音频应用   音频插件联盟,正版插件,欢迎大家选择!
阅读: 32538|回复: 13
[音源] 【飞天弦乐2代】Musical Sampling Trailer Strings
发表于 2008-9-15 | |阅读模式
产品名称 :        【飞天弦乐2代】Musical Sampling Trailer Strings
官网试听:http://www.musicalsampling.com/trailer-strings/
Musical Sampling Trailer Strings  |   5.14GB
Trailer Strings shares the same mantra its portly, brassy cousin follows: LOUD, HUGE, AGGRESSIVE.60-string ensemble: 18 violins, 16 violas, 14 cellos and 12 double basses recorded separately in the same concert hall as Trailer Brass. We've also incorporated our wide/centered seating arrangement to help achieve the same modern, oversized aesthetic we were going for.
What you get is a useful array of short and long articulations, but with a size and clarity that's specifically geared towards hugantic (hugh-jan-tik), over-the-top productions. As with the brass, we really pushed the players to give us everything they had with the triple-forte dynamic. After a series of unrelenting requests demanding "MORE!" volume, the players really sailed through with inspired, bow hair-snapping performances.
What you may not expect with this release is that the dynamic range is quite wide. In addition to the fortississimo dynamic, we went all the way down to piano. Feathery spiccatos, pillowy staccatos and smooth marcatos performed a la dolce. Tasty.
And the sustains? Six dynamics deep. The softest two performed sul tasto (over the fingerboard) to get that whispered, feathery tone.
We've also included our "Adventure" patch programming for all four sections, a cool asset for on-the-fly, pompous string lines. Seriously, load up the basses/cellos Adventure patches, set the basses an octave down, arm both tracks and get your pomposity on. See? You're smiling.
Also included in the basses and cellos are three cluster effects patches. "Snap and Grunt" provides an arsenal of atonal snap pizzicatos, spiccatos/staccato chugs and behind-the-bridge scrapes. "The Brooding" includes subtle, low-range aleatoric meanderings (good for: "alligator sneaking up on prey"). "Behind the Bridge!" is exactly that, tremelo'd (good for: "alligator eats prey").
Our favorite part? The "All Strings" patch, which includes all the respective articulations, spread out over the keyboard. Be prepared to waste a lot of time playing with this patch.
以下是百度翻译,仅供参考:
  飞天弦乐2代相同的咒语,它胖胖的,黄铜色的表哥:大声的,巨大的,aggressive.60-string合奏:18把小提琴,16中提琴、大提琴和低音提琴14 12分别记录在同一个音乐厅为拖车黄铜。我们还采用了我们的宽/中心座位安排,以帮助实现同样的现代,超大的审美,我们要去。
  你得到的是短期和长期的关节一个有用的阵列,但有大小和清晰度,是专门针对hugantic(休米简狄),在上面制作。和黄铜一样,我们真的推动球员给我们他们拥有的三重动力。在一系列无情的要求之后,要求“更多!”音量上,选手们真的带着灵感驶过,低头发发表演。
  您可能不期望这个版本的动态范围是相当宽的。除了对fortississimo动态,我们一路走到钢琴。spiccatos柔软光滑的羽毛,音和marcatos进行甜蜜。美味的.
  而支撑呢?六动态深。柔软的两行近指板奏(在指板)得到的低语,羽毛色调。
  我们还包括了我们的“冒险”补丁程序的所有四个部分,一个很酷的资产在飞,浮夸的弦线。说真的,把贝司/大提琴冒险片,把低音音下来,胳膊都让你在轨道和浮华。看到了吗?你在微笑。
  也包括在低音大提琴三集群效应的补丁。”SNAP和咕噜”提供的无调性弹拨奏阿森纳,spiccatos /断续的轧轧和背后的桥梁的作用。”育雏”包括微妙的,低范围内任意漫步(适用:“鳄鱼偷袭猎物”)。”在桥后面!”正是如此,特雷梅洛会(适用:“鳄鱼吃掉猎物”)。
  我们最喜欢的部分?“所有的弦乐“补丁,包括所有的各个关节,分布在键盘。准备浪费很多时间玩这个补丁。
1万
发表于 2008-9-15 |
:victory: :victory:
2万
音频应用初级会员
Rank: 6Rank: 6
发表于 2008-9-15 |
【飞天弦乐2代】Musical Sampling Trailer Strings........:handshake
16
发表于 2008-9-16 |
顶!:victory:
44
发表于 2020-3-4 |
  我们最喜欢的部分?“所有的弦乐“补丁,包括所有的各个关节,分布在键盘。准备浪费很多时间玩这个补丁。 飞天弦乐, Musical, Sampling, Trailer, Strings 本主题由 admin 于 2020-1-1 14:37 移动
208
发表于 2020-3-5 |
Hardstyle、Trance、Trap和Dubstep等Bass登得上大堂
65
发表于 2020-4-9 |
准备浪费很多时间玩这个补丁
65
发表于 2020-4-9 |
准备浪费很多时间玩这个补丁
65
发表于 2020-4-9 |
准备浪费很多时间玩这个补丁
65
发表于 2020-4-9 |
准备浪费很多时间玩这个补丁
75
发表于 2020-5-11 |
我们最喜欢的部分
