»ìÏìÆ÷²ÎÊýµÄµ÷½Ú
812219363
2009-9-8 15:55:58
ÒôÏì
Reverb Hall 1 Ä£Äâ´óÒôÀÖÌüµÄ»ìÏì
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time2.8s0.3-30.0s»ìÏìʱ¼ä
    High Ratio0.80.1-1.0¸ßƵ˥¼õÂÊ
    Diffusion60-10»ìÏìÀ©É¢
Ini.Dly40.0ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF7.0kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPFTHRUTHRU,32Hz-8KHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Reverb Hall 2 Ä£Äâ´óÒôÀÖÌüµÄ»ìÏìµÄ±äÖÖ
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time3.2s0.3-30.0s»ìÏìʱ¼ä
    High Ratio0.70.1-1.0¸ßƵ˥¼õÂÊ
    Diffusion80-10»ìÏìÀ©É¢
    Ini.Dly38ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF6.3kHz1.0kHz-16.0kHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPFTHRUTHRU,32Hz-8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Reverb Room 1 Ä£ÄâË®Äàǽ±Ú·¿¼ä²úÉú´óÁ¿»ØÉùµÄ»ìÏì *Ϊ¹ÄÒôÉ«Ôö¼ÓÏÖ³¡¸Ð
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time1.4s0.3-30s»ìÏìʱ¼ä
    Diffusion70-10»ìÏìÀ©É¢
    Ini.Dly5.0ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPFTHRU1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPFTHRUTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Reverb Room 2 Room1µÄ±äÖÖ
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time1.8s0.3-30s»ìÏìʱ¼ä
    High Ratio0.60.1-1.0¸ßƵ˥¼õÂÊ
    Ini.Dly17ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF9kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPF80HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Reverb STAGE ÀàËÆ³ÌÐò1£¬µ«¸üÃ÷ÁÁ£¬¸üÓÐÏÖ³¡¸Ð
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time3.4s0.3-30s»ìÏìʱ¼ä
    High Ratio0.90.1-1.0¸ßƵ˥¼õÂÊ
    Ini.Dly45ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    HPF70HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Reverb Plate Ä£Äâ¸ÖÅÌÀà»ìÏìϵͳ£¬ÊÊÓ¦ÐÔºÜ¹ã£¬ÌØ±ðÊÇÈËÉù£¬¹ÄºÍ´ò»÷ÀÖ
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time2.4s0.3-30s»ìÏìʱ¼ä
    Ini.Dly16ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF8kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Rev Ambience 1 Ä£ÄâÀÖÆ÷ÖÜΧµÄ»ìÏ죬ÓÃÓÚÈËÉù£¬ºÏ³ªºÍ´ò»÷ÀÖ
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.2s0.3-30s»ìÏìʱ¼ä
    High Ratio10.1-1.0¸ßƵ˥¼õÂÊ
    Ini.Dly19ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    HPF45HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Rev Ambience 2 ³ÌÐò7µÄ±äÖÖ
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time0.8s0.3-30s»ìÏìʱ¼ä
    Ini.Dly0.1ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    HPF56HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Rev Live Room 1 Ä£ÄâÏÖ³¡·¿¼äµÄ»ìÏì,»ìÏì·´Éä±ÈRecerm RoomÇ¿
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    LPF7kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
ÆÀÂÛÁÐ±í£¨2£©
812219363 Â¥Ö÷
Rev Live Room 2 ³ÌÐò9µÄ±äÖÖ
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time2.2s0.3-30.0s»ìÏìʱ¼ä
    High Ratio0.50.1-1.0¸ßƵ˥¼õÂÊ
    Ini.Dly12.0ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF4.0kHz1.0kHz-16.0kHz.THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Reverb Vocal ÓÃÓÚÈËÉù,ºÏ³ªµÄ»ìÏì
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Rev.Time1.9s0.3-30.0s»ìÏìʱ¼ä
    Ini.Dly16ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF12kHz1.0kHz-16.0kHz.THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPF100HzTHRU,32Hz-8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Chorus Reverb Á¢ÌåÉùºÏ³ªºó½Ó»ìÏì
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Mod.Freq0.8Hz0.1-20Hzµ÷ÖÆËÙ¶È
    Mod.Depth40%0-100%µ÷ÖÆÉî¶È
    Mod.Dly1.3ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
    High Ratio0.70.1-1¸ßƵ˥¼õÂÊ
    Ini.Dly30ms0.1-139msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF6.3kHz1kHz--16kHz, THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPFTHRUTHRU,32Hz--8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Rev.Depth24%0-100%»ìÏìÉî¶È
    Flange Reverb Á¢ÌåÉùÆ®ºöºó½Ó»ìÏì
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Mod.Freq1.4Hz0.1-20Hzµ÷ÖÆËÙ¶È
    Mod.Depth22%0-100%µ÷ÖÆÉî¶È
    FB Gain+45%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÆ®ºöµÄÔöÒæ
    Mod.Dly13ms0-15.5msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
    Ini.Dly26ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
    LPF4.5kHz1kHz--16kHz, THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    HPF45HzTHRU,32Hz--8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
    Rev.Depth30%0-100%»ìÏìÉî¶È
    Delay L-C-R ×ó£¬ÖУ¬ÓÒÉùµÀ¶ÀÁ¢µÄÑÓ³Ù
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Dly L250ms0.1-661ms×óÉùµÀÑÓ³Ùʱ¼ä
    Dly R500ms0.1-661msÓÒÉùµÀÑÓ³Ùʱ¼ä
    Dly C125ms0.1-661msÖÐÑëÉùµÀÑÓ³Ùʱ¼ä
    Level C700-100ÖÐÑëÉùµÀÑÓ³ÙÒôÁ¿
    FB.Dly500ms0.1-661msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
    FB.Gain+40%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
    High Ratio0.80.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
    Monodly-Chorus µ¥ÉùµÀÑÓ³Ùºó½ÓÁ¢ÌåÉùºÏ³ª
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Delay400ms0.1-618msÑÓ³Ùʱ¼ä
    FB.Gain+32%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
    Mod.Freq0.4Hz0.1-20HzºÏ³ªµ÷ÖÆËÙ¶È
    Mod.Depth10%0-100%ºÏ³ªµ÷ÖÆÉî¶È
    Mod.Dly0.1Ms0-24msºÏ³ª¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
    Chrous-Dly L C R Á¢ÌåÉùºÏ³ªºó½Ó×ó£¬ÖУ¬ÓÒÉùµÀ¶ÀÁ¢µÄÑÓ³Ù
    ²ÎÊýÊýÖµ·¶Î§ËµÃ÷
    Mod.Depth24%0-100%µ÷ÖÆÉî¶È
    Mod.Dly5.9ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
Dly L26.4ms0.1-618ms×óÉùµÀÑÓ³Ùʱ¼ä
    Dly R33.2ms0.1-618msÓÒÉùµÀÑÓ³Ùʱ¼ä
    Dly C13.1ms0.1-618msÖÐÑëÉùµÀÑÓ³Ùʱ¼ä
    Level C600-100ÖÐÑëÉùµÀÑÓ³ÙÒôÁ¿
    FB.Dly40.5ms0.1-618msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
    FB.Gain-48%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
    High Ratio0.10.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
2009-9-8 16:03:11 »Ø¸´
·ÖÏí£¬Ð»Ð»Â¥Ö÷·¢²¼£¬ÎÒÊÕ²ØÁ˰¡
2009-9-8 19:24:45 »Ø¸´
