´óËÂÔº3-WAYÓÐÔ´¼àÌýÒôÏä
3·ÖƵ¼ÒôÅï¼àÌýÒôÏä
ÊÖ¹¤¶¨ÖƵÄAIR Motion»ðÅ£
¶¨ÖƵÄȫƵ¶ÎÖÐÒôÀ®°È
Á½¸ö¶¨ÖƵÄ6.5´çµÍÒôÀ®°È
¹¦ÂÊ£º200WRMSµÍƵ£¬100WRMSÖÐÆµ£¬100WRMS¸ßƵ
·ÖƵµã£º24DB pre Octave Linkwitz-Riley set at 120Hz and 2500
ƵÂÊÏìÓ¦£º28Hz-35kHz +/-XdB, 38Hz-35kHz +/-3dB
¹¤×÷»·¾³£º100-240VAC input IEC 320-14
Tech SpecsPoweredLF Driver SizeHF Driver TypeLF Driver Power AmpHF Driver Power AmpFrequency RangeCrossover FrequencyMaximum Peak SPLEnclosure TypeInput TypesHeightWidthDepthWeightManufacturer Part Number
Yes
Low: 2 x 6.5"; Mid: 5.25"
Air Motion Transformer
Low: 200W (RMS); Mid: 100W (RMS)
100W (RMS)
35Hz-38kHz
24 dB/octave @ 120Hz and 2500Hz
108 dB SPL @ 1m, 1%THD (1kHz)
Ported
1 x XLR/TRS Combo
14.2"
10.6"
15.2"
35.2 lbs.
Abbey MB
3-Way studio monitor
Custom designed Air Motion Transformer (94dB@1W)
Custom full range driver for midrange
Two Custom 6.5 inch subwoofers
Amplification: 200WRMS to low frequencies, 100WRMS to mid frequencies, 100WRMS to high frequencies
Crossover: 24dB per Octave Linkwitz-Riley set at 120Hz and 2500Hz
Frequency response: 28Hz-35kHz +/-XdB, 38Hz-35kHz +/-3dB
Internal SMPS power supply, 100-240VAC input IEC 320-14
- Æ·ÅÆ£ºAvantone
- ÐͺţºAvantone Pro Abbey-Black
- ÀàÐÍ£ºÂ¼ÒôÅïÈý·ÖƵÓÐÔ´ÒôÏä
- ¼Ó¹¤¶¨ÖÆ£º·ñ
- ÖØÁ¿£º9kg
- LF Driver Size£º7
- HF Driver Size£º3
- requency Range£º47Hz-22kHz
- Crossover Frequency£ºCrossover Frequency 380Hz, 2.5kHz
- Maximum Peak SPL£º109 dB SPL @ 1m
