Embertone Ancient Voices for KONTAKT
ÒôÔ´
¹Å´úÈËÉùÊÇNI KontaktµÄÒ»¸öÐéÄâÄÐÉùºÏ³ª¿â¡£ÀÖÆ÷¿ÉÒÔÒÔÕæÕýµÄÁ¬×àģʽ£¨¶À×àÑÝ×ࣩ»òÊʺϵ¯×àºÍÏҵĺÍÏÒģʽÑÝ×à¡£ÕâÁ½ÖÖģʽÌýÆðÀ´ÕæÊµºÍ×ÔÈ»£¬²ÉÑùvocals²¢²»×ÜÊÇÈç´Ë¡£ÀÖÆ÷¿çÔ½C2µ½C4Á½¸ö°Ë¶ÈÒô½×µÄ·¶Î§¡£
¸Ã½çÃæ¾ßÓÐÓÃÓÚÑ¡Ôñ²¥·ÅģʽµÄLegatoºÍPoly°´Å¥£¨ÕâÒ²¿ÉÒÔʹÓð´¼ü¿ª¹ØÍê³É£©£¬¹Ø±ÕºÍ·¿¼äÂó¿Ë·çµÄÒôÁ¿ÒÔ¼°Ìí¼ÓµÄ»ìÏìÁ¿¡£¶¯Ì¬»¬¿é¿ØÖÆÂ¼ÖƵÄÈËÉùµÄÇ¿¶È£¬×îÓÐȤµÄ¹¦ÄÜ£¬Ò²ÊÇ×îÖØÒªµÄÒ»¸ö×ÔÈ»ÌýÆðÀ´µÄ±íÏÖ¡£ÓÃÈýÖÖ²»Í¬µÄ¶¯Ì¬²ÉÑùÒôÉ«£¬¿ÉÒÔʹÓÃMIDI¼üÅÌÉϵϬ¿é»òµ÷ÖÆÂÖÎÞ·ìµØ±ä»»ÒôÉ«¡£ÕâÔö¼ÓÁ˶ԱíÑݵÄÐËȤ£¬Ê¹±³¾°ºÏ³ª»ò¶À×à±íÑÝÌýÆðÀ´¸üÓÐ˵·þÁ¦¡£
¼æÈÝKontakt Full 5.4.1+
ÕâÊÇÒ»¸öÍêÕû°æ±¾µÄKontaktÀÖÆ÷£¬ÕâÒâζ×ÅÄã±ØÐëÓÐÍêÕû°æ±¾µÄKontakt²ÅÄÜʹÓÃËü£¡Ëü½«ÔÚÈκÎVST / AU / RTAS / AAX¼æÈÝÖ÷»ú³ÌÐò»òDAW£¨ÈçCubase£¬Logic£¬Ableton Live£¬Digital Performer£¬Reaper£¬Pro-Tools£¬SonarµÈ£©ÖÐ×÷Ϊ²å¼þ¹¤¾ßÔËÐС£ÎÞÐè¶îÍ⹺Âò£¡
ϵͳҪÇó£º
500 MBµÄ´ÅÅ̿ռä
×î´óÄÚ´æÕ¼ÓÃÁ¿Îª500MB
Intel Core 2 Duo£¬Mac OS X 10.10,10.11»òMacOS 10.12£¨×îиüУ©
Windows 7£¬Windows 8»òWindows 10£¨×îеÄService Pack£¬32/64룩Intel Core 2 Duo»òAMD Athlon 64 X2
ÐèÒªInternetÁ¬½ÓºÍÖ§³ÖOpenGL 2.1»ò¸ü¸ß°æ±¾µÄͼÐ免ÅÄÜÏÂÔØºÍ¼¤»î´Ë²úÆ·¡£Ò»µ©°²×°²¢¼¤»î£¬²úÆ·¿ÉÒÔÀëÏßʹÓá£
4 GB RAM£¨ÍƼö´óÐÍKONTAKTÒÇÆ÷ʹÓÃ6 GB£©
Ô­ÎÄ
Ancient Voices is a virtual male choir library for NI Kontakt. The instrument can be played in true legato mode (for solo performances) or in polyphonic mode which is suitable for playing chords. Both modes sound authentic and natural, which isn¡¯t always the case with sampled vocals. The instrument spans a range of two octaves, from C2 to C4.
The interface features Legato and Poly buttons for choosing the playback mode (this can also be done using keyswitches), the volume of close and room microphones, and the amount of added reverb. The most interesting feature, and one that¡¯s the most important for a natural-sounding performance, is the Dynamics slider which controls the intensity of the recorded vocals. The voices were sampled with three different dynamics which can be morphed between seamlessly using the slider or the modulation wheel on the MIDI keyboard. This adds interest to the performance and makes background choirs or solo performances sound more convincing.
Compatible with Kontakt Full 5.4.1+
This is a FULL Version Kontakt instrument, meaning that you MUST have the full version of Kontakt to use it! It will run as a plug-in instrument in any VST/AU/RTAS/AAX compatible host program or DAW, such as Cubase, Logic, Ableton Live, Digital Performer, Reaper, Pro-Tools, Sonar, etc. No extra purchase needed!
System Requirements:
500 MB of disk space
Max RAM footprint is 500MB
Mac OS X 10.10, 10.11 or macOS 10.12 (latest update), Intel Core 2 Duo
Windows 7, Windows 8, or Windows 10 (latest Service Pack, 32/64-bit) Intel Core 2 Duo or AMD Athlon 64 X2
An Internet connection and a graphics card that supports OpenGL 2.1 or higher are required to download and activate this product. Once installed and activated, the product can be used offline.
4 GB RAM (6 GB recommended for large KONTAKT Instruments)
Embertone Ancient Voices for KONTAKT | 430MB
ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ÆÀÂÛÁÐ±í£¨2£©
²»´í¡£ÐÀÉÍ¡£:victory:
2009-12-10 10:10:20 »Ø¸´
2009-12-14 14:16:15 »Ø¸´
