TDA1540
4 t3 H4 q- I" z/ n: x3 B14-BIT DAC (SERIAL OUTPUT): j- g( K2 _$ t. m8 h
PhilipsÔçÆÚµÄcdʹÓõÄоƬ£¬1986Äê11ÔÂ14ÈÕÑз¢,½âÎöÁ¦Ò»°ã£¬ÒôÉ«ÎÂů," L) H% J# |& q: V: `4 I0 D" Z
28½Å·â×°£¬¹©µç±È½ÏÌØÊ⣨+5v£¬-5v£¬-17v£©£¬I2S¼Ü¹¹) Z. f/ e( p1 g8 O6 J
S/N 80dB/min 85dB/Type
3 C* ~4 P; p% z/ k _; S& ?ºó׺±íʾ²»Í¬µÄ·âװģʽ7 p& I6 U- j. G' B; p0 C, v
TDA1540D
! k; v' X) ~, `7 H& u# t& ~14-BIT DAC (SERIAL OUTPUT)2 a: ^# J2 k" f
TDA1540PN |+ @1 m0 k5 h" h
. R F* l4 G" H6 \TDA1540TD) d4 w3 z0 S. x5 @
14-BIT DAC (SERIAL OUTPUT). m" `0 s9 d# V2 ]' `' Y! H8 |
9 f3 X. d. F& V* ]9 G1 v% S
TDA1541
0 o& ]& V; ^( lDUAL 16-BIT DAC; G4 E2 {; J4 O5 W+ ]
Philips×î³öÃûµÄdacоƬ£¬1985Äê11ÔÂÑз¢,ÔÏζʮ×㣬ÈáÇéËÆË®£¬ÈËÉù³öÉ«£¬¸öƵ¶ÎÊ®·Ö¾ùºâÄÍÌý6 ^ v: s" h- ^' }
ΪPhilips´òÏÂÁË´ó´óµÄ½®ÍÁ# W, H. @7 ?: l6 ^
28½Å·â×°£¬¹©µç£¨+5£¬-5£¬-15£©£¬I2S¼Ü¹¹,S/N 90dB/min 95dB/Type ÉùµÀ·ÖÀë 80dBºó׺AÊÇ1541µÄÉý¼¶°æ£¬S1±íʾ¾«Ñ¡
1 t) C5 e/ Y1 x: s0 ~TDA1541A5 g; x/ M2 \+ Z/ T
STEREO HIGH PERFORMANCE 16-BIT DAC
?% `" d' d. B! iTDA1541A/N26 h1 w! j; ^% p9 }2 Y6 d( C
STEREO HIGH PERFORMANCE 16-BIT DAC E# t$ R! K4 g
TDA1541A/N2/R1# c7 k: A' v8 D8 p3 Y+ q& `
STEREO HIGH PERFORMANCE 16-BIT DAC% i3 r: Y# g; k& g4 q2 D# O# a+ y9 y# s
TDA1541A/N2/S1) S! m# M! {5 z% v2 x% q
t) d$ I3 n* ]2 `& J
0 f" @4 c* Q9 |) ]" U9 WTDA1543
+ I& P' l2 y7 N1 ]: e+ i* SDUAL 16-BIT DAC ECONOMY VERSION I2S INPUT FORMAT
! G5 S7 ?8 y1 lPhilipsΪСÐÍÉ豸¿ª·¢µÄоƬ£¬1991Äê2ÔÂÑз¢
' _5 B& e/ E# e) x½âÎöÁ¦Ò»°ã£¬ÒôÉ«ÎÂů£¬ÖÐÆµÃÔÈË£¬ÃܶȺܺñ¶ÈÁîÈ˳Ծª
+ H5 e7 @9 `# U8½Å·â×°(TΪ16½Å)£¬¹©µç+5v£¬ S/N 96dB ·ÖÀë90dB
5 ~9 d* e; C) K7 M( R) p% B5 sTDA1543T, u3 D+ p5 X5 C* j
DUAL 16-BIT DAC ECONOMY VERSION I2S INPUT FORMAT( L) h$ U5 O; O3 |' j9 Q0 Y E
$ B: p, |! a) u: \$ V! @2 ]6 J2 `TDA1545# V' \! `* O& t0 h `3 \
STEREO CONTINUOUS CALIBRATION DAC9 B1 h- o% t4 j
µÚÒ»¿îCONTINUOUS CALIBRATION dac£¬1993Äê3ÔÂÑз¢|ÒôÉ«²»Ã÷$ G9 Q, q4 n% G+ q/ N- ]* c
8½Å·â×°£¨ATTΪ14½Å£©,¹©µç+5v£¬S/N 98dB ÉùµÀ·ÖÀë 95dB
: E% C0 O; u _7 r* V, T9 @TDA1545A
! g2 e: M1 }( D# X2 ^1 vSTEREO CONTINUOUS CALIBRATION DAC. w( l+ I8 c; W* {4 v
TDA1545AT
! F5 W* T" {8 d ^# I+ KSTEREO CONTINUOUS CALIBRATION DAC
