Vibe Pro VST也适用于PC和MAC,并且具有32Bit / 64Bit,适用于PC和VST / AU支持Mac。
有一个非常干净和简单的设计GUI这个仪器是重点和让你进入生病的声音准备好了。
原文
Fellow Music Producers We Are Proud To Bring You Yet Another HIGH QUALITY VST Instrument That Will Be One Of Your Go-To Weapons Of Choice For DOPE Presets For Some Time To Come!!
This VST Has A HUGE Library 10GB+ All Kinds Of Preset Types Such As...
The Vibe Pro VST Also Works For BOTH PC & MAC And Has 32Bit / 64Bit For PC & VST/AU Support For Mac As Well.
With A Very Clean & Simple Design GUI This Instrument Is To The Point & Gets You Rite Into The Sick Sounds READY TO GO.
IndustryKits Vibe Pro VST Instrument WiN OSX | 5.51 GB
