Dangerous Music Monitor ST¿ØÖÆÆ÷
6 J5 p4 W; O1 d* o( p; J6 O, ~1 |
4 k' h. |1 I. O* Z$ ]Dangerous Music¹«Ë¾½üÈÕÐû²¼£ºDangerous Monitor ST ¼°Dangerous Monitor SR¼´½«ÃæÊС£¸ÃϵÁвúÆ·×ÅÖØÓÚ½â¾öÔÚ¼ÒôÊÒÔËÓÃDAWϵͳƽ̨½øÐмÒôºÍ»ìÒô¹ý³ÌÖеļàÌýÎÊÌâ¡£ÆäÖÐMonitor STÊÇÒ»¿îÔ¶³Ì¿ØÖÆÒÇ£¬Ëü¼¯³ÉÁËÒôÔ´ÊäÈë¡¢ÑïÉùÆ÷¿ª¹Ø£¬¶Ô½²ÏµÍ³£¬ÒÔ¼°Ò»¸öËæ»ú¸½´øµÄ¶ú»úʽ¹¦ÂÊ·Å´óÆ÷¡£Monitor SRÊÇMonitor STµÄÀ©Õ¹Ä£¿é£¬¿ÉʵÏÖ5.1»·ÈÆÁ¢ÌåÉùЧ¹û¼àÌý¡£Â¼ÒôʦÔÚ¹¤×÷ÊÒ¿ÉÒÔÏÈʹÓÃMonitor ST£¬Ö®ºóÔÙ¼ÓÈëMonitor SRÒÔʵÏÖÁ¢ÌåÉù»·ÈÆÐ§¹ûͬʱ¼õÉÙÁËÉ豸ÈßÓࡣ¼Òôʦ½«É豸ͨ¹ýcat-5Á¬½ÓÖÁÔ¶³Ì¿ØÖƵ¥Ôª£¨ÖîÈçMonitor ST£©Ö®ºó£¬±ã¿ÉÔÚ¼ÒôÊÒµÄÌýÒôλÖÃʵÏÖ¶ÔÕû¸öϵͳµÄ¿ØÖÆ¡£ % v, H% J8 Z3 i1 C* ]
8 R- ]0 L- f/ [. f+ @
¡¡¡¡¡¡¡°ÎÒÃÇÉè¼Æ³öMonitor ST ¡¢Monitor SRÒÔÂú×ãDAWϵͳƽ̨Óû§¶ÔÒôƵ´¦Àí¹ý³ÌÖмàÌýµÄÒªÇ󡣡± Dangerous MusicµÄ´´Ê¼ÈËBob MullerÈçÊÇ˵¡£Í¬Ê±Dangerous MusicµÄÉè¼ÆÊ¦ Chris MuthҲ˵µ½£º¡°Ä¿Ç°DAWƽ̨ºÍÊý×ÖÄ£Ä⹤×÷ÊÒµÄÓ¦ÓÃÈÕÒæ¹ã·º£¬ÊµÏÖºÍÖÚ¶àÊý×ÖÄ£ÄâÉ豸µÄÎÞ϶¼æÈÝÊÇÎÒÃǵÄʹÃü¡£ÎÒÃÇÔÚÉè¼Æ¹ý³ÌÖо¡Á¿¿¼ÂÇMonitor ST¡¢Monitor SRµÄ¼á¹ÌÐÔ£¬ÓÉÓÚÕâÀàÉ豸¾ßÓÐÖÚ¶àµÄ¹¦Äܵ÷½ÚÆ÷ËùÒԺܿÉÄÜÔÚÉèÖùý³ÌÖвúÉú´íÎó¡£ËùÒÔÎÒÃÇÔÚMonitor ST¡¢Monitor SR¸´ÔÓµÄÄÚ²¿¹¹ÔìÍâ²ÉÓÃÁ˼ò½àµÄÍâ¹ÛÉè¼Æ£¬ÒÔ±ãÓÚÓû§½øÐÐÉ趨¡£¡±
' Q/ o# }+ t5 u% F) i, j# g5 N, Y4 U7 ^7 ]
" z2 D* M& A8 N5 [, ] Dangerous Music Dangerous Monitor ST Features:
3 O" p! W, Y- X$ b
! A& N1 V. Z; Q2 c5 w- E# ^Scalable monitor management solution
/ t3 e x* {% j8 a. Q6 M" `8 h, A; j# G4 W) R
Relied upon by world-class mix and mastering engineers+ m& L. K- ]8 u0 z% D
6 t5 e( Z# j3 Z* r W" nDesigned and built by a company founded upon mastering
$ D, {+ z& d% k. x4 j: ]# f- J
9 Y3 {7 K. O. H5 I3 ^/ J! s |Programmable remote tethered by a simple, elegant Cat 5e cable U4 m7 z* V! I7 y, q# V
4 a6 b0 A8 m1 [ yCustomize the five analog inputs, three speaker sets and dedicated subwoofer output
, U3 u/ j. d* c! M0 z) v4 `
. T* @# E/ k: o7 ?Pristine 20W headphone amp will inspire an artist&££39;s best performance
. i! z# t5 k' I) l: O: c" }& N& y- r
& c7 l8 F7 O4 s% B* KAnalog stepped-attenuator volume control
/ `, B; B0 C' ]5 g- @0 K7 E. u) F, U
No level control IC&££39;s used - pristine, accurate and repeatable.6 Z# `: U l. O# n/ g$ }& B$ u
$ l, l+ F' }* ^3 K U) o4 input sources
( s5 o+ T1 x& Q9 b$ J) X! r1 w& C" p; P7 o+ ~: g+ J5 p; J) _
Switch between your DAW outputs, DVD player, CD player, tape machines, etc.- m5 ^* O: w% N+ I9 r3 ^& I