0 S5 t5 ^ D' x6 Y# UTDA1545ATT5 ~5 H& i& K& z; D/ |
0 G% U7 a* O/ G( A4 R1 Z! o, U$ ^9 E0 U
TDA1547
" ^' m# h- P0 [7 N6 {DUAL TOP-PERFORMANCE BITSTREAM DAC
6 y4 p8 g7 f8 I1 F9 F% r! UPhilipsΪ¶¥¼¶ÒôƵÉ豸¿ª·¢µÄ³¬¼¶Ð¾Æ¬£¬1991Äê9ÔÂÑз¢²ÉÓñÈÌØÁ÷¼¼ÊõµÄ1±ÈÌØdac£¬, N: P8 m+ w: A" C
ºÍËû´îÅäµÄ²ÉÓñÈÌØÁ÷¼¼ÊõµÄоƬSAA7350£¬ËûÕûºÏÁËÈý½×¾²ÔëºÍ1±ÈÌØdacÁ½Æ¬Ð¾Æ¬ÒôÉ«¼æ¹ËÔÏζºÍËÙ¶È£¬
/ c: Z2 o* P7 DÊÕ·Å×ÔÈ磬ƵÏì¿í¹ã£¬ÆøÊƺê࣬Êʺϸ÷ÖÖÒôÀÖ. X, p2 h+ H3 y
32½Å·â×°£¬¹©µç£¨+-5£¬-3.5£©S/N 113dB/A¼ÆÈ¨ THD-101dB
) g& H0 ]8 c/ uÉùµÀ·ÖÀë115dB
7 x) z6 z5 J( `6 j! h1 {; {5 ^: BAD Audio D/A Convertersart#; _) i# N2 L+ Y6 q. n5 g. S9 F$ c' M6 k
¡¡ | DAC DNR (dB) | SNR (dB) | DAC THD+N @ 1 kHz (-3dB) | Product Description | Price* (1000-4999) | Function | | AD1955 | 120 | 120 | 110 | Multibit Sigma-Delta D/A w/ SACD Playback | $6.86 | DAC | | AD1853 | 116 | 117 | 104 | 24-bit 192 kHz Multibit Sigma-Delta DAC (Current Output) | $7.59 | DAC | | AD1852 | 114 | 114 | 104 | Stereo, 24-bit 192 kHz Multibit Sigma-Delta D/A (Voltage Output) | $5.57 | DAC | | AD1854 | 113 | 112 | 97 | Complete Single Chip Stereo Audio D/A | $4.05 | DAC | | AD1953 | 112 | 112 | 100 | SigmaDSP 3 Ch, 26-/48-Bit Processing D/A | $7.14 | DAC, Signal Processor | | AD1954 | 112 | 112 | 100 | SigmaDSP 3 Ch, 26-/48-Bit Processing D/A | $7.14 | DAC, Signal Processor | | AD1933 | 110 | 110 | 96 | 192 kHz, 24-Bit CODEC w/ PLL | $3.66 | DAC | | AD1833A | 110 | 110 | 95 | Multi-Ch, 24-bit 192 kHz, Sigma-Delta D/A | $3.98 | DAC | | AD1958 | 109 | 108 | 96 | Stereo, 24-bit 192 kHz Multibit Sigma-Delta D/A w/ PLL | ** | DAC | | AD1934 | 108 | 108 | 96 | 192 kHz, 24-Bit CODEC w/ PLL, IC and SPI. | $3.15 | DAC | | AD1851 | 96 | 110 | 90 | 16-Bit, 16 3 FS PCM Audio DACs Dual 5V Supplies | $4.71 | DAC | | AD1857 | 94 | - | 90 | Stereo, Single Supply 16/18/20-bit Sigma-Delta D/A | ** | DAC | | AD1859 | 94 | - | 88 | Stereo, Single Supply 18-bit Integrated Sigma-Delta D/A | $4.45 | DAC | | AD1858 | 94 | - | 90 | Stereo, Single Supply 16-bit Sigma-Delta D/A | ** | DAC | | AD1868 | 92 | 98 | 88 | Single Supply Dual 18-Bit Audio DAC | ** | DAC | | AD1866 | 90 | 95 | 86 | Single Supply Dual 16-Bit Audio DAC | $10.57 | DAC |
