»ìÏìÆ÷²ÎÊýµÄµ÷½Ú
ÒôÏì
Reverb Hall 1 Ä£Äâ´óÒôÀÖÌüµÄ»ìÏì
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time2.8s0.3-30.0s»ìÏìʱ¼ä
    High Ratio0.80.1-1.0¸ßƵ˥¼õÂÊ
    Diffusion60-10»ìÏìÀ©É¢
Ini.Dly40.0ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF7.0kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPFTHRUTHRU,32Hz-8KHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Reverb Hall 2 Ä£Äâ´óÒôÀÖÌüµÄ»ìÏìµÄ±äÖÖ
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time3.2s0.3-30.0s»ìÏìʱ¼ä
    High Ratio0.70.1-1.0¸ßƵ˥¼õÂÊ
    Diffusion80-10»ìÏìÀ©É¢
    Ini.Dly38ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF6.3kHz1.0kHz-16.0kHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPFTHRUTHRU,32Hz-8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Reverb Room 1 Ä£ÄâË®Äàǽ±Ú·¿¼ä²úÉú´óÁ¿»ØÉùµÄ»ìÏì *Ϊ¹ÄÒôÉ«Ôö¼ÓÏÖ³¡¸Ð
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time1.4s0.3-30s»ìÏìʱ¼ä
    Diffusion70-10»ìÏìÀ©É¢
    Ini.Dly5.0ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPFTHRU1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPFTHRUTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Reverb Room 2 Room1µÄ±äÖÖ
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time1.8s0.3-30s»ìÏìʱ¼ä
    High Ratio0.60.1-1.0¸ßƵ˥¼õÂÊ
    Ini.Dly17ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF9kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPF80HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Reverb STAGE ÀàËÆ³ÌÐò1£¬µ«¸üÃ÷ÁÁ£¬¸üÓÐÏÖ³¡¸Ð
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time3.4s0.3-30s»ìÏìʱ¼ä
    High Ratio0.90.1-1.0¸ßƵ˥¼õÂÊ
    Ini.Dly45ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    HPF70HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Reverb Plate Ä£Äâ¸ÖÅÌÀà»ìÏìϵͳ£¬ÊÊÓ¦ÐÔºÜ¹ã£¬ÌØ±ðÊÇÈËÉù£¬¹ÄºÍ´ò»÷ÀÖ
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time2.4s0.3-30s»ìÏìʱ¼ä
    Ini.Dly16ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF8kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Rev Ambience 1 Ä£ÄâÀÖÆ÷ÖÜΧµÄ»ìÏ죬ÓÃÓÚÈËÉù£¬ºÏ³ªºÍ´ò»÷ÀÖ
