AEA KU4 超指向铝带话筒
! Q: E' z9 T# n/ }& W
& }/ X; F; H/ m' o
P% T# x2 {3 P% r: }基于经典的更新版!, K' @+ K8 z W* e: G
% z3 l2 V# ?4 j G$ N, M. OMade from authentic new old stock RCA materials, the AEA KU4 is a modern revival of the legendary RCA unidirectional KU3A. This high-sensitivity ribbon microphone was originally designed for top-end Hollywood movie studios. Fewer than 600 KU3As were ever made, and those few engineers who were lucky enough to use them simply raved about their smooth sound, wide sweet spot, and minimal proximity effect. Now, the KU4 lets you experience this amazing mic in your own studio!
/ [3 n& ~8 W, g, M8 r& | G: k& p4 c' _5 z0 h; K3 k! }
AEA KU4 Unidirectional Ribbon Mic Features:1 E0 \( p7 s! O2 R) y* r. l/ C
' j* _1 E' y+ b1 CContemporary realization of the RCA KU3A classic8 C6 C) n" }/ Y& @# u) N. x
! v0 i; H) g* A- r0 G
Supercardioid pattern for excellent rear rejection% g) N1 ]2 [/ N3 F0 V( I
( f! E$ x o# Y# T" s
Reduced proximity effect
, V: ^! y& k4 \) f; U! n4 z' X, i U
Smooth, high-bandwidth frequency response
' A5 B: p) V$ [0 o' L6 c
3 F/ G' K8 I+ ?+ C0 M( ZAuthentic New Old Stock RCA ribbon material
6 _5 q: L8 o0 H; g+ L; `
) y; a' P& T d- fHigh-quality anodized & nickel-plated finish" U8 C8 X' [- _4 ]4 z9 p
8 n- P L( u u. o, L2 g& kCustom AEA transformer, neodymium magnets; q" S) w) I0 j# h) ~0 ^
, s9 x: u( S; \/ T) `8 I$ kConsistent Quality- F5 J! a5 Z- M; [$ d7 Z8 X
( i7 V, d/ J h+ b9 r' jField-tech replaceable ribbon assembly
& ~- I8 Z" @ J, G3 k3 N, B, S) p, y- S
Hand-crafted in Pasadena, California
9 t2 P- U5 G/ u8 P+ a9 I' ?/ A4 ]$ a' h7 Q. f/ I7 c
7 N+ G; M% `' n% x: J& y
* W( I) L* a" p# _9 s+ bTech Specs: ~3 V# j7 ~; `- n
2 a5 C- P9 `2 V2 [1 ]! S LMicrophone Type | Ribbon | Polar Pattern | Supercardioid | Ribbon Type | Aluminum, 1.8 microns Thick, 2.1mm x 28.6mm | Frequency Response | 30Hz-20kHz | Max SPL | 140dB SPL | Output Impedance | 300 ohms | Connector | XLR | Weight | 4.7 lbs. | Included Accessories | Stand adapter, Case |
/ Y1 ?3 O/ X k( q0 P |
