÖÃ
    Jack socket ²å¿×
    Jaff ¸´¸ÉÈÅ
    Jagg club ¾ôÊ¿ÀÖ¾ãÀÖ²¿Ð§¹û
    Jam ÒÖÖÆ£¬¸ÉÈÅ
    Jamproof ¿¹¸ÉÈŵÄ
    Jazz ¾ôÊ¿
    JB junction box ½ÓÏߺÐ
    JIS ÈÕ±¾¹¤Òµ±ê×¼
    Job ʼþ£¬×÷ÒµÖ¸Á³ÉÆ·
    Jog ÐýÅÌ»º½ø£¬Âý½ø£¬Í»È»×ªÏò
    Joker °µ²ØµÄ²»ÀûÒòËØ£¬º¬»ì²»Çå
    Joystick ¿ØÖÆÊÖ±ú£¬²Ù×ݸˣ¬Ò¡¸Ë
    JSS jet servo system ÅçÉäËÅ·þÊ½ÖØµÍÒôÑïÉùÆ÷ϵͳ
    Jumper ÌøÏߣ¬ÌõÐÎ½ÓÆ¬
    Justify µ÷Õû
K
    K key °´¼ü
    Karaoke ¿¨À­OK£¬ÎÞÈ˰é×àÀÖ¶Ó
    KB key board ¼üÅÌ£¬°´Å¥
    Kerr ¿Ë¶úЧӦ£¬£¨¿É¶Áд¹âÅÌ£©´Å¹âЧӦ
    Key ¼ü£¬°´¼ü£¬Éùµ÷
  Keyboard ¼üÅÌ£¬°´Å¥
    Key control ¼ü¿Ø£¬±äµ÷¿ØÖÆ
    Keyed ¼ü¿Ø
    Key EQ Òôµ÷¾ùºâ
    kHz Kiloherts ǧºÕ×È
    Kikll Çå³ý£¬ÏûÈ¥£¬ÒÖÖÆ£¬Ë¥¼õ£¬¶Ï¿ª
    Killer ÒÖÖÆÆ÷£¬¶Ï·Æ÷
    Kit É趨
    Knee ѹÏÞÆ÷¹Õµã
    Knob °´Å¥£¬ÐýÅ¥£¬µ÷½ÚÆ÷
    KP key pulse ¼ü¿ØÂö³å
    KTV karaoke TV °è³ªµçÊÓ£¨½ÚÄ¿£©
    KX key ¼ü¿Ø
L
Lesion ¹ÊÕÏ£¬Ëðº¦
    Leslie ÁÐ˹Àû£¨Ò»ÖÖµ÷ÏàЧ¹û´¦Àí·½Ê½£©
    LEV level µçƽ
    LEVCON level control µçƽ¿ØÖÆ
    Level µçƽ£¬Ë®Æ½£¬¼¶
    LF low frequency µÍƵ£¬µÍÒô
    LFB local feedback ±¾»ú·´À¡£¬¾Ö²¿·´À¡
    LFE lowfrequency response µÍƵÏìÓ¦
    LFO low frequency oscillation µÍƵÕñµ´ÐźÅ
    LGD long delay ³¤ÑÓʱ
    LH low high µÍÔëÉù¸ßÊä³ö
    LH low noise high output µÍÔëÉù¸ßÊä³ö´Å´ø
    L.hall large hall ´óÌüЧ¹û
    Lift ÌáÉý£¨Ò»ÖÖÌáÉýµØµçλµÄ×°Öã©
    Lift up ÉýÆð
    Labial ´½Òô
    L left ×ó£¨Á¢ÌåÉùϵͳµÄ×óÉùµÀ£©
    L line Ïß·
    L link Á´Â·
    L long ³¤£¨Ê±¼ä£©
    LA laser ¼¤¹â£¨ÀØÉ䣩
    Lag ÑÓ³Ù£¬Öͺó
    Lamp µÆ£¬ÕÕÃ÷µÆ
    Land ¹âÅÌÂÝÐýµÀµÄ¼ç£¬½ÓµØ£¬ÕæµØ
    Lap dissolve Âýת»»
    Lapping SW ͨ¶Ï¿ª¹Ø
    Large ´ó£¬´óÐÍ
    Large hall ´óÌü»ìÏì
    Larigot Áù±¶Òô
   Laser ¼¤¹â£¨ÀØÉ䣩
    Latency ¿Õת£¬´ý»ú
    Launching ¼¤Àø£¬·¢Éä
    Layer ²ãµþ¿ØÖÆ£¬¶àÒôɫͬ²½¿ØÖÆ
    LCD liquid crystal display Òº¾§ÏÔʾ
    LCR left center right ×óÖÐÓÒ
    LD laser vision disc ¼¤¹âÊÓÅÌ£¬Ó°µú»ú
    LD load ¸ºÔØ
    LDP input Ó°µúÊäÈë
    LDTV low definition television µÍ·Ö±æÂÊÊý×ÖµçÊÓ
    LCD projictor Òº¾§Í¶Ó°»ú
    Lead ͨµÀ£¬Ç°Öã¬ÊäÈë
    Lead-in ÒýÈëÏß
    Leak ©й
    Learn ѧϰ
    LED light emitting deivce ·¢¹â·øÉäÆ÷£¬·¢¹âÆ÷¼þ
    LED litht emitting diode ·¢¹â¶þ¼«¹Ü£¨ÏÔʾ£©
    Legato Á¬×à
    Length ×Ö³¤£¬·¶Î§
    Lento Âý°å
    Light switch ÕÕÃ÷¿ª¹Ø
2010-3-28 19:25:46 »Ø¸´
hdaudio Â¥Ö÷
M
  M main Ö÷ÐŵÀ
    M master Ö÷¿Ø
    M memory ´æ´¢Æ÷
    M mix »ìƵ
    M moderate ÊÊÖеÄ
    M music ÒôÀÖ
    Mac manchester auto code ÂüÇÐË¹ÌØ×Ô¶¯Âë
    MADI musical audio digital interface ÒôƵÊý×Ö½Ó¿Ú
    Main Ö÷ÒªµÄ£¬Ö÷Ïߣ¬Ö÷ͨµÀ£¬µçÔ´
    MAG magnet ´ÅÌú
    Magnetic tape ´Å´ø
    Magnetic type recorder ´Å´øÂ¼Òô»ú
    Main µçÔ´£¬Ö÷ÒªµÄ
    Major chord ´óÈýºÍÏÒ
    Make ½Óͨ£¬±ÕºÏ
    Makeup ½Óͨ£¬Ñ¡Åä
    Male ²åÍ·£¬²å¼þ
    MAN manual ÊÖ¶¯µÄ£¬ÊÖ¿Ø
    Manifold technology £¨ÒôÏ䣩¶àÆç¹Ü¼¼Êõ
    Manipulate ²Ù×÷£¬¼ü¿Ø
    MANP ÊÖ¶¯´©²å
  Manual ÊÖ¶¯µÄ£¬È˹¤µÄ£¬Êֲᣬ˵Ã÷Êé
    March ½øÐÐÇú
    Margin £¨µçƽ£©ÓàÁ¿
    Mark ±êÖ¾£¬·ûºÅ£¬±ê¼Ç
    Mash ѹµÍ£¬ÄëËé
    Masking ÑÚ±Î
    Master ×ÜÒôÁ¿¿ØÖÆ£¬µ÷Òǫ̂£¬Ö÷ÅÌ£¬±ê×¼µÄ£¬Ö÷µÄ£¬×Ü·
    MAR Matrix ¾ØÕ󣬵÷Òǫ̂¾ØÕó£¨M£©£¬±à×é
    Match Æ¥Å䣬ÊÊÅ䣬Åä¶Ô
    Matrix quad system ¾ØÕóËÄÉùµÀÁ¢ÌåÉùϵͳ
    MAX maximum ×î´ó£¬×î´óÖµ
    MB megabytes Õ××Ö½Ú
    Mb/s megabytes per second Õ××Ö½Ú/Ãë
    MC manual control ÊÖ¿Ø£¬ÊÖ¶¯¿ØÖÆ
    MCH multiple chorus ¶à·ºÏ³ª
    MCR multiple cjhannel amplification reverberation ¶à·»ìÏìÔöÇ¿
    MD mini disc ¹â´ÅÅ̳ª»ú£¬Ð¡Ðͼ·Å³ªÅÌ
    MD moving coil ¶¯È¦Ê½
    MDL modulation delay µ÷ÖÆÑÓʱ
    MEAS measure ²âÁ¿£¬·¶Î§£¬²âÊÔ
    Measure ÀÖÇúµÄ£¬Ð¡½Ú
    Meas edit С½á±à¼­
    MECH mechanism »úеװÖÃ
    MED medium ÊÊÖУ¬Öм䣨µ²Î»£©
    Medley »ìºÏ
    Mega bass ³¬ÖصÍÒô
    MEM memory ´æ´¢Æ÷£¬´æ´¢£¬¼ÇÒä
    Member ²¿¼þ£¬³ÉÔ±
    Menu ²Ëµ¥£¬Ä¿Â¼£¬±í¸ñ
    MEQ mono equalizer µ¥ÉùµÀ¾ùºâÆ÷
    Merge ºÏ²¢£¬»ã×Ü£¬ÈÚºÏ
    Meridian ¶¥µãµÄ£¬·åÖµ
    Measure С½á
    Megaphone À®°ÈͲ
    Mel ÃÀ£¨Òôµ÷µ¥Î»£©
    Menu ²Ëµ¥£¬½ÚÄ¿±í
    Message ͨÐÅ£¬ÁªÏµ
    Metal ½ðÊô£¨Ð§¹ûÉù£©
    Metal tape ½ðÊô´Å´ø
    Meter µçƽ±í£¬±íÍ·£¬ÒDZí
    Metronome ½ÚÅÄÆ÷
    MF matched filter Æ¥ÅäÂ˲¨Æ÷
    MF maveform ²¨ÐÎ
    MF middle frequency ÖÐÆµ£¬ÖÐÒô
  MFL multiple flange ¶à²ã·¨À¼£¨Ïâ±ß£©Ð§¹û
    MFT multiplprogramming with a fixed number of tasks ÈÎÎñÊýÁ¿¹Ì¶¨µÄ¶àͨµÀ³ÌÐòÉè¼Æ
    MIC micro ΢Ã×
    MIC microphone »°Í²£¬Âó¿Ë·ç£¬´«ÉùÆ÷
    Michcho level »°Í²»ìÏìµçƽ
    Micro monitor amp ΢Òô¼àÌý·Å´óÆ÷
    MICROVERB microcomputer reverb ΢´¦Àí»ú»ìÏì
    MID middle ÖмäµÄ£¬Öв¿µÄ£¬ÖÐÒô£¬ÖÐÆµ
    MIDI music instrument digital interface µç×ÓÀÖÆ÷Êý×Ö½Ó¿Ú
    MIN minimum ×îС£¬×îСֵ
    MIN minute ·ÖÖÓ
    MIND master integrated network device Ò»Ìå»¯ÍøÂç×Ü×°ÖÃ
    Minitrim ΢µ÷
    Minitrue ΢»úµ÷Õû
    Minor chord СÈýºÍÏÒ
    Mismatch ʧÅä
    Mistermination ÖÕ¶ËʧÅä
    MIX »ìºÏ£¬ÒôÁ¿±ÈÀýµ÷½Ú
    Mixer µ÷Òǫ̂£¬»ìÒôÆ÷
    MM moving magnet ¶¯´Åʽ
    MNTR monitor ¼à¿ØÆ÷
    MNOS metallic nitrogen - oxide semiconductor ½ðÊôµªÑõ»¯Îï°ëµ¼Ìå
    MO magneto optical ¿ÉĨ¿É¼Ð͹âÅÌ
    MOC magnet oscillator circuit Ö÷Õñµ´µç·
    MOD mode ״̬£¬·½Ê½£¬Ä£Ê½
    MOD model Ðͺţ¬Ñùʽ£¬Ä£ÐÍ£¬µäÐ͵Ä
    MOD modulation µ÷ÖÆ
    Mode ״̬£¬£¨ÀÖÇúµÄ£©µ÷ʽ
    Mode select ·½Ê½Ñ¡Ôñ
    Mush ÔëÉù¸ÉÈÅ£¬·Öг²¨