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.2s0.3-30s»ìÏìʱ¼ä
    High Ratio10.1-1.0¸ßƵ˥¼õÂÊ
    Ini.Dly19ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    HPF45HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Rev Ambience 2 ³ÌÐò7µÄ±äÖÖ
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time0.8s0.3-30s»ìÏìʱ¼ä
    Ini.Dly0.1ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    HPF56HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Rev Live Room 1 Ä£ÄâÏÖ³¡·¿¼äµÄ»ìÏì,»ìÏì·´Éä±ÈRecerm RoomÇ¿
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    LPF7kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
ÆÀÂÛÁÐ±í£¨7£©
maya88 Â¥Ö÷
Rev Live Room 2 ³ÌÐò9µÄ±äÖÖ
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time2.2s0.3-30.0s»ìÏìʱ¼ä
    High Ratio0.50.1-1.0¸ßƵ˥¼õÂÊ
    Ini.Dly12.0ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF4.0kHz1.0kHz-16.0kHz.THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Reverb Vocal ÓÃÓÚÈËÉù,ºÏ³ªµÄ»ìÏì
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time1.9s0.3-30.0s»ìÏìʱ¼ä
    Ini.Dly16ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF12kHz1.0kHz-16.0kHz.THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPF100HzTHRU,32Hz-8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Chorus Reverb Á¢ÌåÉùºÏ³ªºó½Ó»ìÏì
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Mod.Freq0.8Hz0.1-20Hzµ÷ÖÆËÙ¶È
    Mod.Depth40%0-100%µ÷ÖÆÉî¶È
    Mod.Dly1.3ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
    High Ratio0.70.1-1¸ßƵ˥¼õÂÊ
    Ini.Dly30ms0.1-139msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF6.3kHz1kHz--16kHz, THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPFTHRUTHRU,32Hz--8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Rev.Depth24%0-100%»ìÏìÉî¶È
    Flange Reverb Á¢ÌåÉùÆ®ºöºó½Ó»ìÏì
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Mod.Freq1.4Hz0.1-20Hzµ÷ÖÆËÙ¶È
    Mod.Depth22%0-100%µ÷ÖÆÉî¶È
