阅读: 16890|回复: 0
[转载] Uplifting Music Studio Indie Rock Vocal KONTAKT 独立摇滚人声
发表于 2020-7-14 | |阅读模式
KONTAKT – 900 MB
这个库的特点是使用任何声乐短语的高度灵活性,以及混合它与其他短语的能力,而不管速度和你的项目的关键。更重要的是,使用任何MIDI键盘,你可以立即切换到任何歌唱的音节。额外的一个音节位于键盘上的一个单独的区域,使它有可能创造几乎无限的新的音乐短语。
为了创建这个库,我们使用了一个多小时的录音室会议,三个声乐家在双轨技术的帮助下录制了所有音调,并通过仔细的编辑相互结合。因此,一个成熟的六声部合唱的效果是实现的,听起来没有任何计算机技术的使用。另外值得注意的是,除了电子管前置放大器之外,一直到最后的信号都没有使用任何处理。这样做并不是为了引入额外的转换,而是为了允许用户根据自己的选择处理每个音轨的声音。
需要NI Kontakt FULL v5.3.1和更高!
The feature of this library is the high flexibility of using any vocal phrase, as well as the ability to mix it with other phrases regardless of the tempo and the key of your project. More than that, using any MIDI keyboard, you can instantly switch to any sung syllable. Additional Oneshot syllables located in a separate area on the keyboard make it possible to create an almost unlimited number of new musical phrases.
To create this library we used a multi-hour studio session of three vocalists recorded with the help of Double Track technology in all tones and combined with each other using careful editing. Thus, the effect of a full-fledged six-voice chorus is achieved, sounding without any use of computer technology. It is also worth noting that in addition to the tube preamp, no processing was used all the way up to the final signal. This was done not to introduce additional transformations, but to allow the user to process the sound of each track at his option.
Requires NI Kontakt FULL v5.3.1 and higher!
