查看: 24346|回复: 2
[转载] Solid State Logic Nucleus 16路主控台控制器
发表于 2007-10-19 12:48:09 | 显示全部楼层 |阅读模式
Nucleus主要特性:
通过网线与电脑连接的DAW控制器
支持Pro Tools、Logic、Cubase/Nuendo等主流DAW软件
可同时连接3个不同的DAW软件,一键切换
8个通道控制,带2个库,等于可切换16种通道控制
触感100mm电动推子
SD卡可存储配置文件
可看到每个通道的电平,按钮带背光,旋钮也带一圈LED显示灯指使位置
带有SuperAnalogue技术的高质量电路
USB音频接口,可连接DAW软件的输入和输出通道
两个XLR/TRS混合输入接口,可连接其它声卡或监听输出
数字SPDIF输入/输出接口
零延迟监听
SuperAnalogue的话放。带80Hz高通滤波、反相和幻相供电
4个USB接口,可串接4个USB设备
带一个标准的踏板接口
两个耳机输出和一个iJack监听输入
Physical *
Depth385mm / 15.25"including trim, excluding connectors
Height120mm / 4.75"including feet
Width730mm / 28.75"including trim
Weight7.5kg / 16.5 pounds
Power< 90 Watts
Boxed size460mm x 200mm x 800mm / 18.25" x 8.0" x 31.5"
Boxed weight8.0kg / 17.75 pounds
* All values are approximate
Environmental
TemperatureOperating:+5 to 30 deg. C
Non-operating:–20 to 50 deg. C
Max. gradient:15 deg. C/hour
Relative HumidityOperating:20 to 80 %
Non-operating:5 to 90 %
Max. wet bulb: (non-condensing)29 deg. C
VibrationOperating:< 0.2 G (3 – 100Hz)
Non-operating, power off:< 0.4 G (3 – 100Hz)
ShockOperating:< 2 G (10ms max.)
Non-operating:< 10 G (10ms max.)
Altitude (above sea level)Operating:0 to 3000m
Non-operating:0 to 12000m
Connections
PowerIEC320 3-pin connector, 100 – 240 Vac, 50 – 60 Hz, < 2.5A
Network8P8c modular connector; ‘RJ-45’ type (100bT, Cat5)
USB1 x type-B chassis socket, 4 x type-A chassis sockets
TerminalRS232, 9-pin sub-D (SSL diagnostic use only)
External InBalanced, 3-pin XLR-F, Zi > 10k
Pre-amp InBalanced, 3-pin XLR-F, Zi ≈ 1k2/10k
Balanced, 1/4" stereo jack socket, Zi > 10k/1M
Pre-amp, Monitor OutBalanced, 3-pin XLR-M, Zo ≈ 100Ω
Monitor –10dBVUnbalanced, phono (RCA) socket, Zo ≈ 100Ω
InsertsBalanced, stereo 1/4" jack socket, Zi > 10kΩ, Zo ≈ 100Ω
HeadphonesStereo 1/4" jack socket, Zo ≈ 75Ω
FootswitchStereo 1/4" jack socket (2 circuits)
iJackStereo 3.5mm jack socket, Zi ≈ 10k
Performance Specification
Frequency Response(+/- 0.1db 20-20kHz)
THD +N (1kHz)0.001% @ +24 dBU
Soundcard Specs44.1kHz-192kHz - 24 Bit
Max Headroom (INPUT)+26 dBU
Max Headroom (OUTPUT)+25 dBU
Dynamic Range>115dB A weighted
Equivalent Input Noise-128dBU A weighted
System Requirements
Macintosh
  • Intel only, 1.2GHz or faster
  • OS X Version 10.5.8 or greater (‘Leopard’ or ‘Snow Leopard’) (32bit only)
Windows
  • Pentium IV or equivalent, 1GHz or faster
  • Windows XP SP3, Vista SP1 or higher, or Windows 7 (32 or 64bit)
  • 512MB RAM
  • 15MB Hard Disk space
  • VGA colour screen (1024 x 768 pixels or higher)
  • Internet connection (for product registration and software upgrade)
6504
发表于 2007-11-4 20:17:28 | 显示全部楼层
学习学习:victory:
4万
音频应用中级会员
Rank: 5Rank: 5Rank: 5
发表于 2007-12-2 20:11:48 | 显示全部楼层
GMT+8, 2025-9-5 03:40 , Processed in 0.030153 second(s), 7 queries , Redis On.