@- R3 \, }) G8 d1 w% A% F2 e6 }) a8 p/ d3 L+ f* M6 ]
' r, g4 {* v' [. v$ N" w0 F' F
9 p$ W: }. r' t
2 h, x; u* M2 w# C
1 e+ I4 [# f/ N7 P; X4 S* q* a! ^! l! ^$ y/ H# l5 ]+ H: m
PCM1700# w: A% J) K6 k3 X/ E( u
DUAL 18-BIT MONOLITHIC AUDIO DIGITAL-TO-ANALOG CONVERTER9 {$ B4 @2 c! R6 O& e
1702µÄ¸ç¸ç£¬Ò²ÊÇ´óÃû¶¦¶¦£¬ÔçÆðºÜ¶à´óÅÆµÄ½âÂëÆ÷¶¼ÓÃËû
0 _0 E j% g/ l1 f: c1 MÄÚº¬Á½¸öDACµ¥Ôª£¬·Ö±ðת»»×óÓÒÁ½¸öÉùµÀµÄÐźţ¬ÒײúÉú×óÓÒÉùµÀÏ໥¸ÉÈÅ£¬ÊÇËû²îÉùµÄÔÒò# e# B2 K2 B* y' {- }
PCM1700P% x$ H+ d) _& x9 L2 m1 \
DUAL 18-BIT MONOLITHIC AUDIO DIGITAL-TO-ANALOG CONVERTER# S4 ]) n7 ]9 ]( c
PCM1700P-J
, F2 f3 O' t4 S6 a3 NDUAL 18-BIT MONOLITHIC AUDIO DIGITAL-TO-ANALOG CONVERTER
0 Z6 G4 |7 t# FPCM1700P-K
* t, e, N! J2 j2 bDUAL 18-BIT MONOLITHIC AUDIO DIGITAL-TO-ANALOG CONVERTER. ^- Q; |; O. C6 I. N
PCM1700U! _0 _' T9 i1 E, a- Q
O. U7 G2 t. cPCM1700U-J; V& |& P0 q! F! G( B2 i) w) Y
# K# g; g; h0 u1 D9 D/ w0 Z% \: vPCM1700U-K% {* L" X8 K8 o2 C$ M5 D5 r
DUAL 18-BIT MONOLITHIC AUDIO DIGITAL-TO-ANALOG CONVERTER/ q) A/ a! I" j) A) {" k
, A6 M& C4 f% ^# J! x7 u
PCM1702
2 r- ~; t! H3 zBICMOS ADVANCED SIGN MAGNITUDE 20-BIT DIGITAL-TO-ANALOG CONVERTER9 @9 R# L" g0 b& a( X2 r. @
µ±ÄêBB¹«Ë¾µÄ¶¥¼¶½âÂ룬ÒôÖʳöÖÚ¡£
7 C9 ^5 n- f3 T5 S# k9 lPCM1702µÄ²¢ÁªÓ¦Óñ»¹ã·ºÊ¹ÓÃÔڸߵµCD³ª»úºÍ¸ßµµDAC½âÂëÆ÷ÖУ¬ÖøÃûµÄÒôÏ칫˾ACCUPHASE£¨½ðɤ×Ó£©Ôø½«¶àƬPCM1702²¢ÁªÓÃÓÚÒ»¸öÉùµÀ½âÂ룬½á¹ûµÃµ½Ò»´ú¾«Æ·CD»úDP-55
x, Z! g8 X8 IPCM1702-J2 \6 A* R! t1 _2 {& b
BICMOS ADVANCED SIGN MAGNITUDE 20-BIT DIGITAL-TO-ANALOG CONVERTER: w a1 Z) q. P9 z9 g
PCM1702-K1 \5 N3 [; u: }) Y6 [( d z# _
7 }2 T3 m4 b, u8 o0 OPCM1702P
. I3 ?- O% X1 `- {6 ^BICMOS ADVANCED SIGN MAGNITUDE 20-BIT DIGITAL-TO-ANALOG CONVERTER
! p7 o. G- ~% M$ Q1 M* LPCM1702U
- `0 [6 @4 Q: _9 [& BBICMOS ADVANCED SIGN MAGNITUDE 20-BIT DIGITAL-TO-ANALOG CONVERTER. @, h9 E0 X9 Z8 [$ d$ e
PCM1704
3 G6 N8 \" H* L7 I% `24-BIT, 96KHZ BICMOS SIGN-MAGNITUDE DIGITAL-TO-ANALOG CONVERTER
2 ?8 P1 h# L/ K& n3 V. l1702µÄÉý¼¶°æ£¬ËÙ¶È£¬ÆµÏ죬Éù³¡¶¼·Ç³£³öÉ«" Y r8 z' Q: ?7 _4 b
PCM1704U# p1 H6 L* l' X+ C% L4 z; k! A
