cubase sxÒôÀÖÖÆ×÷Èí¼þ£¨Î壩
Cubase
¼üÅÌ¿ì½Ý¼ü
ÔÚCubase SXÖУ¬´ó¶àÊýÖ÷Òª²Ëµ¥Ö¸Áî¶¼ÌṩÓÐÏàÓ¦µÄ¼üÅÌ¿ì½Ý¼ü²Ù×÷·½Ê½£¬¶Ô´ËÒÑÓÉCubase SXÌṩÓÐÍ걸µÄÔ¤ÖÃĬÈÏÉèÖ㬶øÇÒ»¹ÄÜÈÃÓû§½øÐÐ×Ô¶¨Òå¸öÈ˵ļüÅÌ¿ì½Ý¼ü¡£
Edit
Autoscroll£ºK
Snap On/Off£ºJ
Duplicate£ºCtrl+D
Open£ºCtrl+E
Repeat£ºCtrl+K
Lock£ºCtrl+Shift+L
Unlock£ºCtrl+Shift+U
Cut Time£ºCtrl+Shift+X
Delete Time£ºShift+Back
Paste Time£ºCtrl+Shift+V
Paste at Origin£ºAlt+V
Split Range£ºShift+X
Insert Silence£ºCtrl+Shift+E
Select All on Tracks£ºShift+A
Split At Cursor£ºAlt+X
Move to Cursor£ºAlt+L
Solo£ºS
Mute£ºM
Record Enable£ºR
Mute Objects£ºShift+M
Unmute Objects£ºShift+U
Mute/Unmute Objects£ºAlt+M
Open Scores£ºCtrl+R
Open List Editor£ºCtrl+G
Open/Close Editor£ºReturn
Left Selection Side to Cursor£ºE
Right Selection Side to Cursor£ºD
Undo£ºCtrl+Z
Redo£ºCtrl+Shift+Z
HistoryCut£ºCtrl+X
Copy£ºCtrl+C
Paste£ºCtrl+V
Delete£ºDel/Back
Select All£ºCtrl+A
Select None£ºA
Zoom
Zoom In£º.
Zoom Out£º,
Zoom to Selection£ºShift+/
Zoom to Event£ºCtrl+/
Zoom Full£º/
Zoom In Vertical£ºCtrl+Down Arrow
Zoom Out Vertical£ºCtrl+Up Arrow
Zoom In Tracks£ºAlt+Down Arrow
Zoom Out Tracks£ºAlt+Up Arrow
Devices
VST Send Effects£ºF6
VST Master Effects£ºF7
VST Outputs£ºF4
VST Inputs£ºF5
VST Performance£ºF12
VST Instruments£ºF11
Mixer£ºF3
Video£ºF8
MIDI Quantize
Select Next Quantize£º=
Select Prev Quantize£º-
Auto Quantize On/Off£ºCtrl+Q
Files
New£ºCtrl+N
Open£ºCtrl+O
Close£ºCtrl+W
Save£ºCtrl+S
Save New Version£ºCtrl+Alt+S
Save As£ºCtrl+Shift+S
Pool
Show Used Automation£ºCtrl+=
Hide All Automation£ºCtrl+-
Open Pool£ºCtrl+P
Open Markers£ºCtrl+M
Open MasterTrack£ºCtrl+T
Open Browser£ºCtrl+B
Setup£ºShift+S
Editor
Show/Hide Inspector£ºAlt+I
Show/Hide Infoview£ºCtrl+I
Show/Hide Overview£ºAlt+O
Audio
Crossfade£ºX
Find Selected in Pool£ºCtrl+F
Transport
Panel£ºF2
Play Selection Range£ºAlt+Space
Locate Next Event£ºN
Locate Previous Event£ºB
Locators to Selection£ºP
Locate Selection£ºL
Loop Selection£ºShift+G
Start£ºEnter
Stop£ºPad0
Start/Stop£ºSpace
Record£ºPad *
Rewind£ºPad -
Forward£ºPad +
Return to Zero£ºPad .
Cycle£ºPad /
AutoPunch In£ºI
AutoPunch Out£ºO
Nudge Up£ºCtrl+Pad +
Nudge Down£ºCtrl+Pad -
To Left Locator£ºPad1/Shift+1
To Right Locator£ºPad2/Shift+2
To Marker 3£ºPad3/Shift+3
To Marker 4£ºPad4/Shift+4
To Marker 5£ºPad5/Shift+5
To Marker 6£ºPad6/Shift+6
To Marker 7£ºPad7/Shift+7
To Marker 8£ºPad8/Shift+8
To Marker 9£ºPad9/Shift+9
Locate Next Marker£ºShift+N
Locate Previous Marker£ºShift+B
Set Left Locator£ºCtrl+Pad1/Ctrl+1
Set Right Locator£ºCtrl+Pad2/Ctrl+2
Set Marker 3£ºCtrl+Pad3/Ctrl+3
Set Marker 4£ºCtrl+Pad4/Ctrl+4
Set Marker 5£ºCtrl+Pad5/Ctrl+5
Set Marker 6£ºCtrl+Pad6/Ctrl+6
Set Marker 7£ºCtrl+Pad7/Ctrl+7
Set Marker 8£ºCtrl+Pad8/Ctrl+8
Set Marker 9£ºCtrl+Pad9/Ctrl+9
Input Position£ºShift+P
Input Left Locator£ºShift+L
Input Right Locator£ºShift+R
Insert Marker£ºInsert
Metronome Setup£ºShift+C
Metronome On£ºC
MIDI
Quantize£ºQ
Fixed Lengths£º;
Legato£º
Transpose£ºT
Velocity£ºV
Fixed Velocity£º'
Delete Overlaps£¨mono£©£º[
Delete Overlaps£¨poly£©£º]
Reset£ºZ
Merge Midi£ºO
Logical Editor£ºCtrl+L
Tool
Next Tool£ºF10
Previous Tool£ºF9
Select Tool£º`
Range Tool£º2
Split Tool£º3
Glue Tool£º4
Delete Tool£º5
Zoom Tool£º6
Mute Tool£º7
Draw Tool£º1
Play Tool£º9
Stroke Tool£ºAlt+1
Nudge
Start Left£ºCtrl+Left Arrow
Start Right£ºCtrl+Right Arrow
End Left£ºAlt+Left Arrow
End Right£ºAlt+Right Arrow
Left£ºLeft Arrow
Right£ºRight Arrow
Navigate
Up£ºUp Arrow
Down£ºDown Arrow
Add Left£ºShift+Left Arrow
Add Right£ºShift+Right Arrow
Add Up£ºShift+Up Arrow
Add Down£ºShift+Down Arrow
Window Layout
New£ºCtrl+Pad0
Recapture£ºAlt+Pad0
Organize£ºW
Layout 1£ºAlt+Pad1
Layout 2£ºAlt+Pad2
Layout 3£ºAlt+Pad3
Layout 4£ºAlt+Pad4
Layout 5£ºAlt+Pad5
Layout 6£ºAlt+Pad6
Layout 7£ºAlt+Pad7
Layout 8£ºAlt+Pad8
Layout 9£ºAlt+Pad9
