·çµÑµÄ½á¹¹
·çµÑµÄ½á¹¹
The structure of bagpipe
A bagpipe minimally consists of an air supply, a bag, and a chanter. Optionally, further chanters and/or drones can be added.
Air supply
The most common method of supplying air to the bag is by a blowpipe, or blowstick, into which the player blows. A more recent innovation, dating from the 16th or 17th centuries, is the use of a bellows to supply air. This has the advantage that the supplied air has not been heated and moistened by the player''s breathing.
Bag
The bag is simply an airtight (or near airtight) reservoir which can hold air while the player breathes. Materials for the bag vary widely: most common are skins of local animals, for example, goat, sheep, cow, pig, and so on. In modern times, players have experimented with modern materials such as rubber, Gore-Tex, and other airtight fabrics.
Chanter
The chanter is the melody pipe, played by one or both hands. The chanter is usually open-ended; thus, there is no easy way for the player to stop the pipe from sounding. So, embellishments are used to break up notes and to create the illusion of dynamic effect.
Drone
Most bagpipes have at least one drone. A drone is most commonly a cylindrical tube with a single reed, although drones with double reeds do exist. The drone is generally designed in two or more parts, with a sliding joint so that the pitch of the drone can be manipulated.
ÍêÕûµÄËÕ¸ñÀ¼·çµÑÖÁÉÙÊÇÓÉÒ»¸ù´µ¹Ü¡¢Ò»¸ö·ç´üºÍÒ»¸ùµ÷ÐýÂɹÜ×é³É¡£ÓеķçµÑÉÏ»á¶îÍâÌí¼Óµ÷ÐýÂɹܺ͵¥Òô¹Ü¡£
´µ¹Ü£º
×î³£¼ûµÄÏò·ç´üÊäËÍ¿ÕÆøµÄ·½·¨±ãÊÇÓõ¼¹Ü»òÕß¹÷×Ó¡£¶øÔÚ16»ò17ÊÀ¼ÍÒ²ÓÐÈË·¢Ã÷ÁËÓ÷çÏä´úÌæ´µ¹ÜÀ´ÊäËÍ¿ÕÆø£¬ÕâÑù×öµÄºÃ´¦ÊDZ£Ö¤·âµØÔÚÑÝ×à¹ý³ÌÖв»»áÒòΪ¿ÕÆø±»ÑÝ×àÕߵĺôÎü¼ÓÈÈ»òå¦Êª¶ø³öÏÖÎÊÌâ¡£
·ç´ü£º
·ç´ü£¬¼òµ¥ËµÀ´¾ÍÊÇÒ»¸öÃܱջò½üºõÃܱյįøÄÒ£¬ÔÚÑÝ×àÕߺôÎüʱ¿ÉÒÔÓÃÀ´ÔÝʱ´¢´æ¿ÕÆø£¬ÒÔ±£Ö¤ÑÝ×àµÄÁ¬ÐøÐÔ¡£ºÜ¶à²ÄÁ϶¼¿ÉÒÔÓÃÀ´ÖÆ×÷·ç´ü£¬×î³£¼ûµÄÊÇÓõ±µØµÄÊÞÆ¤À´×ö£¬ÈçɽÑòƤ¡¢ÃàÑòƤ¡¢Å£Æ¤¡¢ÖíÆ¤µÈ¡£¶øÏÖÔÚ£¬ÈËÃÇÒ²ÒѾ­³¢ÊÔÓúܶàÏÖ´ú²ÄÁÏÀ´ÖÆ×÷·ç´ü£¬ÈçÏ𽺡¢¸ê¶ûÌØË¹ÃæÁÏÒÔ¼°ÆäËüÖÖÀàµÄÃÜ·â²ÄÖÊ¡£
µ÷ÐýÂɹܣº
µ÷ÐýÂɹܿÉÒÔÓõ¥ÊÖ»òÕßË«ÊÖ²Ù×÷¡£Ò»°ã·çµÑµÄµ÷ÐýÂɹܵÄÁ½¶Ë¶¼²»ÊÇ·â±ÕµÄ£¬ËùÒÔÑÝ×àÕßÍùÍùºÜÄÑʹËüÍ£Ö¹·¢³öÉùÒô¡£Òò´Ë£¬Ò»Ð©¶îÍâµÄ×°ÊÎÎï¾ÍÊÇÓÃÀ´±êʾ½ÚÅĺÍÖÆÔìÇ¿ÓÐÁ¦µÄÑÝ×àЧ¹ûµÄ¡£
µ¥Òô¹Ü£º
´ó²¿·ÖµÄ·çµÑÖÁÉÙ¶¼ÓÐÒ»¸ùµ¥Òô¹Ü¡£ËüÊÇÒ»ÖÖ´øÓÐÒ»¸ö»ÉƬµÄÔ²ÖùÐεĹÜ×Ó£¬µ±È»£¬Ò²ÓдøÁ½¸ö»ÉƬµÄµ¥Òô¹Ü£¬µ«ÊDz¢²»³£¼û¡£µ¥Òô¹ÜÍùÍù·ÖºÃ¼¸²¿·Ö£¬Óɿɻ¬¶¯µÄ½Ó·ì£¬ÕâÑù¾Í¿ÉÒÔµ÷½Úµ¥Òô¹ÜµÄÒô¸ßÁË¡£
British Council
ÆÀÂÛÁÐ±í£¨1£©
:victory::victory:
2009-11-27 14:19:03 »Ø¸´