24-BIT, 96KHZ BICMOS SIGN-MAGNITUDE DIGITAL-TO-ANALOG CONVERTER; s+ ?# B. i3 a, N' g+ u
PCM17105 z+ V5 X6 s% M2 Q$ x5 [: y
STEREO AUDIO DIGITAL-TO-ANALOG CONVERTER
* c+ ]: i& V( [) {VCDÀïÓõÄ×î¶à£¬ÎҾͲ»ËµÁË J) D; j1 U- X4 X
PCM1710U
( @: `! R z0 @ cSTEREO AUDIO DIGITAL-TO-ANALOG CONVERTER$ d. P& z9 o1 ]( S( `% \
PCM1715
L0 y( w7 p3 z* d' oDUAL VOLTAGE OUTPUT CMOS DELTA-SIGMA DIGITAL-TO-ANALOG CONVERTER WITH ON-CHIP DIGITAL FILTER PCM1715U
0 K; r1 F# K0 \2 R! F N$ `5 X" f$ ~DUAL VOLTAGE OUTPUT CMOS DELTA-SIGMA DIGITAL-TO-ANALOG CONVERTER WITH
' X* J0 i* G1 i9 m- R( }6 x2 I! d4 |PCM1716: O7 V {2 z- _& I& r# w: F" E
24-BIT, 96KHZ SAMPLING CMOS DELTA-SIGMA STEREO AUDIO DIGITAL-TO-ANALOG CONVERTER
& G! T/ r$ J1 kÎÂůÐÍ£¬Ò»Ð©dvdÓÃËû
5 y4 F" g3 `3 t( JPCM17204 I4 g/ J! J& W6 H" u
STEREO AUDIO DIGITAL-TO-ANALOG CONVERTER MPEG2/AC-3 COMPATIBLE( Y4 Y, m( R0 o
DVDÀïÓõÄоƬ
$ c4 a4 ~7 E7 M$ ?6 T- C U0 O# v) j' i: W3 f
PCM1730
$ V% q2 J5 ]4 K ^24-BIT, 192-KHZ SAMPLING ADVANCED SEGMENT, AUDIO STEREO DIGITAL-TO-ANALOG CONVERTER( S# p9 F' ~( i) M5 |4 c
PCM1730E
0 J+ V; W, g9 U24-BIT, 192-KHZ SAMPLING ADVANCED SEGMENT, AUDIO STEREO DIGITAL-TO-ANALOG CONVERTER PCM1730E/2K3 g6 U* M1 W' c8 j( X
+ L Q5 C( e Q- C1 k1 q4 Y( gPCM17328 f' R/ d; d o$ D
24-BIT, 96KHZ, STEREO AUDIO DIGITAL-TO-ANALOG CONVERTER WITH HDCD DECODER( j# x$ b3 V5 M L- q
´øHDCD£¬ºÜ¶àCD£¬DVD¶¼ÓÃËû# N4 S2 W' \- W9 q+ x
PCM1733
5 ]# [( n/ J; u6 hSTEREO AUDIO DIGITAL-TO-ANALOG CONVERTER 18 BITS, 96KHZ SAMPLING. s/ [ p4 h% L
1732µÄ¼ò»¯°æ±¾
# c: J% \, I* z0 }! h9 GPCM1738( u0 K$ G! g+ A7 k
24-BIT, 192KHZ SAMPLING, ADVANCED SEGMENT, AUDIO-STEREO DIGITAL-TO-ANALOG CONVERTER- f0 l. W, n$ B- E
¸ßÖÊÁ¿µÄdac£¬¾ßÓÐDSDºÍPCMË«¹¦ÄܵÄоƬ£¬³£Ó¦ÓÃÓڸ߼¶½âÂëÆ÷ÖÐ' W# s. I2 O1 S; ] b0 d
PCM1738E24-BIT, 192KHZ SAMPLING, ADVANCED SEGMENT, AUDIO-STEREO DIGITAL-TO-ANALOG CONVERTER PCM1738E2K% g, a8 Q7 ]$ Z* ^0 r; j, J3 T" q
8 | m& l" l) t! X" H9 D& JPCM1739
/ U' o# d" _1 I; F6 D$ k/ v24-BIT, 192KHZ SAMPLING, ENHANCED MULTI-LEVEL, DELTA-SIGMA, AUDIO DIGITAL-TO-ANALOG CONVERTER9 D; ^/ F. p" G
PCM1739E2 i, t$ x* Q [. Z8 m
24-BIT, 192KHZ SAMPLING, ENHANCED MULTI-LEVEL, DELTA-SIGMA, AUDIO DIGITAL-TO-ANALOG CONVERTER; K3 n# ]4 ?' E4 y
