SAWStudioÈçºÎʵÏÖSide ChainºÍDe-esser¡¾½ø½×ƪ¡¿
Sawstudio
*Ãû´Ê½âÊÍ£ºside chain(²àÁ´)£¬ De-esser(È¥³ÝÒô£©¡£
ʲôÊDzàÁ´£¿²Î¿´Ö®Ç°ÎÒÃǵÄÎÄÕ¡¶Side chain? What is it? What is it used for¡·¡£
1£©Ducking/Cross Limiting
So far, we have been talking about compressors that process the signal that is being used in the level detection process. But in some cases, you would prefer to have a signal's level controlled by a different signal - when one signal level is high, the other signal is attenuated, as in Figure 4. This is called 'ducking' (since it 'ducks' a signal out of the way) or cross limiting. The most common example would be a radio DJ. While music is playing, speaking into the microphone will cause the level of the music to drop so that it's easier to understand the DJ. When mixing in the studio, a ducker can also be used to emphasize certain elements, such as the kick drum. The kick could lower other tracks in the mix, increasing its 'presence.'
ÉÁ±Ü´¦Àí/½»²æÏÞÖÆ
    ĿǰΪֹ£¬ÎÒÃǶ¼ÊÇÔÚÌÖÂÛѹËõÆ÷±»ÓÃÓÚlevel detection£¨ÐźŴóС̽²â£©µÄ´¦Àí¡£µ«ÔÚijЩÇé¿öÏ£¬ÄãÐèÒªÓÃÁíÍâÒ»¸öÐźÅÈ¥¿ØÖÆÄ㵱ǰµÄÐźţ­µ±Ò»¸öÐźŵÄÒôÁ¿±ä´ó£¬ÄÇôÁíÍâÒ»¸öÐźžͻᱻÏ÷Èõ£¬Çë¿´ÉÏͼ¡£Õâ¸ö±»³ÆÎª¡°ÉÁ±Ü¡±»òÕß½»²æÏÞÖÆ£¨cross limiting£©¡£×î¶àÔËÓÃÕâ¸ö·½·¨µÄ¾ÍÊǵç̨µÄDJ¡£ÔÚÒôÔ´ÕýÔÚ²¥·ÅµÄʱºò£¬¶øµ±DJ¶ÔÕâMIC˵»°µÄʱºò£¬ÒôÀ־ͻᱻ´¥·¢¡°ÉÁ±Ü¡±´¦Àí£¬¶ø½µµÍÒôÁ¿£¬Ê¹µÃDJµÄÉùÒô¸üÈÝÒ×±»Ìý¼û¡£ÔÚ¹¤×÷ÊÒMIXINGµÄʱºò£¬ÉÁ±Ü´¦ÀíÆ÷Ò²ÄÜÓÃÓÚÇ¿µ÷MIXÖеÄÖ÷ÒªÔªËØ£¬ÀýÈçKICK DRUM.KICKÔÚMIXÖÐÄÜ±ÈÆäËûµÄÀÖÆ÷µÄƵÂʸüµ×£¬Í¨¹ýÉÁ±Ü´¦Àí£¬Ìá¸ßËûµÄ¡°³ö³¡ÂÊ¡±¡£
£¨¸üÕý£º¸öÈËÈÏΪ£¬ÕâÀïÓ¦¸ÃÀí½â³É£ºKICK¿ÉÒÔѹµÍÆäËû¹ìµÄÉùÒô£¬´Ó¶ø¡­¡­ lower = low + er×ö¶¯´Ê½â£¬¶ø²»ÊÇÐÎÈÝ´Ê¡£Èç¹ûÊÇÉÏÎÄÕâÑù·­Ò룬lower  Ç°Ãæ±ØÐë¼ÓÒ»¸öbe£¬Í¬Ê±ºóÃæÒª¼ÓÒ»¸öthan¡£Ô­Îĵı¾Ò⣬´ó¸ÅÊÇ£¬½«ÆäËû¹ìµÄkeyÉèÖóÉkick£¬¿ÉÒÔÓÃkickѹËõÆäËû¹ìµÄÉùÒô£¬´Ó¶ø¿ÉÒÔÍ»³öKICK µÄÉùÒô¡££©
2£©ÈçºÎÔÚSAWÒÔcompressor×÷ de-esser µÄ¹¦ÄÜ???
    Ê×ÏÈÔÚ saw µÄÏÞѹ(compressor)²¿·Ý, ÎÒÃǻῴµ½ key, eq hi , eq lo , key listen µÄ×ÖÑÛ¡£
½« Hi Key filter µ÷ ÖÁ7khz , Lo key filter to around 6.5khz... (ʺõ²»Í¬ÒôÔ´¶ø¶¨, Ò»°ãÈËÉùÔÚÕⷶΧ),  È»ºó°´ key listen ÌýÒ»Ìý "˻˻"ÉùÊÇ·ñÔÚÕâλÖÃ....Èç¹ûûÓÐÎÊÌâ....¿ÉÒÔ¿ªÊ¼Ïò×óÒÆ¶¯compressor Ãż÷(threshold)µÄÍÆ×Ó, Ö±ÖÁ¿´µ½ gain reduction µÄѶºÅ³öÏÖʱ, ÁôÒâÄǸö²ÎÊý×îΪ˳»¬....ÕâÑù±ã¸ã¶¨ÁË!!  Saw µÄ levelizer Ò²ÓÐÕ⹦ÄܵÄ, Ч¹ûÏ൱²»Ë×!! ͬÑùÔ­ÀíµÄÓ¦Óõ½ÆäËû¸÷ÖÖ¶à¶ÎѹËõÆ÷ÉÏÃæ£¬ÀýÈçWAVES C4, ULTRAFUNK, Samplitude MultibandDynamic, Nuendo MultibandCompressor, TC Compressor Deessor,Izotope Ozone³ôÑõÀïµÄMultibandDynamicµÈ¡­¡­ÓÃÀ´ÊµÏÖÈ¥³ÝÒôµÄ¹¦ÄÜ£¬¾ßÌå×ö·¨Çë´ó¼Ò¾ÙÒ»·´Èý£¬Ôڴ˲»ÔÙ׸Êö¡£
ÆÀÂÛÁÐ±í£¨1£©
:victory::time:
2009-10-28 18:15:48 »Ø¸´
