楼主 |
发表于 2018-3-21
Mr. GEE, Yeong also said about his first use of the PM10 from rehearsals, “In fact I have used the PM1D for 17 years and I thought that existence of many knobs and buttons above the control surface of the PM1D was a great advantage, so I was initially worried about the PM10's user interface. But after using it several times I realized my worries were unnecessary as there are actually knobs and buttons that are easily accessed for functions that need fast, precise adjustment. As for other functions, the UI is very well organized so I didn't feel any inconvenience whatsoever.”
“我认为插件也是一个巨大的优势,因为对于大多其他数字调音台的插件,你不得不从第三方公司购买。但是 PM10 有一套广受好评的实用板载插件,这套插件由来自 TC Electronics 与 Eventide 备受尊敬的音效插件设计师参与设计,前置放大器甚至采用了 Neve SILK 处理器。除此之外,我认为 PM10 中的 Scene Global Paste(场景全局粘贴) 功能非常棒,该功能来自于Yamaha CL 系列。使用 PM1D 时,如果您想要将当前场景的参数设置复制并粘贴到其他场景中,必须重复诸如场景内存加载,更正和保存等几个步骤,但现在您可以更轻松地完成。”
On plugins, “I also think it's a big advantage regarding plugins since, for other digital mixer's plugins, you mostly have to buy from 3rd party companies, but with the PM10 there is an extensive suite of popular, practical onboard plugins from esteemed effects and plugin designers such as tc electronics and Eventide, and the preamps even features the Neve SILK processor. I also think it is great that the Scene Global Paste function from the Yamaha CL Series was adopted by the PM10. With the PM1D, if you want to copy and paste parameter settings from the current scene to other scenes, you always had to repeat several steps such as Scene Memory load, correction and save, but now you can do it much more easily.”
根据 GEE Yeong 先生的说法,虚拟声音检查功能也有很大贡献,“我们在本次演出中使用了虚拟声音检查功能。在记录整个表演时,我们可以清楚地了解演员在每首歌曲中唱歌的方式或他们正在唱什么样的歌曲,使得我们能够详细分析和混合。所以对于这个节目,尽管排练期很短,但我们可以快速且相当融洽地达到完美状态。所以说,虚拟声音检测实际上是现在音乐剧的一个必要功能。”
The Virtual Sound Check function contributed greatly as well according to Mr. GEE, Yeong, “We used the Virtual Sound Check function for this show. Recording the whole performance we can understand clearly how the actors sing in every song or what kind of part they are singing, allowing us to analyze and mix in detail. So for this show, in spite of the fact that the rehearsal period was very short, we could arrive at the perfect mix quickly and fairly easily. So it can be said Virtual Sound Check is actually a necessary function for musicals now.”
综上,GEE 先生非常满意地评价道:“虽然我们才刚开始使用 PM10,但即使是在这段有限的时间里,我们也可以说,PM10 在音质和操作简便性上的提高,在我们生产和工作的流程中起到了很大帮助。”
Overall Mr. GEE, Yeong is very satisfied remarking “We just started to use it but even in a limited amount of time we can tell the PM10 has much improved sound quality and ease of operation contributing greatly to our production and workflow.”
* 参考 PROFESSIONAL AUDIO MAGAZINE,由专业音响系统和录音制作提供
*Reference to PROFESSIONAL AUDIO MAGAZINE by courtesy of Professional Sound System and Recording Production
