发表于 2009-7-22
|阅读模式
产品简介
双通道调音台*2平衡式XLR麦克风输入*3.5mm立体声迷你输出*电源开/关/低电池LED指示灯*1/4"监听耳机输出接口*切换输入限制器,以减少的可能性超负荷失真。 详细介绍
Azden FMX-20 Portable 2-Channel Field Mixer
*2通道调音台*2平衡式XLR麦克风输入*3.5mm立体声迷你输出*电源开/关/低电池LED指示灯*1/4"监听耳机输出接口*切换输入限制器,以减少的可能性超负荷失真。
*尺寸:42x130x103(mm)*重量:600g*电源:9v直流。
Azden FMX-20 2-Channel Field Mixer
Professional field mixer with 2 XLR inputs, 2 XLR Outputs plus a mini-plug output.
Adjustable input level, headphone monitor with volume control.
LED's for Peak Level, Power and battery Condition.
Azden
Azden replaces the FMX-2 portable, two-channel field mixer with theFMX-20field mixer, which adds XLR I/O as well as a mini-plug output. Beyond the improved signal-to-noise ratio, new features include a three-step LED array for monitoring, a 12V DC input for external power, the mixer, a switchable input limiter (guards against the possibility of overload distortion), and a channel-addressable 1/4in. monitor headphone jack with its own level control.
FMX-20 Deion:
· Special circuitry for an improved signal-to-noise ratio
· 3-step LED array for easy signal monitoring
· 12V DC input for externally powering the mixer
· Switchable input limiter to reduce the possibility of overload distortion
· Channel-add |
