Arturia Mini V 3.3.1.1782
´Ó70Äê´úµÄÐǽ¢¿Ö²ÀÒýÁìÏßµ½90Äê´úÖÐÆÚÎû¹þµÄºÚ°ïÎØÎØÉù£¬ÓÀÔ¶´æÔÚµÄMiniMgÒѾʹÆäÖ¬·¾´æÔÚÒÑÓÐ40¶àÄêµÄÀúÊ·¡£
ÎÒÃÇÓëBob MoogºÏ×÷£¬ÖØÐ´´ÔìÁËËûÔçÆÚ70Äê´úºÏ³ÉÆ÷µÄ´«Ææ½çÃæ£¬Õâ¸ö½çÃæÔø±»¼¸´úÒôÀÖ¼ÒËùϲ°®¡£ ÕæÕýʹÕâ¸öºÏ³ÉÆ÷³ÉΪ´«ËµÖеĴ«ÆæÊÇËüµÄÉùÒô£¬ËùÒÔÎÒÃÇÒ²·Ç³£½÷É÷µØÄ£ÄâÆäÄÚ²¿ÌØÕ÷µÄ΢ÃîÖ®´¦¡£
Ò»¼þºÃʱäµÃ¸üºÃ
Mini V±£ÁôÁËÆäÂÅ»ñÊâÈÙµÄÏÈǰ°æ±¾µÄËùÓÐÔÊ¼ÌØÕ÷¡£
Mini V°æ±¾3¸üÐÂÁËÂ˲¨Æ÷Éè¼Æ£¬Ê¹Æä±ÈÒÔÍù¸ü¼Ó׼ȷ¡£ Ç¿´ó¶ø·á¸»µÄµÍÒô£¬Æ¾½èÎÒÃǾþ¿¼ÑéµÄTAE®¼¼ÊõµÄнøÕ¹£¬ÖÒʵÔÙÏÖÁË¡°×ÔÓÉÔËÐС±µÄ²¨ÐΡ£
ÔÎÄ
From the starship funk lead lines of the ¡®70s to the gangster whine of mid ¡®90s hip-hop, the ever-present MiniMg has been making its fat presence known for over 4 decades.
In partnership with Bob Moog we recreated the legendary interface of his early 70's synth that was and is loved by generations of musicians. What truly makes this synth the Legend of Legends is its sound, and so we took great care to model the subtleties of its internal characteristics as well.
A good thing made better
Mini V has kept all of the original characteristics of its award-winning previous versions.
Mini V version 3 updates the filter design to make it even more accurate than ever. Powerful and rich bass, faithfully reproduced ¡®free-running¡¯ waveforms thanks to new advances in our long proven TAE® technology.
A class of its own
When fat, deep blistering bass is needed, there is no further need to go anywhere but to Mini V. Also famous for its powerful lead sounds, the greatest hit makers in the '70's knew that this synth was the goto tool.
A Sonic Expansion
But we¡¯re not resting on our laurels.
While the original product set the sound of the 70's we have taken it to new realms. We have added an advanced modulator that allows you to draw a shape and control many parameters creating a movement and interest. A vocal filter expands sonic possibilities with a formant-analysis based effect: now you can make that synth talk! A modulation matrix has been added dramatically improving on the original design and doing away with its limitations.
Main Features:
All the parameters of the original Mini V
3 voltage controlled oscillators with 5 waveforms
1 amazing 24 dB/octave filter
2 ADSR envelopes
LFO with 7 waveforms
1 Noise Generator
1 VCA
1 Mixer
1 external audio input and 1 external oscillator and filter modulation input
Modulation matrix with up to 8 connections (15 sources and 35 destinations)
Arpeggiator
Vocal Filter: a fully automatable, formant-based effect with its own LFO
Up to 32 voices of polyphony
Unison mode option
More than 450 presets created by an international team of top-notch sound designers
Stereo effects: chorus and delay
Soft clipping function
Advanced automation mode
Whats New:
New Features
KeyLab MK2 Integration
Clicking on the preset browser "Clear All" button now scrolls back the result list to its top
Improvements
Reworked preset leveling and consistency
Bugfixes
When adjusting PWM, waveform selector knob doesn't move anymore
User MIDI configuration is now properly recalled when loaded from an external file
Fixed an issue where you had to click twice on the empty MIDI configuration to properly select it
Default MIDI configuration is now properly working
No more white flash when resizing our instruments inside macOS applications in AU
Various Komplete Kontrol / Maschine improvement
No more crash when a "Song Select" message is received
No more cracks and glitches appearing when modifying effects dry/wet parameters
User preset saving feature is now working properly
No more duplicated presets
Live 10 doesn't crash anymore when browsing preset from AU version
Resizing the plugin window don't open the export bank popup for some users anymore
No more crash when switching instruments on a track in FL Studio on macOS
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´
Arturia Mini V 3.3.1.1782 | 143 MB
