阅读: 8681|回复: 2
[资讯] 8DiO CAGE Woodwinds KONTAKT
发表于 2010-3-16 | |阅读模式
CAGE(Custom Aleatoric Group Effects)系列由奥斯卡奖,TEC和G.A.N.G获奖作曲家,Troels Folmann和艾美奖提名的作曲家兼协调者Colin O'Malley制作。 CAGE有三个专用音量,用于弦乐器,黄铜和木管乐器,每个音量包含9个麦克风位置。麦克风分为两个核心组:组合(close,混合,Decca,远,宽)和Divisi(Spot Mic 1,2,3和4)。所以无论你想要全合奏还是更多的室(divisi)导向的FX - 它的所有在那里你的指尖。
CAGE木管乐器版包含一个无关的列表。我们想创造一个绝对无与伦比的东西。单独的木管乐版包含超过380个外汇,几乎不可能找到没有涵盖的效果。我们定制的CAGE混沌引擎支持令人难以置信的深度,其中包含超过80.000行代码。 CAGE混沌引擎允许您完全控制样品,您可以通过一次点击控制超过1.500个样品参数。此外,您还可以随机分配所有rack-fx(例如恍惚门,过滤器,EQ)。
所以想像有一个令人难以置信的直观和强大的混沌引擎的最深刻的发音。无限可能。整个用户界面(UI)设计在华丽的3D中,并允许新手和专家在几秒钟内滚动。 CAGE正在使用我们独家V8P系列的各种组件,并包含超过80.000行代码,为您提供极致的灵活性和可演奏性。一个例子是在不同发声之间建立循环链的能力,所以你可以建立自己的一套FX链。
原文
CAGE (Custom Aleatoric Group Effects) series is produced by Academy Award, TEC and G.A.N.G Award Winning Composer, Troels Folmann and Emmy nominated composer and orchestrator, Colin O’Malley. CAGE comes in three dedicated volumes for Strings, Brass and Woodwinds and each volume contains 9 microphone positions. The microphones are divided into two core groups: Ensemble (Close, Mixed, Decca, Far, Wide) and Divisi (Spot Mic 1, 2, 3 and 4). So whether you want full ensemble or more chamber (divisi) oriented FX – its all there at your finger tips.
The CAGE Woodwinds Edition contains an articulation list second to none. We wanted to create something definitive and unrivaled. The Woodwind Edition alone contains over 380 FX and it is near impossible to find an effect not covered. The incredible depth of articulations is supported by our custom CAGE Chaos Engine, which contains over 80.000 lines of code. The CAGE Chaos Engine allows you to take complete control of the samples and you can control over 1.500 sample parameters with a single click. In addition you can also randomize all the rack-fx (ex. trance-gate, filters, EQ).
So imagine having the deepest set of articulations with an incredibly intuitive and powerful Chaos Engine. An infinity of possibilities. The entire user-interface (UI) was designed in gorgeous 3D and in a way that allows both newcomers and experts to get rolling in a matter of seconds. CAGE is using a variety of components from our exclusive V8P series and contains over 80.000 lines of code giving you the ultimate flexibility and playability. One example is the ability to make round robin chains between different articulations, so you can build your own sets of FX chains.
But most importantly CAGE is the most comprehensive collection of orchestral FX ever done. Take something as simple a “string riser”. It’s no longer matter of whether you want a rising string sound. It is a matter of whether you want it in normal legato glissando or perhaps with tremolo motion to it – maybe you want more of a trill based glissando or maybe you just want a horrific grinding string variation. CAGE has it all and is the definitive collection of orchestral FX.
8DiO CAGE Woodwinds KONTAKT | 7.71 Gb
下载地址:
游客,如果您要查看本帖隐藏内容请回复
3万
音频应用初级会员
Rank: 6Rank: 6
发表于 2010-3-16 |
欣赏支持。:victory::victory:
2万
音频应用初级会员
Rank: 6Rank: 6
发表于 2010-3-16 |
欣赏!支持!:victory:
