发表于 2022-3-23
|阅读模式
CyberLink AudioDirector Ultra 12.3.2708.0 WIN音频剪辑处理软件
AudioDirector 极致版 – 创造声音无限可能、视频声动精彩! 立即试用,感受强大声音编辑魅力:
动态强化视频的声音质量,自打造精准的5.1或7.1声道动态环场音效
与威力导演完美整合,拥有极为顺畅、无接缝的音效/视频工作流程
利用直觉式录音及混音工具,创作独一无二听觉特效
使用专业级视觉修复工具,移除多余声音,将声音还原至最纯净状态。
从DirectorZone云端资源网站免费下载各式音效风格文件套用至剪辑项目
使用iPhone app – AudioClipper随时录制各种声音并汇入使用。
Windows x64 | Languages: Multilingual | File Size: 127.27 MB
Your One Stop Shop for Mixing, Editing, and Mastering Your Tracks. Create the Perfect Recording Environment. Let powerful AI tools create the perfect recording environment anywhere. Remove wind gusts, reverb, and echo from audio clips intelligently so dialogue and ambient sounds are clearly heard.
Extract Vocals Out of Any Audio Track
Separate vocals from your favorite songs or add your own background tracks to your projects.
Achieve Crystal Clear Speech
Restore and fine tune speech in your video and audio projects and create unmatched clarity, even in loud, or noisy environments.
Clean Up Your Audio
Apply a range of restoration tools to get crisp, clear, distraction-free vocals. No noise, hiss, hum and distortion.
Restoration Tools
– Contour Dialogue
– Plosive Removal
– Reduce Noise
– Remove clicks, pops, crackles
– Distortion Removal
– Hiss & Hum Removal
Create Perfect Podcasts and Voiceovers
Produce error-free podcasts and voiceovers with a full-bodied, balanced sound.
Studio Quality Tools to Guide Your Workflow
Enhance the speed and quality of your production. Combine multiple effects, record from multiple channels, and apply your core sound to all your audio files at the same time.
Integrated with PowerDirector.
Export your entire audio project from AudioDirector, directly into PowerDirector. Your project edits will automatically synchronize perfectly between the two apps.
Release Notes
Operating System
– Microsoft Windows 11, 10, 8/8.1, 7 (64-bit OS only)
– Microsoft Windows 10 or above is required to use AI features
https://www.r3ndy.com/cyberlink-audiodirector-full/
