O
ohm Å·Ä·£¨µç×èµÄµ¥Î»£©
Oboe Ë«»É¹Ü
O/C open circuit ¿ªÂ·
OCK operation control key ²Ù×÷¿ØÖƼü
OCL output capacitorless ÎÞÊä³öµçÈݹ¦ÂÊ·Å´óÆ÷
OCL output control line Êä³ö¿ØÖÆÏß
OCT octave ±¶Æµ³Ì£¬°Ë¶ÈÒô
OD operations directive ²Ù×÷ָʾ
OD optical density ¹âÃܶÈ
OD over drive ¹ý¼¤Àø
OFC office Ö°ÄÜ
OFC oxygen-free cupreous ÎÞÑõ͵¼Ïß
Off ¹Ø±Õ£¬¶Ï¿ª
Offering ÌîÈ룬Ìṩ
Offset £¨ÒÆÏࣩ²¹³¥£¬ÐÞÊΣ¬Æ«ÖÃ
OFHC oxygen free high conductivity copper
¸ßµ¼µçÂÊÎÞÑõ͵¼Ïß
Ohm Å·Ä·
OK È·ÈÏ
OL on line ÔÚÏߣ¬Á¬»ú
OL over load ¹ýÔØ
Omnidirectional ÎÞ·½ÏòÐÔµÄ
On ¿ª£¬½Óͨ
Once Ò»´Î£¬µ¥´Î
One-way relay play µ¥ÏòÌæ»»·ÅÒô
Online Áª»ú£¬ÁªÏß
Only ½ö½ö£¬Ö»
On-mike ÕýÔÚËÍ»°£¬¿¿½ü»°Í²
One touch µ¥´¥Á¬½Ó
OP output ÐźÅÊä³ö
OP over pressure ¹ýѹ
Open ´ò¿ª£¬¿ªÆô
Opera ¸è¾ç
Operate ²Ù×÷£¬ÔËת
Operation ²Ù×÷£¬ÔËת
Operator ²Ù×ÝÆ÷£¬ºÏ³ÉÆ÷Ëã×Ó
Optical ÊýÂë¹âÀ½ӿÚ
Optical master ¼¤¹âÆ÷
Option Ñ¡ÐÍ£¬Ñ¡Ôñ
Optimum ×î¼Ñ״̬
OPTOISO optoisolator ¹â¸ôÀëÆ÷
Or »ò£¬»òÕß
ORC optimum recording current ´ÅÍ·×î¼Ñ¼Ç¼µçÁ÷
Orchestra ¹ÜÏÒÀÖÆ÷
Organ ·çÇÙ£¬Ôª¼þ Original Ô£¨³ÌÐò£©£¬³õʼ£¨»¯£©
OSC oscillator Õñµ´Æ÷£¬ÊÔ»úÐźţ¨Ò»Ç§ºÕ×È£©
OSC oscillograph ʾ²¨Æ÷
OSS optimal stereo signal ×î¼ÑÁ¢ÌåÉùÐźÅ
OTL ÎÞÊä³ö±äѹÆ÷¹¦ÂÊ·Å´óÆ÷
OTR one-touch time recording µ¥´¥Ê½¶¨Ê±Â¼Ïñ
OTR operation temperature range ¹¤×÷ζȷ¶Î§
OTR overload time relay ¹ýÔØÏÞʱ¼ÌµçÆ÷
OUT output Êä³ö
Outage ÖжÏ
Out-burst Âö³å£¬ÉÁ¹â£¬ÉÁÁÁ
Outcome ½á¹û£¬Êä³ö£¬¿ªÊ¼
Out let Êä³ö¶Ë×Ó£¬Òý³öÏß
Outline ÂÖÀªÏß
Out phase ·´Ïò
OVDB ÖØµþ¼Òô
Overall ÂÖÀª£¬×ÜÌåÉÏ
Overcut ¹ýµ÷ÖÆ
Over drive ¹ý¼¤Àø
Overdubs µþ¼
Overflow ÐźŹýÇ¿
Overhang £¨¼¤ÀøÆ÷£©µÍÒôÑÓÉìµ÷½Ú
Overhearing ´®Òô
OVLD over lode ¹ýÔØ£¬³¬¸ººÉ
Over sampling ¹ýÈ¡Ñù
Overtone ·ºÒô
OVWR overwrite ¸²¸Çʽ¼Òô
P
Proximity effect ½ü¾àÀëЧ¹û
Prwsnt Í»³ö¸Ð
PS position λÖã¬×´Ì¬
PSC program switching center ½ÚÄ¿Çл»ÖÐÐÄ
PSL phase sequence logic Ïàλ˳ÐòÂß¼
PSM peak selector memory ·åֵѡÔñ´æ´¢Æ÷
PSM phase shifter module ÒÆÏàÄ£¼þ
PSM pitch shift modulation ½»Æµµ÷ÖÆ
PST posterrior ºóÃæ
PST preset Ô¤ÖÃ
PSU power supply ¹©µç
Psychological acoustics ÐÄÀíÉùѧ
PT power transformer µçÔ´±äѹÆ÷
PT portable ±ãЯʽ
PT pulse timer Âö³å¼ÆÊ±Æ÷
PTD pan turnout piece delay ÉùÏñ·ÖÖ§ÑÓʱ
PTE private רÓõÄ
PTN pattern ģʽ£¬Ñùʽ
PTN procedure turn ³ÌÐò±ä»¯
PU pickup ʰÒô
PU power unit µçÔ´É豸
Pull À£¬Ç÷Ïò
Pull-in ½Óͨ£¬ÒýÈë
Pumping ³éÆøÐ§Ó¦
Pure tone ´¿Òô
Purging ¾»»¯
Push ÍÆ£¬°´Å¥£¬Ñ¹
Push-pull ÍÆÍìʽµÄ
PWM pulse width modulation Âö³å¿í¶Èµ÷ÖÆ
PWR power µçÔ´£¬¹¦ÂÊ
PZM pressure zone microphone ѹÁ¦Çø»°Í²
P.P.Panoramic potentiometer È«¾°µçλÆ÷
P-P peak-Peak ·å-·åÖµ
PPD pingpong delay ƹÅÒÑÓʱ
PPG programme pulse generator Âö³å³ÌÐò·¢ÉúÆ÷
PPI peak program indicator ·åÖµÏÔʾÆ÷
PPI programmable peripheral interface ³ÌÐòÍⲿ½Ó¿Ú
PPL peak program level ·åÖµÒôÁ¿µçƽ
PPM peak program meter ·åÖµ½ÚÄ¿±í£¬·åÖµÒôÁ¿±í
PPM pulse phase modulation Âö³åÏàλµ÷ÖÆ
Pr power rate ¹¦ÂʱÈ
PR program register ³ÌÐò¼Ä´æÆ÷
PRC precision ¾«È·£¬¾«Ï¸£¬¾«ÃܶÈ
Pre ǰÖã¬Ô¤±¸£¬Ö®Ç°
Pre-delay Ô¤ÑÓ³Ù
Pre echoes Ô¤»ØÉù
Pre emphasis Ô¤¼ÓÖØ
PREAMP preamplifier ǰÖ÷ŴóÆ÷
Preselection Ԥѡ
Presence ÁÙ³¡Ð§¹û£¬ÏÖ³¡¸Ð
Present µ±Ç°ÈÕÆÚ£¬ÏÖʱ£¬¼´Ê±
Preserve ±£´æ£¬Î¬³Ö
Preset Ô¤Öã¬Ô¤µ÷
Press °´£¬Ñ¹
PREV ³ªÆ¬Ìø»ØÉÏÇú¼ü
Preview Ô¤ÑÝ
Previous Ïòǰ£¬Ç°Î»µÄ
Prime ͬ¶ÈÒô
PRM parameter ²ÎÁ¿
PRO professional רҵµÄ
Probe ´«¸ÐÆ÷
Process ´¦Àí£¬¼Ó¹¤
PROCR processor ´¦ÀíÆ÷
PROG program ³ÌÐò£¬»ù±¾ÒôÉ«
Program cartridge ³ÌÐòºÐʽ´æ´¢Æ÷
Program set indicator µçÄÔÑ¡Çú½ÚĿѡ¶¨Ö¸Ê¾
Prosody ÔÏÂÉ
Protect ±£»¤£¬·À»¤
