Antelope Audio MP32 两U机架话放
- k, I% W4 v4 V8 P `
5 s5 v- B# H. P; l; G& N, w0 ~6 u3 y
- z j0 A) v9 L6 c8 E* K6 ?THE NEW APPROACH TO ANALOG CIRCUITRY ]. z: s( J$ m ]' V
Pushing the Antelope Audio’s Zen Studio to the next level, the MP32 is a front-end recording device with 32-channel mic preamp that fits within two rack spaces. Each of the 32 Class A preamps have phantom power, and four channels can be utilized as Hi-Z instrument inputs. The MP32 has incredible headroom and an extremely open sound, which can create magnificent results when teamed with the up to 65 db of gain each channel can get.* T* L7 ^" a+ n1 f$ T; g( y
! u: n9 P- s" t# E
$ I4 {6 r# j; e/ Q0 Y" |5 R: k% m% I5 r
ULTIMATE USER FRIENDLY CONTROLS% k: f3 K5 }4 n& \1 B! s: |3 }
Via the Mac and PC compatible control panel, MP32 users can control the mic gain levels, change input types and even recall presets. Thanks to an extremely quick set up experience, it’s easy to get started with the MP32 and immediately start tweaking each of the 32 mic pres. Every aspect of control is literally a mouse click away with the MP32, whether it be changing gain structures or creating new preamp settings, and the system also features a remote control for added ease .
& ]+ x$ N- ?) F' [* `9 R7 d% p% J* s
& B% C; N- ^- Y* {$ F# t
( P* |4 M$ ~3 ^2 t
MATCH MADE IN ANALOG AND DIGITAL HEAVEN, Q" B$ j) e3 D
By combining the MP32 with Antelope Audio’s Orion 32, it’s possible to create an amazing workstation for both studio and live spaces. The Orion 32’s immaculate conversion abilities ensure that you get great transparency and complete integrity throughout the entire signal chain. Fitting perfectly together in your rig, the combination of both the MP32 and Orion 32 will only take up three rack spaces.
" C6 x7 I( m* _' l. A- p# n/ u, d2 h: P0 c! ]$ ~% @7 Z
