音频应用 首页 新闻资讯 查看内容
Chameleon Guitar Amp Plugin by GuitarML
2021-7-6 22:57| 发布者: 8655230| 查看: 386| 评论: 0
摘要: Chameleon is a guitar plugin/standalone app using neural networks to create three distinct sounds from a vintage style amp head. The core sound comes from a neural net inference engine which allows th ...
Chameleon is a guitar plugin/standalone app using neural networks to create three distinct sounds from a vintage style amp head. The core sound comes from a neural net inference engine which allows the plugin to disguise itself as a high end tube amplifier. Advanced machine learning was used to capture three distinct sounds, named Red (high gain), Gold (crunchy), and Green (clean). In the same way a real amp head is used with a cabinet and other effects, this plugin is intended to be used in the signal chain along with IR's (cab sim), reverb, and any number of guitar effects.
Chameleon is free and open source on Github for anyone interested in audio DSP with machine learning and neural networks. The capture technique used here is capable of reproducing the dynamic response of real amps and pedals to near perfection.
Check out the source code on GitHub.
Read the tech article published on Towards Data Science.
Visit the website for more from GuitarML.
路过
雷人
握手
鲜花
鸡蛋
相关阅读
最新评论
原创周排行