    Mush area ²»Á¼½ÓÊÕÇø
    Music ÒôÀÖ£¬ÀÖÇú
    Music center ÒôÀÖÖÐÐÄ£¬×éºÏÒôÏì
    Music conductor ÒôÀÖ¿ØÖÆÆ÷
    MUT mute ¾²Òô£¬ÑÆÒô£¬ÔëÉù¿ØÖÆ
    Muting ÒÖÖÆ£¬Ïû³ý
    Multiple ¸´ºÏµÄ£¬¶àÏîµÄ£¬¶àÖØµÄ
    MV mean value ƽ¾ùÖµ
    MV multivibrator ¶àгÕñµ´Æ÷
    MW medium wave Öв¨
    MXE mono exciter µ¥ÉùµÀ¼¤ÀøÆ÷
    MXR mixer »ìƵÆ÷
    MODEM modulator demodulator µ÷ÖÆ½âµ÷Æ÷
    Moderato ÖÐËÙ
   Modifier µ÷½ÚÆ÷
    Modify Ð޸쬵÷ÊÔ£¬Ä¦»ú£¬ÏÞ¶¨
    Modulator µ÷ÖÆÆ÷
    Module Ä£¿é£¬×é¼þ£¬ÒòÊý£¬³ÌÐòƬ
    MOL maximum output level ×î´óÊä³öµçƽ
    MON monitor ¼àÌý£¬¼àÊÓÆ÷
    MONI ¼àÌý£¬µ÷Òôʦ
    Monkey chatter ´®Òô£¬ÁÚÆµ¸ÉÈÅ£¬½»²æÊ§Õæ
    Mono µ¥ÉùµÀ£¬µ¥Ò»
    Monopit µ¥Éù±äµ÷
    Motor cue »»»úÐźţ¬Çл»ÐźÅ
    MOS metal-oxide semiconductor ½ðÊôÑõ»¯Îï°ëµ¼Ìå
    Motor Âí´ï£¬µç»ú
    Movie theater Ó°¾çÔº
    Moviola Éù»­¼ô¼­»ú
    Moving-iron loudspeaker Éà»ÉÑïÉùÆ÷
    MPEG motion picture coding experts group »î¶¯Í¼Ïñ±àÂëר¼Ò×飬Êý×ÖÉùÏñÐÅϢѹËõ±ê×¼
    MPF master pre feed Ö÷¿ØÇ°À¡ËÍ
    MPH multiple phaser ¶à¼¶ÒÆÏàÆ÷
    MPO maximum power output ×î´óÊä³ö¹¦ÂÊ
    MPO music power output ÒôÀÖÊä³ö¹¦ÂÊ
    MPR master pre return Ö÷¿ØÇ°·µ»Ø
    MPS main power switch Ö÷µçÔ´¿ª¹Ø
    MPS manual phase shifter ÊÖ¿ØÏàÒÆÆ÷
    MPS microphone power supply »°Í²µçÔ´
    MPS microprocessor system ¶àÓÃ;ȡÑùϵͳ
    MPX multiplex ¶à·´«Ê䣬¶à´ÎÖØ¸´Ê¹Ó㬶à·ת»»£¬¸´ºÏ
    MPX multiplexer ¶à·ת»»Æ÷£¬¶à·µ÷ÖÆÆ÷
    MPX VCO ¶à·½âµ÷ѹ¿ØÕñµ´
    MQSS music quick select system ¿ìËÙÒôÀÖÑ¡Ôñϵͳ
    MR memory read ´æ´¢Æ÷¶Á³ö
    MS manual search ÊÖ¶¯¼ìË÷
    MS middle side Ò»ÖÖµüºÏ¼Òô¼¼Êõ
    MS(MSEC) millisecond ºÁÃë
    MSSS multi space ound system ¶àά¿Õ¼äÉùϵͳ
    MST(MSTR) master Ö÷¿Ø
    MSW microswitch ΢¶¯¿ª¹Ø
    MT multi track ¶à¹ì
    MTD multiple delay ¶à´ÎÑÓʱ
    MTR magnetic tape redorder ´Å´ø¼Ç¼Æ÷
    MTR micro-wave transmission ΢²¨´«Êä
    MTR motor µç¶¯»ú
    MTS multi-channel television sound ¶àÉùµÀµçÊÓ°éÒô
    MTV music TV ÒôÀÖµçÊÓ£¨½ÚÄ¿£©
  MUF maximum usable frequency ×î¸ß¿ÉÓÃÆµÂÊ
    MULT multiplier ±¶ÔöÆ÷£¬¹âµç±¶Ôö¹Ü
    Multi ²¢ÁªµÄ£¬¶à·ϵͳ
    Multidimention control Éù³¡Õ¹¿í¿ØÖÆ£¬¶àά¿ØÖÆ
    Multiband ¶àƵ¶Î
    Multi-echo ¶àÖØ»ØÉù
    Multi plex ¶à·´«Éù
    Multitap ת½Ó£¬£¨¶à²åÍ·£©²å×ù
    Multiple channel ¶àͨµÀ
    Multiple effects ×ÛºÏЧ¹û´¦Àí×°ÖÃ
    Multiple jack ¶àÑÛ²å×ù
    Multisound ԭʼÒôÉ«
    MUPO maximum undistorted power output ×î´ó²»Ê§ÕæÊä³ö¹¦ÂÊ
    MUSE multiple sub-Nyquist sompling encoding ¶àÖØÄοüË¹ÌØÈ¡Ñù±àÂë
    MIDI ¸ñʽÎļþ
    MIDI ÐÅÏ¢£¬È«¹ý³Ì
N
  Name Ãû³Æ£¬ÃüÃû
    Natural ×ÔÈ»µÄ£¬ÌìÈ»µÄ£¬¹ÌÓеÄ
    Naught Á㣬ÎÞ¼ÛÖµ
    NC network controller ÍøÂç¿ØÖÆÆ÷
    NC numberical control Êý×Ö¿ØÖÆ
    NC needle chatter ³ªÕëÔëÉù
    Nazard Èý±¶Òô
    Near field ½ü³¡
    NEG negative ¸º£¬Òõ£¨¼«£©
    NEMO ʵ¿öת²¥
    NEP noise equivalent power ÔëÉùµÈЧ¹¦ÂÊ
    News ÈËÉù¹ã²¥ÒôÏìЧ¹û£¬ÐÂÎÅ
    Next ÏÂÒ»¸ö£¬³ªÆ¬Ìø»ØÏÂÇú¼ü
    NF NFB negative feedback ¸º·´À¡
    NG no go ²»Í¨£¬²»¹¤×÷
    NG noise generator ÔëÉù·¢ÉúÆ÷
    Ni-Cd nickel-cadmium ÄøïÓ³äµçµç³Ø
    NICAM near instantaneous companded audio multiplex ׼˲ʱѹÀ©ÉùÒô¶à·¸´Ó㬵çÊÓÀöÒô£¬Êý×Ö¶à·°éÒôϵͳ
    NIL Áãµã
    Noise ÔëÒô
    Noise gate ÔëÉùÃÅ£¬Ñ¡Í¨Æ÷
    Noise suppressor ÔëÉùÒÖÖÆÆ÷
    NOM nominal ±ê³ÆµÄ£¬¶î¶¨µÄ
    Non-direction È«ÏòµÄ£¬ÎÞÖ¸ÏòÐÔµÄ
    Nonieme ¾Å±¶Òô
    NOP no operation ÎÞ²Ù×÷Ö¸Áî
   NOR(NORM) normal ÆÕͨµÄ£¬±ê×¼µÄ£¬Õý³£µÄ£¬³£¹æµÄ
    NORM ƽ¾ùÖµ
    Normal frequency ¼òÕý£¨¹²Õñ£©ÆµÂÊ
    Notch ´¥µã
    Note ·ûºÅ£¬×¢ÊÍ£¬Òôµ÷£¬ÒôÂÉ£¬¼Ç¼
    Notice ×¢ÒâÊÂÏ¼ò½é
    NO number Êý×Ö£¬ºÅÂë
    NR noise ratio ÔëÉù±È
    NR noise reduction ½µÔ룬ÔëÉùÏû³ý
    NR number Êý×Ö£¬±àºÅ
    NAB national association of broadcasters ¹ú¼Ò¹ã²¥¹¤×÷ÕßЭ»á
    NTSC national television system committee £¨ÃÀ¹ú£©¹ú¼ÒµçÊÓϵͳίԱ»á£¬Õý½»Æ½ºâµ÷·ùÖÆ²ÊÉ«µçÊÓÖÆÊ½
    Null ¿Õ룬ÎÞЧµÄ
    NV noise variance ÔëÉù·½²î
    NVT network virtual terminal ÍøÂçÐéÄâÖÕ¶Î
    N normal Õý³££¬ÆÕͨ£¬±ê×¼
    N negative Òõ¼«£¬¸º¼«
2010-3-28 19:27:07 »Ø¸´
hdaudio Â¥Ö÷
O
  ohm Å·Ä·£¨µç×èµÄµ¥Î»£©
    Oboe Ë«»É¹Ü
    O/C open circuit ¿ªÂ·
    OCK operation control key ²Ù×÷¿ØÖƼü
    OCL output capacitorless ÎÞÊä³öµçÈݹ¦ÂÊ·Å´óÆ÷
    OCL output control line Êä³ö¿ØÖÆÏß
    OCT octave ±¶Æµ³Ì£¬°Ë¶ÈÒô
    OD operations directive ²Ù×÷ָʾ
    OD optical density ¹âÃܶÈ
    OD over drive ¹ý¼¤Àø
    OFC office Ö°ÄÜ
    OFC oxygen-free cupreous ÎÞÑõÍ­µ¼Ïß
    Off ¹Ø±Õ£¬¶Ï¿ª
    Offering ÌîÈ룬Ìṩ
    Offset £¨ÒÆÏࣩ²¹³¥£¬ÐÞÊΣ¬Æ«ÖÃ
    OFHC oxygen free high conductivity copper ¸ßµ¼µçÂÊÎÞÑõÍ­µ¼Ïß
    Ohm Å·Ä·
    OK È·ÈÏ
    OL on line ÔÚÏߣ¬Á¬»ú
    OL over load ¹ýÔØ
    Omnidirectional ÎÞ·½ÏòÐÔµÄ
    On ¿ª£¬½Óͨ
    Once Ò»´Î£¬µ¥´Î
    One-way relay play µ¥ÏòÌæ»»·ÅÒô
    Online Áª»ú£¬ÁªÏß
  Only ½ö½ö£¬Ö»
    On-mike ÕýÔÚËÍ»°£¬¿¿½ü»°Í²
    One touch µ¥´¥Á¬½Ó
    OP output ÐźÅÊä³ö
    OP over pressure ¹ýѹ
    Open ´ò¿ª£¬¿ªÆô
    Opera ¸è¾ç
    Operate ²Ù×÷£¬ÔËת
    Operation ²Ù×÷£¬ÔËת
    Operator ²Ù×ÝÆ÷£¬ºÏ³ÉÆ÷Ëã×Ó
    Optical ÊýÂë¹âÀ½ӿÚ
    Optical master ¼¤¹âÆ÷
    Option Ñ¡ÐÍ£¬Ñ¡Ôñ
    Optimum ×î¼Ñ״̬
    OPTOISO optoisolator ¹â¸ôÀëÆ÷
    Or »ò£¬»òÕß
    ORC optimum recording current ´ÅÍ·×î¼Ñ¼Ç¼µçÁ÷
