izotope neutron advanced 3ÖÇÄÜ»ìÒô²å¼þ
תÌû
Neutron 3 Ö¼ÔÚ½«ÄúµÄ»ìÒô¹¤×÷Á÷³Ì´øÈë 21 ÊÀ¼Í¡£ÏÖÔÚÓÐÁË Mix Assistant£¬Neutron 3 ÊÇÓÐÊ·ÒÔÀ´µÚÒ»¸ö²å¼þ£¬Ëü¿ÉÒÔñöÌýÄúµÄÕû¸ö»á»°ÒÔ½¨ÒéÕûÌå¼¶±ðµÄ»ìÒôÒÔÕýÈ·Æô¶¯¡£ÔÚÒ»¸öĸ½¢²å¼þÖÐʹÓà 8 ¸öÄ£¿é»¯»ìÒô¹¤¾ß£¬ÕâÊÇΪÄúµÄ»ìÒô´øÀ´ÎÞÓëÂױȵÄÖÊÁ¿ºÍËٶȵÄ×î¼òµ¥¡¢×îÖÇÄܵķ½Ê½¡£Ê¹Óà ¸ú×ÙÖúÊÖ Îªµ¥¸ö¹ìµÀʹÓûúÆ÷ѧϰ´´½¨×Ô¶¨ÒåÔ¤É裬ʹÓõØÇòÉÏ×îÖÇÄÜµÄ EQ ÔÚÄúµÄ»á»°Öпç²å¼þ½øÐÐͨÐÅ£¬Ê¹Óà Sculptor ½«ÄúµÄÒôƵÍäÇúºÍËÜÔì³ÉÈκÎÀÖÆ÷ÅäÖÃÎļþ£¬²¢Ê¹ÓÃ×îÖÇÄÜµÄ Masking Meter£¬ÈÃÄú»ñµÃ±ÈÒÔÍù¸üºÃ¡¢¸ü¿ìµÄ»ìÒô¡£
Neutron 3 is designed to bring your mix workflows into the 21st century. Now with Mix Assistant, Neutron 3 is the first-ever plug-in that listens to your entire session to suggest an overall level mix to kick things off right. With 8 modular mixing tools in one mothership plug-in, it¡¯s the easiest, most intelligent way to bring unrivaled quality and speed to your mix. Create custom presets using machine learning for individual tracks with Track Assistant, communicate across plug-ins in your session with the smartest EQs on the planet, bend and shape your audio to any instrument profile with Sculptor, and automatically find and fix masking issues with the most intelligent Masking Meter that gets you to a mix that sounds better than ever, faster than ever.
ÆÀÂÛÁÐ±í£¨1£©
2005-7-23 19:43:00 »Ø¸´
