·¢ÉÕÒôÏìÏß²ÄÏà¹ØµÄÊõÓïÏê½â
5888717
2009-8-13 16:58:00
¡¡¡¡·¢ÉÕÒôÏì¾ÍÊǼ¶Êý¸ß£¬Ð§¹ûÓÅÐãµÄÒôÏìϵͳûǮÉÕ²»ÆðÒôÏì,ÓÐÇ®ÉÕ²»ºÃÒôÏì¡£ÒÔÒôÀÖΪ»ù´¡£¬×ö¸ö°®ÀÖ¼æÒôÏì·¢ÉÕÓÑ£¬·ñÔòһζ½²ÇóÒôЧ»áÎóÈëÆç;£¬Ê§È¥ÁËÒôÏì×î»ù±¾µÄÄ¿µÄ£ºÊ¹ÒôÀÖ¸ü¼ÓÏÊ»îµÄ³ÊÏÖÔÚÎÒÃÇÃæÇ°¡£ÏÂÃæ¸ú×ÅС±àÀ´¿´¿´·¢ÉÕÒôÏìÏß²ÄÏà¹ØµÄÊõÓïÏê½â°É£¡Ï£Íû¶ÔÄãÓÐËù°ïÖú¡£
¡¡¡¡·Çƽºâ½Ó²µÏß(Unbalanced Interconnect)£º
¡¡¡¡Ô­ÎÄ£ºAn unbalanced interconnect has two conductors and is usually terminated with RCA plugs. Also called a single-ended interconnect.
¡¡¡¡ÒëÎÄ£º·Çƽºâ½Ó²µÏßÓÐÁ½¸öÁ¬½Ó½Å£¬Í¨³£¶Ë½ÓÒÔRCA²åÍ·¡£Ò²³ÆÎªµ¥¶Ë½Ó²µÏß¡£
¡¡¡¡Æ½ºâ½Ó²µÏß(Balanced Interconnect)£º
¡¡¡¡Ô­ÎÄ£ºA balanced interconnect has three conductors instead of two, and is terminated with three-pin XLR connectors. Balanced interconnects are used only between components having balanced inputs and outputs.
¡¡¡¡ÒëÎÄ£ºÆ½ºâ½Ó²µÏßÓÐÈý¸öÁ¬½Ó½Å£¬¶ø²»ÊÇÁ½¸ö£¬¶Ë½ÓÒÔ3оµÄXLR²åÍ·¡£Æ½ºâ½Ó²µÏß½öÓÃÓÚÓÐÆ½ºâÊäÈëÊä³ö¿ÚµÄÆ÷²ÄÉÏ¡£
¡¡¡¡Êý×Ö½Ó²µÏß(Digital Interconnect)£º
¡¡¡¡Ô­ÎÄ£ºA single interconnect that carries a stereo digital audio signal in the S/PDIF format, usually from a CD transport, music server, or other digital source to a DAC.
¡¡¡¡ÒëÎÄ£º½Ó²µÏß´«ËÍS/PDIF¸ñʽµÄÁ¢ÌåÉùÊý×ÖÒôƵÐźţ¬Í¨³£´ÓCDתÅÌ£¬ÒôÀÖ·þÎñÆ÷»òÆäËüÊý×ÖÔ´´«Ë͵½DAC¡£
¡¡¡¡USBÏß(USB Cable)£º
¡¡¡¡Ô­ÎÄ£ºA single cable that carries digital audio from a computer-based music server to a USB-capable DAC.
¡¡¡¡ÒëÎÄ£ºUSBÏß´Ó»ùÓÚ¼ÆËã»úµÄÒôÀÖ·þÎñÆ÷ÏòÓÐUSB½Ó¿ÚµÄDAC´«ËÍÊý×ÖÒôƵ¡£
¡¡¡¡FireWireÏß(FireWire Cable)£º
¡¡¡¡Ô­ÎÄ£ºAlso called IEEE1394, FireWire is a bidirectional interface that can carry high-resolution digital audio.
¡¡¡¡Bi-wiring£º Bi-wiring is a method of connecting a power amplifier to a loudspeaker with two runs of cable instead of one.
¡¡¡¡ÒëÎÄ£ºFireWireÏßÒ²³ÆIEEE1394£¬ÊÇÒ»ÖÖÄÜ´«Ë͸߷ֱæÂÊÊý×ÖÒôƵµÄË«Ïò½Ó¿Ú¡£Ë«Ïß½Ó·¨£ºË«Ïß½Ó·¨ÊÇͨ¹ýÁ½×éÏßÀ´Á¬½Ó¹¦·ÅºÍÒôÏä¡£
¡¡¡¡·ÇƽºâÏߺͶË×Ó(RCA Plug and Jack)£º
¡¡¡¡Ô­ÎÄ£ºRCA plugs and jacks are the most common termination for
¡¡¡¡unbalanced signals. Virtually all audio equipment has RCA jacks to accept the RCA plugs on unbalanced interconnects. RCA jacks are mounted on the audio component¡¯s rear panel; RCA plugs are the termination of unbalanced interconnects.
¡¡¡¡ÒëÎÄ£º·ÇƽºâÏߺͶË×ÓÊÇ×î³£¼ûµÄ·ÇƽºâÐźŵÄÁ¬½ÓÖÕ¶Ë¡£»ù±¾ÉÏËùÓеÄÒôƵÉ豸¶¼ÓпÉÒÔÁ¬½Ó·Çƽºâ½Ó²µÏßÉÏRCA²åÍ·µÄ¶Ë×Ó¡£ RCA¶Ë×Óͨ³£ÖÃÓÚÒôƵÆ÷¼þµÄ±³°åÉÏ¡£RCA²åÍ·ÊÇ·ÇÆ½ºâ½Ó²µÏßµÄ'ÖÕ¶Ë¡£
¡¡¡¡Æ½ºâÏߺͶË×Ó(XLR Plug and Jack)£º
¡¡¡¡Ô­ÎÄ£ºXLR plugs are three-pin connectors terminating a balanced interconnect. XLR jacks are rear-panel¨Cmounted connectors that accept XLR plugs.