PCM17927 p9 X! U: l* a
24 BIT 192KHZ SAMPLING ADVANCED SEGMENT, AUDIO STEREO DIGITAL TO ANALOG CONVERTER7 U' k. M. U2 ]2 j
µ±½ñ×îÇ¿µÄdacоƬ£¬¿ÉʹÓÃÈíÓ²¼þ¿ØÖÆ£¬ÒôÖʳ¬Èº£¬ÎÞÓëÂױȵÄÖ¸±êÌØÐÔ£¬Ó¦ÓÃÓڸ߼¶SACDµÄ½âÂëPCM1792DB, W% j# N7 Z1 G
24 BIT 192KHZ SAMPLING ADVANCED SEGMENT, AUDIO STEREO DIGITAL TO ANALOG CONVERTER( U' p& w! A# x$ N$ ?! x
PCM1792DBR8 \2 @/ K4 |% ?2 r8 U
24 BIT 192KHZ SAMPLING ADVANCED SEGMENT, AUDIO STEREO DIGITAL TO ANALOG CONVERTER# e* c7 n# `4 i7 F
PCM1793' V2 ^8 }/ ~1 A# d3 c' K; k- L
24 BIT 192KHZ SAMPLING ADVANCED SEGMENT AUDIO STEREO DIGITAL TO ANALOG CONVERTER0 Q( n) y" a! P, j2 c
Ò²ÊǷdz£NBµÄоƬ0 [! [; N4 l9 o' _5 M* c
PCM1793DB: m; \. `6 [7 E7 m# ~) b
0 ~# y9 h" N1 v3 p/ e& ^- _& kPCM1793DBR5 O* l2 o4 ^$ U% A2 F
. [: J) f# u& d: v# yPCM1794
& W. }! |% E3 P( S/ D24BIT 192KHZ SAMPLING , ADVANCED SEGMENT, AUDIO STEREO DIGITAL TO ANALOG CONVERTER
5 G+ l+ a, d% b1792µÄ¼ò»¯°æ±¾£¬ÒôÖʾÝ˵±È1792²îÄÇôһµãµã
# Z4 l9 d, `5 ~+ R+ h7 d2 V) bPCM1794DB
4 ^" v1 N/ X+ t2 [. ?' a, B24BIT 192KHZ SAMPLING , ADVANCED SEGMENT, AUDIO STEREO DIGITAL TO ANALOG CONVERTER PCM1794DBR
0 C3 i& b5 y& ?+ t$ S) b# C24BIT 192KHZ SAMPLING , ADVANCED SEGMENT, AUDIO STEREO DIGITAL TO ANALOG CONVERTER
7 M3 r5 {4 d3 ^, D, ]5 P[/td][/tr]# E+ p! J& Y' c$ `# i' _; l
[tr][td=99%]
A5 U' k6 X" D. pPCM17965 X2 w, ~6 A' Y
24BIT 192 KHZ SAMPLING ADVANCED SEGMENT AUDIO STEREO DIGITAL TO ANALOG CONVERTER" H) W1 k9 N% j
PCM1796DB
2 p. D n$ a x' t$ E9 v4 y+ w24BIT 192 KHZ SAMPLING ADVANCED SEGMENT AUDIO STEREO DIGITAL TO ANALOG CONVERTER
6 l$ h8 X% j, d4 [2 b- sPCM1796DBR
5 T3 ^9 o6 V4 ]9 r24BIT 192 KHZ SAMPLING ADVANCED SEGMENT AUDIO STEREO DIGITAL TO ANALOG CONVERTERPCM1798
( i0 c& |- |. f1 w- G24-BIT, 192-KHZ SAMPLING ADVANCED SEGMENT, AUDIO STEREO DIGITAL TO ANALOG CONVERTER 1792ºÍ1794µÄ¼ò»¯°æ±¾£¬Ö»Ö§³ÖÓ²¼þ¿ØÖÆ£¬ÒôÖÊÔÚÈýÐÖµÜÀï×î²î£¬ËäÈ»×î²îµ«Ò²±ÈÒ»°ãµÄºÃÉϲ»ÉÙ£¬Ë½ÐËüÊÇÆì½¢ÄØ
; ?, N! V$ h+ LPCM1798DB
0 U2 a8 }8 m( k# v6 ]4 e* q: t3 a24-BIT, 192-KHZ SAMPLING ADVANCED SEGMENT, AUDIO STEREO DIGITAL TO ANALOG CONVERTER PCM1798DBR