    Orchestra ¹ÜÏÒÀÖÆ÷
    Organ ·çÇÙ£¬Ôª¼þ Original Ô­£¨³ÌÐò£©£¬³õʼ£¨»¯£©
    OSC oscillator Õñµ´Æ÷£¬ÊÔ»úÐźţ¨Ò»Ç§ºÕ×È£©
    OSC oscillograph ʾ²¨Æ÷
    OSS optimal stereo signal ×î¼ÑÁ¢ÌåÉùÐźÅ
    OTL ÎÞÊä³ö±äѹÆ÷¹¦ÂÊ·Å´óÆ÷
    OTR one-touch time recording µ¥´¥Ê½¶¨Ê±Â¼Ïñ
    OTR operation temperature range ¹¤×÷ζȷ¶Î§
    OTR overload time relay ¹ýÔØÏÞʱ¼ÌµçÆ÷
    OUT output Êä³ö
    Outage ÖжÏ
    Out-burst Âö³å£¬ÉÁ¹â£¬ÉÁÁÁ
    Outcome ½á¹û£¬Êä³ö£¬¿ªÊ¼
    Out let Êä³ö¶Ë×Ó£¬Òý³öÏß
    Outline ÂÖÀªÏß
    Out phase ·´Ïò
    OVDB ÖØµþ¼Òô
    Overall ÂÖÀª£¬×ÜÌåÉÏ
    Overcut ¹ýµ÷ÖÆ
    Over drive ¹ý¼¤Àø
    Overdubs µþ¼
    Overflow ÐźŹýÇ¿
    Overhang £¨¼¤ÀøÆ÷£©µÍÒôÑÓÉìµ÷½Ú
    Overhearing ´®Òô
    OVLD over lode ¹ýÔØ£¬³¬¸ººÉ
    Over sampling ¹ýÈ¡Ñù
    Overtone ·ºÒô
   OVWR overwrite ¸²¸Çʽ¼Òô
P
   Proximity effect ½ü¾àÀëЧ¹û
    Prwsnt Í»³ö¸Ð
    PS position λÖã¬×´Ì¬
    PSC program switching center ½ÚÄ¿Çл»ÖÐÐÄ
    PSL phase sequence logic Ïàλ˳ÐòÂß¼­
    PSM peak selector memory ·åֵѡÔñ´æ´¢Æ÷
    PSM phase shifter module ÒÆÏàÄ£¼þ
    PSM pitch shift modulation ½»Æµµ÷ÖÆ
    PST posterrior ºóÃæ
    PST preset Ô¤ÖÃ
    PSU power supply ¹©µç
    Psychological acoustics ÐÄÀíÉùѧ
    PT power transformer µçÔ´±äѹÆ÷
    PT portable ±ãЯʽ
    PT pulse timer Âö³å¼ÆÊ±Æ÷
    PTD pan turnout piece delay ÉùÏñ·ÖÖ§ÑÓʱ
    PTE private רÓõÄ
    PTN pattern ģʽ£¬Ñùʽ
    PTN procedure turn ³ÌÐò±ä»¯
    PU pickup ʰÒô
    PU power unit µçÔ´É豸
    Pull À­£¬Ç÷Ïò
    Pull-in ½Óͨ£¬ÒýÈë
    Pumping ³éÆøÐ§Ó¦
    Pure tone ´¿Òô
    Purging ¾»»¯
    Push ÍÆ£¬°´Å¥£¬Ñ¹
    Push-pull ÍÆÍìʽµÄ
    PWM pulse width modulation Âö³å¿í¶Èµ÷ÖÆ
    PWR power µçÔ´£¬¹¦ÂÊ
    PZM pressure zone microphone ѹÁ¦Çø»°Í²
    P.P.Panoramic potentiometer È«¾°µçλÆ÷
    P-P peak-Peak ·å-·åÖµ
    PPD pingpong delay ƹÅÒÑÓʱ
    PPG programme pulse generator Âö³å³ÌÐò·¢ÉúÆ÷
    PPI peak program indicator ·åÖµÏÔʾÆ÷
    PPI programmable peripheral interface ³ÌÐòÍⲿ½Ó¿Ú
    PPL peak program level ·åÖµÒôÁ¿µçƽ
    PPM peak program meter ·åÖµ½ÚÄ¿±í£¬·åÖµÒôÁ¿±í
    PPM pulse phase modulation Âö³åÏàλµ÷ÖÆ
    Pr power rate ¹¦ÂʱÈ
  PR program register ³ÌÐò¼Ä´æÆ÷
    PRC precision ¾«È·£¬¾«Ï¸£¬¾«ÃܶÈ
    Pre ǰÖã¬Ô¤±¸£¬Ö®Ç°
    Pre-delay Ô¤ÑÓ³Ù
    Pre echoes Ô¤»ØÉù
    Pre emphasis Ô¤¼ÓÖØ
    PREAMP preamplifier ǰÖ÷ŴóÆ÷
    Preselection Ԥѡ
    Presence ÁÙ³¡Ð§¹û£¬ÏÖ³¡¸Ð
    Present µ±Ç°ÈÕÆÚ£¬ÏÖʱ£¬¼´Ê±
    Preserve ±£´æ£¬Î¬³Ö
    Preset Ô¤Öã¬Ô¤µ÷
    Press °´£¬Ñ¹
    PREV ³ªÆ¬Ìø»ØÉÏÇú¼ü
    Preview Ô¤ÑÝ
    Previous Ïòǰ£¬Ç°Î»µÄ
    Prime ͬ¶ÈÒô
    PRM parameter ²ÎÁ¿
    PRO professional רҵµÄ
    Probe ´«¸ÐÆ÷
    Process ´¦Àí£¬¼Ó¹¤
    PROCR processor ´¦ÀíÆ÷
    PROG program ³ÌÐò£¬»ù±¾ÒôÉ«
    Program cartridge ³ÌÐòºÐʽ´æ´¢Æ÷
    Program set indicator µçÄÔÑ¡Çú½ÚĿѡ¶¨Ö¸Ê¾
    Prosody ÔÏÂÉ
    Protect ±£»¤£¬·À»¤
    Protocol ͨÐÅЭÒé
    POSTF ºóÖã¨Íò·Ö£©
    POT potentiometer µçλÆ÷£¬µçλ¼Æ
    Potable ±ãЯµÄ£¬Ð¡Ð͵Ä
    Power µçÔ´£¬¹¦ÂÊ
    Power amplifier ¹¦ÂÊ·Å´óÆ÷
    Power dump ÇжϵçÔ´
    Power out ¹¦ÂÊÊä³ö
    Piower supply µçÔ´¹©¸ø
    PP peak power ·åÖµ¹¦ÂÊ
    PP personal preference ¸öÈËÔ¤ÖÃ
    P plug ²åÍ·
    P positive Õý¼«
    P pulse Âö³å
    P power ¹¦ÂÊ
    PA preamplifier ǰÖ÷ŴóÆ÷
    PA public address À©Éù
  Pace ²½ËÙ£¬¼¶Êý
    Packed cell »ý²ãµç³Ø
    Packing ͼÏñѹËõ
    P-I-P picture in picture »­Öл­
    PAD ¶¨ÖµË¥¼õ£¬Ë¥¼õÆ÷£¬£¨´ò»÷ÀÖ´ó°´¼üµÄ£©¹Äµæ
    Padding ͳµ÷£¬Ê¹¡­¡­Æ½Ö±
    Paddle ¿ª¹Ø£¬Ãŵç·
    Page Ò»Ãæ£¬£¨´æ´¢Æ÷£©Ò³ÃæµØÖ·£¬Ñ°ÕÒ
    Pair £¨Á¢ÌåÉù£©Åä¶Ô£¬±È½Ï
    PAL phase alternation line ÖðÐе¹Ïà²ÊÉ«µçÊÓÖÆÊ½
    PAM pulse amplitude modulation Âö·ùµ÷ÖÆ
    PAM pole amplitude modulation ¼«µãµ÷·ù
    Pan panorama ÉùÏñµ÷½Ú£¬¶¨Î»£¬È«¾°
    Panel Ãæ°å£¬²Ù×ݰ壬ÅäµçÅÌ
    Panotrope µç³ª»ú
    Paper cone Ö½Åè
    Parallel ²¢Áª£¬Æ½ºâ
    PAR(PARAM) parameter ²ÎÊý£¬²ÎÁ¿£¬ÏµÊý
    Parametric ²ÎÁ¿µÄ
    Part Éù²¿Êý£¬²¿·Ö
    Partial tone ·ÖÒô£¬·ºÒô
    PAS public address system À©Éùϵͳ
    PASC precision adaptive subband coding ¾«ÃÜ×ÔÊÊÓ¦·Ö¶Î±àÂë
    Pass ͨ¹ý
    Passive ±»¶¯£¬±»¶¯·ÖƵ£¬¹¦ÂÊ·ÖÆµ
    Paste Õ³Ìù
    PAT pattern Ä£·Â£¬Ðͺţ¬Í¼Æ×ÌØÐÔÇúÏß
    Patch ÁÙʱ£¬²å½ÓÏߣ¬ÓÃÁ¬½ÓµçÀ²åÈë
    Patch bay ÅäµçÅÌ
    Patch board ²åÏß°å
    Patching ÁÙʱ½ÓÏߣ¬²¹³¥
    Patching cord system µ÷¶ÈÈûÉþϵͳ
    Path ÐźÅͨ·
    Pattern Ñùʽ£¬·½Ê½£¬Ñù°å
    Pause ÔÝÍ££¬¼äЪ£¬Í£¶Ù
    PB playback ²¥·Å£¬ÖØ·Å
    PB push button °´Å¥¿ª¹Ø
    PBASS proper bass active supply system ×î¼ÑµÍÒôÖØ·Åϵͳ
    PBC play back control ÖØ·Å¿ØÖÆ£¬»Ø·Å¿ØÖÆ
    PC perceptual coding ¸Ð¾õ±àÂë
    PC program control ³ÌÐò¿ØÖÆ
    PCB printed circuit board Ó¡Ë¢Ïß·°å
    PCC phase correlation cardioid microphone ÏàλÏà¹ØÐÄÐλ°Í²
    PCM precision capacitor microphone ¾«ÃܵçÈÝ»°Í²
  PCM pulse code modulation Âö³å±àÂëµ÷ÖÆ
    PCM card ²¨ÐÎÀ©³ä¿¨£¨Ôö¼ÓÐÂÒôÉ«£©
    PC-COC pure copper continuous casting Á¬ÐøÖýÔì´¿Í­µ¼Ïß
    PD power divider ¹¦ÂÊ·ÖÅäÆ÷
    PD power doubler ¹¦Âʱ¶ÔöÆ÷
    PD program directive ³ÌÐòÖ¸Áî
    PD pro-digital רҵÊý×Ö½Ó¿Ú
    PD protective device ±£»¤×°ÖÃ
    PDM pulse density modulation Âö³åÃܶȵ÷ÖÆ
    PDP plasma display panel µÈÀë×ÓÏÔʾ°å
    PDS partitioned data set ·ÖÇøÊý¾Ý×é
