  • 60959580  2021-6-26 22:02
    zero-g stamina production toolkit [kontakt]
    STAMINA is a Kontakt instrument that is designed with the songwriter in mind. In a world where life is so busy it is often hard to think about details or choice, as your time matters. STAMINA is here to assist in those decisive moments, with its full-on melody sections and loops that are waiting to be explored.
    Packed with 31 crafted drumkits, including efx oneshots, 227 drumloops – at the touch of a key and 21 melody kits, transition fx breaks, risers, efx and effects section.
    The idea is simple, to Select, Play and Create – let the music guide you so you can start off with an idea, then add to it as you develop your own creative inspiration – or simply work with what’s there and edit it to fit your needs – there are no rules here, just your own creative mind.
    stamina is broken d ...查看全文
    • 60959580  2021-6-26 15:54
      slate digital virtual mix rack [win]
      Virtual Mix Rack crack allows audio engineers to easily create the channel strips of their dreams using a library full of analog modeled plugins. Choose from dozens of modules including vintage modeled EQs, compressors, enhancers, filters, preamps, mixing consoles, and more.
      But even beyond the sound you can get with Virtual Mix Rack crack, you also get the added bonus of speed and efficiency from having your entire processing chain in one convenient window.
      Virtual Mix Rack crack ships with the Mix Bundle One, which contains four Slate Digital processing modules: FG-401 Compressor, FG-S EQ, FG-161 FET Compressor, and FG-N EQ.
      what’s new in virtual mix rack crack:
      Dream Strips – 8 Instantly Recallable and Customizable Channel Strip Configurations Accessible with 1-Click
      Redesigned In ...查看全文
    • 60959580  2021-6-26 12:35
      写给音响工程师的科普文章—从模电角度去了解调音台的信号流程
      很多自称做了多年调音师的音响工程师,由于没有模电基础,外加网络教程千篇一律,说法不一,并没有从根本上去解释一些很常见的问题,比如说最简单的,动圈话筒线1和3要不要短接,DI盒有没有必要使用,这些问题在网络上各有说法,但是却没有从根本上去解释,虽然音响工程师的技术有感性的一面,但是我认为,如果去多学习一些模电基础,可能就会对你现在所使用的设备有更新的认识。所以一些千篇一律的教程,我就不再多说了,自己上网查,我把自己从教材上的知识和实物联系起来,去解释一些很常见但是却在网上找不到解释的东西。
      先从调音台说起,调音台的内部是由N多运放组成的,可能很多工程师做了很多年,却没有自己动手搭建过一块基础的放大电路,所以这一开始我还得讲慢一点。运放,也就是运算放大器,当年集成电路还没有发达的时候,电视机、收音机的放大都是由N多晶体管组成的,晶体管也就是我们常说的三极管,三极管具有电压和电流的放大作用,不同的接法决定这个部分的电路是电压放大还是电流放大,如今集成电路取代了分立元件,在音响方面最常见的就是我们说的运放,运放就是整合一堆三极管在 ...查看全文
    • 60959580  2021-6-26 11:19
      鼓手不可缺少的调音台
      鼓手不可缺少的调音台
      作为国内现代音乐教育的必备音频设备,MIX5和MIX8对乐器演奏监听提供了经济且高质量的解决方案。
      MIX5体积小巧,具备一个XLR输入,AUX音频输入和输出及耳机输出,可为小型演出的现场监听提供支持。
      MIX8在MIX5的基础上增加了一个XLR输入,并且具备48伏幻象电源供电,可对现场环境进行双声道监听,当采用入耳式耳机进行监听时,该功能尤其重要,以避免演奏者因听不到自己的演奏力度而产生的过度演奏。