4 `4 R0 s% [$ r" E. A- \3 speaker outputs) w u! o: r4 B
: ~( X) O& F* @, O0 |7 eSwitch between up to 3 sets of monitors( b4 @' }9 f% n G8 b/ v+ J/ r
3 p5 B1 {1 r. K3 Z' `6 z
Programmable input gain offsets" E4 G# q9 U4 G; s" D
( l/ w; f2 A# N) V
Adjust for and store level offsets for different source devices
+ o; r8 T& b& l/ o( u# Y2 N; ^/ e Y7 }( z
Input level compensation for -10dBV and +4dBu sources
; h' q1 @9 n! y% f; ]9 x6 M+ a
# w7 g$ n) t1 W& J9 J% RInstantly adjust and store gain compensation for consumer devices9 w. N& p) f# o, n) b) A
' b& x2 I' D, s4 B& x4 T
Input 4 has continuously variable level offset
7 l4 v' n6 {( ^4 ?: q9 W/ b+ `$ |1 o n
! b7 {% D6 A# e% A2 I9 e% w$ yCompensate for commercial CD levels and perform true A/B comparisons without compromising sound quality.9 f, N$ c6 y/ b: k6 u) W0 _) s
+ f4 ~! Z+ x+ n
Programmable output level offsets" R8 [7 k% G7 {) F( O& f7 F+ v
8 ]. ]4 e9 E, z+ {Fine-tune and store offsets to achieve equal apparent loudness on all your control room speakers- SR unit has continually variable level trims for L-R rear, center and LFE.! i7 R3 s" Z5 N6 H0 g u) r7 D( M3 I
" d: Y) |+ i3 U2 o1 X+ u
Assignable subwoofer output" e Z$ M$ V2 O. Y3 s2 `+ f
/ ]) q* I; [: q+ n7 D" T
Choose and store which sets of speakers you want to use with your sub8 c0 O7 Y2 o# |8 d
7 I8 Y% m3 P. e' M( |; d( uProgrammable subwoofer level offset% B+ E/ ` w4 V; H
2 o# k5 o: X( ~- S# A. u ]
Adjust and store subwoofer levels, easily alternate between sub function and LFE function7 i+ c) ~4 |& ?) R( z3 @/ t! V2 a
1 b; \" y9 a: H1 ? `4 |+ ?3 XSelectable subwoofer filtering! h: |9 v! B! `; m% r/ X1 [
. S- Q1 c9 n, M+ dSelect and store subwoofer filter options for each set of speakers. Switch between full bandwidth for surround mixing and bottom octave only for stereo work.1 ^4 f: ?9 v V/ ^+ {
6 K- V1 T1 e9 |' O5 |% LComprehensive speaker Mute and Solo
( C0 W5 W7 E4 G5 k+ D1 h6 z# x* {
; X1 F' d2 t6 I4 }9 d7 L- _Easily mute and solo speakers in any combination+ z8 a- Y6 F, l, h) I
9 \$ N3 W; f jFlexible stereo cue system with main and auxiliary inputs
' Q- f' L9 X$ C; T" ^; r5 K1 v" d. W. f( w, Q+ {8 ?, t
Use the aux input as a Beep channel to monitor computer alert tones or click tracks on the main speakers.