    PDS programmable data system ³ÌÐò¿É¿ØÏµÍ³
    PDS power distribution system Åäµçϵͳ
    PE phase encoding Ïàλ±àÂë
    PE program execution ³ÌÐòÖ´ÐÐ
    Peak ·åÖµ£¬Ï÷²¨£¨µÆ£©
    Peak and dip ·åʽƵÂÊÅ·ÖÞ±ê×¼21½ÅAV½Ó¿Ú
    Pedal ̤°å
    PEM pulse edge molulation Âö³å±ßÔµµ÷ÖÆ
    Pentatonic ÎåÉùµ÷ʽ
    PEQ parameter equalizer ²ÎÁ¿¾ùºâÆ÷
    PERC percussion ´ò»÷ÀÖÆ÷
    PERCUS ´ò»÷ÀÖÆ÷
    Performance Ê©ÐУ¬±íÑÝ£¬±íÏÖ£¬Ñݳö
    Permalloy head ÆÂĪºÏ½ð´ÅÍ·
    Permutator ת»»¿ª¹Ø£¬±ä»»Æ÷
    Perspective Á¢Ìå¸Ð
    Perform Ö´ÐУ¬Íê³É£¬Ê©ÐÐ
    Period ÖÜÆÚ
    PFL per fader louder speaker Ë¥¼õǰ¼àÌý£¬Ô¤¼àÌý
    PG pulse generator Âö³å·¢ÉúÆ÷
    PGM program ½ÚÄ¿£¬³ÌÐò
    Pgmno/Step ½ÚÄ¿ºÅÂë/²½Öè
    Pgmtime ½ÚĿʱ¼ä
    PH phase Ïàλ
    PH phasemeter ÏàλÒÇ
    PHA phase Ïàλ
    Phantom »ÃÏñµçÔ´£¬»ÃÏ󹩵ç
    Phase Ïàλ£¬×´Ì¬
    Phase REV µ¹Ïࣨµç·£©
    Phaser ÒÆÏàÆ÷
    Phasing ÏàλУÕý£¬ÒÆÏàЧ¹û
    Phon ·½£¨Ïì¶Èµ¥Î»£©
    Phone ¶ú»ú£¬¶ú»ú²å¿Ú
  Phoneme ÒôËØ
    Phono(phonograph) ³ª»ú
    PHS phaser ÒÆÏàÆ÷
    Physiological acoustics ÉúÀíÉùѧ
    PI phase inversion µ¹Ïà
    PIA peripheral interface adapter ÍâΧ½Ó¿ÚÊÊÅäÆ÷
    Pianotron µç×Ó¸ÖÇÙ
    Piano ¸ÖÇÙ
    Piano whine ¸ÖÇÙÃùÉù
    Piccolo ¶ÌµÑ
    Pick-up ʰÒôÆ÷£¬³ªÍ·£¬´«¸ÐÆ÷
    Piezoelectric polymer earphone ѹµç¾ÛºÏÎï¶ú»ú
    Pilot ָʾÆ÷£¬µ÷½ÚÆ÷
    Pilot jack ¼àÌý²å¿×
    Pin ÕëÐͲå¿Ú£¬²»Æ½ºâÒôƵ²å¿Ú
    PIN position indercator λÖÃָʾÆ÷
    PIN positive-intrinsic-negative Õý-±¾-¸º
    Pinboard ת½Ó°å£¬²å½Ó°å
    Ping ±¬ÃùÉù£¬ÉùÏì
    Pink noise ·ÛºìÔëÉù
    Pipe ¹Ü£¬µÑ
    Pitch Òô¸ß£¬Òôµ÷
    Pitch shifter ±äµ÷Æ÷£¬ÒÆÆµÆ÷
    PK peak Ï÷²¨£¨µÆ£©£¬·åÖµ
    PL parental lock ·ÀÖ¹Îó¶¯Ëø¶¨
    PL phase lock ÏàÎ»Ëø¶¨£¬ËøÏà
    PL pilot lamp ָʾµÆ
    PL pre listen Ô¤¼àÌý£¬Ë¥¼õǰ¼àÌý
    Place ÖÃÈ룬Æð×÷ÓÃ
    Placement Á¬½Ó·½Ê½
    Plate ½ðÊô°åЧ¹û£¬°å»ìÏìÆ÷
    Play ²¥·Å£¬ÖØ·Å£¬µ¯×à
    Playback ²¥·Å
    Player ³ª»ú£¬·ÅÒôÆ÷
    Plesoelectric supper tweeters ѹµçʽ³¬¸ßÒôÀ®°È
    PLL phase locked loop ËøÏà»ØÂ·
    PLR plate reverb ½ðÊô°å»ìÏì
    Plug ²åÍ·
    Plunge ÇÐÈë
    PMPO peak music power output ÒôÀÖ·åÖµ¹¦ÂÊÊä³ö
    PN pseudo noise Î±Ëæ»úÔëÉù
    Pneumatic loudspeaker Æø¶¯ÑïÉùÆ÷
    PNM pulse number modulation Âö³åÊýµ÷ÖÆ£¬Âö³åÃܶȵ÷ÖÆ
    Point ½Óµã£¬Î»Ö㬽»»ãµã
   Point soure µãÉùÔ´
    Pointer ָʾÆ÷£¬Ö¸Õë
    Polarity ¼«ÐÔ
    Poly ¸´Òô£¬¶à·£¬¶à
    Pop ͻȻ£¬±¬ÆÆÒô£¬£¨»°Í²½ü½²Ê±µÄ£©ÆøÏ¢àÛàÛÉù
    Pop filter àÛÉùÂ˳ýÆ÷
    Pops Á÷ÐÐÒôÀÖ£¬Á÷ÐÐÒôÀÖÒôÏìЧ¹û
    Portamento »¬Òô
    Ported reflex Ô¤·ÅÓ³
    Position λÖã¬×´Ì¬
    POSITVE positive Ñô¼«
2010-3-28 19:27:45 »Ø¸´
hdaudio Â¥Ö÷
Q
quality factor Æ·ÖÊÒòÊý£¬QÖµ£¬Æµ´ø¿í¶È
    QD quadrant ÏóÏÞ
    QD quick disconnect ѸËÙ¶Ï¿ª
    Quack àÐÔÓÉù
    QUAD quadriphonic ËÄÉùµÀÁ¢ÌåÉù
    Quadrature Õý½»£¬90¶ÈÏàλ²î£¬¾«µ÷
    Quality ÒôÖÊ£¬ÉùÒô
    QUANT quantitative ¶¨Á¿µÄ
    QUANT quantize Á¿»¯£¬Êý×Ö»¯
    Quantizing Á¿»¯
    Quartz synthesized FM/AM digital tuner ʯӢ¾§Ì寵ÂʺϳÉʽµ÷Ƶ/µ÷·ùÊý×Öµ÷гÆ÷
    Quartz PLL frequency synthesizer ¾§ÌåÏúÏ໷ƵÂÊ
    Quaver °Ë·ÖÒô·û
    Quench ¶Ï¿ª£¬ÒÖÖÆ
    Quint Îå¶È£¬´ÎÈý±¶Òô
    Quiver ²ü¶¯Éù
R
  Ribbon microphone ÂÁ´ø»°Í²£¬Ñ¹Á¦´ø»°Í²
    Richness ·áÂú¶È
    Rhythm ½Ú×à
    Right ÓÒÉùµÀ£¬´¹Ö±µÄ£¬Êʵ±µÄ
    Ring »·£¬´óÈýо»·¶Ë£¬Àä¶Ë½Óµã£¬ÕñÁå
    Ring mode Éù·´À¡ÁÙ½çÕñÁåÕñµ´ÏÖÏó
    Rit ½¥Âý
    RF radio frequency É䯵£¬¸ßƵ
    RM regular matrix record Õý¹æ¾ØÕóʽËÄ·³ªÆ¬
    RM ring modulation »·Ðε÷ÖÆÆ÷
    RMD fing mode decoupling £¨ÒôÏ䣩ÕñÁåÍËñî¼¼Êõ
    RMR room reverb ·¿¼ä»ìÏì
    RMS random music sensor Ëæ»úÒôÀÖ̽²âÆ÷
  Rms root mean square ÓÐЧֵ
    RND random Ëæ»úµÄ
    RNG ring ÕñÁå
    Roadrack רҵÆ÷²Ä¼Ü
    Rock Ò¡¹öÀÖ¡¢Ò¡¹öÀÖÒôÏìЧ¹û
    Rod antenna À­¸ËÌìÏß
    RODS reverberation on demand system »ìÏìÇëÇóϵͳ
    Rolloff ¸ßµÍƵ¹æÂÉÐÔË¥¼õ£¬¹ö½µ
    ROM read only memory Ö»¶Á´æ´¢Æ÷
    Room ·¿¼ä
    Rose ½ÓÏߺÐ
    Rotary Ðýת
    RT60 Reverberation time »ìÏìʱ¼ä
    Rough ´ÖµÄ£¬´Ö²ÚµÄ£¬½üËÆµÄ
    Routing »ìºÏĸÏßÑ¡Ôñ
    RP record playback ¼·Å
    RP repeater ÔöÒôת·¢Æ÷
    RPLC replace Ìæ»»
    RSS Roland sound space processing system ÂÞÀ¼Éù¿Õ¼ä´¦Àíϵͳ
    RT rael time ʵʱ·ÖÎö
    RT recovery time »Ö¸´Ê±¼ä
    RT return ·µ»Ø
    RTA real time analyzer ʵʱ·ÖÎö£¨ÒÇ£©£¬ÆµÆ×·ÖÎö£¨ÒÇ£©
    RTS real time simulator ʵʱģÄâ
    RTS real time system ʵʱϵͳ
    RTY rotary Ðýת£¨ÑïÉùÆ÷£©
    Rubber corrugated ri loudspeaker ÏðÆ¤±ßÑïÉùÆ÷
    Ruby stylus ºì±¦Ê¯³ªÕë
    Rumba Â×°Í
    Rumble £¨µÍƵ£©Â¡Â¡Éù
    RV rendezvous »á¾Ûµã
    RVS reverse shift ·´ÏòÒÆ¶¯
    RZ return to zero ¹éÁã
    Reversal ·´Ï࣬Ïà·´£¬·´×ª£¬¸Ä±ä¼«ÐÔ
    Reverse »Ø¸´£¬·­×ª£¬·´»ìÏì
    Revert ¸´Ô­£¬·µ»Ø
    Review ¼ì²é£¬¸´²é£¬Öظ´
    Revolve Ðýת£¬Ñ­»·
    REW rewind ¿ìËÙµ¹´ø
    RF reception fair ½ÓÊÕÇé¿öÁ¼ºÃ
    RFI RF interface É䯵½Ó¿Ú
    RFI RF interferece É䯵¸ÉÈÅ
    Revcolor »ìÏìȾɫÉù
  RPS direct program Ö±½Ó½ÚÄ¿ËÑѰ£¬¿¨À­OKËÑË÷
    R(RD)radio É䯵
    R(RD)read ¶ÁÈ¡
    R receiver ½ÓÊÕ»ú
    R register ¼Ä´æÆ÷
    R right ÓÒÉùµÀ
    Rack »ú¼Ü£¬Ö§¼Ü£¬»ú¹ñ£¬¹æ¶¨¿í¶È£¬Õð¶¯Éù
    Radiation ·øÉä
    Radio ÎÞÏߵ磬µëÒô»ú£¬É䯵
    Ram random access memory Ëæ»ú´æ´¢Æ÷
    RAM ÌîÈ룬װÈë
    RAN random Ëæ»úµÄ£¬ÈÎÒâµÄ£¬ÎÞ¹æÔòµÄ
