查看: 17479|回复: 0
打印 上一主题 下一主题
[资讯] HitPaw Object Remover [1.0.0.16] 多语言免费下载
跳转到指定楼层
1#
发表于 2022-10-1 15:49:19 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Freely and intelligently remove unwanted objects from video with the help of HitPaw Object Remover. This smart tool will automatically track the object’s movements with AI Power.
Remove Object from Video with AI Power
• Remove unwanted objects, people, and clutter in 3 seconds
• Automatically track and identify the object movement with AI-recognition
• Easily remove background of video in 1-2-3 steps
• Accurately adjust the removed area with the magic selection brush
Intelligently Remove Unwanted Objects from Video
Get in trouble with unwanted objects in your video? With this stunning object eraser, things will become easier when you want to remove object from your video background. The AI technology will lock the object trajectory automatically, and restore the details in video background, so as to perfectly remove the whole lot in one go.
Easily Remove People from Background in Video
• Without bidding farewell to the past, how to look for the possible future? This smartest AI object remover will clean up and sweep the EX-partner from your favorite video as if they were never there.
• Get this best people remover tool and take the boldest shot. By automatically locking the movement of the unwelcomed tourist, our powerful removal feature will bring your video to the flawless effect you desired.
HitPaw Object Remover [1.0.0.16] 多语言免费下载.txt (266 Bytes, 下载次数: 0)
Miraculously Remove Background in Video Like a Charm
Get away from the headache caused by messy background of a video with the help of HitPaw Object Remover. Download and try this amazing background eraser to remove the background of video, and you can easily change your background to be transparent or just keep a green screen filling of the video background. One click, and things better.