3 J& Q* W" k- g& f6 p9 m# n24-BIT, 192-KHZ SAMPLING ADVANCED SEGMENT, AUDIO STEREO DIGITAL TO ANALOG CONVERTER: f9 e, i- X1 R1 A, t
PCM2702
7 ^* B$ z3 r6 t# B0 p6 P5 S. z16-BIT STEREO DIGITAL-TO-ANALOG CONVERTER WITH INTERFACE
* I9 Y: J9 H1 B6 F) kUSBÀàµÄdacоƬ£¬¿É±»µçÄÔÖ±½Óʶ±ð£¬USB½âÂëÆ÷µÄÊ×Ñ¡£¬µ«Êܵ½µçÄԵĵ粨¸ÉÈÅ£¬JitterÎÊÌâµÈµÄÓ°Ï죬ÒôÖÊÎÞ·¨ºÍÉÏÃæÄÇЩרҵµÄ±È£¬µ«·Ç³£ÊʺÏÎÒÃÇdiyÃÇ£¬Ã»ÓбðµÄ£¬¾ÍÒòΪËû¼òµ¥3 B4 H: {) U; m# D8 U5 ]
PCM2702E
' L0 w" i' ~! Z" L16-BIT STEREO DIGITAL-TO-ANALOG CONVERTER WITH INTERFACE7 M+ _$ n& V9 F8 n$ L
8 L$ S- W7 G+ D4 U4 a2 ~. d1 MPCM2704
, n. K5 J$ w9 P% ySTEREO AUDIO DAC WITH U££££ INTERFACE, SINGLE-ENDED HEADPHONE OUTPUT AND S/PDF OUTPUT PCM2704DB0 v6 p' A8 t' B8 Q
STEREO AUDIO DAC WITH U££££ INTERFACE, SINGLE-ENDED HEADPHONE OUTPUT AND S/PDF OUTPUT PCM2704DBR2 M w! X1 M& C. S
; C) q, P3 S9 ~+ F- J0 l: d6 wPCM27057 f9 j( T* C, C
STEREO AUDIO DAC WITH U££££ INTERFACE, SINGLE-ENDED HEADPHONE OUTPUT AND S/PDF OUTPUT PCM2705DB
: X1 |/ m/ ~' w2 \) ^% p8 |STEREO AUDIO DAC WITH U££££ INTERFACE, SINGLE-ENDED HEADPHONE OUTPUT AND S/PDF OUTPUT PCM2705DBR
' M( b- L: ^/ \' ?) pSTEREO AUDIO DAC WITH U££££ INTERFACE, SINGLE-ENDED HEADPHONE OUTPUT AND S/PDF OUTPUT0 u6 `1 [) {' _* p1 Y5 w
PCM27064 A- a$ t5 F9 x
STEREO AUDIO DAC WITH U££££ INTERFACE, SINGLE-ENDED HEADPHONE OUTPUT AND S/PDF OUTPUT PCM2706PJT% j; g2 l5 K( P) c7 k2 L0 @
STEREO AUDIO DAC WITH U££££ INTERFACE, SINGLE-ENDED HEADPHONE OUTPUT AND S/PDF OUTPUT PCM2706PJTR
$ u' [$ V- I5 X, B cSTEREO AUDIO DAC WITH U££££ INTERFACE, SINGLE-ENDED HEADPHONE OUTPUT AND S/PDF OUTPUT3 G- ^: w. E- y* c
PCM2707
! r4 q! P- @$ R, c8 U0 t \7 XSTEREO AUDIO DAC WITH U££££ INTERFACE, SINGLE-ENDED HEADPHONE OUTPUT AND S/PDF OUTPUT PCM2707PJT
4 p2 ^2 f$ V4 \. h% [( [STEREO AUDIO DAC WITH U££££ INTERFACE, SINGLE-ENDED HEADPHONE OUTPUT AND S/PDF OUTPUT PCM2707PJTR& x' w7 f9 W3 R
STEREO AUDIO DAC WITH U££££ INTERFACE, SINGLE-ENDED HEADPHONE OUTPUT AND S/PDF OUTPUT1 C: d0 s) \8 k2 D4 C' V
PCM2900+ p1 A5 I, h( r% w) Z* M- a4 ~2 }9 g- i
STEREO AUDIO CODEC WITH U££££ INTERFACE, SINGLE ENDED ANALOG INPUT/OUTPUT AND S/PDIF9 R% Q# t' m7 G