¡¡¡¡Binding Post£º Binding posts are terminations on power amplifiers
¡¡¡¡and loudspeakers that provide connection points for loudspeaker cables.
¡¡¡¡ÒëÎÄ£ºXLR²åÍ·ÊÇÖÕֹƽºâ½Ó²µÏßµÄÈýо²åÍ·¡£ÖÃÓÚ±³°åÉϵÄXLR¶Ë×ÓÊÇÓÃÀ´Á¬½ÓXLR²åÍ·µÄ¡£½ÓÏßÖù¶Ë×Ó£º½ÓÏßÖù¶Ë×ÓÊǹ¦·ÅºÍÒôÏäÉÏÓÃÀ´¸øÒôÏäÏßÌṩÁ¬½ÓµãµÄÖÕ¶Ë¡£
¡¡¡¡Five-way½ÓÏß¶Ë×Ó(Five-way Binding Post)£º
¡¡¡¡Ô­ÎÄ£ºA type of binding post that can accept bare wire, spade lugs, pins, round lugs over the post, or banana plugs.
¡¡¡¡Five-way posts are found on most power amplifiers and loudspeakers.
¡¡¡¡ÒëÎÄ£ºFive-way½ÓÏß¶Ë×ÓÊÇÒ»ÖÖÄÜÁ¬½ÓÂãÏߣ¬Æ½½ÓÏ߯¬£¬²å½Å£¬Ô²ÐÎÏ߯¬ºÍÏã½¶ÏߵĽÓÏß¶Ë×Ó¡£´ó²¿·Ö¹¦·ÅºÍÒôÏäÉ϶¼ÓÐÕâÖÖ½ÓÏß¶Ë×Ó¡£
¡¡¡¡Æ½½ÓÏ߯¬(Spade Lug)£º
¡¡¡¡Ô­ÎÄ£ºA flat, pronged for loudspeaker cables. Spade lugs fit around power-amplifier and loudspeaker binding posts. The most popular kind of loudspeaker-cable termination.
¡¡¡¡ÒëÎÄ£ºÆ½½ÓÏ߯¬ÊÇÒ»ÖÖ±âÆ½¼â¶Ë·Ö²æµÄÒôÏäÏßÖÕ¶Ë¡£Æ½½ÓÏ߯¬Á¬½ÓÓÚÔÚ¹¦·ÅºÍÒôÏäµÄ½ÓÏßÖù¶Ë×ÓÉÏ¡£ÕâÊÇÒ»ÖÖ×î³£ÓõÄÒôÏäÏßÖÕ¶Ë¡£
¡¡¡¡Ïã½¶ÏߺͶË×Ó(Banana Plug and Jack)£º
¡¡¡¡Ô­ÎÄ£ºBanana plugs are sometimes found on loudspeaker cables in place of spade lugs. Banana plugs will fit into five-way binding posts or banana jacks. Many European products use banana jacks on power amplifiers for loudspeaker connection.
¡¡¡¡ÒëÎÄ£ºÒôÏäÏßÉÏÓÐʱҲʹÓÃÏã½¶²åÍ·À´È¡´úƽ½ÓÏ߯¬¡£Ïã½¶²åÍ·ÄÜÁ¬½ÓFive-way½ÓÏßÖù¶Ë×Ó£¬Ò²ÄܲåÈëÏã½¶¶Ë×Ó¡£Ðí¶àÅ·ÖÞ²úÆ·ÔÚ¹¦·ÅÉÏʹÓÃÏã½¶¶Ë×ÓÀ´Á¬½ÓÒôÏä¡£
¡¡¡¡ÃÀ¹úÏß¹æ(AWG£º American Wire Gauge)£º
¡¡¡¡Ô­ÎÄ£ºA measure of conductor thickness,usually in loudspeaker cables. The lower the AWG number, the thicker the wire. Lamp cord has an AWG of 18, usually referred to as ¡°18 gauge.¡±
¡¡¡¡ÒëÎÄ£ºÃÀ¹úÏß¹æÊÇÒ»ÖÖÇø·ÖÒôÏäµ¼ÏßÖ±¾¶µÄ±ê×¼¡£AWGÊýֵԽС£¬µ¼ÏßÔ½´Ö¡£µçµÆÏßÉϵÄAWGÊýÖµ18ͨ³£Ö¸µÄÊÇ¡°18 gauge¡±¡£
¡¡¡¡HDMI£º
¡¡¡¡Ô­ÎÄ£ºAn initialism for High-Definition Digital Multimedia Interface, HDMI was developed for home theater to carry highdefinition
¡¡¡¡video along with highresolution digital audio on the same cable.
¡¡¡¡ÒëÎÄ£ºHDMIÊǸßÇåÎú¶È¶àýÌå½Ó¿Ú(High-Definition Digital Multimedia Interface)µÄÊ××ÖĸËõд¡£HDMIÊÇͨ¹ýͬһ¸ùÏßÀÂΪ¼ÒÍ¥Ó°Ôº´«Ë͸ßÇåÊÓÆµºÍ¸ß·Ö±æÂʵÄÊý×ÖÒôƵ¶ø¿ª·¢µÄ¡£
ÆÀÂÛÁÐ±í£¨1£©
»¶Ó­ÐÂÅóÓÑ£¡
2009-8-13 19:27:53 »Ø¸´
