µ¤ÄÃ|Dynaudio BM12 mkIII ½ü³¡¼àÌýÒôÏä
BM12 mkIIIÌáÉýÁ˾µäµÄBM12AµÄ´«Í³Éè¼Æ¡£ÐµÄÒôȦÉè¼ÆÅäºÏµ¤ÄÃÐÂÒ»´úµÄ²¨µ¼¼¼Êõ£¬BM12mkIIIÅäºÏ´¿ÊÖ¹¤Çý¶¯µ¥ÔªÉè¼Æ£¬ÌṩÁ˾«×¼µÄ˲̬ÏìÓ¦ºÍ123dBµÄ´óÉùѹ¼¶Êä³ö¡£
Dynaudio BM12 mkIIIÖ÷ÒªÌØµã£º
ÔöÇ¿µÄ8´çµÍÒôµ¥Ôª£¬´¿ÂÁÒôȦ
1.1´çÈíÇ󶥸ßÒôµ¥Ôª£¬´¿ÂÁÒôȦ
100WµÍƵºÍ50W¸ßƵ£¬ABÀ๦·Å
ÅäºÏIsoAuoustics ISO-L8R200¼àÌýÒôÏäÖ§¼Ü£¬ÈÃÄúÁé»îµÄµ÷½Úµ½Î»ÖÃ
Ñ¡¹ºµÄTC Electronic Level Pilot»òÕßBMC-2£¬ÈÃÄú¿ÉÒÔ¾«×¼µÄ¿ØÖÆÒôÁ¿´óС
µ¤ÂóÖÆÔì
123dbÉùѹ¼¶·åÖµÊä³ö
ƵÂÊÏìÓ¦38Hz-21kHz
¿ÉÒÔÅäºÏBM14S II µÍÒôÅÚÀ©Õ¹µÍƵ
HF,MF,LF¸ù¾Ý·¿¼äÇé¿ö²»Í¬£¬¿ÉÒÔÁé»îÅäÖÃ
¸ßͨÂ˲¨Æ÷ÔÚ60/80HzÓëµÍÒôÍêÃÀÊÊÅä
ÊäÈëÁéÃô¶È¿ª¹Ø(-10/+4dB)
Dynaudio BM12 mkIII----IsoAcoustics¼àÌýÖ§¼Ü
µ±ÎÒÃÇ¿ªÊ¼Ñ°ÕÒÊÊÅäBM MKIIIϵÁÐÒôÏäµÄ½â¾ö·½°¸Ê±£¬ÎÒÃÇ·¢ÏÖIsoAcousticsÌṩÊг¡ÉϵĺÍ×îÁé»îµÄ²úÆ·¡£
Òò´Ë£¬ÎÒÃÇÐγÉÁ˺Ï×÷»ï°é¹ØÏµIsoAcoustics£¬Ê¹ÎÒÃÇÿһ¸öÀ¦°óµÄBM MKIII¼àÌýÒôÏäÓëË«Æ·ÅÆÖ÷ÕÅ£¬Ò²¿ÉÒÔÈÃÄãµÄ½Ç¶ÈÄãµÄÏÔʾÆ÷ÂÔ΢ÏòÉÏ»òÏòÏ£¬ÒÔÍêÃÀÆ¥ÅäÄúµÄñöÌýλÖá£
ISO-L8R155ÊÇÓëBM Compact MKIIIºÍBM5 MKIIIÒ»ÆðÏúÊ۵쬶øISO-L8R200°üº¬ÔÚBM6 MKIIIÓëBM12 MKIII¡£
An Honest and Accurate Monitor
Mixing in a large room? The Dynaudio BM12 mkIII active monitor delivers the SPL, transient response, and detailed imaging that you need to make accurate decisions while mixing in a bigger space. Designed around highly efficient handcrafted neodymium drivers, the BM12 mkIII&££39;s 8" woofer and 1.1" soft dome tweeter deliver an astounding 38Hz-21kHz frequency response. Re-voiced around Dynaudio&££39;s next generation waveguide for amazingly accurate monitoring, the BM12 mkIII ensures that you won&££39;t have any problems getting your mixes to translate. At Sweetwater, we understand that your monitors are the most important part of your studio. After all, if you can&££39;t hear it, you can&££39;t mix it! You can trust your ears when you use Dynaudio BM12 mkIII active monitors.
Dynaudio BM12 mkIII Active Monitors at a Glance:
The BM mkIII series delivers industry standard quality
IsoAcoustics stand allows for an authentic and uncolored sound
With over 35 years of experience building speaker drivers, Dynaudio knows what goes into a great monitor speaker. Add to that 20-plus years of producing professional monitors for top studios, and you have a company perspective that few pro audio manufacturers can match. Continuing their tradition of industry standard sound quality and performance, the BM mkIII series utilizes Dynaudio&££39;s proven waveguide technology, delivering a neutral, uncolored sound and an amazingly accurate sweet spot. This silky clarity, in combination with amazing dynamic capabilities, let you work marathon sessions without ear fatigue. Handcrafted in Denmark, there is an incredible consistency across the entire BM mkIII series that performs well above its class.
Each Dynaudio BM12 mkIII comes with an IsoAcoustic speaker stand for easy positioning and improved accuracy. By decoupling, or eliminating energy transfer to surrounding surfaces, the IsoAcoustic stands ensure that you&££39;ll experience tighter bass and improved imaging. Thanks to IsoAcoustics, your BM12 mkIII will perform up to its fullest pontential.
Dynaudio BM12 mkIII Active Monitor Features:
123dB SPL peak power output ensures accurate monitoring in large spaces
HF, MF, LF analog room filters allow flexible positioning
Highpass filters at 60/80Hz for perfect subwoofer adaption
IsoAcoustics speaker stand ensures accurate, detailed monitoring
Hear your mix, your whole mix, and nothing but your mix with the BM12 mkIII active monitor!
Tech Specs| Powered | Yes | | Power Configuration | Bi-amped | | LF Driver Size | 8" | | LF Driver Type | Cone | | LF Driver Material | Molded Poly-Prop | | HF Driver Size | 1.1" | | HF Driver Type | Soft Dome | | HF Driver Material | Aluminum | | LF Driver Power Amp | 100W | | HF Driver Power Amp | 50W | | Total Power | 150W | | Frequency Range | 38Hz-21kHz | | Crossover Frequency | 6 dB/octave @ 1500Hz | | Maximum Peak SPL | 123 dB SPL @ 1m | | Enclosure Type | Ported | | Input Types | 1 x XLR | | Height | 14.6" | | Width | 9.2" | | Depth | 14.9" | | Weight | 27.5 lbs. |