PCM2900E
$ {5 L: X* j) H* dSTEREO AUDIO CODEC WITH U££££ INTERFACE, SINGLE ENDED ANALOG INPUT/OUTPUT AND S/PDIF PCM2900E/2K8 g( D# g: k" O1 w9 U! o0 m: ?. u) s) `
" o$ x! ~5 p8 N2 M8 e& \PCM29018 h2 V2 g0 Y) L* c& c( a) F
STEREO AUDIO CODEC WITH U££££ INTERFACE SINGLE ENDED ANALOG INPUT/OUTPUT AND S/P DIF% y, l/ u. H* M/ ]1 S- i
PCM2901E
) ^: k8 L% m; Y9 bSTEREO AUDIO CODEC WITH U££££ INTERFACE SINGLE ENDED ANALOG INPUT/OUTPUT AND S/P DIF PCM2901E/2K
* A% A4 c- ]# u6 d) _( vSTEREO AUDIO CODEC WITH U££££ INTERFACE SINGLE ENDED ANALOG INPUT/OUTPUT AND S/P DIF
2 |) U, X/ Z4 f$ r$ ^! v6 \" A$ l' TPCM29024 H$ R1 C7 m, u
0 F; W& ?0 L1 u2 c1 c) u2 cPCM2902E
% D0 X# Z* c$ o/ X4 B. X1 e0 PSTEREO AUDIO CODEC WITH U££££ INTERFACE, SINGLE ENDED ANALOG INPUT/OUTPUT AND S/PDIF PCM2902E/2K
3 u6 x. p& I* ?+ x- L# l5 n: WSTEREO AUDIO CODEC WITH U££££ INTERFACE, SINGLE ENDED ANALOG INPUT/OUTPUT AND S/PDIF9 j/ k: a N# Y9 n$ N: ^9 ^5 V
" V1 q, `4 w- s4 }# @' W# bPCM54- c0 X. b# o1 B9 p- e1 H
16-BIT MONOLITHIC DIGITAL-TO-ANALOG CONVERTERS, e: Q; t! }0 b3 `" ]9 _) s
ÒôÖÊÒ»°ã£¬Ìå»ýÅÓ´ó£¬Ñù×ÓͦYYµ«ËØÖʲ»¸ß£¬ÔçÆÚµÄÈÕ±¾¶¥¼¶cdϲ»¶ÓÃËû£¬ÒôÉ«ÎÂů£¬½âÎöÁ¦²»ºÃ£¬ÉùÒô½Ï´Ö£¨±ðÅÄÎÒ¡£¡£¡££©4 i5 T8 Z) {; @# n
PCM54HP
% q0 V. j( F3 j; n* w& d16-BIT MONOLITHIC DIGITAL-TO-ANALOG CONVERTERS
$ z3 P7 ^/ P1 H" ?+ r3 B6 XPCM54JP
2 }0 R/ B8 a* a) D3 X! p( N16-BIT MONOLITHIC DIGITAL-TO-ANALOG CONVERTERS: J5 \$ R9 ]) f+ E$ }
PCM54KP
' |. w* Q9 S Z16-BIT MONOLITHIC DIGITAL-TO-ANALOG CONVERTERS, R1 ~. ^: f* L) _! ?! E
4 r c1 m. ?! x% U/ k2 wPCM55" w2 v; K+ e) i' ~
# x; ?4 |- H# N0 P" L% n9 b; _; PPCM55HP
! q$ G: w# ~% f8 F) x3 G16-BIT MONOLITHIC DIGITAL-TO-ANALOG CONVERTERS& r3 K* f0 F1 _/ l' Y) J7 E: @% P5 a
PCM55JP) K% A, @& \/ W$ A' B u( ^
16-BIT MONOLITHIC DIGITAL-TO-ANALOG CONVERTERS# |9 N: O1 K, [! T- p
4 K: J# U& o* Q, A
PCM56
# O7 g/ l8 k% { YSERIAL INPUT 16-BIT MONOLITHIC DIGITAL-TO-ANALOG CONVERTER
- e2 q! F: q0 z# ]7 VСÇɾ«¸É£¬ÉùÒô²»´í£¬Éù³¡½âÎöÁ¦½ÏºÃ£¬µ«ÊýÂëζ½ÏÖØ£¬ÉùÒô½ÏÓ²£¬ÊÇBBÔçÆÚ×î³É¹¦µÄ×÷Æ·Ö®Ò»
) Y5 D2 x2 @8 A, @! tPCM56P
3 | }0 w' Y' R3 X" j! Q' F% ASERIAL INPUT 16-BIT MONOLITHIC DIGITAL-TO-ANALOG CONVERTER
