音频应用   音频插件联盟,正版插件,欢迎大家选择!
阅读: 27808|回复: 1
[调音台] 美国APL迷你型M12.2L Mixer调音台
发表于 2006-2-28 | |阅读模式
M12.2L Mixer调音台
        1、12通道输入((8路话筒+4路立体声;另带2路立体声的辅佐输入 (AUX IN)及2路立体声(REC OUT)和1路单声:1路(AUX SENDS)辅助输出:2路主输出(R &L)
        2、12 channel input (8 way MIC+4 way STEREO),2 way STEREO AUX IN and 2way STEREO REC OUT, 1way MONO;1 way AUX SENDS; 2way main output(R &L)
M系列迷你型调音台特点:
           1.迷你型设计,具有精美的外观及携带方便:
           2.带耳机(PHONES)监控输出,并有专门的FADER来控制信号大小,使操作更加方便:
           3.自带48V话简供电,可以与各种类型话筒匹配;
           4.外置式电源和低频滤波器(80Hz),有效的抑制了话筒录音或处理过程中产生的低频共振和失真(MIC NOISE<一129dBu, THD: <0.0068%);
           5.高/中/低 EQ均衡调节,享受完美的均衡效果;
           6·多种连接口(MIC/LINE/AUXS EN DS/PlayBack/Record等),是家庭影院录音室和乐队的最佳装备:
           1、Mini size design, exquisite appearance and portable;
            2、PHONE MON output with professional FADER to control signal, easy operation;
           3、48 V MIC power supply can be matched with all kinds of MIC;
           4、External power supply and LF filter (80Hz),effectively reduce LF syntony and distortion produced during MIC recording or processing (MIC NOISE<-129dBu, THD: <0.0068%)
           5、High/Middle/Low EQ, perfect EQ effect;
           6、Multi interfaces (MIC/LINE/AUXSENDS/PlayBack/Record etc.)the best choice for family film recording room and Music Bands.
1299
发表于 2017-9-23 |
欣赏了,谢谢楼主发布啊 ,我收藏了啊
