查看: 18490|回复: 1
打印 上一主题 下一主题
[转载] Impаct Soundwоrks ReForged KONTAKT
6万
音频应用高级会员
Rank: 7Rank: 7Rank: 7
跳转到指定楼层
1#
发表于 2008-4-24 18:48:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一组发现的金属物体被重新锻造出来,仿佛它们是敲击乐器:一个旧炊具、金属铲子、耙子、锡浴、气罐等等。这些独特的物体被敲打、敲击、敲击,并通过各种各样的传统技术和不那么传统的技术引起共鸣。
从这个美丽的自然记录池中,我们精心制作了一组新的设计材料——电影的影响、清扫、噪音、有节奏的循环、小故障、次击、色调的氛围、黑暗的纹理等等。这是一个完美的工具包,用于音轨,评分,和进一步的声音设计,由钢铁,钢铁,锡,铜和铝熔融的核心推动。
为了将自然和设计的世界重新结合在一起,我们把图书馆作为一个完整的WAV集合(近2000个声音)和一组Kontakt补丁和一个光滑的现代声音引擎。从细微的调整到戏剧性的改变,再铸成的界面:电影金属的声音设计将为你提供无尽的变化和灵感,为你的作品。
原文
ReForged features an array of found metal objects performed as if they were percussive instruments: an old cooker, metal shovels, rakes, a tin bath, gas canisters, and much more. These unique objects were hammered, struck, tapped, and resonated using a wide variety of both conventional and not-so-conventional techniques.
From this pool of beautifully-captured natural recordings, we crafted a new collection of designed material – cinematic impacts, sweeps, noises, rhythmic loops, glitches, sub strikes, tonal atmospheres, dark textures, and beyond. This evocative material is a perfect toolkit for soundtracks, scoring, and further sound design, fueled by a molten core of iron, steel, tin, copper, and aluminum.
To tie the natural and designed worlds of ReForged together, we have presented the library as a complete WAV collection (nearly 2,000 sounds) and a set of Kontakt patches with a sleek, modern sound engine. From subtle tweaks to dramatic alterations, the interface of ReForged: Cinematic Metallic Sound Design will provide you with endless variation and inspiration for your compositions.
Impаct Soundwоrks ReForged KONTAKT WAV REX | 2.76 Gb
下载地址:
游客,如果您要查看本帖隐藏内容请回复
5699
2#
发表于 2008-5-1 06:16:32 | 只看该作者
