查看: 14418|回复: 0
[Sawstudio] Celemony Melodyne Studio 修音软件应用程序
发表于 2022-5-5 16:23:34 | 显示全部楼层 |阅读模式
Cele Celemony Melodyne Studio 修音软件应用程序
Melodyne 是一款软件应用程序,您可以通过它以前所未有的音乐方式编辑音频。在 Melodyne 中,您使用的是音符——而不是无意义的波形。您不仅可以看到音乐在哪里变大或变小,还可以看到音符在哪里开始和结束,以及它们的音高。
您可以修改每个音符,从而直接影响语调、乐句和动态——不仅可以使用人声和单音乐器,还可以使用钢琴和吉他等复音乐器。与 Melodyne 合作就像能够对歌手说“把这个音符唱久一点”,或者对钢琴家说“在这个和弦中给第三个音稍微轻一点”——在录音之后的几个小时、几周甚至几年。
完整的旋律。 Melodyne 5 studio 为您提供所有 Melodyne 功能,用于在无限数量的轨道上进行校正和创意应用。您可以以如此直观的方式编辑录音的声音和音乐内容,或者在没有其他音频工具的情况下进行如此深远的更改。
整个 Melodyne 家族的新技术和新的自由度。 Celemony 正在发布其传奇音频软件 Melodyne 的第 5 版。这是公司历史上对整个产品系列的最广泛更新,重点是 Melodyne 5 studio。
亮点包括具有全新声音设计可能性的声音编辑器、DNA 直接音符访问 – 最后,在无限数量的轨道上 – 以及超准确的速度检测。此外,Melodyne 5 studio 现在还可以直接作为插件在您的 DAW 中运行——当然,也可以在 64 位分辨率下运行。较小的 Melodyne 版本(编辑器、助手和基本版)也得到了增强。
Melodyne is a software application which you can edit audio in a more musical way than was ever thought possible. In Melodyne, you work with notes – and not with a meaningless wave form. You don’t just see where the music gets louder or quieter but also where notes begin and end and at what pitch they lie.
You can modify each note and thereby influence directly the intonation, phrasing and dynamics – and do this not only with vocals and monophonic instruments but with polyphonic instruments such as pianos and guitars as well. Working with Melodyne is like being able to say to a vocalist “sing this note a bit longer” or to a pianist “give slightly less weight to the third in this chord” – hours, weeks, even years after the recording session.
The complete Melodyne. Melodyne 5 studio offers you all Melodyne functions for both correction and creative applications on an unlimited number of tracks. You can edit the sound and musical content of your recordings in such an intuitive manner or make such far-reaching changes with no other audio tool.
New technologies and a new degree of freedom for the entire Melodyne family. Celemony is releasing Version 5 of its legendary audio software Melodyne. This constitutes the most extensive update to the entire product family in the company’s history, with the emphasis on Melodyne 5 studio.
Highlights include the Sound Editor with its totally new sound design possibilities, DNA Direct Note Access – at last, on an unlimited number of tracks – and ultra-accurate tempo detection. Furthermore, Melodyne 5 studio now also runs directly as a plug-in within your DAW – also, naturally, in 64-bit resolution. The smaller Melodyne editions – editor, assistant and essential – have also been enhanced.
https://4download.net/tags/VST%20Plugins/
GMT+8, 2025-6-2 21:57 , Processed in 0.025469 second(s), 8 queries , Redis On.
