楼主 |
发表于 2004-12-26 01:14:00
显示全部楼层
还有你用着鼠标点来点去的是不是很麻烦,如果结合键盘使用就更快捷了,下面介绍一些常用快捷键:
*或.--------------[附点]
R-----------------[休止符]
/-----------------[三分音符]
L-----------------[连音]
Ctrl+L------------[连拍子]
C-----------------[复制拍/三连音 至本小节]
lnsert------------[插入一拍(是休止符)
Delete------------[删除音符/休止符]
Ctrl+X------------[剪切小节]
Ctrl+C------------[拷贝小节]
Ctrl+V------------[粘贴小节]
Ctrl+Ins----------[插入小节]
Ctrl+SHIFT+Ins----[插入音轨]
Ctrl--------------SHIFT Sup[删除音轨]
F5----------------Score Information(乐谱信息)
F6----------------音轨属性
F10 --------------综合参数变化表
[H]---------------Hammer on / Pull off[击弦]
[S]---------------Slide Up / Down[滑音(上或下)]
---------------Bend[推放弦]
[A]---------------Chord[和弦图]
[T]---------------Text[注解]
[V]---------------Vibrato[左手颤音]
[F]---------------Fade in[渐强(符号为<)]
[X]---------------Dead note[闷音]
---------------Let Ring [延长发音]
[G]---------------Grace note[装饰音]
[Ctrl U]----------Upstroke[扫弦音长(上扫)]
[Ctrl D]----------Downstroke[扫弦音长(下扫)]
[Enter] ----------Next note[下一音符]
[Home]------------First beat of the bar[本小节的最开始]
[End]-------------Last beat of the bar[本小节的最末端]
[Ctrl+←]---------Previous bar[前一小节]
[Ctrl+→]---------Next bar[下一小节]
[Ctrl Home]-------First bar[第一小节]
[Ctrl End]--------Last bar[做后一小节]
[Ctrl+↓]---------Next track[下一个音轨]
[Ctrl+↑]---------Previous track[上一个音轨]
[Ctrl+SHIFT+↓]---Last track[最后一个音轨]
[Ctrl+SHIFT+↑]---First track[最前一个音轨]
Space bar[空格]---Play / Stop[播放/暂停]
[F9]--------------Speed Trainer速度教练
[Ctrl+N]----------New[新建]
[Ctrl+O]----------Open[打开]
[Ctrl+B]----------Browser[浏览器]
[Ctrl+S]----------Save[存储]
[Ctrl+P]----------Print[打印]
[F1]--------------Help[帮助]
[F9]--------------Preferences[参数选择]
打击乐器最常用的几个
31 - stick[敲鼓棰]
36 - bass drum[底鼓]
40 - snare drum[军鼓]
41, 43, 45, 47, 48 - toms, from low to high[通鼓,从低到高]
42, 44, 46 - respectively[分别为]: closed charleston[闭合踩镲], charleston pedal[踩住踩镲], open charleston[镲弓(踩镲边)]
51, 53 - cymbals[吊镲], dome et body[镲帽]
54 - tambourine[小手鼓]
49, 57 - crachs, two sounds[高低吊镲]