    FB Gain+45%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÆ®ºöµÄÔöÒæ
    Mod.Dly13ms0-15.5msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
    Ini.Dly26ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF4.5kHz1kHz--16kHz, THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPF45HzTHRU,32Hz--8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Rev.Depth30%0-100%»ìÏìÉî¶È
    Delay L-C-R ×ó£¬ÖУ¬ÓÒÉùµÀ¶ÀÁ¢µÄÑÓ³Ù
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Dly L250ms0.1-661ms×óÉùµÀÑÓ³Ùʱ¼ä
    Dly R500ms0.1-661msÓÒÉùµÀÑÓ³Ùʱ¼ä
    Dly C125ms0.1-661msÖÐÑëÉùµÀÑÓ³Ùʱ¼ä
    Level C700-100ÖÐÑëÉùµÀÑÓ³ÙÒôÁ¿
    FB.Dly500ms0.1-661msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
    FB.Gain+40%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
    High Ratio0.80.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
    Monodly-Chorus µ¥ÉùµÀÑÓ³Ùºó½ÓÁ¢ÌåÉùºÏ³ª
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Delay400ms0.1-618msÑÓ³Ùʱ¼ä
    FB.Gain+32%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
    Mod.Freq0.4Hz0.1-20HzºÏ³ªµ÷ÖÆËÙ¶È
    Mod.Depth10%0-100%ºÏ³ªµ÷ÖÆÉî¶È
    Mod.Dly0.1Ms0-24msºÏ³ª¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
    Chrous-Dly L C R Á¢ÌåÉùºÏ³ªºó½Ó×ó£¬ÖУ¬ÓÒÉùµÀ¶ÀÁ¢µÄÑÓ³Ù
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Mod.Depth24%0-100%µ÷ÖÆÉî¶È
    Mod.Dly5.9ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
Dly L26.4ms0.1-618ms×óÉùµÀÑÓ³Ùʱ¼ä
    Dly R33.2ms0.1-618msÓÒÉùµÀÑÓ³Ùʱ¼ä
    Dly C13.1ms0.1-618msÖÐÑëÉùµÀÑÓ³Ùʱ¼ä
    Level C600-100ÖÐÑëÉùµÀÑÓ³ÙÒôÁ¿
    FB.Dly40.5ms0.1-618msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
    FB.Gain-48%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
    High Ratio0.10.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
2009-9-12 12:41:45 »Ø¸´
maya88 Â¥Ö÷
    Delay-Chrous Á½¼¶ÑÓ³Ùºó½ÓÁ¢ÌåÉùºÏ³ª
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Dly 1250ms0.1-618ms1 ÑÓ³Ùʱ¼ä
    Dly 2500ms0.1-618ms2 ÑÓ³Ùʱ¼ä
    FB.Dly500ms0.1-618msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