Protocol ͨÐÅÐÒé
POSTF ºóÖã¨Íò·Ö£©
POT potentiometer µçλÆ÷£¬µçλ¼Æ
Potable ±ãЯµÄ£¬Ð¡Ð͵Ä
Power µçÔ´£¬¹¦ÂÊ
Power amplifier ¹¦ÂÊ·Å´óÆ÷
Power dump ÇжϵçÔ´
Power out ¹¦ÂÊÊä³ö
Piower supply µçÔ´¹©¸ø
PP peak power ·åÖµ¹¦ÂÊ
PP personal preference ¸öÈËÔ¤ÖÃ
P plug ²åÍ·
P positive Õý¼«
P pulse Âö³å
P power ¹¦ÂÊ
PA preamplifier ǰÖ÷ŴóÆ÷
PA public address À©Éù
Pace ²½ËÙ£¬¼¶Êý
Packed cell »ý²ãµç³Ø
Packing ͼÏñѹËõ
P-I-P picture in picture »Öл
PAD ¶¨ÖµË¥¼õ£¬Ë¥¼õÆ÷£¬£¨´ò»÷ÀÖ´ó°´¼üµÄ£©¹Äµæ
Padding ͳµ÷£¬Ê¹¡¡Æ½Ö±
Paddle ¿ª¹Ø£¬Ãŵç·
Page Ò»Ãæ£¬£¨´æ´¢Æ÷£©Ò³ÃæµØÖ·£¬Ñ°ÕÒ
Pair £¨Á¢ÌåÉù£©Åä¶Ô£¬±È½Ï
PAL phase alternation line ÖðÐе¹Ïà²ÊÉ«µçÊÓÖÆÊ½
PAM pulse amplitude modulation Âö·ùµ÷ÖÆ
PAM pole amplitude modulation ¼«µãµ÷·ù
Pan panorama ÉùÏñµ÷½Ú£¬¶¨Î»£¬È«¾°
Panel Ãæ°å£¬²Ù×ݰ壬ÅäµçÅÌ
Panotrope µç³ª»ú
Paper cone Ö½Åè
Parallel ²¢Áª£¬Æ½ºâ
PAR(PARAM) parameter ²ÎÊý£¬²ÎÁ¿£¬ÏµÊý
Parametric ²ÎÁ¿µÄ
Part Éù²¿Êý£¬²¿·Ö
Partial tone ·ÖÒô£¬·ºÒô
PAS public address system À©Éùϵͳ
PASC precision adaptive subband coding
¾«ÃÜ×ÔÊÊÓ¦·Ö¶Î±àÂë
Pass ͨ¹ý
Passive ±»¶¯£¬±»¶¯·ÖƵ£¬¹¦ÂÊ·ÖÆµ
Paste Õ³Ìù
PAT pattern Ä£·Â£¬Ðͺţ¬Í¼Æ×ÌØÐÔÇúÏß
Patch ÁÙʱ£¬²å½ÓÏߣ¬ÓÃÁ¬½ÓµçÀ²åÈë
Patch bay ÅäµçÅÌ
Patch board ²åÏß°å
Patching ÁÙʱ½ÓÏߣ¬²¹³¥
Patching cord system µ÷¶ÈÈûÉþϵͳ
Path ÐźÅͨ·
Pattern Ñùʽ£¬·½Ê½£¬Ñù°å
Pause ÔÝÍ££¬¼äЪ£¬Í£¶Ù
PB playback ²¥·Å£¬ÖØ·Å
PB push button °´Å¥¿ª¹Ø
PBASS proper bass active supply system
×î¼ÑµÍÒôÖØ·Åϵͳ
PBC play back control ÖØ·Å¿ØÖÆ£¬»Ø·Å¿ØÖÆ
PC perceptual coding ¸Ð¾õ±àÂë
PC program control ³ÌÐò¿ØÖÆ
PCB printed circuit board Ó¡Ë¢Ïß·°å
PCC phase correlation cardioid microphone
ÏàλÏà¹ØÐÄÐλ°Í²
PCM precision capacitor microphone ¾«ÃܵçÈÝ»°Í²
PCM pulse code modulation Âö³å±àÂëµ÷ÖÆ
PCM card ²¨ÐÎÀ©³ä¿¨£¨Ôö¼ÓÐÂÒôÉ«£©
PC-COC pure copper continuous casting Á¬ÐøÖýÔ촿͵¼Ïß
PD power divider ¹¦ÂÊ·ÖÅäÆ÷
PD power doubler ¹¦Âʱ¶ÔöÆ÷
PD program directive ³ÌÐòÖ¸Áî
PD pro-digital רҵÊý×Ö½Ó¿Ú
PD protective device ±£»¤×°ÖÃ
PDM pulse density modulation Âö³åÃܶȵ÷ÖÆ
PDP plasma display panel µÈÀë×ÓÏÔʾ°å
PDS partitioned data set ·ÖÇøÊý¾Ý×é
PDS programmable data system ³ÌÐò¿É¿ØÏµÍ³
PDS power distribution system Åäµçϵͳ
PE phase encoding Ïàλ±àÂë
PE program execution ³ÌÐòÖ´ÐÐ
Peak ·åÖµ£¬Ï÷²¨£¨µÆ£©
Peak and dip ·åʽƵÂÊÅ·ÖÞ±ê×¼21½ÅAV½Ó¿Ú
Pedal ̤°å
PEM pulse edge molulation Âö³å±ßÔµµ÷ÖÆ
Pentatonic ÎåÉùµ÷ʽ
PEQ parameter equalizer ²ÎÁ¿¾ùºâÆ÷
PERC percussion ´ò»÷ÀÖÆ÷
PERCUS ´ò»÷ÀÖÆ÷
Performance Ê©ÐУ¬±íÑÝ£¬±íÏÖ£¬Ñݳö
Permalloy head ÆÂĪºÏ½ð´ÅÍ·
Permutator ת»»¿ª¹Ø£¬±ä»»Æ÷
Perspective Á¢Ìå¸Ð
Perform Ö´ÐУ¬Íê³É£¬Ê©ÐÐ
Period ÖÜÆÚ
PFL per fader louder speaker Ë¥¼õǰ¼àÌý£¬Ô¤¼àÌý
PG pulse generator Âö³å·¢ÉúÆ÷
PGM program ½ÚÄ¿£¬³ÌÐò
Pgmno/Step ½ÚÄ¿ºÅÂë/²½Öè
Pgmtime ½ÚĿʱ¼ä
PH phase Ïàλ
PH phasemeter ÏàλÒÇ
PHA phase Ïàλ
Phantom »ÃÏñµçÔ´£¬»ÃÏ󹩵ç
Phase Ïàλ£¬×´Ì¬
Phase REV µ¹Ïࣨµç·£©
Phaser ÒÆÏàÆ÷
Phasing ÏàλУÕý£¬ÒÆÏàЧ¹û
Phon ·½£¨Ïì¶Èµ¥Î»£©
Phone ¶ú»ú£¬¶ú»ú²å¿Ú
Phoneme ÒôËØ
Phono(phonograph) ³ª»ú
PHS phaser ÒÆÏàÆ÷
Physiological acoustics ÉúÀíÉùѧ
PI phase inversion µ¹Ïà
PIA peripheral interface adapter ÍâΧ½Ó¿ÚÊÊÅäÆ÷
Pianotron µç×Ó¸ÖÇÙ
Piano ¸ÖÇÙ
Piano whine ¸ÖÇÙÃùÉù
Piccolo ¶ÌµÑ
Pick-up ʰÒôÆ÷£¬³ªÍ·£¬´«¸ÐÆ÷
Piezoelectric polymer earphone ѹµç¾ÛºÏÎï¶ú»ú
Pilot ָʾÆ÷£¬µ÷½ÚÆ÷
Pilot jack ¼àÌý²å¿×
Pin ÕëÐͲå¿Ú£¬²»Æ½ºâÒôƵ²å¿Ú
PIN position indercator λÖÃָʾÆ÷
PIN positive-intrinsic-negative Õý-±¾-¸º
Pinboard ת½Ó°å£¬²å½Ó°å
Ping ±¬ÃùÉù£¬ÉùÏì
Pink noise ·ÛºìÔëÉù
Pipe ¹Ü£¬µÑ
Pitch Òô¸ß£¬Òôµ÷
Pitch shifter ±äµ÷Æ÷£¬ÒÆÆµÆ÷
