Steinberg Dorico 打谱软件
Dorico 可帮助您编写乐谱,自动生成卓越品质的打印结果 – 并以惊人的真实感进行回放。它对任何人来说都很容易学习,但具有数百种高级符号、功能、选项和声音,即使是最苛刻的专业人士也能满足。
你可以用 Dorico 做什么?
撰写
使用 Dorico 可以更快、更高效地创作、编曲——或者只是编写和打印音乐。由于其智能设计,它会在您书写时自动调整符号。由于包含近 1,500 种声音,编曲可以非常逼真地播放,并且不需要高级记谱法的变通方法,Dorico 可以比以前更快地产生出色的结果。
凭借其流线型、自然的用户界面,学生和乐谱经验较少的人可以直接在 Dorico 中作曲和编曲,从而更快、更直观地学习乐谱语言。编辑和进行更改(例如乐器、拍号或调号)非常简单,记谱法会立即正确地适应以包含它们,从而增强学习成果。对于教师来说,制作混合音乐和文本的教材和讲义很容易,而且为您的乐队、管弦乐队或其他学校合奏改编安排从未如此快捷。
Dorico 是音乐雕刻、出版和复制的完美工具。它自动布局平衡和美丽的页面,具有全面的防撞和高级算法,可以轻松处理几乎任何音乐上下文。使用 Dorico 制作的音乐具有最好的传统雕刻音乐的外观,并且该软件提供了调整工具以满足最苛刻的专业人士的需求。为销售或业绩制作高质量、清晰的分数从未如此快捷或容易。
Dorico helps you to write music notation, automatically producing printed results of exceptional quality – and plays it back with breathtaking realism. It is easy enough for anyone to learn, yet has hundreds of advanced notations, features, options and sounds to satisfy even the most demanding professionals.
What you can do with Dorico?
Compose
Composing, arranging – or just writing and printing out music – is made much quicker and more efficient with Dorico. Thanks to its intelligent design, it automatically adjusts the notation as you write. With nearly 1,500 sounds included, arrangements can be played back with exceptional realism and, with no workarounds needed for advanced notation, Dorico produces excellent results much more quickly than has been possible before.
Learn
With its streamlined, natural user interface, students and those with less experience in scoring can compose and arrange straight into Dorico, making learning the language of music notation much faster and more intuitive. Editing and making changes — such as instrument, time signature or key — are straightforward, with the notation instantly and correctly adapting to include them, reinforcing the learning outcome. For teachers, producing teaching materials and hand-outs that mix music and text is easy, and it’s never been quicker to adapt arrangements for your band, orchestra or other school ensemble.
Publish
Dorico is the perfect tool for music engraving, publishing and copying. It automatically lays out pages of balance and beauty, with comprehensive collision avoidance and advanced algorithms that handle almost any musical context with ease. Music made with Dorico has the look of the finest traditionally engraved music, and the software provides tweaking tools to satisfy the most demanding professional. Producing high-quality, crystal-clear scores for selling or performance has never been faster or easier. |