    FB.Gain+33%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
    High Ratio0.70.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
    Mod.Freq1.2Hz0.1-20Hzµ÷ÖÆËÙ¶È
    Mod.Depth25%0-100%µ÷ÖÆÉî¶È
    Mod.Dly10ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
    Karaoke Echo 1 ¿¨À­OKЧ¹û
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Dly L220ms0.1-332ms×óÉùµÀÑÓ³Ùʱ¼ä
    FB.Gain L+40%-99--+99%×óÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ
    Dly R223ms0.1-332msÓÒÉùµÀÑÓ³Ùʱ¼ä
    FB.Gain R+40%-99--+99%ÓÒÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ
    High Ratio0.40.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
    Karaoke Echo 2 ¿¨À­OKЧ¹û
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    FB.Gain L+44%-99--+99%×óÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ
    Dly R180ms0.1-332msÓÒÉùµÀÑÓ³Ùʱ¼ä
    FB.Gain R-55%-99--+99%ÓÒÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ
    High Ratio0.20.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
    ST.Pitch Change Á½²¿·ÖµÄÁ¢ÌåÉùÒô¸ß±ä»¯Æ÷£¬ÓжÀÁ¢µÄÉùÏñ²ÎÊý
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Pitch0-12--+12Òô¸ß´Öµ÷
    Fine 1+10-50--+50±ä»¯Æ÷1µÄÒô¸ß΢µ÷
    Fine 2-10-50--+50±ä»¯Æ÷2µÄÒô¸ß΢µ÷
    Out.Lvl 1+100-100--+100±ä»¯Æ÷1µÄÊä³öÒôÁ¿
    Out.Lvl 2+100-100--+100±ä»¯Æ÷2µÄÊä³öÒôÁ¿
    Pan 1L100L100--R100±ä»¯Æ÷1µÄÉùÏñ
Pan 2R100L100--R100±ä»¯Æ÷2µÄÉùÏñ
    FB.Gain 1+28%-99--+99%´¦ÀíºóµÄÐźŷµ»Ø±ä»¯Æ÷1µÄÔöÒæ
    FB.Gain 2-28%-99--+99%´¦ÀíºóµÄÐźŷµ»Ø±ä»¯Æ÷2µÄÔöÒæ
    FB.Dly25ms0.1-223msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
    "MALE
    VOCAL"ÄÐÐÔÉùÒô,Ç¿µ÷ÖеÍÒôG+3db+1db+2db
    F280Hz1.8KHz5KHz
    Q3oct3/4octÆÂ×´
    "FEMALE
    VOCAL"Å®ÐÔÉùÒô,Ç¿µ÷¸ßÖÐÒôG-1db+1db+2db
    F220Hz2KHz7KHz
    QÆÂ×´3oct3oct
    CHROUSÈËÉùºÏ³ªG+1db+2db+5db
    F280Hz1.4KHz5.6KHz
    Q3oct3/2octÆÂ×´
    "MALE
    ANNOUCER"ÄÐÐÔ½²»°,Ôö¼ÓÇåÎú¶ÈG-3db+2db-4db
    F100Hz4.5KHz7KHz
    Q1oct3octÆÂ×´
    "FEMALE