PK peak Ï÷²¨£¨µÆ£©£¬·åÖµ
PL parental lock ·ÀÖ¹Îó¶¯Ëø¶¨
PL phase lock ÏàÎ»Ëø¶¨£¬ËøÏà
PL pilot lamp ָʾµÆ
PL pre listen Ô¤¼àÌý£¬Ë¥¼õǰ¼àÌý
Place ÖÃÈ룬Æð×÷ÓÃ
Placement Á¬½Ó·½Ê½
Plate ½ðÊô°åЧ¹û£¬°å»ìÏìÆ÷
Play ²¥·Å£¬ÖØ·Å£¬µ¯×à
Playback ²¥·Å
Player ³ª»ú£¬·ÅÒôÆ÷
Plesoelectric supper tweeters ѹµçʽ³¬¸ßÒôÀ®°È
PLL phase locked loop ËøÏà»ØÂ·
PLR plate reverb ½ðÊô°å»ìÏì
Plug ²åÍ·
Plunge ÇÐÈë
PMPO peak music power output ÒôÀÖ·åÖµ¹¦ÂÊÊä³ö
PN pseudo noise Î±Ëæ»úÔëÉù
Pneumatic loudspeaker Æø¶¯ÑïÉùÆ÷
PNM pulse number modulation Âö³åÊýµ÷ÖÆ£¬Âö³åÃܶȵ÷ÖÆ
Point ½Óµã£¬Î»Ö㬽»»ãµã
Point soure µãÉùÔ´
Pointer ָʾÆ÷£¬Ö¸Õë
Polarity ¼«ÐÔ
Poly ¸´Òô£¬¶à·£¬¶à
Pop ͻȻ£¬±¬ÆÆÒô£¬£¨»°Í²½ü½²Ê±µÄ£©ÆøÏ¢àÛàÛÉù
Pop filter àÛÉùÂ˳ýÆ÷
Pops Á÷ÐÐÒôÀÖ£¬Á÷ÐÐÒôÀÖÒôÏìЧ¹û
Portamento »¬Òô
Ported reflex Ô¤·ÅÓ³
Position λÖã¬×´Ì¬
POSITVE positive Ñô¼«
Q
Q quality factor Æ·ÖÊÒòÊý£¬QÖµ£¬Æµ´ø¿í¶È
QD quadrant ÏóÏÞ
QD quick disconnect ѸËÙ¶Ï¿ª
Quack àÐÔÓÉù
QUAD quadriphonic ËÄÉùµÀÁ¢ÌåÉù
Quadrature Õý½»£¬90¶ÈÏàλ²î£¬¾«µ÷
Quality ÒôÖÊ£¬ÉùÒô
QUANT quantitative ¶¨Á¿µÄ
QUANT quantize Á¿»¯£¬Êý×Ö»¯
Quantizing Á¿»¯
Quartz synthesized FM/AM digital tuner
ʯӢ¾§Ì寵ÂʺϳÉʽµ÷Ƶ/µ÷·ùÊý×Öµ÷гÆ÷
Quartz PLL frequency synthesizer ¾§ÌåÏúÏ໷ƵÂÊ
Quaver °Ë·ÖÒô·û
Quench ¶Ï¿ª£¬ÒÖÖÆ
Quint Îå¶È£¬´ÎÈý±¶Òô
Quiver ²ü¶¯Éù
R
Ribbon microphone ÂÁ´ø»°Í²£¬Ñ¹Á¦´ø»°Í²
Richness ·áÂú¶È
Rhythm ½Ú×à
Right ÓÒÉùµÀ£¬´¹Ö±µÄ£¬Êʵ±µÄ
Ring »·£¬´óÈýо»·¶Ë£¬Àä¶Ë½Óµã£¬ÕñÁå
Ring mode Éù·´À¡ÁÙ½çÕñÁåÕñµ´ÏÖÏó
Rit ½¥Âý
RF radio frequency É䯵£¬¸ßƵ
RM regular matrix record Õý¹æ¾ØÕóʽËÄ·³ªÆ¬
RM ring modulation »·Ðε÷ÖÆÆ÷
RMD fing mode decoupling £¨ÒôÏ䣩ÕñÁåÍËñî¼¼Êõ
RMR room reverb ·¿¼ä»ìÏì
RMS random music sensor Ëæ»úÒôÀÖ̽²âÆ÷
Rms root mean square ÓÐЧֵ
RND random Ëæ»úµÄ
RNG ring ÕñÁå
Roadrack רҵÆ÷²Ä¼Ü
Rock Ò¡¹öÀÖ¡¢Ò¡¹öÀÖÒôÏìЧ¹û
Rod antenna À¸ËÌìÏß
RODS reverberation on demand system »ìÏìÇëÇóϵͳ
Rolloff ¸ßµÍƵ¹æÂÉÐÔË¥¼õ£¬¹ö½µ
ROM read only memory Ö»¶Á´æ´¢Æ÷
Room ·¿¼ä
Rose ½ÓÏߺÐ
Rotary Ðýת
RT60 Reverberation time »ìÏìʱ¼ä
Rough ´ÖµÄ£¬´Ö²ÚµÄ£¬½üËÆµÄ
Routing »ìºÏĸÏßÑ¡Ôñ
RP record playback ¼·Å
RP repeater ÔöÒôת·¢Æ÷
RPLC replace Ìæ»»
RSS Roland sound space processing system
ÂÞÀ¼Éù¿Õ¼ä´¦Àíϵͳ
RT rael time ʵʱ·ÖÎö
RT recovery time »Ö¸´Ê±¼ä
RT return ·µ»Ø
RTA real time analyzer ʵʱ·ÖÎö£¨ÒÇ£©£¬ÆµÆ×·ÖÎö£¨ÒÇ£©
RTS real time simulator ʵʱģÄâ
RTS real time system ʵʱϵͳ
RTY rotary Ðýת£¨ÑïÉùÆ÷£©
Rubber corrugated ri loudspeaker ÏðÆ¤±ßÑïÉùÆ÷
Ruby stylus ºì±¦Ê¯³ªÕë
Rumba Â×°Í
Rumble £¨µÍƵ£©Â¡Â¡Éù
RV rendezvous »á¾Ûµã
RVS reverse shift ·´ÏòÒÆ¶¯
RZ return to zero ¹éÁã
Reversal ·´Ï࣬Ïà·´£¬·´×ª£¬¸Ä±ä¼«ÐÔ
Reverse »Ø¸´£¬·×ª£¬·´»ìÏì
Revert ¸´Ô£¬·µ»Ø
Review ¼ì²é£¬¸´²é£¬Öظ´
Revolve Ðýת£¬Ñ»·
REW rewind ¿ìËÙµ¹´ø
RF reception fair ½ÓÊÕÇé¿öÁ¼ºÃ
RFI RF interface É䯵½Ó¿Ú
RFI RF interferece É䯵¸ÉÈÅ
Revcolor »ìÏìȾɫÉù
RPS direct program Ö±½Ó½ÚÄ¿ËÑѰ£¬¿¨ÀOKËÑË÷
R(RD)radio É䯵
R(RD)read ¶ÁÈ¡
R receiver ½ÓÊÕ»ú
R register ¼Ä´æÆ÷
R right ÓÒÉùµÀ
Rack »ú¼Ü£¬Ö§¼Ü£¬»ú¹ñ£¬¹æ¶¨¿í¶È£¬Õð¶¯Éù
Radiation ·øÉä
Radio ÎÞÏߵ磬µëÒô»ú£¬É䯵
Ram random access memory Ëæ»ú´æ´¢Æ÷
RAM ÌîÈ룬װÈë
RAN random Ëæ»úµÄ£¬ÈÎÒâµÄ£¬ÎÞ¹æÔòµÄ
Range ·¶Î§£¬×î´óÌáË¥Á¿£¬·ù¶È
Rate ±ÈÂÊ£¬ËÙÂÊ£¬±ä»¯ÂÊ£¬ÆµÂÊ
Ratio ѹËõ±È£¬À©Õ¹±È£¬±È£¬ÏµÊý
RCA radio corporation of America ÃÀ¹úÎÞÏߵ繫˾
RCA jack Á«»¨½Ó¿Ú
R-CH ÓÒÉùµÀ
R-DAT rotary head-DAT Ðýת´ÅͷʽÊý×Ö¼Òô»ú
RE rack earth Íâ¿Ç½ÓµØ
RE reset ¸´Î»
RE right end ÓÒ¶Ë
Reactance µç¿¹
Readjustment ÖØµ÷
Ready Ô¤±¸£¬×¼±¸Íê±Ï
Rear ±³Ã棬ºó²¿£¬ºóÖÃ
REC recording ¼Òô£¬¼Ç¼£¬Â¼ÖÆ
Recall Õлأ¬µ÷³ö£¬ÖØÂ¼
Receiver ½ÓÊÜ»ú£¬½ÓÊÜÆ÷