    Range ·¶Î§£¬×î´óÌáË¥Á¿£¬·ù¶È
    Rate ±ÈÂÊ£¬ËÙÂÊ£¬±ä»¯ÂÊ£¬ÆµÂÊ
    Ratio ѹËõ±È£¬À©Õ¹±È£¬±È£¬ÏµÊý
    RCA radio corporation of America ÃÀ¹úÎÞÏߵ繫˾
    RCA jack Á«»¨½Ó¿Ú
    R-CH ÓÒÉùµÀ
    R-DAT rotary head-DAT Ðýת´ÅͷʽÊý×Ö¼Òô»ú
    RE rack earth Íâ¿Ç½ÓµØ
    RE reset ¸´Î»
    RE right end ÓÒ¶Ë
    Reactance µç¿¹
    Readjustment ÖØµ÷
    Ready Ô¤±¸£¬×¼±¸Íê±Ï
    Rear ±³Ã棬ºó²¿£¬ºóÖÃ
    REC recording ¼Òô£¬¼Ç¼£¬Â¼ÖÆ
    Recall Õлأ¬µ÷³ö£¬ÖØÂ¼
    Receiver ½ÓÊÜ»ú£¬½ÓÊÜÆ÷
    Recharge ÔÙ³äµç
    Record ¼Ç¼£¬Â¼ÖÆ£¬³ªÆ¬
    Recorder ¼Òô»ú
    Recovery »Ö¸´£¬¸´Ô­
    Red ºìÉ«
    Redo ÔÙÖ´ÐвÙ×÷
    Reduce ¼õÉÙ£¬½µµÍ£¬ËõС
    Reduction ѹËõ£¬Ë¥¼õ£¬ÐγÉ
    Reecho »ØÉù
    REF Reference ˵Ã÷Ê飬²Î¿¼£¬»ù×¼£¬¶¨Î»
    REF Reflection ·´Éä
    Refraction ÕÛÉä
    Refresh »Ö¸´
    REG register ¼Ä´æÆ÷
    REG regulate ¿ØÖÆ£¬Ð£×¼£¬µ÷½Ú
  REGEN regeneration ÔÙÉú£¨»ìÏìÉùÕóÐγɷ½Ê½£©£¬Õý·´À¡
    Rehearsal ÅÅÁ·£¬Ô¤ÑÝ
    Reject ³ýÈ¥£¬ÂËÈ¥
    Rejection ÒÖÖÆ
    Reinforcement À©Éù
    Relay ¼ÌµçÆ÷£¬ÖØ·Å£¬×ª·Å
    Release »Ö¸´Ê±¼ä£¬ÊÍ·Å£¬¶Ï·Æ÷
    Rename ¸ÄÃû£¬ÃüÃû
    Remain ±£³Ö£¬Ê£Óà
    REM remote Ò£¿ØµÄ£¬Ò£Ô¶µÄ£¬Ô¶¾àÀëµÄ
    REM removable ¿É²ð×°µÄ
    REM remove ³ýÈ¥
    Remain ÓàÁ¿£¬×´Ì¬±£³Ö
    Renumber ÖØÐ´ºÅÂë
    REP repeat ÖØ¸´£¬·´¸´£¬ÖØ·Å
    Repeat mode Ë«Ãæ·´¸´·ÅÒô£¨Â¼Òô»ú£©
    Replacing Ìæ»»£¬Öû»£¬¸´Î»
    REQ room equalizer ·¿¼ä¾ùºâÆ÷
    Reset ¸´Î»£¬»Ö¸´£¬¹éÁã£¬ÖØ¸´£¬ÖØÐ°²×°
    Resolution ·Ö±æÂÊ£¬·ÖÎö
    Resonance ¹²Õñ£¬»ØÉù
    RESP response ÏìÓ¦£¬ÌØÐÔÇúÏߣ¬»Ø´ð
    Resistance ×迹
    Resister µç×è
    Resonance ¹²Ãù£¬Ð³Õñ Rest ÐÝÖ¹·û£¬¾²Ö¹£¬Í£Ö¹
    Restraint ÒÖÖÆ£¬ÏÞÖÆÆ÷
    RET return ·µ»Ø£¬»ØËÍ
    REV reverse µßµ¹£¬·´×ª
    REV reverberation »ìÏ죬²ÐÏì
    Reverb depth control »ìÏìÉî¶È¿ØÖÆ
    RIAA recording industry association of America ÃÀ¹ú¼Òô¹¤ÒµÐ­»á
2010-3-28 19:28:43 »Ø¸´
hdaudio Â¥Ö÷
S
  SAF Safety °²È«×°Ö㬱£ÏÕ×°Ö㬱£»¤×°ÖÃ
    Safeguard by ·À»¤Æ÷
    SALT symmetry air load technique ¶Ô³Æ¿ÕÆø¸ºÔؼ¼Êõ
    Samba É£°Í
    Sample ÉùÒôÐźÅÑùÆ·£¬²ÉÑù£¬È¡Ñù£¬³éÑù
    Sampling ³éÑù£¬Âö³åµ÷ÖÆ
    SAP second audio program µÚ¶þÌ×ÒôƵ½ÚÄ¿
    SAT saturate ±¥ºÍЧ¹û´¦Àí
    Save Öü´æ
    Save ´æ´¢£¬±£´æ
    Saxphone Èø¿Ë˾¹Ü
  Saxophome ¶¥À¡Ö±ÏßÌìÏß
    SC set clock ÖÃλʱÖÓ
    SC sigmal control ÐźſØÖÆ
    SC subcarrier ¸±Ôز¨
    SC system controller ϵͳ¿ØÖÆÆ÷
    SC scan ɨÃè
    Scale Òô½×£¬¿Ì¶È³ß±ê
    Scale unit ±ê¶Èµ¥Î»£¬·ÖƵÆ÷
    Scan ËÑË÷£¬¼Ç¼£¬É¨Ãè
    Scar ¼¤¹â³ªÆ¬ÉϵÄȱÏÝ
    SCART connectorÅ·ÖÞ±ê×¼21½ÅAV½Ó¿Ú
    Scattering É¢Éä
    Scene ʵ¿ö£¬³¡Ãæ
    SCH search ËÑË÷£¬Ñ°ÕÒ
    Scheme Éè¼ÆÍ¼£¬Ô­Àíͼ
    SCMS serial copy management system ³ÉÌ׸´ÖƹÜÀíϵͳ
    Screw ÂÝË¿¶¤
    Scrollback »ØÕÒ
    SCH stereochrous Á¢ÌåÉùºÏ³ª
    Schmidt trigger Ê©ÃÜÌØ´¥·¢Æ÷
    Scintillation ÉÁ˸£¬µ÷ÖÆÒýÆðµÄÔØÆµ±ä»¯
    SCMS successive copy manage system Á¬Ðø¸´ÖƹÜÀíϵͳ£¨DATÉ豸ÖзÀÖ¹¶à´Îת¼½ÚÄ¿µÄϵͳ£©
    Scoop ìæ¶·£¬ÊÕ¼¯Æ÷
    Scope ·¶Î§£¬ÏÔʾÆ÷
    Scoring ÒôÀÖ¼Òô
    SCR signal to clutter ratio ÐÅÔë±È
    SCR silicon controlled rectifier ¾§Õ¢¹ÜÕûÁ÷Æ÷
    Scraper ¹ÎÉùÆ÷
    Screen ÆÁ±Î
    SD space division ¿Õ¼ä·Ö²¼
    S-DAT stationary head DAT ¹Ì¶¨´ÅÍ·DAT»ú
    SDDS sony dynamic digital sound Ë÷Äᶯ̬Êý×Ö»·ÈÆÉùϵͳ
    SDI standard data interface ±ê×¼Êý¾Ý½Ó¿Ú
    SDLC synchronous data link control ͬ²½Êý¾ÝÁ´¿ØÖÆÆ÷
    SE single end µ¥¶ËµÄ
    SE sound effect ÒôÏìЧ¹û
    SE storage element ´æ´¢Ôª¼þ
    SE support equipment Ö§Ô®É豸
    SEA soond effect amplifier ÒôÏìЧ¹û·Å´óÆ÷
    SEA special effects amplifier ÌØÊâЧ¹û·Å´óÆ÷
    Search ËÑË÷£¬É¨Ãè
    Searcher ɨÃèÆ÷
    SEC Second Ã룬µÚ¶þ
    SECAM sequential color and memory µ÷ƵÐÐÂÖ»»²ÊÉ«ÖÆÊ½
   Section µ¥Ôª£¬»·½Ú
    Sectoral horm ÉÈÐκÅͲ
    Security ±£ÏÕ£¬¼ÓËø
    SED system effectiveness demonstration ϵͳЧ¹ûÑÝʾ
    Seek ËÑË÷
    SEL selector Ñ¡Ôñ×°Öã¬Ñ°Ï߯÷£¬×ª»»¿ª¹Ø
    Select Ñ¡Ôñ
    Selectivity £¨ÊÕÒô»ú£©Ñ¡ÔñÐÔ
    Semi- °ë-
    Semibreve È«Òô·û
    Semioctave °ë¸ö°Ë¶ÈÒô
    Semit °ëÒô
    SEN sensor ´«¸ÐÆ÷
    Send Ëͳö£¬·¢ËÍ£¬·¢Éä
    SENS Sensitivity ÁéÃô¶È
    Sense ·Ö±æÂÊ
    Sensor ´«¸ÐÆ÷
    Sentinel ·¢ÉäÆ÷£¬´«ËÍÆ÷
    SEP standard electronic package ±ê×¼µç×Ó×é¼þ
    SEP system engineering process ϵͳ¹¤³Ì´¦Àí
    Separator ·ÖÀëÆ÷£¬·Ö½âÆ÷
    Septieme Æß±¶Òô
    SEQ sequencer ÒôÐòÆ÷£¬¶¨ÐòÆ÷
    SEQ Stereo equalizer Á¢ÌåÉù¾ùºâÆ÷
    Sequence ÅÅÐò£¬ÐòÁÐ
    Series ϵÁУ¬´®Á¬
    Service άÐÞ£¬·þÎñ
    Servo ËÅ·þ»ú¹¹£¬Ëæ»úϵͳ
    Servo motor ËÅ·þÂí´ï
    SES spatial effect system Á¢ÌåÉù¿Õ¼äЧ¹ûϵͳ
    Session ¸úËæ×Ô¶¯°é×à
    Set µ÷Õû£¬É趨£¬×°Ö㬶¨Î»£¬½ÓÊÕ»ú
    Setout ¿ªÊ¼£¬×¼±¸
    Setup É趨£¬¹¹³É£¬²Ëµ¥£¬×éºÏ£¬µ÷Õû
    SFC sound field compos, er Éù³¡ºÏ³É×°ÖÃ
    SFL stereo flange Á¢ÌåÉù·¨À¼Ïâ±ß
    SFS sound field synthesis Éù³¡ºÏ³É
    SG signal generator Ðźŷ¢ÉúÆ÷
    SGL signal ÐźÅ
    S-hall small hall СÐÍÌüÌÃЧ¹û
    Shake Õð¶¯
    Shape ²¨ÐΣ¬ÂÖÀÈ
    Shaper ÕûÐÎÆ÷£¬Âö³å³ÉÐÎ
    Share drum С¾ü¹Ä
  Sharpness ÇåÎú¶È£¬ÏÊÃ÷¶È£¬Èñ¶È
    Shelving Â˳ý£¬Â˲¨´¦Àí
    SHG sub harmonic generator ´Î£¨·Ö£©Ð³²¨·¢ÉúÆ÷
    Shield ±£»¤£¬ÆÁ±Î
    Shift ת»»£¬±äµ÷£¬ÒÆÆµ£¬Æ¯ÒÆ
    Shock ³å»÷
    Short ¶ÌµÄ
    Short gate ¶ÌʱѡͨÃÅ£¨»ìÏìЧ¹û£©
    Shower ָʾÆ÷£¬ÏÔʾÆ÷
    SHUF Shuffle Ëæ»ú˳Ðò½ÚÄ¿²¥·Å
