רҵÒôƵÉ豸
ÐÐÒµÐÂÎÅ
ËÉÏÂAJ-HPX3100MCÉãÏñ»ú
cakewalk
ÒôƵӦÓÃ×¢²á»áÔ±
2009-7-17 18:44:12
É豸
ÉãÏñÐÔÄÜ£ºÁ¿»¯£º14λ
ˮƽÇý¶¯ÆµÂÊ£º50Hz£º74.25MHz£¬59.94Hz£º74.1758MHz
²ÉÑùƵÂÊ£º50Hz£º74.25MHz£¬59.94Hz£º74.1758MHz
Êý×ÖÐźŴ¦Àí£º50Hz£º74.25MHz£¬59.94Hz£º74.1758MHz
¿É±à³ÌÔöÒæ£º-6dB£¬-3dB£¬0dB£¬3dB£¬6dB£¬9dB£¬12dB£¬15dB£¬18dB£¬21dB£¬24dB£¬27dB£¬30dB£¬¿ÉÑ¡Ôñ
Êý×Ö³¬¼¶ÔöÒæ£º6dB£¬10dB£¬12dB£¬15dB£¬20dB£¬24dB£¬28dB£¬34dB¿ÉÑ¡Ôñ
³¬¼¶ÔöÒæ£º30dB£¬36dB£¬42dB¿ÉÑ¡Ôñ
Êý×ÖÊÓÆµ£º
²ÉÑùƵÂÊ£ºAVC-Intra 100/AVC-Intra 50/DVCPRO HD£º
Y£º74.2500 MHz£¬PB/PR£º37.1250 MHz£¨50 Hz£©
Y£º74.1758 MHz£¬PB/PR£º37.0879 MHz£¨59.94 Hz£©
DVCPRO£ºY£º13.5 MHz£¬PB/PR£º3.375 MHz
DVCPRO50£ºY£º13.5 MHz£¬PB/PR£º6.75 MHz
Á¿»¯£ºAVC-Intra 100/AVC-Intra 50£º10 bit
DVCPRO HD/DVCPRO50/DVCPRO/DV£º8 bit
ÊÓÆµÑ¹Ëõ£ºAVC-Intra100/AVC-Intra50£ºMPEG-4 AVC/H.264 IntraÎļþ
DVCPRO HD£ºDV »ù±¾Ñ¹Ëõ£¨SMPTE 370M£©
DVCPRO 50/DVCPRO£ºDV »ù±¾Ñ¹Ëõ£¨SMPTE 314M£©
DV£ºDVѹËõ£¨IEC 61834-2£©
¿ìÃÅÃèÊö£º¿ìÃÅËÙ¶È£º
1/60(50Hz) Ãë
1/100£¨59.94Hz£©Ãë
1/120 Ã룬1/250 Ãë
1/500 Ã룬1/1000 Ãë
1/2000 Ã룬HALF 180.0¶È
172.8 ¶È£¬144.0¶È
120.0 ¶È£¬90.0¶È
45.0 ¶È
¿ìÃÅËÙ¶È£¨Í¬²½É¨Ã裩£º
1/51.4 ÃëÖÁ1/6000 Ã루1080/50i£¬576/50i£©
1/25.7 ÃëÖÁ1/3000 Ã루1080/25p£¬576/25p£©
1/61.7 ÃëÖÁ1/7200 Ã루1080/59.94i£¬480/59.94£©
1/30.9 ÃëÖÁ1/3600 Ã루1080/29.97i£¬480/29.97p£©
1/24.7 ÃëÖÁ1/2880 Ã루1080/23.98i£¬480/23.98p£© ¾À´í
zuiµÍÕÕÃ÷¶È£º0.005Á÷Ã÷£¨F1.4£¬³¬¼¶ÔöÒæ42dB+DS.GAIN34dB
Â¼ÖÆ¸ñʽ£ºAVC-Intra 100/AVC-Intra 50/DVCPRO HD/DVCPRO50/DCPRO/DV ¸ñʽ¿ÉÇл»
¶¯Ì¬Ó°Ïñ£º1080/50i£¬1080/25p over 50i£¬ 1080/25pN£¬1080/59.94i£¬1080/29.97p over 59.94i£¬
1080/23.98p over 59.94i£¬1080/23.98pA over 59.94i£¬1080/29.97pN£¬1080/23.98pN£¬
576/50i£¬576/25p over 50i£¬480/59.94i£¬480/29.97p over 59.94i£¬480/23.98p over 59.94i£¬480/23.98pA over 59.94i
¼Òôϵͳ£ºÒôƵÐźţºAVC-Intra 100/50£º48 kHz£¬16 bit/24 bit ¿ÉÇл»£¬4ch DVCPRO HD/DVCPRO 50£º48 kHz£¬16 bit£¬4ch
DVCPRO/DV£º48 kHz£¬16 bit£¬2ch/4ch ¿ÉÇл»
Êý×ÖÒôƵ£º
ƵÂÊÏìÓ¦£º20HzÖÁ20kHz¡À1.0dB£¨²Î¿¼µçƽ£©
¶¯Ì¬·¶Î§£º³¬¹ý85dB£¨1kHz£¬AWTD£¬16룩
³¬¹ý93dB£¨1kHz£¬AWTD£¬24 ±ÈÌØ£©
Ê§Õæ£º0.1%£¨1kHz£¬²Î¿¼µçƽ£¬16 룩·¶Î§ÄÚ
0.05%£¨1kHz£¬²Î¿¼µçƽ£¬24±ÈÌØ£©·¶Î§ÄÚ
ÈßÓࣺ18/20dB ¿ÉÑ¡
·³ª×¨Çø
Cubase/Nuendo
MacÌÖÂÛÇø
¼ÒôÅ﹤³Ì
»áÔ±×÷Æ·