Recharge ÔÙ³äµç
Record ¼Ç¼£¬Â¼ÖÆ£¬³ªÆ¬
Recorder ¼Òô»ú
Recovery »Ö¸´£¬¸´Ô
Red ºìÉ«
Redo ÔÙÖ´ÐвÙ×÷
Reduce ¼õÉÙ£¬½µµÍ£¬ËõС
Reduction ѹËõ£¬Ë¥¼õ£¬ÐγÉ
Reecho »ØÉù
REF Reference ˵Ã÷Ê飬²Î¿¼£¬»ù×¼£¬¶¨Î»
REF Reflection ·´Éä
Refraction ÕÛÉä
Refresh »Ö¸´
REG register ¼Ä´æÆ÷
REG regulate ¿ØÖÆ£¬Ð£×¼£¬µ÷½Ú
REGEN regeneration ÔÙÉú£¨»ìÏìÉùÕóÐγɷ½Ê½£©£¬Õý·´À¡
Rehearsal ÅÅÁ·£¬Ô¤ÑÝ
Reject ³ýÈ¥£¬ÂËÈ¥
Rejection ÒÖÖÆ
Reinforcement À©Éù
Relay ¼ÌµçÆ÷£¬ÖØ·Å£¬×ª·Å
Release »Ö¸´Ê±¼ä£¬ÊÍ·Å£¬¶Ï·Æ÷
Rename ¸ÄÃû£¬ÃüÃû
Remain ±£³Ö£¬Ê£Óà
REM remote Ò£¿ØµÄ£¬Ò£Ô¶µÄ£¬Ô¶¾àÀëµÄ
REM removable ¿É²ð×°µÄ
REM remove ³ýÈ¥
Remain ÓàÁ¿£¬×´Ì¬±£³Ö
Renumber ÖØÐ´ºÅÂë
REP repeat ÖØ¸´£¬·´¸´£¬ÖØ·Å
Repeat mode Ë«Ãæ·´¸´·ÅÒô£¨Â¼Òô»ú£©
Replacing Ìæ»»£¬Öû»£¬¸´Î»
REQ room equalizer ·¿¼ä¾ùºâÆ÷
Reset ¸´Î»£¬»Ö¸´£¬¹éÁã£¬ÖØ¸´£¬ÖØÐ°²×°
Resolution ·Ö±æÂÊ£¬·ÖÎö
Resonance ¹²Õñ£¬»ØÉù
RESP response ÏìÓ¦£¬ÌØÐÔÇúÏߣ¬»Ø´ð
Resistance ×迹
Resister µç×è
Resonance ¹²Ãù£¬Ð³Õñ Rest ÐÝÖ¹·û£¬¾²Ö¹£¬Í£Ö¹
Restraint ÒÖÖÆ£¬ÏÞÖÆÆ÷
RET return ·µ»Ø£¬»ØËÍ
REV reverse µßµ¹£¬·´×ª
REV reverberation »ìÏ죬²ÐÏì
Reverb depth control »ìÏìÉî¶È¿ØÖÆ
RIAA recording industry association of America
ÃÀ¹ú¼Òô¹¤ÒµÐ»á
S
SAF Safety °²È«×°Ö㬱£ÏÕ×°Ö㬱£»¤×°ÖÃ
Safeguard by ·À»¤Æ÷
SALT symmetry air load technique ¶Ô³Æ¿ÕÆø¸ºÔؼ¼Êõ
Samba É£°Í
Sample ÉùÒôÐźÅÑùÆ·£¬²ÉÑù£¬È¡Ñù£¬³éÑù
Sampling ³éÑù£¬Âö³åµ÷ÖÆ
SAP second audio program µÚ¶þÌ×ÒôƵ½ÚÄ¿
SAT saturate ±¥ºÍЧ¹û´¦Àí
Save Öü´æ
Save ´æ´¢£¬±£´æ
Saxophoneb Èø¿Ë˾¹Ü
Saxophome ¶¥À¡Ö±ÏßÌìÏß
SC set clock ÖÃλʱÖÓ
SC sigmal control ÐźſØÖÆ
SC subcarrier ¸±Ôز¨
SC system controller ϵͳ¿ØÖÆÆ÷
SC scan ɨÃè
Scale Òô½×£¬¿Ì¶È³ß±ê
Scale unit ±ê¶Èµ¥Î»£¬·ÖƵÆ÷
Scan ËÑË÷£¬¼Ç¼£¬É¨Ãè
Scar ¼¤¹â³ªÆ¬ÉϵÄȱÏÝ SCART connector
Å·ÖÞ±ê×¼21½ÅAV½Ó¿Ú
Scattering É¢Éä
Scene ʵ¿ö£¬³¡Ãæ
SCH search ËÑË÷£¬Ñ°ÕÒ
Scheme Éè¼ÆÍ¼£¬ÔÀíͼ
SCMS serial copy management system ³ÉÌ׸´ÖƹÜÀíϵͳ
Screw ÂÝË¿¶¤
Scrollback »ØÕÒ
SCH stereochrous Á¢ÌåÉùºÏ³ª
Schmidt trigger Ê©ÃÜÌØ´¥·¢Æ÷
Scintillation ÉÁ˸£¬µ÷ÖÆÒýÆðµÄÔØÆµ±ä»¯
SCMS successive copy manage system
Á¬Ðø¸´ÖƹÜÀíϵͳ£¨DATÉ豸ÖзÀÖ¹¶à´Îת¼½ÚÄ¿µÄϵͳ£©
Scoop ìæ¶·£¬ÊÕ¼¯Æ÷
Scope ·¶Î§£¬ÏÔʾÆ÷
Scoring ÒôÀÖ¼Òô
SCR signal to clutter ratio ÐÅÔë±È
SCR silicon controlled rectifier ¾§Õ¢¹ÜÕûÁ÷Æ÷
Scraper ¹ÎÉùÆ÷
Screen ÆÁ±Î
SD space division ¿Õ¼ä·Ö²¼
S-DAT stationary head DAT ¹Ì¶¨´ÅÍ·DAT»ú
SDDS sony dynamic digital sound Ë÷Äᶯ̬Êý×Ö»·ÈÆÉùϵͳ
SDI standard data interface ±ê×¼Êý¾Ý½Ó¿Ú
SDLC synchronous data link control ͬ²½Êý¾ÝÁ´¿ØÖÆÆ÷
SE single end µ¥¶ËµÄ
SE sound effect ÒôÏìЧ¹û
SE storage element ´æ´¢Ôª¼þ
SE support equipment Ö§Ô®É豸
SEA soond effect amplifier ÒôÏìЧ¹û·Å´óÆ÷
SEA special effects amplifier ÌØÊâЧ¹û·Å´óÆ÷
Search ËÑË÷£¬É¨Ãè
Searcher ɨÃèÆ÷
SEC Second Ã룬µÚ¶þ
SECAM sequential color and memory µ÷ƵÐÐÂÖ»»²ÊÉ«ÖÆÊ½
Section µ¥Ôª£¬»·½Ú
Sectoral horm ÉÈÐκÅͲ
Security ±£ÏÕ£¬¼ÓËø
SED system effectiveness demonstration ϵͳЧ¹ûÑÝʾ
Seek ËÑË÷
SEL selector Ñ¡Ôñ×°Öã¬Ñ°Ï߯÷£¬×ª»»¿ª¹Ø
Select Ñ¡Ôñ
Selectivity £¨ÊÕÒô»ú£©Ñ¡ÔñÐÔ
Semi- °ë-
Semibreve È«Òô·û
Semioctave °ë¸ö°Ë¶ÈÒô
Semit °ëÒô
SEN sensor ´«¸ÐÆ÷
Send Ëͳö£¬·¢ËÍ£¬·¢Éä
SENS Sensitivity ÁéÃô¶È
Sense ·Ö±æÂÊ
Sensor ´«¸ÐÆ÷
Sentinel ·¢ÉäÆ÷£¬´«ËÍÆ÷
SEP standard electronic package ±ê×¼µç×Ó×é¼þ
SEP system engineering process ϵͳ¹¤³Ì´¦Àí
Separator ·ÖÀëÆ÷£¬·Ö½âÆ÷
Septieme Æß±¶Òô
SEQ sequencer ÒôÐòÆ÷£¬¶¨ÐòÆ÷
SEQ Stereo equalizer Á¢ÌåÉù¾ùºâÆ÷
Sequence ÅÅÐò£¬ÐòÁÐ
Series ϵÁУ¬´®Á¬
Service άÐÞ£¬·þÎñ
Servo ËÅ·þ»ú¹¹£¬Ëæ»úϵͳ
Servo motor ËÅ·þÂí´ï
SES spatial effect system Á¢ÌåÉù¿Õ¼äЧ¹ûϵͳ