# D [* [* Z, ~8 ~
& }+ `- _: b$ f3 K7 x( ^) N" ]40 watts of clean power for your headphones
% y7 e# g' n& a. Y* h! X
: N- H- }+ M, j0 A5 fTalkback system with dual control and dedicated slate output ?2 u1 X; K$ T8 L
. m* p, M8 n( X% ^7 T9 a: VGive the producer his own talkback button! Easily slate tracks, or send the slate output to a powered speaker for open-air talkback1 j3 l) b+ u7 u# n, g1 y
* E) D& y& ^( F; N' }, PSR unit has selected source output3 N* u' j8 m& c
/ F! }# G3 g# ?, \
Send source signals to meters or any other external device
& ~. W+ S* K, k8 K* Z7 n2 f6 d: i; y* P) G7 n [
Gain Tracking Accuracy: better than 0.05dB for 6 channels
5 L2 R ~' ^' K0 j' E$ z
) W; F( n: }6 A% x4 DTHD+N: 0.002%
0 a: L, h: }; \$ V C/ ?7 ^/ \
5 i- ?7 l) t0 f# gIMD: 0.003%
: U$ v* {& W) z1 O; X3 g/ i- z, i
4 h3 P' Q1 t: u" s W; KFrequency Response: 1Hz-100kHz -0.1dB2 J/ f- R- X+ x$ l8 [* N( w0 y& E
+ ]; D. e2 b5 V' mCrosstalk Rejection: >96dB
' w6 p8 p+ \7 q! H e, ?$ y
* X* _ \- _! ^* } L( SNominal Input Level: +4dBu or -10dBV1 }6 e+ _# R8 d X$ B
! W9 d# Z4 ~ O4 y$ g h3 qCrossover: -3dB @ 57Hz 18dB/octave modified Butterworth/Chebyshev
0 c9 g" @1 Q3 F( ^$ T
: R5 d9 r- t, {1 vHeadphone amp: 0.002% THD+N' Q: k5 u' b% F H2 F
6 e& n' ?* U1 F9 ^% R( A! VHeadroom: +25dBu to main outputs2 ~4 w% s% o! D2 I
2 I p1 C9 V3 WWarranty: 2 years parts and labor, subject to inspection.
8 O8 Z" ~8 y( K# b; p
$ y9 ~# u1 p$ n; }+ PTech Specs/ w0 n& Q5 M4 |* h
Tech Specs | Number of Input Channels | 8 | | Number of Output Channels | 8 | | Analog Inputs | 2 x XLR, 1 x DB-25 | | Analog Outputs | 2 x XLR, 1 x DB-25 | | Digital Inputs | No Digital Inputs | | Digital Outputs | No Digital Outputs | | Headphones | 1 x 1/4" | | Talkback | Yes | | Form | Rackmount | | Height | 1.75" | | Depth | 9.5" | | Width | 19" | | Weight | 16 lbs.
. N; A$ f9 j f, M" |; g
" O& X; G$ g& ~" }2 w |
4 l0 @, ?. f/ C( l |