    ANNOUCER"Å®ÐÔ½²»°,Ç¿µ÷ÖÐÒôG-3db+3db-1db
    F200Hz2KHz8KHz
    QÆÂ×´1octÆÂ×´
    "TELEPHONE
    VOICE"Ä£Äâµç»°Éù,¼õÉٸߵÍÒôG-15db+12db-10db
    F500Hz1.1KHz9KHz
    QÆÂ×´2oct3/4oct
    "NOTCH
    4KHz"ÔÚ4Hz´¦Â˲¨ÒÔ¼õÉÙ·´À¡Ð¥½ÐG0db0db-10db
    F80Hz2KHz4KHz
    QÆÂ×´3/2oct1/6oct
    "HUM
    REDUCE
    50Hz"ÔÚ50Hz´¦Â˲¨ÒÔ¼õÉÙÎËÎËÉùG-9db-10db0db
    F50Hz160Hz10KHz
    Q1/6oct1/6octÆÂ×´
    "HUM
    REDUCE
    60Hz"ÔÚ60Hz´¦Â˲¨ÒÔ¼õÉÙÎËÎËÉùG-9db-10db0db
    F60Hz180Hz10KHz
    Q1/6oct1/6octÆÂ×´
    "W.NOISE
    REDUCE"Ϊ´Å´ø·ÅÒô¼õÉÙ¸ßÆµÔëÒôG0db0db-13db
    F80Hz2KHz16KHz
    QÆÂ×´3/2octÆÂ×´
2009-9-13 11:49:21 »Ø¸´
maya88 Â¥Ö÷
»ìÒôµÄÐ¡ÃØ·½
    êPì¶compressorµÄʹÓÃ:
    »ìÒô•r³£•þÓõ½compressor£¬ËüµÄºÃÌŽ³ýÁË׌ÕûówÒôÁ¿µÃÒÔ¿ØÖÆÔÚÒ»¶¨¹ ‡ú£¬Ò²¿ÉÒÔʹÒôÐÔ Æð�íÝ^žéÓÐÁ¦Á¿¡£µ«ÊÇʹÓò»ºÃÒ²ÈÝÒ×Ôì³ÉÒÔϵĎ×üc†–î}¡£
    1)ÈôŒ¢mixºÃµÄ–|Î÷ÔÙ×÷È«ÃæÐÔµÄcompress£¬•þʹ×î´ó•Åc×îС•֮ég²»Í¬Ö®²î¾àœpÉÙÔS¶à£¬Õû‚€Â•ÒôµÄ±í¬F¿ÉÄÜ•þÒòžé̫ƽ¾ù·´¶øÊ§È¥ÁËÔ­�íµÄ„Ó‘B¡£
    2)Èç¹ûŒ¢compressorµÄ×î¸ßpeak levelÔOÔÚ´ó¼sÅcδ‰º¿sǰµÄ×î¸ßpeak levelÏà֮ͬ̎£¬„tÆä½Y¹ûƽ¾ùlevel±Ø¶¨•þÌá¸ß¡£Ö÷Ó^¶øÑÔ£¬ÊÇ¿ÉʹÒô˜·¸üÓÐÄÜÁ¿¡£È»¶ø£¬Ò»‚€Â•Òô•þ¸Ðµ½Ý^´ó•ͨ³£ÊÇÓÐÝ^С•µÄ•ÒôÅcÆä×÷Œ¦±È£¬Òò´Ë®”compressÌ«´ó•r£¬•þÓÐʹÒô˜·µÄ•Òô¸üС•µÄΣëU¡£
    3)®”‰º¿smix•r£¬¿ÉÒÔŒ¢compressorµÄattack timeͨ³£•þ׌ËüéLÒ»üc£¬´ÙʹһЩ˲égµÄ•ÒôÈç´ò“ô˜·Æ÷Ôö¼ÓÆäpunch£¬¸üÓÐÁ¦¡£ß@ÕæµÄÒªÓöú¶äȥ £¬È¥ÅДࡣ®”È»Ôõ˜Ó²ÅÊÇ×î¼ÑµÄÔO¶¨•þÒòžéÿ‚€Òô˜·µÄ î›r¶øÓÐËù²»Í¬¡£ÁíÍâҪעÒâµÄÊÇ£¬�K·Çÿ·N�SÅÆÐÍÌ–µÄcompressor½Ô¿ÉÓÃÔÚÕûówµÄ»ìÒôÉÏ¡£
    êPì¶exciterµÄʹÓÃ:
    »ìÒô•rÒ²³£•þÓõ½exciter£¬ËüµÄÔ­ÀíÔÚì¶ÒÔԭʼ֮Ó�Ì–žé»ùµA£¬ºÏ³É³öharmonics�íÑa×½mix®”Öв»×ãµÄ²¿·Ý¡£Í¨³£ß@˜ÓµÄ½Y¹û•þ׃µÃÒôÐÔ±ÈÝ^ÁÁû�¡£ËüµÄºÃÌŽ³ýÁË�ŠÕ{ij¶ÎÏàŒ¦ì¶dynamic signalÖ®îl×V£¬Ê¹Ë²ég֮•ÒôÓиü¸ßÖ®½âÎö¶È£¬Ò²ÔÚì¶Ê¹Â•ÒôÔÚ�V²¥Ïµ½y(Èç�V²¥¡¢ëŠÒ•µÈ)Öиüstandout³ö�í¡£È»¶øÈçcompressorÒ»°ã£¬exciterÒ²³£±»ÈËžEÓᣱØíš×¢ÒâµÄÊÇ£¬Èç¹û›]ÓЛQŒ¦µÄ±ØÒª£¬ÔÚ»ìÒô•r²»ÒªëSÒâʹÓÃexciter¡£
    êPì¶±O ϵ½yµÄʹÓÃ:
