音频应用   音频插件联盟,正版插件,欢迎大家选择!
阅读: 15913|回复: 0
[资讯] Steinberg WaveLab Elements
发表于 2021-5-20 | |阅读模式
Download Steinberg WaveLab Elements 10 - Software edit and master audio, which is perfectly designed for the musician hobby, who work freely
Steinberg WaveLab Elements:
Steinberg WaveLab Elements is a software edit and master audio, which is perfectly designed for the musician hobby, who work freely on the radio, and studio owners at home. Based on the solution master WaveLab Pro has been approved, WaveLab Elements highlights the editing tools, and analysis has proven a valuable choice restoration and mastering plug-ins, tool CD recordings, and more - all accessible via the intuitive user interface.
Steinberg WaveLab Elements introduced many improvements to make and edit workflows, as well as the features are carefully selected to refine and Polish the sound. Different from The edited spectrum leading to the plug-in new recovery technology unique Sound along with the plug-in is re-designed and advanced - WaveLab 9.5 is a leap in terms of sound quality.
The features of Steinberg WaveLab Elements
Tools audio 64 bit raw yet with the ability to handle the exact dual and for support write integer 32 bit
Modern Spectrogram provides view, custom color schemes with the presets, display settings, stairs, audio drama and more
Screen Wavelet totally new to express, intuitive, more accurate musical content of audio files
The edit spectrum modern with a set of tools and functions completely new to editing by surgery in the Spectrogram
Technology audio playback is waiting for a patent to regenerate and / or replace audio material broken by proper use of information spectrum of the region around
Tab bug Fixes designed to detect and correct errors simple and easy
The software support RestoreRig new include DeClicker, DeCrackler, DePopper, DeNoiser and DeBuzzer
Program spectrum directly to display real time information of the signal while recording or playback
The plug-in to be refurbished include the modular handle new series, the improvement in MasterRig, redesign the GUI in most of the dynamic effects as well as the processing algorithm, new
Apple Touch Bar support access easily and directly to the tasks and functions of your favorite fingertips
Further enhancements, including high DPI support, the moderated secret the MP3 not distance, supports track name iXML, and more.
https://en.taiwebs.com/windows/d ... -elements-5209.html