Session ¸úËæ×Ô¶¯°é×à
Set µ÷Õû£¬É趨£¬×°Ö㬶¨Î»£¬½ÓÊÕ»ú
Setout ¿ªÊ¼£¬×¼±¸
Setup É趨£¬¹¹³É£¬²Ëµ¥£¬×éºÏ£¬µ÷Õû
SFC sound field composer Éù³¡ºÏ³É×°ÖÃ
SFL stereo flange Á¢ÌåÉù·¨À¼Ïâ±ß
SFS sound field synthesis Éù³¡ºÏ³É
SG signal generator Ðźŷ¢ÉúÆ÷
SGL signal ÐźÅ
S-hall small hall СÐÍÌüÌÃЧ¹û
Shake Õð¶¯
Shape ²¨ÐΣ¬ÂÖÀÈ
Shaper ÕûÐÎÆ÷£¬Âö³å³ÉÐÎ
Share drum С¾ü¹Ä
Sharpness ÇåÎú¶È£¬ÏÊÃ÷¶È£¬Èñ¶È
Shelving Â˳ý£¬Â˲¨´¦Àí
SHG sub harmonic generator ´Î£¨·Ö£©Ð³²¨·¢ÉúÆ÷
Shield ±£»¤£¬ÆÁ±Î
Shift ת»»£¬±äµ÷£¬ÒÆÆµ£¬Æ¯ÒÆ
Shock ³å»÷
Short ¶ÌµÄ
Short gate ¶ÌʱѡͨÃÅ£¨»ìÏìЧ¹û£©
Shower ָʾÆ÷£¬ÏÔʾÆ÷
SHUF Shuffle Ëæ»ú˳Ðò½ÚÄ¿²¥·Å
Shunt ·Ö·£¬²¢Áª
SHUTT shuttle ±äËÙËÑË÷£¬Íù¸´
SI sneak in µÈë
Sibilance ³ÝÒô£¬ßÐÒô
Sibilant ßÐÒô
Sibilation ßÐÒô£¬¸ßƵÉù»û±ä
SICS sound image control system ÉùÏñ¿ØÖÆÏµÍ³
Side ±ß£¬Ã棬²àÃæ£¬·½Ãæ
Side chain ÅÔÁ´
SIG signal ÉùÒôÐźÅ
Signature ÌØÕ÷£¬ÒôÀֵĵ÷ºÅ
SIF °éÒôÖÐÆµ
Silencer ¾²ÔëÆ÷
Silent ¾²Ôëµ÷г
Simple tone ´¿Òô
Simplex µ¥¹¤
Simulate Ä£ÄâµÄ
Simultaneous ͬ²½£¬ÁªÁ¢
SINAD signal to noise and distortion ratio
ÐźŶÔÔëÉùºÍÊ§Õæ±È
Sine wave ÕýÏÒ²¨
Single µ¥£¬µ¥´ÎµÄ£¬µ¥¶ÀµÄ£¬µ¥µú
SIP solo in place ¶À×àÈëλ
SIP standard information package ±ê×¼ÐÅÏ¢°ü
Siren ÐýµÑ
Size ³ß´ç
Skew control ŤÇúУÕý£¬ÁâÐÎÊ§ÕæÆ÷
Skip ÌøÔ¾£¬Ê¡ÂÔ
SL signal level ÐÅºÅµçÆ½
Slap ÅÄ´òЧ¹û
Slap back ɽ¹È»ØÉù
Slap reverb ɽ¹È»ìÏìЧ¹û
Slate Ô¤¶¨£¬±ê¼Ç£¬£¨Â¼Òôµ÷Òǫ̂£©±ê¼Ç¿ª¹Ø
Slave ´ÓÊôµÄ£¬´Ó»ú£¬´Ó¶¯µÄ
Sleep ˯Ãß¶¨Ê±¿ª¹Ø£¬¾²Ö¹
Sleeve(SLE) ½ÓµØµã£¬Ðä¶Ë£¬Ì×
Slew rate ˲̬ÂÊ
Sliding tone »¬Òô
Slope бÂÊ£¬ÆÂ¶È£¬¿çµ¼
Slow ÂýËÙ
SLP super long play ³¬³¤£¨Èý±¶£©Ê±¼ä²¥·Å
Sliding tone »¬Òô
SLS studio listen Ñݲ¥ÊÒ¼àÌý
SM sequential machine ʱÐò»ú SM signal meter ÐźÅÇ¿¶È¼Æ
SM storage mark ´æ´¢±êÖ¾
S/M speech/music ÓïÑÔ/ÒôÀÖ
S/N signal-to-noise radio ÐÅÔë±È
Small club С¾ãÀÖ²¿Ð§¹û
Smear ҷ⣬ÍÏ⣬»ë×Dz»Çå
Smear correction ÍÏβУÕý
SMF Standard MIDI File ±ê×¼
SMP sampler È¡ÑùÆ÷
SMPTE society of motion picture television engineers
£¨ÃÀ¹ú£©µçÓ°¼°µçÊÓ¹¤³Ìʦѧ»á
S/N signal/noise ÐźÅ/ÔëÉù£¬ÐÅÔë±È
SND sound ÉùÒô£¬ÒôÏ죬°éÒô
Snake ¼¯ÌåÏß
Snapshot Ƭ¶Î£¬³¡¾°×´Ì¬ÉèÖÃ
Snubber »º³åÆ÷£¬¼õÕðÆ÷
SO sneak out µ³ö
Socket ²å×ù£¬²å¿Ú
Soft ÈíµÄ£¬ÈáºÍµÄ
Soft click ÈáÐÔóéλ
Soft knee Èí¹Õµã£¨Ñ¹ÏÞÆ÷£©
Soft-touch Çᴥʽ
Software ¼ÆËã»úÈí¼þ
Solo ¶À³ª£¬¶À×à
Sone ËΣ¨Ïì¶Èµ¥Î»£©
Song ÀÖÇú
Sound colum ÉùÖù
Sound field Éù³¡
Sound image ÉùÏñ
Sound intensity ÉùÇ¿
Sound shadow region ÉùÓ°Çø
Sound cousole desk µ÷Òǫ̂
Source ÉùÔ´
SOS sound on sound µþ¼Ó¼Òô
SP speaker ÑïÉùÆ÷
SP speed ËÙ¶È
SP standard-play ±ê×¼×ß´øËٶȼ·Å
SPA stereo pan allochthonous Á¢ÌåÉùÉùÏñÆ¯ÒÆ
Space ¼ä϶£¬¿Õ¼äЧ¹û
Spaciousness ¿Õ¼ä¸Ð
ST stereo Á¢ÌåÉù£¬Á¢Ìå
STI speech transmission index ÓïÑÔ´«Êäϵͳ
Sticks ²Ù×÷¸Ë£¬°²Ö㬿¨×Ó
Still ¾²Ö¹
STM send test massage ·¢ËͲâÊÔÐźÅ
STO stand point λÖÃ
STO stereo Á¢ÌåÉù
STO stop ֹͣ
STO store ´æ´¢£¬´æ´¢Æ÷
STP shielded twisted pnir ÆÁ±ÎË«½ÊÏß
Strike note »÷ÏÒÒô£¬×²»÷Éù
String instrument ÏÒÀÖÆ÷
Strip жϸ½ÊôÉ豸£¬¹ìµÀ£¬Àà±ð
Strobe ѡͨÂö³å£¬ÆµÉÁ·Åµç¹Ü
Strong ÓÐÁ¦µÄ
Structure ×°Ö㬽ṹ
STU Studio Ñݲ¥ÊÒЧ¹û
SUB ¸±£¬¸¨Öú£¬¸½¼Ó£¬µÍÒô
Subgroup ¸±£¬£¨µ÷Òǫ̂µÄͨµÀ¼¯ÖпØÖÆÍøÂ磩±à×é
Suboctave ´Î°Ë¶È
Subsonic ´ÎÉù£¬³¬µÍÒô
Subwoofer ³¬µÍÒô
Sum ºÍ£¬×ܺͣ¬×ÜÊý
SUP Supply µçÔ´
Supper ³¬
Super bass ³¬µÍÒô
Super over drive ³¬¼¤Àø
Suppressor ÒÖÖÆÆ÷
Support programs Ö§Ô®³ÌÐò
SUR Surround »·ÈÆÉù£¬»·ÈÆ£¬°üΧ
Sustain ±£³Ö£¬Î¬³Ö
SVP surge voltage protector ÀËФµçѹ±£»¤Æ÷
SW signal wire ÐźÅÏß
SW S-Wite ÈûÌ×ÒýÏß
SW switch ¿ª¹Ø£¬Çл»
SW short wave ¶Ì²¨
S/W specification of wiring ²¼Ïß¹æ¸ñ
