阅读: 11797|回复: 0
[合成器] Steinberg Retrologue 2.3.0 MacOS模拟合成器
发表于 2022-5-19 | |阅读模式
灵活、直观的 Retrologue 2 模拟了经典模拟合成器的温暖和丰满。三个虚拟模拟振荡器和一组一流的滤波器可产生丰富的丰富声音;其适应性强的琶音器、强大的调制系统和 FX 机架使 Retrologue 2 成为各地制作人的首选。
针对低 CPU 负载进行了优化的经典虚拟模拟合成器。
超过 700 种出色的预设,涵盖经典模拟合成器音色及其他音色
直观的界面,用于快速、富有创意的声音设计
3 个振荡器,带有多达 8 个可解调的声音以及子振荡器和噪声振荡器
具有多达 32 个步骤和“导出到主机”功能的琶音器
24种一级过滤器类型
4 个 LFO 加上滤波器、放大器和自定义包络
支持音符表达的 16 级拖放调制矩阵
5种失真模式,包括电子管、剪辑、比特减少和速率减少
带有延迟、合唱、镶边、移相器、复古合奏、混响和 4 段均衡器的 FX 部分
具有 14 种不同滤波器配置和集成 LFO 的 3 频段谐振器
The flexible, intuitive Retrologue 2 emulates the warmth and fatness of classic analog synthesizers. Three virtual analog oscillators and a first-class set of filters produce a wealth of rich, inspring sounds; its adaptable arpeggiator, powerful modulation system and FX rack help make Retrologue 2 the first choice for producers everywhere.
Classic virtual analog synthesizer optimized for low CPU load.
Over 700 outstanding presets covering classic analog synth sounds and beyond
Intuitive interface for fast, creative sound design
3 oscillators with up to 8 de-tunable voices alongside sub and noise oscillators
Arpeggiator with up to 32 steps and “Export to host” feature
24 first-class filter types
4 LFOs plus filter, amp and custom envelopes
16-stage drag and drop modulation matrix with Note Expression support
5 distortion modes including tube, clip, bit reduction and rate reduction
FX section with delay, chorus, flanger, phaser, vintage ensemble, reverb and 4-band EQ
3-band Resonator with 14 different filter configurations and integrated LFO