    Shunt ·Ö·£¬²¢Áª
    SHUTT shuttle ±äËÙËÑË÷£¬Íù¸´
    SI sneak in µ­Èë
    Sibilance ³ÝÒô£¬ßÐÒô
    Sibilant ßÐÒô
    Sibilation ßÐÒô£¬¸ßƵÉù»û±ä
    SICS sound image control system ÉùÏñ¿ØÖÆÏµÍ³
    Side ±ß£¬Ã棬²àÃæ£¬·½Ãæ
    Side chain ÅÔÁ´
    SIG signal ÉùÒôÐźÅ
    Signature ÌØÕ÷£¬ÒôÀֵĵ÷ºÅ
    SIF °éÒôÖÐÆµ
    Silencer ¾²ÔëÆ÷
    Silent ¾²Ôëµ÷г
    Simple tone ´¿Òô
    Simplex µ¥¹¤
    Simulate Ä£ÄâµÄ
    Simultaneous ͬ²½£¬ÁªÁ¢
    SINAD signal to noise and distortion ratio ÐźŶÔÔëÉùºÍÊ§Õæ±È
    Sine wave ÕýÏÒ²¨
    Single µ¥£¬µ¥´ÎµÄ£¬µ¥¶ÀµÄ£¬µ¥µú
    SIP solo in place ¶À×àÈëλ
    SIP standard information package ±ê×¼ÐÅÏ¢°ü
    Siren ÐýµÑ
    Size ³ß´ç
    Skew control ŤÇúУÕý£¬ÁâÐÎÊ§ÕæÆ÷
    Skip ÌøÔ¾£¬Ê¡ÂÔ
    SL signal level ÐÅºÅµçÆ½
    Slap ÅÄ´òЧ¹û
    Slap back ɽ¹È»ØÉù
    Slap reverb ɽ¹È»ìÏìЧ¹û
    Slate Ô¤¶¨£¬±ê¼Ç£¬£¨Â¼Òôµ÷Òǫ̂£©±ê¼Ç¿ª¹Ø
    Slave ´ÓÊôµÄ£¬´Ó»ú£¬´Ó¶¯µÄ
    Sleep ˯Ãß¶¨Ê±¿ª¹Ø£¬¾²Ö¹
   Sleeve(SLE) ½ÓµØµã£¬Ðä¶Ë£¬Ì×
    Slew rate ˲̬ÂÊ
    Sliding tone »¬Òô
    Slope бÂÊ£¬ÆÂ¶È£¬¿çµ¼
    Slow ÂýËÙ
    SLP super long play ³¬³¤£¨Èý±¶£©Ê±¼ä²¥·Å
    Sliding tone »¬Òô
    SLS studio listen Ñݲ¥ÊÒ¼àÌý
    SM sequential machine ʱÐò»ú SM signal meter ÐźÅÇ¿¶È¼Æ
    SM storage mark ´æ´¢±êÖ¾
    S/M speech/music ÓïÑÔ/ÒôÀÖ
    S/N signal-to-noise radio ÐÅÔë±È
    Small club С¾ãÀÖ²¿Ð§¹û
    Smear ҷ⣬ÍÏ⣬»ë×Dz»Çå
    Smear correction ÍÏβУÕý
    SMF Standard MIDI File ±ê×¼
    SMP sampler È¡ÑùÆ÷
    SMPTE society of motion picture television engineers £¨ÃÀ¹ú£©µçÓ°¼°µçÊÓ¹¤³Ìʦѧ»á
    S/N signal/noise ÐźÅ/ÔëÉù£¬ÐÅÔë±È
    SND sound ÉùÒô£¬ÒôÏ죬°éÒô
    Snake ¼¯ÌåÏß
    Snapshot Ƭ¶Î£¬³¡¾°×´Ì¬ÉèÖÃ
    Snubber »º³åÆ÷£¬¼õÕðÆ÷
    SO sneak out µ­³ö
    Socket ²å×ù£¬²å¿Ú
    Soft ÈíµÄ£¬ÈáºÍµÄ
    Soft click ÈáÐÔóéλ
    Soft knee Èí¹Õµã£¨Ñ¹ÏÞÆ÷£©
    Soft-touch Çᴥʽ
    Software ¼ÆËã»úÈí¼þ
    Solo ¶À³ª£¬¶À×à / ¼àÌý
    Sone ËΣ¨Ïì¶Èµ¥Î»£©
    Song ÀÖÇú
    Sound colum ÉùÖù
    Sound field Éù³¡
    Sound image ÉùÏñ
    Sound intensity ÉùÇ¿
    Sound shadow region ÉùÓ°Çø
    Sound cousole desk µ÷Òǫ̂
    Source ÉùÔ´
    SOS sound on sound µþ¼Ó¼Òô
    SP speaker ÑïÉùÆ÷
    SP speed ËÙ¶È
    SP standard-play ±ê×¼×ß´øËٶȼ·Å
  SPA stereo pan allochthonous Á¢ÌåÉùÉùÏñÆ¯ÒÆ
    Space ¼ä϶£¬¿Õ¼äЧ¹û
    Spaciousness ¿Õ¼ä¸Ð
    ST stereo Á¢ÌåÉù£¬Á¢Ìå
    STI speech transmission index ÓïÑÔ´«Êäϵͳ
    Sticks ²Ù×÷¸Ë£¬°²Ö㬿¨×Ó
    Still ¾²Ö¹
    STM send test massage ·¢ËͲâÊÔÐźÅ
    STO stand point λÖÃ
    STO stereo Á¢ÌåÉù
    STO stop Í£Ö¹
    STO store ´æ´¢£¬´æ´¢Æ÷
    STP shielded twisted pnir ÆÁ±ÎË«½ÊÏß
    Strike note »÷ÏÒÒô£¬×²»÷Éù
    String instrument ÏÒÀÖÆ÷
    Strip жϸ½ÊôÉ豸£¬¹ìµÀ£¬Àà±ð
    Strobe ѡͨÂö³å£¬ÆµÉÁ·Åµç¹Ü
    Strong ÓÐÁ¦µÄ
    Structure ×°Ö㬽ṹ
    STU Studio Ñݲ¥ÊÒЧ¹û
    SUB ¸±£¬¸¨Öú£¬¸½¼Ó£¬µÍÒô
    Subgroup ¸±£¬£¨µ÷Òǫ̂µÄͨµÀ¼¯ÖпØÖÆÍøÂ磩±à×é
    Suboctave ´Î°Ë¶È
    Subsonic ´ÎÉù£¬³¬µÍÒô
    Subwoofer ³¬µÍÒô
    Sum ºÍ£¬×ܺͣ¬×ÜÊý
    SUP Supply µçÔ´
    Supper ³¬
    Super bass ³¬µÍÒô
    Super over drive ³¬¼¤Àø
    Suppressor ÒÖÖÆÆ÷
    Support programs Ö§Ô®³ÌÐò
    SUR Surround »·ÈÆÉù£¬»·ÈÆ£¬°üΧ
    Sustain ±£³Ö£¬Î¬³Ö
    SVP surge voltage protector ÀËФµçѹ±£»¤Æ÷
    SW signal wire ÐźÅÏß
    SW S-Wite ÈûÌ×ÒýÏß
    SW switch ¿ª¹Ø£¬Çл»
    SW short wave ¶Ì²¨
    S/W specification of wiring ²¼Ïß¹æ¸ñ
    Swap ½»»»£¬µ÷¶¯£¨µÈÁ¿Æë¹Û£©£¬µ÷»»
    Sweep ɨÃ裬ÇúÏß
    Swell ÔöÒôÆ÷
    Swing °Ú·ù£¬Ò¡°ÚÎè
  Swishing ì¬ì¬Éù
    SX simplex µ¥¹¤
    SXE stereo exciter Á¢ÌåÉù¼¤ÀøÆ÷
    Symphobass µ÷гµÍÒôϵͳ
    Symphonic ½»Ï죬гÒô
    SPD speed µ÷ÖÆËÙ¶È
    SPDIF sony/philips digital interface Ë÷Äá/·ÉÀûÆÖÊý×Ö½Ó¿Ú
    SPE speaker ÑïÉùÆ÷£¬ÒôÏä
    Special ÁÙʱ£¨×°Öã©£¬ÌØÉèµÄ
    Specificatin ÐÔÄÜ
    Spectrum ÒôÓò£¬ÆµÆ×
    Speech ÓïÑÔ£¬ÓïÒô
    Speed ËÙ¶È£¬µ÷ÖÆËÙ¶È
    Speed select £¨Â¼Òô»ú£©´øËÙÑ¡Ôñ
    SPG severo pulse generator ËÅ·þÂö³å·¢ÉúÆ÷
    SPH single phase µ¥Ïà
    SPL sound pressure level Éùѹ¼¶
    Split ·Ö¸î£¬·ÖÅ䣬µÈÐźÅÇø
    SPM spiral modulation ÂÝÐýµ÷ÖÆ
    Spot effects ÏÖ³¡Ð§¹û
    Spring µ¯»ÉЧ¹û£¬µ¯»É»ìÏìÆ÷
    SPS stereo pitch shift Á¢ÌåÉù±äµ÷
    SPSS self program search system ×Ô¶¯½ÚÄ¿ËÑË÷ϵͳ
    Sport Ô˶¯³¡Ð§¹û
    SQ squelch ¾²Ô룬ÔëÉùÒÖÖÆ£¨µç·£©
    SQ stereo quadraphonic record ËÄÉùµÀÁ¢ÌåÉù³ªÆ¬
    Square ¹ã³¡ÒôÏìЧ¹û
    Squawker ÖÐÒôÑïÉùÆ÷
    Squeal Ð¥½Ð
    Squegger ¼äЪÕñµ´Æ÷
    Squib drivers µç±¬¼¤ÀøÆ÷
    SR Ò£¿Ø²Ù×÷
    SR speed ratio ת»»ËÙÂÊ
    SR stabilizeation receiver Îȶ¨½ÓÊÕ»ú
    SRL standard recording level ±ê׼¼Òôµçƽ
    SRS sound retrieval system ÉùÒô¹éÕæ£¨»Ö¸´£©ÏµÍ³£¬ÊÇÒ»ÖÖÀûÓÃË«ÉùµÀ²úÉú»·ÈÆÉù³¡µÄÐéÄâ»·ÈÆÉù·½Ê½¡£
    SS starting -point sensor £¨´Å´ø£©Ê¼¶Ë¸ÐÓ¦Æ÷
    SS switch selector ¿ª¹ØÑ¡ÔñÆ÷
    SSG synchronizing signal generator ͬ²½Ðźŷ¢ÉúÆ÷£¬Í¬²½»ú¡£
    SSLSC solid state logic studio computer¹Ì̬Âß¼­Â¼ÒôÊÒ¼ÆËã»úϵͳ
    ST sawtooth ¾â³Ý²¨
    ST start Æô¶¯£¬¿ªÊ¼
    ST status ״̬£¬×´¿ö
    ST stereo Á¢ÌåÉù
   ST store ´æ´¢
    Stability ƽºâ£¬Îȶ¨ÐÔ
    Stacking Õ¼¿ÕϵÊý
    Stadium ¶ÌìÌåÓý³¡Ð§¹û
    Stage Îę̀Ч¹û£¬¼¶£¬½×¶Î
    Stand-by µÈ´ý£¬×¼±¸£¬±¸ÓÃ
    Standard ±ê×¼£¬ÖÆÊ½£¬¹æ¸ñ
    Standing wave פ²¨
    Star ÐÇ£¬ÐÇÐΣ¬ÐǺÅ
    Start Æô¶¯£¬¿ªÊ¼£¬Ê¼¶Ë
