Spitfire Audio PP018 DC Noisemaker KONTAKT
这是一套真正而深刻的神秘乐器,其中有令人难以忘怀的音乐作品,由David Coulter执导,由Martyn Ware制作。可能是Spitfire库中尚未呈现的最原始的一组声音。这是一次性的!
与所有生产商组合产品一样,DC Noisemaker已在干燥环境中进行记录,以便为您提供最终控制。有许多麦克风和混音可以为您提供不同的视角,每个乐器都加载了一系列按键“关节”,让您可以最终控制您的艺术方向。我们还有一系列策划的“Mercury Synth”预设,可让您快速灵感地演奏David的乐器,并且非常容易调整声音选项和效果。
当接近音乐剧时,我们获得了创造工匠小提琴和工匠大提琴的经验,从大卫的演奏和乐器中获得最大的个性。这些不同的乐器特定关节组合巧妙地组合成一个“演奏补丁”,响应你的演奏,这样你就不会演奏大卫的乐器,你正在扮演大卫演奏大卫的乐器!
原文
A truly and deeply cool set of esoteric instruments with the haunting musical saw at the centrepiece, performed by David Coulter and produced by Martyn Ware. Possibly the most original set of sounds yet to be presented in a Spitfire library. This is a one off!
As with all producer portfolio products, DC Noisemaker has been recorded in a dry environment to give you ultimate control. There are a number of mics and mixes to give you different perspectives and each instrument loads with a series of keyswitched "articulations" to give you ultimate control over your artistic direction. We also have a series of curated "Mercury Synth" presets which give you quick and inspiring takes on David's instruments with very easy to tweak sonic options and effects.
When approaching the musical saw we took experience garnered creating the Artisan Violin and Artisan Cello to get the most personality out of David's playing and instruments. These differing set of instrument specific articulations have been ingeniously combined into a "performance patch" that responds to your playing so that you're not playing David's instruments, you're playing David playing David's instruments!
Spitfire Audio PP018 DC Noisemaker KONTAKT | 4.14 Gb
下载地址: |
