频率范围:+/- 0.3dB (10Hz to 20kHz)+/- 0.5dB (10Hz to 35kHz)
失真:<0.006% (10Hz to 20kHz using a measurement window of 10Hz to 80kHz)
噪声:<80dB (20Hz to 20kHz using a measurement window of 10Hz to 22kHz)
线路输入:
输入阻抗(balanced):> 20k Ohms
输出:
线路输出阻抗:<50 Ohms
线路输出:Maximum of +26dBu into 600 Ohms. Zout 75 Ohms +/-5% @ 1kHz, balanced and earth-free.An unbalanced output 8dB below the level of the balanced output is also provided.
尺寸:
宽度:482mm (19 inches)
高度:44mm (1.75 inches) - 1U
深度:240mm (9.5 inches) - without power socket plugged in
重量:2.5kg (5.5 pounds)