Swap ½»»»£¬µ÷¶¯£¨µÈÁ¿Æë¹Û£©£¬µ÷»»
Sweep ɨÃ裬ÇúÏß
Swell ÔöÒôÆ÷
Swing °Ú·ù£¬Ò¡°ÚÎè
Swishing ì¬ì¬Éù
SX simplex µ¥¹¤
SXE stereo exciter Á¢ÌåÉù¼¤ÀøÆ÷
Symphobass µ÷гµÍÒôϵͳ
Symphonic ½»Ï죬гÒô
SYS Ex system expanding ϵͳÀ©Õ¹
SPD speed µ÷ÖÆËÙ¶È
SPDIF sony/philips digital interface Ë÷Äá/·ÉÀûÆÖÊý×Ö½Ó¿Ú
SPE speaker ÑïÉùÆ÷£¬ÒôÏä
Special ÁÙʱ£¨×°Öã©£¬ÌØÉèµÄ
Specificatin ÐÔÄÜ
Spectrum ÒôÓò£¬ÆµÆ×
Speech ÓïÑÔ£¬ÓïÒô
Speed ËÙ¶È£¬µ÷ÖÆËÙ¶È
Speed select £¨Â¼Òô»ú£©´øËÙÑ¡Ôñ
SPG severo pulse generator ËÅ·þÂö³å·¢ÉúÆ÷
SPH single phase µ¥Ïà
SPL sound pressure level Éùѹ¼¶
Split ·Ö¸î£¬·ÖÅ䣬µÈÐźÅÇø
SPM spiral modulation ÂÝÐýµ÷ÖÆ
Spot effects ÏÖ³¡Ð§¹û
Spring µ¯»ÉЧ¹û£¬µ¯»É»ìÏìÆ÷
SPS stereo pitch shift Á¢ÌåÉù±äµ÷
SPSS self program search system ×Ô¶¯½ÚÄ¿ËÑË÷ϵͳ
Sport Ô˶¯³¡Ð§¹û
SQ squelch ¾²Ô룬ÔëÉùÒÖÖÆ£¨µç·£©
SQ stereo quadraphonic record ËÄÉùµÀÁ¢ÌåÉù³ªÆ¬
Square ¹ã³¡ÒôÏìЧ¹û
Squawker ÖÐÒôÑïÉùÆ÷
Squeal Ð¥½Ð
Squegger ¼äЪÕñµ´Æ÷
Squib drivers µç±¬¼¤ÀøÆ÷
SR Ò£¿Ø²Ù×÷
SR speed ratio ת»»ËÙÂÊ
SR stabilizeation receiver Îȶ¨½ÓÊÕ»ú
SRL standard recording level ±ê׼¼Òôµçƽ
SRS sound retrieval system ÉùÒô¹éÕæ£¨»Ö¸´£©ÏµÍ³£¬ÊÇÒ»ÖÖÀûÓÃË«ÉùµÀ²úÉú»·ÈÆÉù³¡µÄÐéÄâ»·ÈÆÉù·½Ê½¡£
SS starting -point sensor £¨´Å´ø£©Ê¼¶Ë¸ÐÓ¦Æ÷
SS switch selector ¿ª¹ØÑ¡ÔñÆ÷
SSG synchronizing signal generator ͬ²½Ðźŷ¢ÉúÆ÷£¬Í¬²½»ú¡£
SSLSC solid state logic studio computer
¹Ì̬Â߼¼ÒôÊÒ¼ÆËã»úϵͳ
ST sawtooth ¾â³Ý²¨
ST start Æô¶¯£¬¿ªÊ¼
ST status ״̬£¬×´¿ö
ST stereo Á¢ÌåÉù
ST store ´æ´¢
Stability ƽºâ£¬Îȶ¨ÐÔ
Stacking Õ¼¿ÕϵÊý
Stadium ¶ÌìÌåÓý³¡Ð§¹û
Stage Îę̀Ч¹û£¬¼¶£¬½×¶Î
Stand-by µÈ´ý£¬×¼±¸£¬±¸ÓÃ
Standard ±ê×¼£¬ÖÆÊ½£¬¹æ¸ñ
Standing wave פ²¨
Star ÐÇ£¬ÐÇÐΣ¬ÐǺÅ
Start Æô¶¯£¬¿ªÊ¼£¬Ê¼¶Ë
Start Id Æðʼʶ±ð
Static doubling ¾²Ì¬Ë«Éù
Station ²Ù×÷̨
Status ״̬£¬×´¿ö
ST-BY standey ×¼±¸
STD standard ±ê×¼£¬¹æ¸ñ
STD stereo delay Á¢ÌåÉùÑÓʱ
Step ²½Ö裬¼¶£¬µµ£¬½×ÌÝ£¬²½½ø
Step back ºóÍË
Steer ²Ù×Ý£¬¿ØÖÆ
Symphony ½»ÏìÀÖ£¬½»ÏìÀÖЧ¹û
SYN(SYNC)synchronism ͬ²½
SYN synthesizer ºÏ³ÉÆ÷
SYNC synchronizer ͬ²½Æ÷
Sychro ͬ²½»ú
Synth ºÏ³É
Synthesis ºÏ³É£¬×ÛºÏ
SYS system ϵͳ£¬ÖÆÊ½
SYS Ex system exchange ϵͳ½»»»
T
TRIG trigger ´¥·¢£¬´¥·¢Æ÷£¬´¥·¢Âö³å
Trim µ÷Õû£¬Î¢µ÷£¬µ÷г£¬Ï÷²¨
TRK track Òô¹ì
TRK trunk ×ÜÏߣ¬Ä¸Ïߣ¬¸ÉÏß
Trouble ¹ÊÕÏ
Trumpet СºÅ
TRS time reference system ʱ¼ä»ù׼ϵͳ
TST test ²âÊÔ
TTY teleltypewriter Ò£¿Ø´òÓ¡»ú£¬µç´«»ú
Tube µç×ӹܣ¬Õæ¿Õ¹Ü
Tune µ÷г£¬ºÍг£¬µ÷Òô
Tuner µ÷гÆ÷
Tunetable £¨³ªÅ̵ģ©×ªÅÌ
Tunnel reverb ËíµÀ»ìÏìЧ¹û
Tupe ´¦Àíģʽ
Turbo distortion ÎÐÂÖÊ§ÕæÐ§¹û
Turntable µç³ªÅÌ£¬×ªÌ¨
TV television µçÊÓ
Tweeter ¸ßÒôÑïÉùÆ÷¡¤
Twin channel ˫ͨµÀ
Two complement ²¹Âë
Two way mode Ë«ÃæÂÖÁ÷·ÅÒôģʽ£¨Â¼Òô»ú£©
TX transmit ·¢ËÍ£¬·¢Éä
TX transmitter ·¢Éä»ú
TYP trpe ÀàÐÍ
Typical ±ê×¼µÄ£¬µäÐ͵Ä
TRIG trigger ´¥·¢´¥·¢Æ÷£¬´¥·¢Âö³å
TRK track Òô¹ì
Trouble ¹ÊÕÏ
Trumpet СºÅ
TST test ²âÊÔ
TTY teletypewriter Ò£¿Ø´òÓ¡»ú£¬µç´«»ú
Tube µç×ӹܣ¬Õæ¿Õ¹Ü
Tune µ÷г£¬ºÍг£¬µ÷Òô
Tuner µ÷гÆ÷
Tupe ´¦Àíģʽ
TV television µçÊÓ
Tweeter ¸ßÒôÑïÉùÆ÷
Twin channel ˫ͨµÀ
Two complement ²¹Âë
TYP type ÀàÐÍ
T talk ºô½Ð£¬ÁªÂç
Tab ·ÀÎóĨµ²Æ¬
TACH tachometer ²âËÙÆ÷
TADI time assigument digital tnterpolation
ʱ·ÖÊý¾Ý²å¿Õ£¨¼¼Êõ£©
Tag µçÀ²åÍ·
Take ʵ¼
Takeoff È¡³ö
Takeover »Ö¸´£¬»°ÒôµþÈ룬ÉÌÒé
Talkback ¶Ô½²£¬ÁªÂç
Tally ²¥³ö£¬Ìáʾ£¬²åÈë
Tap µçÁ÷Êä³ö£¬½ÚÅÄ
Tape ´ø£¬´Å´ø
Tango ̽¸ê
TB talkback ¶Ô½²»ØËÍ
TB terminal board ½ÓÏß¶Ë×Ó×Ó°å
TB time base ʱ»ù
TBC time base corrector ʱ»ùУÕýÆ÷
TBK tallback ¶Ô½²
TC telecine µçÓ°µçÊÓ»ú
TC time code ʱ¼äÂë
TC transmitter-tunning circuit ·¢Éä»úµ÷гµç·
TC trim coil ΢µ÷ÏßȦ
