查看: 18957|回复: 0
[资讯] Accusonus ERA 5 Bundle Pro v6.2.00 Mac
发表于 2022-7-8 23:14:58 | 显示全部楼层 |阅读模式
Accusonus ERA 5 Bundle Pro Crack v6.2.00 Mac + Torrent Free Download [Latest]
Accusonus ERA 5 Bundle Pro Crack Next-generation multi-proprietary audio repair tools that provide fast, high-quality processing. As a professional in music post-production and production, you face impossible deadlines. Our smart tools will help you save a lot of study time by doing most of the work for you. Access to the fastest resolution technology for complex audio problems.
Salvage tracks which cannot be recorded again. Save tons of time in editing. Clean your tracks with no artifacts in a fraction of the time. The ERA Bundle Pro features 13 powerful plugins to help you tackle all the audio issues you routinely face. Whether you work with video, film, podcasts, voice-overs, broadcast, streaming, or music production, the ERA plugins will help you get the job done in seconds.
Accusonus ERA Bundle Pro Crack + Full Torrent [100% Working]
Accusonus Inc., a company specializing in creating music programs based on artificial intelligence, has released a set of plug-ins for audio restoration Accusonus ERA Bundle. ERA Bundle (Enhancement and Repair of Audio) is a set of easy-to-use VST / AU / AAX plugins for processing, repairing, and repairing problem audio signals. This multi-patented next-gen audio repair bundle offers processing that’s both fast and high-quality. The engineers at Sweetwater have found the ERA Bundle Standard to be a worthwhile addition to our restoration toolboxes. If you’ve got damaged audio and time is at a premium, the ERA Bundle Standard is a great-sounding, time-saving solution.
Audio restoration is a time-consuming endeavor. Unfortunately, time is often in short supply. If that describes your situation, you need the Accusonus ERA Bundle Standard. This multi-patented next-gen audio repair bundle offers processing that’s both fast and high-quality. The engineers at Sweetwater have found the ERA Bundle Standard to be a worthwhile addition to our restoration toolboxes. If you’ve got damaged audio and time is at a premium, the ERA Bundle Standard is a great-sounding, time-saving solution.
Accusonus ERA 5 Bundle Pro Key Features:
De-Esser Pro
  • ERA De-Esser Pro is a sophisticated, yet fast and easy to use audio effect plug-in. It offers precision-grade de-essing and customizable audio repair functionality. Based on the multi-patented accusonus algorithms, De-Esser Pro simply works and allows for efficient sibilance removal from audio recordings.
ERA-D
ERA-D focuses on two things and does them exceptionally well. When you need deep and sophisticated denoise and dereverberation, ERA-D is the tool for you.
  • Multi-patented algorithms for Denoise and Dereverberation
  • The intelligent joint mode takes the natural noise and reverb counter-interaction into account for higher quality sonic results.
  • Dual-Channel mode that enables you to use a secondary mic to improve the audio repair quality on your primary mic.
Noise Remover
  • Noise happens, but you don’t have to settle! Use the ERA Noise Remover to easily reduce or completely remove unwanted fans, air-conditioners, electric hum & hiss, or any other background noise. It’s as simple as turning a single knob.
Reverb Remover
  • Reverb is the unavoidable result of room acoustics. It can make your audio sound distant, “echoey” or hollow. Get the single-knob ERA Reverb Remover to quickly reduce excessive reverb and bring your sound into focus. Add clarity, clean up your dialogue or tighten up your musical performance.
Voice Leveller
  • Gain inconsistencies are common in both audio and video recordings. They often happen as a result of intentional or unintentional speaker movement, non-ideal microphone positioning or heavy audio & video editing. Use this single-knob plugin to save yourself from hours of manual gain adjustments.
De-Esser
  • Harsh sibilance can be very annoying both in dialogue and vocal recordings. The ERA De-Esser is an easy-to-use single-knob plugin that allows you to smooth out audio problems caused by excessive sibilance consonants (such as “s”, “z”, “ch”, “j” and “sh”). Improve the quality of your audio with a single knob.
Plosive Remover
  • Plosives (or p-pops) usually occur due to non-ideal microphone placement and can sound really distracting. Turn the knob of the ERA Plosive Remover to instantly fix unnatural plosive thumps (such as “p”, “t” and “b”). Make your vocal and dialogue tracks sound great!
De-Clipper
  • Clipping results from over-saturation and usually sounds like a harsh distortion. Looking at the loud parts of your waveform, you can see clippings as blocks of audio that are chopped off. Repair your clipped audio in seconds.
More Features:
  • Additionally, ERA-D comes in handy when you need deep as well as sophisticated denoise and dereverberation.
  • Plosive Remover removes the plosives which is a complex type of distortion.
  • An impressive multi-patented and next-generation audio repair tools that offer you fast as well as very high-quality processing.
  • Noise Remover is an impressive application for denoising which automatically estimates the noise profile and lets you adjust background noise.
  • It is around many different tools to add, say, music, which includes medieval-D.\n sounds to remove, reverb, signal phone, signal phone goods of the de-Esser, the sound of the equalizer, and De-haircuts, etc.
  • The De – clipper is a program that will allow you to repair&album title: sounds in no time.
  • Voice Leveler lets you adjust the gains automatically which produces due to the unintentional speaker movement.
  • De-user is the program that will smooth out the process of your history.
  • Reverb Remover estimates the reverberation profile and lets you adjust the amount t of the recorded reverb in the interface.
Including Plugins:
  • Noise Remover
  • Reverb Remover
  • AutoEQ, Leveler
  • Deepener
  • Clean-Up Assistant
  • DeEsser
  • Plosive Remover
  • De-Clipper
  • Noise Remover Pro
  • Reverb Remover Pro,
  • DeEsser Pro
  • RoomTone Match
System Requirements:
  • OS You will Need To Run this App: Windows 7/8/8.1/10
  • You will Need HDD Space: 100 MB of free space required.
  • Random Access Memory [RAM]: 2 GB of RAM required.
  • Central Processing Unit [CPU]: Intel Pentium 4 or later.
https://vstmacs.com/accusonus-era-5-bundle-pro-crack/
GMT+8, 2025-7-16 18:09 , Processed in 0.028135 second(s), 10 queries , Redis On.