    Start Id Æðʼʶ±ð
    Static doubling ¾²Ì¬Ë«Éù
    Station ²Ù×÷̨
    Status ״̬£¬×´¿ö
    ST-BY standey ×¼±¸
    STD standard ±ê×¼£¬¹æ¸ñ
    STD stereo delay Á¢ÌåÉùÑÓʱ
    Step ²½Ö裬¼¶£¬µµ£¬½×ÌÝ£¬²½½ø
    Step back ºóÍË
    Steer ²Ù×Ý£¬¿ØÖÆ
    Symphony ½»ÏìÀÖ£¬½»ÏìÀÖЧ¹û
    SYN(SYNC)synchronism ͬ²½
    SYN synthesizer ºÏ³ÉÆ÷
    SYNC synchronizer ͬ²½Æ÷
    Sychro ͬ²½»ú
    Synth ºÏ³É
    Synthesis ºÏ³É£¬×ÛºÏ
    SYS system ϵͳ£¬ÖÆÊ½
    SYS Ex system exchange ϵͳ½»»»
2010-3-28 19:58:26 »Ø¸´
hdaudio Â¥Ö÷
T
    TRIG trigger ´¥·¢£¬´¥·¢Æ÷£¬´¥·¢Âö³å
    Trim µ÷Õû£¬Î¢µ÷£¬µ÷г£¬Ï÷²¨
    TRK track Òô¹ì
    TRK trunk ×ÜÏߣ¬Ä¸Ïߣ¬¸ÉÏß
    Trouble ¹ÊÕÏ
    Trumpet СºÅ
    TRS time reference system ʱ¼ä»ù׼ϵͳ
    TST test ²âÊÔ
    TTY teleltypewriter Ò£¿Ø´òÓ¡»ú£¬µç´«»ú
    Tube µç×ӹܣ¬Õæ¿Õ¹Ü
    Tune µ÷г£¬ºÍг£¬µ÷Òô
    Tuner µ÷гÆ÷
  Tunetable £¨³ªÅ̵ģ©×ªÅÌ
    Tunnel reverb ËíµÀ»ìÏìЧ¹û
    Tupe ´¦Àíģʽ
    Turbo distortion ÎÐÂÖÊ§ÕæÐ§¹û
    Turntable µç³ªÅÌ£¬×ªÌ¨
    TV television µçÊÓ
    Tweeter ¸ßÒôÑïÉùÆ÷•
    Twin channel ˫ͨµÀ
    Two complement ²¹Âë
    Two way mode Ë«ÃæÂÖÁ÷·ÅÒôģʽ£¨Â¼Òô»ú£©
    TX transmit ·¢ËÍ£¬·¢Éä
    TX transmitter ·¢Éä»ú
    TYP trpe ÀàÐÍ
    Typical ±ê×¼µÄ£¬µäÐ͵Ä
    TRIG trigger ´¥·¢´¥·¢Æ÷£¬´¥·¢Âö³å
    TRK track Òô¹ì
    Trouble ¹ÊÕÏ
    Trumpet СºÅ
    TST test ²âÊÔ
    TTY teletypewriter Ò£¿Ø´òÓ¡»ú£¬µç´«»ú
    Tube µç×ӹܣ¬Õæ¿Õ¹Ü
    Tune µ÷г£¬ºÍг£¬µ÷Òô
    Tuner µ÷гÆ÷
    Tupe ´¦Àíģʽ
    TV television µçÊÓ
    Tweeter ¸ßÒôÑïÉùÆ÷
    Twin channel ˫ͨµÀ
    Two complement ²¹Âë
    TYP type ÀàÐÍ
    T talk ºô½Ð£¬ÁªÂç
    Tab ·ÀÎóĨµ²Æ¬
    TACH tachometer ²âËÙÆ÷
    TADI time assigument digital tnterpolation ʱ·ÖÊý¾Ý²å¿Õ£¨¼¼Êõ£©
  Tag µçÀ²åÍ·
    Take ʵ¼
    Takeoff È¡³ö
    Takeover »Ö¸´£¬»°ÒôµþÈ룬ÉÌÒé
    Talkback ¶Ô½²£¬ÁªÂç
    Tally ²¥³ö£¬Ìáʾ£¬²åÈë
    Tap µçÁ÷Êä³ö£¬½ÚÅÄ
    Tape ´ø£¬´Å´ø
    Tango ̽¸ê
    TB talkback ¶Ô½²»ØËÍ
    TB terminal board ½ÓÏß¶Ë×Ó×Ó°å
    TB time base ʱ»ù
    TBC time base corrector ʱ»ùУÕýÆ÷
    TBK tallback ¶Ô½²
    TC telecine µçÓ°µçÊÓ»ú
    TC time code ʱ¼äÂë
    TC transmitter-tunning circuit ·¢Éä»úµ÷гµç·
    TC trim coil ΢µ÷ÏßȦ
    TCC tripl concentric cable ÈýоͬÖáµçÀÂ
    TDE time domain equalizer ʱÓòµÈ»¯Æ÷
    TECH technique ¼¼Êõ£¬¼¼ÄÜ£¬¼¼ÇÉ
    TED television disk µçÊÓ³ªÆ¬
    TEL telescopic À­¸ËÌìÏß
    TEMP temperature ζÈ
    Temp ½Ú×à
    TEMOP temporary Öм䣨¹¤×÷£©µ¥Ôª
    TEMPO Tempo ½Ú×࣬Á¬½Ó£¬ËÙ¶È
    Terminal ÖÕ¶Ë£¬½ÓÏßÖù£¬ÒýÏߣ¬½ÓÍ·
    Tentelometer ÕÅÁ¦±í
    TER termination ÖÕ¶Ë
  &nb,sp;   Test ²âÊÔ£¬ÊÔÑ飬¼ìÑé
    THD total harmonic distortion ×Üг²¨Ê§Õæ
    Theater ¾ç³¡Ð§¹û£¬ÏÖ³¡
    Thermal noise ÈÈÔëÉù
    Thick ÉòÖØ£¬ºñÖØ¶È
    Thin µ¥±¡ÉùÒô
    Thinness ±¡£¨´ò»÷ÀÖ£©
    THR THRESH threshold ãÐÖµ£¬ãУ¬ÃÅÏÞ
    Thresh thrash ¶à´Î·´¸´
    Three dimension 3DÒôÏ죬ÈýάÁ¢ÌåÉùÒôÏìϵͳ
    Throat ¸ßÒôºÅ½ÇµÄºí
    THRU through ͨ¹ý£¬¹ýÇÅ£¬Ö±½ÓתËÍ
    Trump ¼ü»÷ÔëÉù£¬µÍƵÔëÉù£¬¿ª»úÅéÉù
    Thrust ²åÈ룬ǿÐмÓÈë
   THX tom holman"s eXpriment ÌÀ•»ô¶ûÂüʵÑ飬¼ÒÍ¥Ó°Ôº
    TI temperatun indicator ζÈָʾÆ÷
    TIE terminal interface exchange Öն˽ӿڽ»»»
    Tie Á¬½Ó·ûºÅ£¬À¡Ïߣ¬Í¨ÐÅ
    Tierce µÚÈýÒô£¬Îå±¶Òô
    Tight Ó²£¬½ô£¬Ó²ÀÊ
    TIM transient intermodulation ˲̬»¥µ÷Ê§Õæ
    Timber ÒôÖÊ£¬ÒôÉ«
    Timbre Éù²¿
    Time ʱ¼ä£¬±¶£¬´Î£¬¶¨Ê±µÄ
    Timer ¶¨Ê±Æ÷£¬¼ÆÊ±Æ÷
    Tininess µ¥±¡
    Tint É«µ÷
    TIP terminal interface processor Öն˽ӿڴ¦Àí»ú
    Tip Í·¶Ë£¬ÈȶË
    Title ±êÌ⣬×ÖÄ»
    TK track Òô¹ì
    TL track loss ¹ì¼£¶ªÊ§
    TLE trunk line equipment ¸ÉÏßÉ豸
    TM trade mark ×¢²áÉ̱ê
    TMS transmission mesurement set µçƽ±í
    TMT transmit ·¢ËÍ
    TN tuning unit µ÷гװÖÃ
    TOC ½ÚĿĿ¼
    Tone Òôµ÷£¬Éùµ÷£¬´¿Òô
    Tone burst â§·¢Òô
    Tone color ÒôÉ«
    Tone quality ÒôÉ«£¬ÒôÆ·
    Tonic ÂÉÒô
    Top ×î¸ß
    TOS tape operating system ´Å´ø²Ù×÷ϵͳ
    Total ×Ü£¬×ܹ²
    Total tune ÕûÌåЭµ÷£¬×ܵ÷г
    Touch ´¥£¬Ñ¹£¬°´
    Touch sens ¼üÅÌÀÖÆ÷Ö¸´¥µÄ´¥¸Ð
    TPD turnout piece delay ·ÖÖ§ÑÓʱ
    TR tape recorder ´Å´øÂ¼Òô»ú
    TR telerecording µçÊÓÆÁϼÏñ
    TR tracking ¸ú×Ù
    TR transfer ´«Êä£¬×ªÒÆ
    TR trick ÌØ¼¼Ð§¹û
    Track ÇúÄ¿ºÅ£¬´Å¼££¬Òô¹ì
    Tracking Ѱ¼££¬¸ú×Ù£¬Í³µ÷
    Tracking monitor µ÷У¼àÌý
  Trad Ïݲ¨Æ÷£¬´ø×èÂ˲¨Æ÷
    Tramp ÈýͨµÀ¹¦·Åϵͳ
    Transfer תӡ£¬×ª½Ó
    Transformer ±äѹÆ÷
    Transpose תµ÷£¬±ä»»Æ÷£¬ÒƵ÷
    Transport ÔËÐУ¬·¢ËÍ
    Transient ˲̬
    Transient distortion Ë²Ì¬Ê§Õæ
    Transient response ˲̬·´Ó¦
    Transmit ·¢Éä
    Transistor ¾§Ìå¹Ü£¬Èý¼«¹Ü
    Transponder תµ÷Æ÷£¬±ä»»Æ÷
    Transposer ±äµ÷Æ÷
    Transversal equalizers ºáÏò¾ùºâÆ÷
    Treble ¸ßÒô£¬Èý±¶µÄ£¬ÈýÖØµÄ
    Tremold tremor ²üÒô
    Tremolo ÕðÒô
    Tremor ²üÒô£¬ÕñÒô×°ÖÃ
    Triamp Èý·µç×Ó·ÖÒô
    Trick ÌØ¼¼
    Trig ÐÞÊÎ Spatializer Éù³¡¶¨Î»¼¼Êõ
2010-3-28 19:58:57 »Ø¸´
hdaudio Â¥Ö÷
U
UHF ultra high requency ³¬¸ßƵ
    UL upper limit ÉÏÏÞ
    UL user hanguage Óû§ÓïÑÔ
    ULD unit logic device ×éÖ¯Âß¼­×°ÖÃ
    ULF ultra-low frequency ³¬µÍƵ
    UNBAL Unbalance ·Çƽºâ£¨Á¬½Ó£©£¬²»Æ½ºâ¶È
    Undo ²»Ö´ÐвÙ×÷
    Unit µ¥Î»
    Uni-directinoal microphone µ¥·½ÏòÐÔ»°Í²
    Uniform quantizer ¾ùÔÈÁ¿»¯Æ÷
    Unlocked δÉÏËø£¬²»Í¬²½£¬²»Ëø¶¨
    Unlson гÒô£¬µ÷ºÍ