TCC tripl concentric cable ÈýоͬÖáµçÀÂ
TDE time domain equalizer ʱÓòµÈ»¯Æ÷
TECH technique ¼¼Êõ£¬¼¼ÄÜ£¬¼¼ÇÉ
TED television disk µçÊÓ³ªÆ¬
TEL telescopic À¸ËÌìÏß
TEMP temperature ζÈ
Temp ½Ú×à
TEMOP temporary Öм䣨¹¤×÷£©µ¥Ôª
TEMPO Tempo ½Ú×࣬Á¬½Ó£¬ËÙ¶È
Terminal ÖÕ¶Ë£¬½ÓÏßÖù£¬ÒýÏߣ¬½ÓÍ·
Tentelometer ÕÅÁ¦±í
TER termination ÖÕ¶Ë
Test ²âÊÔ£¬ÊÔÑ飬¼ìÑé
THD total harmonic distortion ×Üг²¨Ê§Õæ
Theater ¾ç³¡Ð§¹û£¬ÏÖ³¡
Thermal noise ÈÈÔëÉù
Thick ÉòÖØ£¬ºñÖØ¶È
Thin µ¥±¡ÉùÒô
Thinness ±¡£¨´ò»÷ÀÖ£©
THR THRESH threshold ãÐÖµ£¬ãУ¬ÃÅÏÞ
Thresh thrash ¶à´Î·´¸´
Three dimension 3DÒôÏ죬ÈýάÁ¢ÌåÉùÒôÏìϵͳ
Throat ¸ßÒôºÅ½ÇµÄºí
THRU through ͨ¹ý£¬¹ýÇÅ£¬Ö±½ÓתËÍ
Trump ¼ü»÷ÔëÉù£¬µÍƵÔëÉù£¬¿ª»úÅéÉù
Thrust ²åÈ룬ǿÐмÓÈë
THX tom holman"s eXpriment ÌÀ¡¤»ô¶ûÂüʵÑ飬¼ÒÍ¥Ó°Ôº
TI temperatun indicator ζÈָʾÆ÷
TIE terminal interface exchange Öն˽ӿڽ»»»
Tie Á¬½Ó·ûºÅ£¬À¡Ïߣ¬Í¨ÐÅ
Tierce µÚÈýÒô£¬Îå±¶Òô
Tight Ó²£¬½ô£¬Ó²ÀÊ
TIM transient intermodulation ˲̬»¥µ÷Ê§Õæ
Timber ÒôÖÊ£¬ÒôÉ«
Timbre Éù²¿
Time ʱ¼ä£¬±¶£¬´Î£¬¶¨Ê±µÄ
Timer ¶¨Ê±Æ÷£¬¼ÆÊ±Æ÷
Tininess µ¥±¡
Tint É«µ÷
TIP terminal interface processor Öն˽ӿڴ¦Àí»ú
Tip Í·¶Ë£¬ÈȶË
Title ±êÌ⣬×ÖÄ»
TK track Òô¹ì
TL track loss ¹ì¼£¶ªÊ§
TLE trunk line equipment ¸ÉÏßÉ豸
TM trade mark ×¢²áÉ̱ê
TMS transmission mesurement set µçƽ±í
TMT transmit ·¢ËÍ
TN tuning unit µ÷гװÖÃ
TOC ½ÚĿĿ¼
Tone Òôµ÷£¬Éùµ÷£¬´¿Òô
Tone burst â§·¢Òô
Tone color ÒôÉ«
Tone quality ÒôÉ«£¬ÒôÆ·
Tonic ÂÉÒô
Top ×î¸ß
TOS tape operating system ´Å´ø²Ù×÷ϵͳ
Total ×Ü£¬×ܹ²
Total tune ÕûÌåе÷£¬×ܵ÷г
Touch ´¥£¬Ñ¹£¬°´
Touch sens ¼üÅÌÀÖÆ÷Ö¸´¥µÄ´¥¸Ð
TPD turnout piece delay ·ÖÖ§ÑÓʱ
TR tape recorder ´Å´øÂ¼Òô»ú
TR telerecording µçÊÓÆÁϼÏñ
TR tracking ¸ú×Ù
TR transfer ´«Êä£¬×ªÒÆ
TR trick ÌØ¼¼Ð§¹û
Track ÇúÄ¿ºÅ£¬´Å¼££¬Òô¹ì
Tracking Ѱ¼££¬¸ú×Ù£¬Í³µ÷
Tracking monitor µ÷У¼àÌý
Trad Ïݲ¨Æ÷£¬´ø×èÂ˲¨Æ÷
Tramp ÈýͨµÀ¹¦·Åϵͳ
Transfer תӡ£¬×ª½Ó
Transformer ±äѹÆ÷
Transpose תµ÷£¬±ä»»Æ÷£¬ÒƵ÷
Transport ÔËÐУ¬·¢ËÍ
Transient ˲̬
Transient distortion Ë²Ì¬Ê§Õæ
Transient response ˲̬·´Ó¦
Transmit ·¢Éä
Transistor ¾§Ìå¹Ü£¬Èý¼«¹Ü
Transponder תµ÷Æ÷£¬±ä»»Æ÷
Transposer ±äµ÷Æ÷
Transversal equalizers ºáÏò¾ùºâÆ÷
Treble ¸ßÒô£¬Èý±¶µÄ£¬ÈýÖØµÄ
Tremold tremor ²üÒô
Tremolo ÕðÒô
Tremor ²üÒô£¬ÕñÒô×°ÖÃ
Triamp Èý·µç×Ó·ÖÒô
Trick ÌØ¼¼
Trig ÐÞÊÎ Spatializer Éù³¡¶¨Î»¼¼Êõ
U
UHF ultra high requency ³¬¸ßƵ
UL upper limit ÉÏÏÞ
UL user hanguage Óû§ÓïÑÔ
ULD unit logic device ×éÖ¯Âß¼×°ÖÃ
ULF ultra-low frequency ³¬µÍƵ
UNBAL Unbalance ·Çƽºâ£¨Á¬½Ó£©£¬²»Æ½ºâ¶È
Undo ²»Ö´ÐвÙ×÷
Unit µ¥Î»
Uni-directinoal microphone µ¥·½ÏòÐÔ»°Í²
Uniform quantizer ¾ùÔÈÁ¿»¯Æ÷
Unlocked δÉÏËø£¬²»Í¬²½£¬²»Ëø¶¨
Unlson гÒô£¬µ÷ºÍ
Unpitched sound ÔëÉù£¬ÎÞµ÷Éù
Unscramble ÇåÀí£¬Ê¹¡¤¡¤¡¤ÇåÎú
UHF ultra high frequency ³¬¸ßƵ
UL upper limit ÉÏÏÞ
UL user language Óû§ÓïÑÔ
Undo ²»Ö´ÐвÙ×÷
Unit µ¥Î»
Unlson гÒô£¬µ÷ºÍ
Unscramble ÇåÀí£¬Ê¹¡ÇåÎú
Unset ¸´Î»£¬¸´Ô£¬Ïû³ý
UP ultra pass ¸ßͨ
UP ultraportable ³¬±ãЯʽ
Up ÏòÉÏ£¬Ôö¼Ó
Update ÐÞÕý£¬Ð£Õý
UPO ²»Ê§Õ湦ÂÊÊä³ö
Upper Éý¸ß£¬ÏòÉÏ
Uppercase ´óдµÄ£¬Óôóд×ÖĸÅÅÓ¡
UPS uniterruptable power output ²»¼ä¶ÏµçÔ´
Up to date ×îÐÂʽµÄ
User Óû§
USS United States Standard ÃÀ¹ú±ê×¼
UTIL utility ʵЧ£¬ÊµÓã¬Ó¦ÓÃ
Utility edit/compare ¹¦Äܼô¼/±È½Ï
UTP unshielded twisted pair δÆÁ±ÎË«½ÊÏß
V
VOL volume ÒôÁ¿£¬Ìå»ý£¬Æ¬ºÅ£¬Ïì¶È
VOS voice operated switch Éù¿Ø¿ª¹Ø
VOX voice operated switching device ÉùÒô¿ØÖÆÇл»×°ÖÃ
VOX voice iperated transmitter Òô¿Ø´«Êä×°ÖÃ
VOX voice test ÓïÑÔ²âÊÔÐźÅ
Vox £¨À¶¡ÓÉùÒô
Vowel ÔªÒô
VPS video phase setter ÊÓÆµÏàλµ÷½ÚÆ÷
VPS video program system ÊÓÆµÑÝ·Åϵͳ
VR variable resistor µçλÆ÷£¬¿É±äµç×èÆ÷
