查看: 18898|回复: 2
[软件] Toontrack EZmix 2 v2.1.4 [Win-Mac]
2万
音频应用初级会员
Rank: 6Rank: 6
发表于 2005-4-13 22:15:00 | 显示全部楼层 |阅读模式
Toontrack EZmix 2 v2.1.4 Crack Free Download r2r Latest Version for Windows. It is full offline installer standalone setup of Toontrack EZmix 2 v2.1.4 Crack mac for 32/64.2 i' e. h7 H: o, }( t- g; \
# i  a& N4 T/ J7 u' |1 ^- s
Toontrack EZmix 2 v2.1.4 Crack Free Download r2r Latest Version for MAC OS. It is full offline installer standalone setup of Toontrack EZmix 2 v2.1.4 for macOS.
9 S2 a8 @( F7 K: Q' I6 d
3 h' o9 Z- f# r& J! d' D$ yToontrack EZmix 2 v2.1.4 Overview
( s3 B+ `: A* V( w, \8 Z0 W5 q
0 J+ m3 M) k$ Z; u. b6 Z2 `EZmix is a simple, yet powerful mixing tool that gives you access to a huge array of mix presets for the whole gamut of mixing needs. Whether you need to mix drums, vocals, guitars, bass or keyboards this is your tool. Simply insert EZmix on a channel strip in your sequencer, and pick a preset to apply to your audio source. Done. In addition, EZmix comes with a standalone host that you can use to practice your guitar with using the included amplifiers and cabinets simulations. Of course, those are available when using your recording application too!( `$ g' g: v$ y( b* A' u
7 f* X" R9 h- u* _$ `& a7 b, u  Q& O
Features of Toontrack EZmix 2 v2.1.4
; o+ Q9 K( v6 h/ j1 ]$ c8 A+ C, B/ ?6 o( H2 H* y
Bug fixes in version 2.1.4:# ^- q/ E9 o7 S0 Y) s
% a5 A6 q% I* E2 j* L( F
Below are some noticeable features which you’ll experience after Toontrack EZmix 2 v2.1.4 free download.
2 O  [! ]' Q# [( Y
* i) j* F7 V+ O& n; a/ j– The internal AU name has been changed back from “EZdrummer 2” to “EZdrummer”, which it was in 2.1.1 and earlier, to restore save file compatibility in some hosts.
& M$ U! s  ]$ i
  y: k" h1 v! f– In Drumkit from Hell, if a sound from another expansion was loaded on an instrument, clicking on that instrument could lead to a crash in some cases.6 G( g$ `! J; c$ p
5 ]1 b. V! p. _+ r4 @– Clicking the tempo button under the song track in Toontrack solo could lead to a crash.
+ D( s! S% w- }8 t( y- [2 z5 n! U- f1 ]' s! r+ Q
– If the User MIDI folder could not be accessed or created, the plug-in crashed when instantiated.
! z9 J& D  F! W% N3 F* A9 z
0 o7 w1 j: L; N– Dragging across articulation lists in Edit Play Style did not preview any sound.
0 @( P- d! ]' V0 s2 p' ^( \/ F# L8 j6 H/ y$ y% D
– Dragging from the Browser had wrong y coordinate.
3 N' ]. P5 h* M+ ^( w; q( A
/ F5 D4 B( }8 {- M- v9 N– The red translucent block that marks the current recording sometimes became too long when a loop endpoint was reached, and it no longer overlaps itself in a loop.
7 H/ b  ]- h- W  {7 o6 v
# Y# u6 c* i$ _2 R– The following is now disabled while recording: moving the playhead or loop area, Undo/Redo, song track context menus, loop toggling and a few more things.; u, ]/ o8 K* N' f
' N( b$ D0 i3 o! m– Up/down arrow keys in the Browser should work in more hosts on Mac now.
5 l; O2 s- D9 @$ }) c8 f3 [
2 e; L. j; p, n% N$ g! S+ j; iToontrack EZmix 2 v2.1.4 Technical Setup Details
  S" `9 ?) i; Z6 y0 O; d2 d/ q4 n3 d# _% ]' x+ ]
Software Full Name: Toontrack EZmix 2 v2.1.4
" a2 _; I% D' h# A7 H1 g& i. }# N! o3 P2 X
Setup File Name: Toontrack EZmix 2 v2.1.4.zip
4 b. S0 A! d2 F$ g* k$ `5 O  P4 a/ |0 D" w
Setup Type: Offline Installer / Full Standalone Setup
# W9 e' V  n; q% V: h* u0 n) G6 }* Z
6 o* s; |0 U$ S% n$ C) [; ?$ G, S5 `+ dCompatibility Architecture: 32 Bit (x86) / 64 Bit (x64)
- m6 G3 Y! ^; `) o! p% S9 ^4 _0 H0 n8 Q5 Q
Homepage:-https://www.toontrack.com/product/ezmix-2/
  F! N% y, ^6 \% m( h  U1 H
7 g$ q' b- l$ H3 A& DSystem Requirements For Toontrack EZmix 2 v2.1.43 ^- h# j6 v* E  h4 ^2 s, I
# a! _# x0 K# U/ |0 e/ A4 S+ LBefore you start Toontrack EZmix 2 v2.1.4 free download, make sure your PC meets minimum system requirements.: t* k+ o* g6 ~+ J0 |1 o
+ ^& c' U0 f) h% GBefore you start Toontrack EZmix 2 v2.1.4 free download, make sure your mac meets minimum system requirements.
4 Z$ Q* F) G2 c# k- Z5 f+ R
3 x1 `" I$ X" m2 Q- c' ]macOS Free DownloadMac OS X 10.7 | 10.8 | 10.9 | 10.10 | 10.11 | macOS Sierra
/ `4 F( D' T9 V' f' U" z
" }5 Z/ R% @! O8 sWindows Free Download Windows XP | Vista | 7 | 8 | 8.1 | 10 [32-bit | 64-bit]+ ^* S- j3 V& g, _& U9 q2 O% b
3 H' Z% ~& u0 E, e0 z/ b, f  sToontrack EZmix 2 v2.1.4 Free Download
) Q& I+ A! A+ s, q8 Z: f1 Z  l) x2 C4 t; v7 W5 c3 R. E& v0 d5 G
Click on below button to start Toontrack EZmix 2 v2.1.4 Free Download. This is complete offline installer and standalone setup for Toontrack EZmix 2 v2.1.4. This would be compatible with both 32 bit and 64 bit windows.
( F5 ]  s4 U. }1 i4 q9 Q. E5 H7 r3 c* E
Click on below button to start Toontrack EZmix 2 v2.1.4 Free Download. This is complete offline installer and standalone setup for Toontrack EZmix 2 v2.1.4. This would be compatible with macOS.5 L. i, O1 F/ {! v9 e
下载地址:
游客,如果您要查看本帖隐藏内容请回复
' K  a7 g+ t* C2 ^1 s/ h8 X& O* ~
: F, `/ f, e/ ]) D3 d% t
d521c28f-4c93-4e2f-b917-3864f180a5c2.jpg ! t# c+ J1 g& n. M
298
发表于 2005-4-13 22:35:00 | 显示全部楼层
2万
音频应用初级会员
Rank: 6Rank: 6
发表于 2005-4-15 07:32:00 | 显示全部楼层
<P>有味道。再深入点会更好。</P>
GMT+8, 2025-6-8 08:13 , Processed in 0.027989 second(s), 6 queries , Redis On.