    Unpitched sound ÔëÉù£¬ÎÞµ÷Éù
    Unscramble ÇåÀí£¬Ê¹•••ÇåÎú
    UHF ultra high frequency ³¬¸ßƵ
    UL upper limit ÉÏÏÞ
    UL user language Óû§ÓïÑÔ
    Undo ²»Ö´ÐвÙ×÷
  Unit µ¥Î»
    Unlson гÒô£¬µ÷ºÍ
    Unscramble ÇåÀí£¬Ê¹¡­ÇåÎú
    Unset ¸´Î»£¬¸´Ô­£¬Ïû³ý
    UP ultra pass ¸ßͨ
    UP ultraportable ³¬±ãЯʽ
    Up ÏòÉÏ£¬Ôö¼Ó
    Update ÐÞÕý£¬Ð£Õý
    UPO ²»Ê§Õ湦ÂÊÊä³ö
    Upper Éý¸ß£¬ÏòÉÏ
    Uppercase ´óдµÄ£¬Óôóд×ÖĸÅÅÓ¡
    UPS uniterruptable power output ²»¼ä¶ÏµçÔ´
    Up to date ×îÐÂʽµÄ
    User Óû§
    USS United States Standard ÃÀ¹ú±ê×¼
    UTIL utility ʵЧ£¬ÊµÓã¬Ó¦ÓÃ
    Utility edit/compare ¹¦Äܼô¼­/±È½Ï
    UTP unshielded twisted pair δÆÁ±ÎË«½ÊÏß
V
    VOL volume ÒôÁ¿£¬Ìå»ý£¬Æ¬ºÅ£¬Ïì¶È
    VOS voice operated switch Éù¿Ø¿ª¹Ø
    VOX voice operated switching device ÉùÒô¿ØÖÆÇл»×°ÖÃ
    VOX voice iperated transmitter Òô¿Ø´«Êä×°ÖÃ
    VOX voice test ÓïÑÔ²âÊÔÐźÅ
    Vox £¨À­¶¡ÓÉùÒô
    Vowel ÔªÒô
    VPS video phase setter ÊÓÆµÏàλµ÷½ÚÆ÷
    VPS video program system ÊÓÆµÑÝ·Åϵͳ
    VR variable resistor µçλÆ÷£¬¿É±äµç×èÆ÷
    VRA variable response amplifier ¿Éµ÷ÏìÓ¦·Å´óÆ÷
    VRR visual radio range ÊÓÆµÎÞÏߵ粨¶Î
    VSR vital slave reels ÐéÄâ´ÓÊô¾í£¨Ó²Å̼Òô»ú£©
    VSS virtual surround system ÐéÄâ»·ÈÆÉùϵͳ
    Vth threshold voltage ãÐÖµµçƽ
    VU volume unit ÒôÁ¿µ¥Î»±í£¬ VU±íV value ÊýÖµ£¬Òô³¤
    VA volt ampere ·ü°²
    VA volt ammerter ·ü°²±í
    Variation ±ä»¯£¬²ÎÊýµ÷½Ú£¬±ä×à
    Variable ¿É±äÁ¿
   VC vocal cancel Ô­¸èÉùÏû³ý
    VCA voltage control Amplifier ѹ¿ØÔöÒæ·Å´óÆ÷
    VCD video compact disk ÊÓÆµ¼¤¹â³ªÆ¬
    VCF video controlled filter µçѹ¿ØÖÆÂ˲¨Æ÷
    VCO voltage controlled oscillator µçѹ¿ØÖÆÕñµ´Æ÷
    VCR video cassette recorder ¼Ïñ»ú
    VDA ÒôÉ«ÒôÁ¿
    VDA variable digital amplifier ¿É±äÊý×ÖʽÂ˲¨Æ÷
    VDF ÒôÉ«ÁÁ¶È
    VDP ¼¤¹âÓ°µú»ú
    VDU video display unit ÊÓÆµÏÔʾÆ÷
    VELO velocity ËÙ¶È£¬Á¦¶È
    Vent ͨ·£¬³ö¿Ú
    VERB reverberate »ìÏì
    Verify ¼ìÑ飬ºË¶Ô
    Verisimilar ±ÆÕæµÄ
    Vertical ´¹Ö±
    VF video frequency ÊÓÆµ
    VFX voice effects ÓïÒôÌØ¼¼Ð§¹û
    VFD vacuum fluorescent display Õæ¿ÕÓ«¹âÏÔʾ
    VGA variable gain amplifier ¿É±äÔöÒæ·Å´óÆ÷
    VHD video high density system ÊÓÆµ¸ßÃܶÈϵͳ
    VHF very high frequency Éõ¸ßƵ
    VI volume indicator ÒôÁ¿Ö¸Ê¾Æ÷
    Via ¾­Çú£¬½èÖúÓÚ
    VIB Vibrato ²üÒô
    Vibration Õñ¶¯
    VID video ÊÓÆµµÄ
    VID virtual image display ÕæÊµÍ¼Ïñ
    Video ÊÓÆµ£¬Í¼Ïñ£¬µçÊÓµÄ
    Videodisc ÊÓÆµ³ªÆ¬
    View ×ÜÀ£¬Ö¸Ê¾£¬¹Û²ì
    Village Gatage СÒôÀÖÌüЧ¹û
    Violin СÌáÇÙ
    VIP variable information processing ¿É±äÐÅÏ¢´¦ÀíÆ÷
    VIP versatile information processor ¶àÖÖÐÅÏ¢´¦ÀíÆ÷
    VIP visual image processor ÊÓÆµÍ¼Ïñ´¦ÀíÆ÷
    VIP visual input ÊÓÆµÊäÈë
    VIR virtual image ÐéÏñ
    Vision Ó°Ïñ
    Vision cable µçÊÓµçÀÂ
    VLF very low frequency ³¬µÍƵ
    VLS virtual listening system ÐéÄâÌýÒôϵͳ
    VMT voltage mate technlolgy µçѹƥÅä¼¼Êõ
  VO vertical output ´¹Ö±Êä³ö£¬Ö¡É¨ÃèÊä³ö
    VO voice ÓïÑÔ£¬ÒôƵ
    VOC vocoder ÉùÂëÆ÷£¬ÓïÒô±àÂëÆ÷
    Vocal ÉùÒôµÄ£¬ÉùÀֵ쬷¢ÒôµÄ
    Vocal partner Éù»ìºÏ£¬°éÒô
    Vibration Õñ¶¯
    VODER voice operation demonstrator ÓïÒôºÏ³ÉÆ÷
    Voice ÓïÑÔ£¬ÈËÉù£¬ÒôƵ
    Voicing Éù²¿£¬£¨¸ÖÇÙ£©ÇÙ¼ü´¥¸ÐÓ²¶ÈÒ»ÖÂÐÔµ÷Õû
    Voice over Éù¹ýÂË
    VOL voltage µçѹ
    VTR video tape recorder ´Å´øÂ¼Ïñ»ú
    VTS video tape splicer ¼Ïñ¼ô¼­»ú
2010-3-29 09:01:25 »Ø¸´
hdaudio Â¥Ö÷
W
  W watt ÍßÌØ£¬Íß
    write дÈë
    Walk-man ÐäÕäºÐʽ·ÅÒô»ú£¬ËæÉíÌý£¨Ë׳ƣ©
    Wall Ç½ÃæÎüÉùÌØÐÔ
    WalFin Ç½ÃæÎ¢µ÷
    Waltz »ª¶û×ÈÔ²ÎèÇú
    Warble tone ßùÉù
    Wargin ÓàÁ¿Ö¸Ê¾
    Warm ÎÂůµÄ£¬·áÂúµÄ
    Warm ¾¯¸æ£¬Ê¾¾¯
    Watcher ָʾµÆ£¬¼àÊÓÆ÷
    Wave ²¨
    Waveguide ²¨µ¼
    Wavelength ²¨³¤
    Way ·£¬Æµ¶Î
    WB wideband ¿íƵ´ø
    WB work bench ¹¤×÷̨
    WBT wide band transmission ¿íƵ´ø´«Êä
    WE weighting ¼ÆÈ¨£¬¼ÓȨ
    Weak ÈõµÄ
    Weight ÖØÁ¿
    Wheel µ÷½ÚÐýÂÖ
    Wet ʪ£¬Ð§¹ûÉùÐźţ¬Î´¼Ó¹¤µÄ
    WF Waveform ²¨ÐÎ
    Whispern ɳɳÉù
    Whistle Ð¥½ÐÉù£¬ÉÚÉù
    White °×É«
    White noise °×ÔëÉù
    Whole ÍêÕûµÄ
  Wide ¿í¹ã£¬¿íÀ«
    Wideband ¿í´ø£¬¿íƵ´ø
    Widening À©Õ¹£¬¼Ó¿í
    Wow ¶¶»Î£¬µÍƵ²ü¶¯
    Wow/flutter ¶¶»ÎÂÊ
    WS working storage ÔÝ´æÆ÷
    Woofer µÍÒôÒôÏä
    WidFin ˮƽ΢µ÷
    Width ÃܶÈ
    Wind ¿ì½ø
    window ´°£¬´°¿Ú
    Wiping head Ïû´ÅÍ·
    Wire µ¼Ïߣ¬Ïß
    Wired ÓÐÏߵģ¬ÓÐÏß´«Êä
    Wireless ÎÞÏßµçµÄ£¬ÎÞÏßµÄ
    Wireless mic ÎÞÏß»°Í²
    Wiring ÅäÏߣ¬×°ÉèÏß·
    With ÄæÏò£¬Ïà¶Ô
    Write дÈ룬´æÈë
    WRMS weighted root mean square ¼ÓȨ¾ù·½¸ùÖµ
    Wtd weighted ¼ÓȨ
    WORM write once read mang Ò»´ÎдÈëÐ͹âÅÌ
    Wole Tone ²»Ð­ºÍµ÷
X
X cross ɾ³ý£¬½»²æ
    X exchange ½»»»
    X exterior À©Õ¹
    X extra ¸½¼Ó£¬±¸ÓÃÆ·
    X-bass µÍÒôÀ©Õ¹
    XBS extra bass system ÖØµÍÒôϵͳ
    XFER transfer ×ªÒÆ
    X-FMR,X-FORMER ±äѹÆ÷
    XIC transmission interface converter ´«Êä½Ó¿Úת»»Æ÷
    XIR extreme infrared Ô¶ºìÍâÏß
    XLR ¿¨Ù¯½Ó¿Ú
    XMIT transmit ´«Ê䣬·¢ËÍ
    XPLN explansonder ½âÊÍ£¬ËµÃ÷
    XPNDR transponder ת·¢Æ÷£¬Ó¦´ðÆ÷
    X pose ³ýα
    XT XTALK cross talk ´®Òô£¬´®ÈÅ
    XVTR transverter ±ä»»Æ÷
2010-3-29 09:01:50 »Ø¸´
ºÃÎÄÕÂ,²»´í,ÎÒÊÕ²ØÁË£¬Ð»Ð»Â¥Ö÷°¡£¡~
2010-3-29 09:16:13 »Ø¸´
ûʾÍÖ§³ÖÏÂ/
2010-4-24 18:50:11 »Ø¸´
