Arturia Matrix-12 V 2.3.1.1784
ÒôÉ«
Ç¿´óµÄOberheim Matrix-12ÖÕÓÚ¸´»îÁË¡£Ê¹ÓÃÎÒÃǵÄTAE™½¨Ä£¼¼Êõ£¬ÎÒÃÇÄܹ»ÖØÐ»ñµÃºÏ³ÉÆ÷µÄÕâÖÖÒ°ÊÞ²¢´ø¸øÄú¡£
ÖÆ×÷Ä£ÐÍ
ÔÚ¶ÔÕâÖÖÊÜ×ð¾´µÄÀÖÆ÷µÄÉùÒô½øÐн¨Ä£Ê±£¬ÐźÅ·¾¶ÖеÄÿ¸öµã¶¼ºÜÖØÒª¡£
Òò´Ë£¬ÎªÁ˽¨Á¢ÕýÈ·µÄ»ù´¡£¬ÎÒÃÇÍêÃÀµØÖؽ¨ÁËԭʼ2¸öÕñµ´Æ÷µÄÒôµ÷ÌØÐÔ¼°ÆäÔÚMatrix-12 VÖеIJ¨ÐΡ£Í¬ÑùÖØÒªµÄÊDz¶»ñÆä15ÖÖÂ˲¨Æ÷ģʽµÄÿ¸öϸ΢²î±ð£¬Òò´ËÎÒÃDZ£³ÖËüÖ±µ½ËûÃÇÓÐÍêÃÀ½¨Ä££¡
¶¨ÒåMatrix-12¸´ÔÓÉùÒôµÄÁíÒ»¸öÒòËØÊÇËüÌṩµÄµ÷ÖÆÔ´ºÍÄ¿µÄµØÊýÁ¿¾ªÈË¡£ÕâÊÇÏÈǰ½öÔÚÍêȫģ¿é»¯ÏµÍ³ÖпÉÓõĸ´Ôӳ̶ȡ£
Òò´Ë£¬ÎªÁËÍê³É·ÂÕæ£¬ÎÒÃÇ»¹½¨Ä£ÁËÕâЩ¹¦ÄÜ£¬ÉõÖÁ³¬Ô½ÁËËüÃÇ¡£Í¨¹ýMatrix-12 VÖм¸ºõÎÞÏ޵ĿÉÄܵ÷ÖÆÂ·ÓÉ£¬Äú¿ÉÒÔ´´½¨¾ßÓÐÆäËûºÏ³ÉÆ÷ËùûÓеĸßÓлúÌØÐÔµÄÉùÒô¡£
Ô­ÎÄ
The massively powerful Oberheim Matrix-12 has been resurrected at last. Using our TAE™ modeling technology, we are able to recapture this beast of a synthesizer and bring it to you.
Making the model
Every point in the signal path is important when modeling the sound of such a revered instrument.
So to establish the proper foundation, we perfectly recreated the tonal characteristics of the original 2 oscillators and their waveforms in Matrix-12 V. And it was equally critical to capture every nuance of its 15 filter modes, so we kept at it until they had been modeled perfectly!
Another factor in defining the complex sound of the Matrix-12 was the amazing number of modulation sources and destinations it provided. This was a level of sophistication previously only available in a fully modular system.
So to complete the emulation we modeled these capabilities also, even surpassing them. With a nearly endless number of possible modulation routings in Matrix-12 V you can create sounds with highly organic qualities not found in other synthesizers.
50 shades of sound
A true chamelion of a synthesizer. With its 15 filter modes you can create everything you need from the thin and airy to the brash and bold.
The power of perfection
While the Matrix-12 was amazing in itself, we pushed it further by adding a new effects chain for further processing of the sound.
We also expanded the maximum number of modulation routings from 20 to 40, giving you even more creative freedom. Add to this the ability to control all the parameters via MIDI, and now you can do automations in a DAW or manually that could never be done before.
Main Features:
Two oscillators, each offering triangle, sawtooth and variable-width pulse wave with PWM.
Oscillator 2 also function as a white noise generator.
Oscillator 1 or the Filter can be frequency modulated.
Single filter with 15 modes: 4 Low Pass, 3 High Pass, 2 Band Pass modes, Notch and Phase Shift plus four additional "combo" filter modes.
Ultra-powerful modulation matrix with 27 sources and 47 destinations.
Sources include 5 envelopes, 5 LFOs, 4 Ramp, 3 Track generators, Velocity, Pressure, Keyboard follow, and more.
Two insert effect slots with six studio-grade effects available.
12 voices of polyphony like the original instrument
Multitimbral
Works in Standalone, VST, VST3, AU, AAX.
Whats New:
New Features
KeyLab MK2 Integration
Clicking on the preset browser "Clear All" button now scrolls back the result list to its top
Improvements
Reworked preset leveling and consistency
Effects default parameter values improvements
Bugfixes
Group is now saved in single preset
No more black GUIs when opening the plugin inside Analog Lab with a size of 90% and 100%
User MIDI configuration is now properly recalled when loaded from an external file
Fixed an issue where you had to click twice on the empty MIDI configuration to properly select it
Default MIDI configuration is now properly working
No more white flash when resizing our instruments inside macOS applications in AU
Various Komplete Kontrol / Maschine improvement
No more crash when a "Song Select" message is received
No more cracks and glitches appearing when modifying effects dry/wet parameters
User preset saving feature is now working properly
No more duplicated presets
Live 10 doesn't crash anymore when browsing preset from AU version
Resizing the plugin window don't open the export bank popup for some users anymore
No more crash when switching instruments on a track in FL Studio on macOS
New features
Redesigned Preset Browser interface
Added 50% zoom size
Added maximize height button
Bugfixes
Improved GUI integration in DAWs
Improved retina / multi-screen GUI support
Instruments user interfaces now open properly on case sensitive OS
It is now possible to process audio at different sample rates with RME Babyface audio interfaces
No more crash happens when deleting two tracks with the same instrument in a DAW
Sharp automations applied to on/off type parameters now work properly in AAX
ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
Arturia Matrix-12 V 2.3.1.1784 | 60.5 MB
ÆÀÂÛÁÐ±í£¨2£©
Ö§³Ö Arturia Matrix
2005-9-6 23:57:00 »Ø¸´
ˬ¡£¡£¡£¡£¡£¡£¡£¡£¡£¡£¡£¡£¡£¡£
2005-9-7 01:41:00 »Ø¸´