VRA variable response amplifier ¿Éµ÷ÏìÓ¦·Å´óÆ÷
VRR visual radio range ÊÓÆµÎÞÏߵ粨¶Î
VSR vital slave reels ÐéÄâ´ÓÊô¾í£¨Ó²Å̼Òô»ú£©
VSS virtual surround system ÐéÄâ»·ÈÆÉùϵͳ
Vth threshold voltage ãÐÖµµçƽ
VU volume unit ÒôÁ¿µ¥Î»±í£¬ VU±í
V value ÊýÖµ£¬Òô³¤
VA volt ampere ·ü°²
VA volt ammerter ·ü°²±í
Variation ±ä»¯£¬²ÎÊýµ÷½Ú£¬±ä×à
Variable ¿É±äÁ¿
VC vocal cancel Ô¸èÉùÏû³ý
VCA voltage control Amplifier ѹ¿ØÔöÒæ·Å´óÆ÷
VCD video compact disk ÊÓÆµ¼¤¹â³ªÆ¬
VCF video controlled filter µçѹ¿ØÖÆÂ˲¨Æ÷
VCO voltage controlled oscillator µçѹ¿ØÖÆÕñµ´Æ÷
VCR video cassette recorder ¼Ïñ»ú
VDA ÒôÉ«ÒôÁ¿
VDA variable digital amplifier ¿É±äÊý×ÖʽÂ˲¨Æ÷
VDF ÒôÉ«ÁÁ¶È
VDP ¼¤¹âÓ°µú»ú
VDU video display unit ÊÓÆµÏÔʾÆ÷
VELO velocity ËÙ¶È£¬Á¦¶È
Vent ͨ·£¬³ö¿Ú
VERB reverberate »ìÏì
Verify ¼ìÑ飬ºË¶Ô
Verisimilar ±ÆÕæµÄ
Vertical ´¹Ö±
VF video frequency ÊÓÆµ
VFX voice effects ÓïÒôÌØ¼¼Ð§¹û
VFD vacuum fluorescent display Õæ¿ÕÓ«¹âÏÔʾ
VGA variable gain amplifier ¿É±äÔöÒæ·Å´óÆ÷
VHD video high density system ÊÓÆµ¸ßÃܶÈϵͳ
VHF very high frequency Éõ¸ßƵ
VI volume indicator ÒôÁ¿Ö¸Ê¾Æ÷
Via ¾Çú£¬½èÖúÓÚ
VIB Vibrato ²üÒô
Vibration Õñ¶¯
VID video ÊÓÆµµÄ
VID virtual image display ÕæÊµÍ¼Ïñ
Video ÊÓÆµ£¬Í¼Ïñ£¬µçÊÓµÄ
Videodisc ÊÓÆµ³ªÆ¬
View ×ÜÀ£¬Ö¸Ê¾£¬¹Û²ì
Village Gatage СÒôÀÖÌüЧ¹û
Violin СÌáÇÙ
VIP variable information processing ¿É±äÐÅÏ¢´¦ÀíÆ÷
VIP versatile information processor ¶àÖÖÐÅÏ¢´¦ÀíÆ÷
VIP visual image processor ÊÓÆµÍ¼Ïñ´¦ÀíÆ÷
VIP visual input ÊÓÆµÊäÈë
VIR virtual image ÐéÏñ
Vision Ó°Ïñ
Vision cable µçÊÓµçÀÂ
VLF very low frequency ³¬µÍƵ
VLS virtual listening system ÐéÄâÌýÒôϵͳ
VMT voltage mate technlolgy µçѹƥÅä¼¼Êõ
VO vertical output ´¹Ö±Êä³ö£¬Ö¡É¨ÃèÊä³ö
VO voice ÓïÑÔ£¬ÒôƵ
VOC vocoder ÉùÂëÆ÷£¬ÓïÒô±àÂëÆ÷
Vocal ÉùÒôµÄ£¬ÉùÀֵ쬷¢ÒôµÄ
Vocal partner Éù»ìºÏ£¬°éÒô
Vibration Õñ¶¯
VODER voice operation demonstrator ÓïÒôºÏ³ÉÆ÷
Voice ÓïÑÔ£¬ÈËÉù£¬ÒôƵ
Voicing Éù²¿£¬£¨¸ÖÇÙ£©ÇÙ¼ü´¥¸ÐÓ²¶ÈÒ»ÖÂÐÔµ÷Õû
Voice over Éù¹ýÂË
VOL voltage µçѹ
VTR video tape recorder ´Å´øÂ¼Ïñ»ú
VTS video tape splicer ¼Ïñ¼ô¼»ú
W
W watt ÍßÌØ£¬ÍßW£¨WR£©
write дÈë
Walk-man ÐäÕäºÐʽ·ÅÒô»ú£¬ËæÉíÌý£¨Ë׳ƣ©
Wall Ç½ÃæÎüÉùÌØÐÔ
WalFin Ç½ÃæÎ¢µ÷
Waltz »ª¶û×ÈÔ²ÎèÇú
Warble tone ßùÉù
Wargin ÓàÁ¿Ö¸Ê¾
Warm ÎÂůµÄ£¬·áÂúµÄ
Warm ¾¯¸æ£¬Ê¾¾¯
Watcher ָʾµÆ£¬¼àÊÓÆ÷
Wave ²¨
Waveguide ²¨µ¼
Wavelength ²¨³¤
Way ·£¬Æµ¶Î
WB wideband ¿íƵ´ø
WB work bench ¹¤×÷̨
WBT wide band transmission ¿íƵ´ø´«Êä
WE weighting ¼ÆÈ¨£¬¼ÓȨ
Weak ÈõµÄ
Weight ÖØÁ¿
Wheel µ÷½ÚÐýÂÖ
Wet ʪ£¬Ð§¹ûÉùÐźţ¬Î´¼Ó¹¤µÄ
WF Waveform ²¨ÐÎ
Whispern ɳɳÉù
Whistle Ð¥½ÐÉù£¬ÉÚÉù
White °×É«
White noise °×ÔëÉù
Whole ÍêÕûµÄ
Wide ¿í¹ã£¬¿íÀ«
Wideband ¿í´ø£¬¿íƵ´ø
Widening À©Õ¹£¬¼Ó¿í
Wow ¶¶»Î£¬µÍƵ²ü¶¯
Wow/flutter ¶¶»ÎÂÊ
WS working storage ÔÝ´æÆ÷
Woofer µÍÒôÒôÏä
X
X cross ɾ³ý£¬½»²æ
X exchange ½»»»
X exterior À©Õ¹
X extra ¸½¼Ó£¬±¸ÓÃÆ·
X-bass µÍÒôÀ©Õ¹
XBS extra bass system ÖØµÍÒôϵͳ
XFER transfer ×ªÒÆ
X-FMR,X-FORMER ±äѹÆ÷
XIC transmission interface converter ´«Êä½Ó¿Úת»»Æ÷
XIR extreme infrared Ô¶ºìÍâÏß
XLR ¿¨Ù¯½Ó¿Ú
XMIT transmit ´«Ê䣬·¢ËÍ
XPLN explansonder ½âÊÍ£¬ËµÃ÷
XPNDR transponder ת·¢Æ÷£¬Ó¦´ðÆ÷
X pose ³ýα
XT XTALK cross talk ´®Òô£¬´®ÈÅ
XVTR transverter ±ä»»Æ÷
WidFin ˮƽ΢µ÷
Width ÃܶÈ
Wind ¿ì½ø
window ´°£¬´°¿Ú
Wiping head Ïû´ÅÍ·
Wire µ¼Ïߣ¬Ïß
Wired ÓÐÏߵģ¬ÓÐÏß´«Êä
Wireless ÎÞÏßµçµÄ£¬ÎÞÏßµÄ
Wireless mic ÎÞÏß»°Í²
Wiring ÅäÏߣ¬×°ÉèÏß·
With ÄæÏò£¬Ïà¶Ô
Write дÈ룬´æÈë
WRMS weighted root mean square ¼ÓȨ¾ù·½¸ùÖµ
Wtd weighted ¼ÓȨ
WORM write once read mang Ò»´ÎдÈëÐ͹âÅÌ
Wole Tone ²»ÐºÍµ÷ |