    ÁíÍâÔÚfinal mixÍê³Éǰ£¬‘ªÔ“Óò»Í¬µÄ±O ϵ½y×÷œyÔ‡£¬ß@ÆäÖаüÀ¨Æû܇Òô푼°¼ÒÓÃÒô푵ȡ£ÓÐÔS¶àÈËϲšgÓôóÐ͵ıO À®°È�í×ö»ìÒô¡£ÄǘӵÄÒôÁ¿¼°šâ„ݵĴ_ºÜÃÔÈË£¬µ«…s²»ÊÇÒ»‚€ºÜºÃµÄ·½·¨£¬ÖÁÉÙ›Q²»ÄÜÊÇΨһµÄßx“ñ¡£Òòžé´óÐ͵ıO À®°ÈºÜÈÝÒ×Ôì³ÉÕ`Œ§£¬¶øÄǘӵĵÍîlÔÚÒ»°ãÈËµÄÆû܇Òô푼°¼ÒÓÃÒôí‘…sÍêÈ«ŸoЧ¡£ËùÒÔ×îºÃÓò»Í¬µÄ±O ϵ½y×÷œyÔ‡¡£ÁíÍâ±ÜÃâÔÚ¸ß·ÖØ�Ö® î›rÏÂ×÷»ìÒô£¬ÄÇ•þÓ°í‘Ä㌦ì¶Â•ÒôÖ®ÅД࣬ÒòžéÈ˶úŒ¦ì¶¸ß·ÖØ�µÄÒôÁ¿•rµÄ¸ßµÍîl·´‘ª�K²»Í¬ì¶µÍÒôÁ¿•rµÄ·´‘ª¡£ÊÂŒ�ÉÏÒ»°ãÈ˵Ä Òô˜·Á•‘TÒ²ÍùÍù¶¼ÊÇÖеÈÒôÁ¿ÒÔÏ¡£
    êPì¶DE-ESSERµÄʹÓÃ:
    CompressorŒ¦ì¶Ý”ÈëÓ�Ì–µÄ�жÈÊÇ’ñƽ¾ùʽ·´‘ª£¬ÇÒ²»Õ“Ëü‚ƒÊǵÍîlµÄ•Òô»òÊǸßîlµÄ˜·Æ÷¡£ß@ÊÇÒ»°ãµÄcompressor£¬µ«ÓЕrºòÎÒ‚ƒÐèÒªŒ¦ì¶Ìض¨îlÂÊ,×÷¸ü�Š´óµÄ‰º¿s¡£¡°De-esser¡±±ãÊÇÔÚ´Ë·NÐèÇóÏ®aÉú¡£ËüÖ÷ÒªÊÇÓÃ�íÈ¥³ý»òœpСÈË•Ó�Ì–ÖеĴ½ýXësÒô
    ´½ýXÒôͨ³£°lÉúì¶2KÖÁ5Kég£¬Èç¹ûÎÒ‚ƒÕÒµ½´ËîlÂÊ£¬Œ¢ËüÌá¸ß10DB£¬ÔÙÓÃcompressor•þŒ¢´ËîlÂʉº¿s£¬Ê¹´ËîlÂʵÄDB”µßhµÍì¶ÆäðNîlÂÊ10DB¡£ß@¾ÍÊÇ¡°De-esser¡±ÓÃ�íœpÉÙ´½ýXësÒôµÄ·½·¨¡£
    ¶øÈçºÎÕÒ´ËîlÂÊ? ÔÚß@ÎÒÌṩһ‚€Ð¡¼¼ÇÉ¡£Äã¿ÉÏÈŒ¢¸ßîlËùÐ裨һ°ãžé2-5k Hz£©²¨¶ÎµÄDB”µÔö¼Ó10DB£¬ÔÙŒ¢¸ßîl²¨¶ÎµÄÐýâoÖÐÑëîlÂÊ£¬ÓÃ�í›Q¶¨EQß^³ÌÖб»EQ²¨¶ÎµÄÖÐÑëîlÂÊÔÚºÎÌŽ£¬�Ä×îµÍµÄîlÂÊÂýÂýÞDµ½×î¸ßµÄîlÂÊ£¨·´Ö®Òà¿É£©£¬ÔÚ´Ë®”ÖÐÈôÓöµ½ÎÒ‚ƒÒªÕÒµÄîlÂÊüc•r£¬´½ýXÒô•þÌØ„e´ó•£¬„tÄ㌢֪µÀ´ËîlÂʾÍÊÇÄãÒªÕҵġ£
2009-9-13 13:12:33 »Ø¸´
maya88 Â¥Ö÷
    ×îááÈç¹ûÓXµÃ»ìÒôµÄ½Y¹û²»ÀíÏ룬¿ÉÒÀÏÂÁз½·¨™z²é:
    1.»Øµ½×îԭʼµÄƽºâ î‘B£¬È¥µôEQ¼°Ð§¹ûÆ÷£¬�Äî^é_ʼ£¬�KÓÆÎ•µÀ´_¶¨´Ë î‘BÊÇ·ñÓÐÏàλµÖÏûÖ® î›r£¬�K×¢Òâ•ÏòµÄλÖÃÊÇ·ñÕý´_¡£
    2.ÊÇ·ñÔÚͬһ•rég³ö�íÌ«¶à–|Î÷£¬ÊÇ·ñß@Щ–|Î÷½ÔÊDZØÐèµÄ£¿Èç¹û¶¼Òª£¬ÊÇ·ñÓÐЩ–|Î÷µÄ¿ÉÒÔÒôÁ¿Ð¡Ò»üc?
    3.ÔÚÖÐîl²¿·ÝÊÇ·ñŒ¢mixŪµÃÓÐЩës�y£¬»òÊǺ͵Íîl²¿·Ý»ìÔÚÒ»Æð£¿Èç¹ûÊÇ£¬ÓÃEQŒ¢ß@Щ•ÒôÐÞ±¡£¬ß@˜ÓµÄ½Y¹û׌Ëü‚ƒÔچΪšÂ •r»òÔS•þÓÐücÆæ¹Ö£¬µ«ÍùÍùÔÚmix®”ÖЕr•þï@µÃºÜßm®”¡£ÀýÈç: Äã¿É‡LÔ‡ÓÃEQ ‘]µôһЩµÍîl£¬¿ÉʹmixÖÐîl²¿·Ý¸üÇåÎö£¬Ç¬œQЩ¡£
    4.Èç¹ûÄãÈÔÓXµÃÓІ–î}£¬ÖØÐÂÕ{Õû¹ÄÅcØ�˹µÄƽºâüc£¬ÔÙŒ¢ÈË•¼ÓÉÏÈ¥£¬È»áá¼ÓÉÏÖ÷Òª˜·Æ÷¿´¿´ÊÇ·ñÓиÄÉÆ¡£
    5.Ч¹ûÆ÷ÒªÖ”É÷ʹÓ᣺ܶà•rºò£¬ÈË‚ƒÍùÍùʹÓÃÌ«¶àЧ¹ûÆ÷£¬»ò»ì푼ÓÌ«¶à£¬ÒÔÖÁì¶Ó�Ì–œp“p»ò•Òô¼Uºý¡£
    6.ÓЕrÔÚfinal mix¼ÓexciterŒ¦ì¶Â•ÒôÇåÎú¶È¼°¼šÄ�¶ÈÖ®¸ÄÉÆ£¬ÓÐÏà®”´óÖ®¹¦Ð§¡£
    7.Èç¹ûÒÔÉϵķ½·¨¶¼Ô‡ß^Ö®áá߀ÊÇŸo·¨½â›Q†–î}£¬ÄdzýÁËÔÙÔ‡Ž×´ÎÖ®Í⣬ֻºÃÖØä›ÁË£¡
    8.ËùÒÔ»ìÒô²»ÊÇÈfì`µ¤,ä›Òô¼°¾ŽÇúµÄºÃ‰Ä²ÅÊÇ»ìÒôµÄ¸ù±¾—l¼þ!
2009-9-14 07:59:35 »Ø¸´
·ÖÏí£¬Ð»Ð»Â¥Ö÷·¢²¼£¬ÎÒÊÕ²ØÁ˰¡
2009-9-14 08:19:31 »Ø¸´
ÔÙÖ§³Ö£¡:victory:
2009-9-14 21:03:03 »Ø¸´
:victory::victory:
2009-9-15 10:40:34 »Ø¸´
