4#
楼主 |
发表于 2005-3-31 22:32:00
只看该作者
Steinberg.WaveLab Elements 8.MacOSX.x64 StefLiON- x, U# t, N5 Y5 i, D0 d
) I4 {* A! r- N; Z8 z. \* K
2 e! b9 s$ _* a0 w; vWaveLab belongs to the very first mastering applications available, its history stretching all the way back to 1995. Over the years WaveLab has seen several milestones in software mastering but, at the same time, has always retained its focus on its sole purpose: to provide the best workflow and tools for mastering, editing and restoration.
/ U+ P/ a* I+ x; I) o5 C! k$ S; @/ J9 ~) U. p7 Q# O6 d @' C4 | C# V
Powerful clip-based Audio Montage for stereo or multi-track projects
: M, l) K2 n+ ISupports audio files with up to 384kHz in 24-bit quality$ Z) M9 i: g% i1 D0 `
Track-based effects, master effect section and master section
[: a+ X7 E- F/ Z: J3 cUnlimited undo/red, powerful batch processing and archiving features
) ] @( @4 [# x5 \+ x& QSpeaker management for monitoring several loudspeaker setups, A! X7 V/ t4 x2 S0 s# E
High-quality set of plug-ins and processors including iZotope's MBIT+? Dithering, Voxengo's CurveEQ and mastering-grade VST 3 plug-ins0 i7 c1 }# A( d: P; v
Intuitive marker system and master transport panel for fast project navigation
% C( |* s$ V8 ?- r0 ]0 \3 ?Comprehensive audio analysis suite and metering functions" \6 [0 Z# @: r; f& x% _+ l! i$ z
Advanced editing toolset with high-resolution zooming/ t! X0 |" R4 {6 }
K) ^8 ~$ W8 ^8 D$ l) \$ k( `- {Audio restoration
0 v5 O0 f5 F7 S$ P* I8 `& k5 C/ X0 v7 g% C+ `% ^8 ^! H
WaveLab highlights advanced spectrum editing and error correction tools. And with the Sonnox DeNoiser, DeClicker and DeBuzzer tools, it also includes the latest restoration plug-in technology available on the market ? best suited to accurately restore impaired audio recordings.1 f6 E) m( [9 G" l
: d- |& G" S( v6 e8 ?
Spectrum editing for correction of errors deeply hidden in the frequency spectrum. c/ M0 R( B3 E7 A! R+ K
Error correction tools with analysis and automatic correction tools
2 s0 a7 J6 \9 x: t. h7 |DeNoiser effectively removes constant background noise
( ?. M0 v' T/ V/ W4 J# cDeClicker is the right choice to eliminate pops, clicks and crackles
4 Y' }; p# v5 L/ z5 n3 uDeBuzzer removes humming noises like the mains hum |
