阅读: 16895|回复: 0
[资讯] Strezov Sampling Orchestral Percussion X3M KONTAKT 管弦打击乐器
音频应用推广专员
Rank: 2Rank: 2
发表于 2021-7-21 | |阅读模式
高度灵活的管弦打击乐器的收集记录在一个大大厅,并移植到X3M发动机的最大可玩性。适合各种音乐。
管弦乐打击乐X3M背后的理念,不仅是在一个干燥、仍然充满活力的房间里,引入不同类型的管弦乐打击乐,而且允许创造更多独特的乐器组合,以及在声音和效果方面的一些新的添加。
我们的主要想法是录制不同种类的管弦乐打击乐,适合各种动态音乐,特别是电影音乐。该库有多个动态级别(从非常软的ppp到爆破的ffff)和多个轮知更鸟(意味着每台仪器都有唯一的样本分配给它,每次你按一个键都会改变)。我们也加入了新的和尚未取样的乐器,如东正教教堂的钟,以及各种乐器尺寸的低音鼓和两个定音鼓,以达到最大的灵活性。库的界面是这样的:
Strezov取样管弦乐打击乐X3M KONTAKT屏幕截图
X3M冲击发动机
我们的引擎背后的概念是相当简单的-它是由12个区域,你分配不同的补丁。当你决定了你所选择的模板后,只需插入并发挥-没有其他需要或期望。
当你加载管弦乐打击乐X3M时,你会自动加载工作站“样本”文件夹中的所有样本。然而,乐器的制作方式不仅是你需要的所有类型的打击乐器都有一个贴片,你还需要一个优化的贴片来适应你的内存容量。更多信息,请参考我们为您准备的。pdf手册。它在这个概览页面的底部。
需要本地仪器Kontakt 5+完整版本!
主页
https://www.strezov-sampling.com ... percussion-x3m.html
Highly flexible collection of orchestral percussion instruments recorded in a large hall and ported into the X3M Engine for maximum playability. Perfect for all kinds of music.
The concept behind ORCHESTRAL PERCUSSION X3M is not only to introduce different types of orchestral percussion recorded in a dry, still lively room, but also to allow for the creation of more unique instrument combinations, as well as some new additions as far as sounds and effects are concerned.
Our main idea was to record different kinds of orchestral percussion sets, suitable for all kinds of dynamic music and especially cinematic music. The library has multiple dynamic levels (from very soft ppp to blasting ffff) and has multiple round-robins (meaning that each instrument has unique samples assigned to it that get changed every time you press a key) . We also included new and not yet sampled instruments like Orthodox Church Bells as well as various instrument sizes for the Bass Drum and two Timpanis for maximum flexibility. Here is what the library’s interface looks like:
The X3M Percussion Engine
The concept behind our engine is fairly simple – it is made of 12 zones that you assign different patches to. After you’ve decided on the template of your choosing, just plug in and play – nothing else is needed or expected.
When you load up Orchestral Percussion X3M, you automatically load all samples that are inside your workstation’s “samples” folder. However, the instruments are built in such a way that not only do you have a single patch with all types of percussion you might need, you also have a patch that is optimized and friendly to your RAM’s capacity. For more info, please refer to the .pdf manual we’ve prepared for you. It’s at the bottom of this overview page.
Requires Native Instruments Kontakt 5+ FULL version!
https://plugincrack.com/sounds/s ... e-drum-x3m-kontakt/
