IndustryKits Hades Cannon VST WiN-OSX
¾¹ýÂþ³¤µÄµÈ´ýÖÕÓÚÓÐÒ»¸öеÄVSTÔÚ½ÖÇø£¬Ëü¾ÍÔÚÕâÀï°ïÄã×ö»ð£¡
½éÉÜ¡°¹þµÏ˹¼ÓÅ©ÅÚVST¡±¡£ÕâÊÇÒ»¸ö¹¦ÄÜÆëÈ«µÄVST£¬ÊÊÓÃÓÚËùÓÐDAWÈí¼þ£¬ÈçFL Studio£¬Logic£¬Cubase£¬Studio One£¬AbletonµÈ¡£Õâ¸ö»µÄк¢¿´ÆðÀ´¼òµ¥µ«ÁîÈ˾ªÌ¾Çҷdz£ÊµÓá£ËüÓи÷ÖÖÉùÒô£¬Èç808£¬µÍÒô£¬ºÏ³É£¬»ÆÍ£¬ºÏ³ª£¬ÏÒÀÖ£¬²ÉÕª£¬Ç±Ôڹ˿ͣ¬µæµÈ¡£¹ØÓÚÕâÒ»ÇеÄ×î¼Ñ²¿·Ö£¿ÊÇÕâÖ»ÊÇ¿ªÊ¼£¡
Äã»á×¢Òâµ½ÓÐÒ»¸öÀ©Õ¹²¿·Ö£¬ÎÒÃǼƻ®ÎªÄã´øÀ´ËùÓзdz£ºÃºÍ¾¼Ãʵ»ÝµÄÀ©Õ¹£¬ÕâÊÇÕý³£µÄÒ°ÊÞËùÒÔÕâÕæµÄÊÇÒ»¸öVSTÄã¿ÉÒԵõ½Ö§³ÖºÍÖ§³ÖºÍʹÓÃWithOut´òÆÆÒøÐС£½öÐè43ÃÀÔª£¬Õâ¼þʾÍûÓÐÓÃÁË¡£Äã±ØÐë°ëËÀ²»ÒªÑ¡ÔñÕâ¼þÊÂLOL¡£ CheckOutÏÂÃæµÄһЩͳ¼ÆÊý¾Ý¡£
¼æÈÝPCºÍMAC 32bitºÍ64bit
ÌṩVSTºÍÒôƵµ¥Ôª¸ñʽ
°üÀ¨50¸ö¾ªÈ˵ÄÔ¤É迪ʼ
Ðí¶àδÀ´µÄÀ©Õ¹¼Æ»®
ÔÎÄ
After A Long Wait Finally A NEW VST Is On The Block & It's Here To Help You MAKE THAT FIRE!!!
Introducing The "Hades Cannon VST". This Is A Fully Functional VST That Works In ALL DAW Software Such As FL Studio, Logic, Cubase, Studio One, Ableton & More. This Bad Boy Looks Simple Yet STUNNING & Very Functional. It Has Sounds Of All Kinds Such As 808, Bass, Synth, Brass, Choir, Strings, Plucks, Leads, Pads & More. And The Best Part About This All? Is That THIS IS ONLY THE BEGGINING!!
You Will Notice There Is An Expansions Section Which We Plan To Bring You All Very Nice & Affordable Expansions For This BEAST On The Regular So This Is Really A VST You Can Get Behind & Support & Use WithOut Breaking The Bank. At Only $43 Dollars This Thing Is A No Brainer. You Would Have To Be Half Dead To Not Pick This Thing Up LOL. CheckOut Some Stats Below.
Compatible With Both PC & MAC 32bit & 64bit
Comes In Both VST & Audio Unit Formats
Includes 50 Amazing Presets To Start With
Many Future Expansions Planned
- VST FUNCTIONAL EFFECTS INCLUDE -
Reverb
LFO Depth
LFO Rate
Amp Low
Amp High
ADSR Envelope
Glide
Pan
Volume
LFO Wave
LFO Type
LFO Source
Quality
Velocity
Voice Mode
Pitch Bend
Modulation Wheel
IndustryKits Hades Cannon VST WiN-OSX| WiN 3.53 GB | OSX UPDATE 4.51 GB |