: h8 j. N! t1 l4 NPCM56P-J
* n8 S8 M* P' I$ q& a+ VSERIAL INPUT 16-BIT MONOLITHIC DIGITAL-TO-ANALOG CONVERTER
- t: W2 |' S8 k8 D3 a% ^PCM56P-K. T) d: R$ e$ h/ J; C
SERIAL INPUT 16-BIT MONOLITHIC DIGITAL-TO-ANALOG CONVERTER/ F$ w! C+ |# [* ~
PCM56P-L
1 Y) w7 x$ |6 W# i& vSERIAL INPUT 16-BIT MONOLITHIC DIGITAL-TO-ANALOG CONVERTER5 X3 S9 [, p$ V# T3 h
PCM56U I4 s3 Q( c; P( L8 b7 ^
SERIAL INPUT 16-BIT MONOLITHIC DIGITAL-TO-ANALOG CONVERTER$ K. ?0 r+ S3 @ y
1 D, s- {% j; j* q* {# C" }" WPCM58J3 Y, [! Z3 ]# S8 A
PRECISION, 18-BIT MONOLITHIC AUDIO DIGITAL-TO-ANALOG CONVERTER1 l, D- ?8 B( q8 F8 V
ÒôÉ«ºñʵÌðÃÀ£¬½âÎöÉù³¡ÔÚͬ¼¶²úÆ·ÖÐÊ®·Ö³öÖÚ£¬ÏÖÔÚÒ²Óкܶàdac²úÆ·»¹ÔÚÓÃËû£¬µ«Í£²ú¶àʱ£¬¼Û¸ñ½Ï¸ß
( P0 j1 n; E6 X* x7 u9 TPCM58K
$ c: Y- z. I9 B# N9 Z- `PRECISION, 18-BIT MONOLITHIC AUDIO DIGITAL-TO-ANALOG CONVERTER4 |4 f9 k" I% S4 f+ K! ?& y" @- _/ e
PCM58P$ w. q ^0 K# n& _6 l
- Y* d" P3 N6 L* Z2 G: t* `: f) x6 T5 w8 [) I
PCM61
8 k' @! F' k7 G, p4 q( H2 d9 I- q" fSERIAL INPUT 18-BIT MONOLITHIC AUDIO DIGITAL-TO-ANALOG CONVERTER E' x6 D# l9 @5 A' B" O
ºÜ¶àÐԼ۱ȽϸߵÄÀÏcd¶¼ÓÃËû£¬Òôɫƽºâ£¬Ò²ÊǾµäоƬ
# M) k6 \+ q+ Z0 [) ]; ~1 OPCM61J-P3 X# d: {: j; Y; m
/ }5 s8 M0 V9 k/ J2 UPCM61K
" Y/ s7 n0 _6 l. e' tSERIAL INPUT 18-BIT MONOLITHIC AUDIO DIGITAL-TO-ANALOG CONVERTER% `8 c, @( D$ [ D. F* `
PCM61P1 P3 \9 U0 u- j" g9 c; |( V9 u6 y9 x
1 o ?$ H' b1 a& \/ p* Z x2 l8 mPCM61P-P
" _( p. \6 d: S) w& M! qSERIAL INPUT 18-BIT MONOLITHIC AUDIO DIGITAL-TO-ANALOG CONVERTER
5 G- ^# v* i! r$ U% J
3 `' {" u n) q0 {! Z U' _PCM63. P% o: {7 Y& H- B
COLINEAR¢Â 20-BIT MONOLITHIC AUDIO DIGITAL-TO-ANALOG CONVERTER
& {3 i* ~, g% X³¬NBµÄоƬ£¬ÉùÒô³öÉ«£¬ÌðÃÀºñʵ£¬½âÎöÁ¦Ç¿£¬Éù³¡ºê࣬µ«µÍƵ¶ÍÏà¶Ô½ÏÊÝ£¬¸ßµµ½âÂëÆ÷µÄ³è¶ù£¬Å¨ÓôµÄÍõÕ߯øÆÇ£¬µ«¼Û¸ñÌ«¸ß£¬Ö»ÄÜYY1 {, G4 Q0 X3 Q p$ {
PCM63P
0 T, }% B! u6 cCOLINEAR¢Â 20-BIT MONOLITHIC AUDIO DIGITAL-TO-ANALOG CONVERTER( i, P, q3 C7 [* I
PCM63P-J" I2 _8 Q9 S7 Z& x% j
" O w2 p. Q" l0 \/ o1 `PCM63P-K, J* E) X# L) m8 V% H1 @5 ^
: h$ B! c8 b7 `! W7 ]% a9 r[/td][/tr]
& y4 u2 s$ i/ J c1 V1 s[/table]) i) J Y+ [9 u5 C
9 ]9 E0 d0 t2 B z[/td][/tr]
; j; W/ F8 n1 i: J) z( L/ k5 r[/table] |
