CineSamples CineBrass Twelve Horn Ensemble KONTAKT
CineBrass Twelve Horn EnsembleÊÇCineBrass PROͼÊé¹Ý¾µäTwelve Horn²¹¶¡µÄ¸Ä½ø°æ±¾¡£ ÕâЩ²¹¶¡¾ßÓÐCineStrings SOLO¿ª´´ÐÔµÄCinesamples×ÔÊÊÓ¦LegatoÒýÇæ£¬ÎªÄúµÄÐýÂÉÏßÔöÌíÁËÁ÷¶¯ÐÔºÍÎÞÓëÂױȵÄÏÖʵ¸Ð¡£ CineBrass Twelve HornÀÖÍÅÔÚÂåÉ¼í¶µÄMGMÅäÀÖÈüÖмµÃ¡£
CINEʾÀý½«CineStrings SOLO£¬Tina Guo Acoustic Cello Legato£¬CineWinds CORE£¦PROºÍViola da GambaµÄ×ÔÊÊÓ¦Legato EngineÓ¦ÓÃÓÚCineBrass Twelve Horn Ensemble¡£ ËüÔÊÐíÄú¸ù¾Ý×Ô¼ºµÄÑÝ×à·ç¸ñ¶¨ÖÆlegatoÏìÓ¦£¬Ö¼ÔÚÏìÓ¦ÄúµÄ±íÑÝ¡£ ÒýÇæ¿ÉÒÔ¼ì²âÄúµÄ²¥·ÅËÙ¶È£¬²¢ÖÇÄܵ÷Õû¼ä¸ôËÙ¶ÈÒÔÆ¥Åä¡£ ÕâÒâζ×ÅÄú¿ÉÒÔÔÚµ¥¸öÑÝ×àÖв¥·Å»ºÂý£¬±íÏÖÁ¦µÄÏßÌõºÍ¿ìËÙÔËÐУ¬¶øÎÞÐè´¥Ãþ¿ìËÙ²¦ºÅ¡£ ÁíÍ⣬ǿ¶È²ÎÊýÏìÓ¦ËÙ¶È
ÔÎÄ
CineBrass Twelve Horn Ensemble is an improved version of the classic Twelve Horn patches from our CineBrass PRO library. These patches feature the groundbreaking Cinesamples Adaptive Legato Engine from CineStrings SOLO, adding fluidity and unparalleled realism to your melodic lines. CineBrass Twelve Horn Ensemble was recorded at the MGM Scoring Stage in Los Angeles.
Cinesamples applied its Adaptive Legato Engine from CineStrings SOLO, Tina Guo Acoustic Cello Legato, CineWinds CORE & PRO, and Viola da Gamba to CineBrass Twelve Horn Ensemble. It allows you to tailor the legato response to your own playing style, and is designed to respond musically to your performance. The engine detects your playing speed and intelligently adjusts the interval speed to match. This means you can play slow, expressive lines and fast runs in a single performance, without touching the speed dial. Additionally, the intensity parameter responds to velocity
CineSamples CineBrass Twelve Horn Ensemble KONTAKT | 1.81 Gb
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´
