Lamprey Oracle Ambient Guitars Volume 2 KONTAKT-FANTASTiC 合成吉他
Oracle Volume 2 是对我原来的 Oracle – Ambient Guitars 库的完全重新想象。
我采用了水洗、混响吉他的概念,并通过更强大的引擎和集成的声音设置为它注入了新的活力。从可用的 18 个音库中加载最多两个音库,并使用 XY Pad 在它们之间无缝融合。调整 ADSR Envelopes 并将 FX 路由到 Y 轴以根据需要塑造声音。
它包含 40 个手工制作的预设,可帮助您快速启动创意。或者只是使用即时随机按钮来制作一个全新的补丁。
为了透明:Oracle 2 重新利用了我以前库中的示例。
特征
18 个可用的音库:
Oracle 2 带有 18 个音库,包括电吉他、贝斯、原声、泛音和各种处理垫。
随机化任何东西:
Random Pluck 和 Random Pad 按钮创建一个新的 Patch,其设置与其同名。效果页面还有一个随机化按钮。即时创意。
包括 10 个 Kontakt FX:
混响、延迟、滤波器、两个失真、合唱、镶边、Lofi 和均衡器。拥有美丽、郁郁葱葱的氛围所需的一切。
完全控制:
在两个样本之间变形并调整它们的 ADSR 包络并随心所欲地开始位置。然后将效果路由到 Y 轴并播放!
自动运动:
Chaos 滑块为 XY Pad 添加随机运动,让您可以在声音变形时使用其他控件进行演奏。
Oracle Volume 2 is a complete re-imagining of my original Oracle – Ambient Guitars library.
I took the concept of washy, reverberated guitars and breathed new life into it with a far more powerful engine and integrated soundset. Load up to two soundbanks from the available 18 and seamlessly blend between them using the XY Pad. Adjust ADSR Envelopes and route FX to the Y Axis to shape the sound however you want.
It comes included with 40 hand-crafted presets to help jumpstart your creative ideas. Or just use the instant Random buttons to make a brand new patch.
FOR TRANSPARENCY: Oracle 2 repurposes samples from my previous libraries.
FEATURES
18 Available Soundbanks:
Oracle 2 comes with 18 sound banks, including picked electric guitar, bass, acoustic, harmonics and assorted processed pads.
Randomize Anything:
The Random Pluck and Random Pad buttons create a new patch with settings appropriate to their namesake. The Effects Page also has a randomize button. Instant creativity.
Includes 10 Kontakt FX:
Reverb, Delay, Filter, Two Distortions, Chorus, Flanger, Lofi and EQ. Everything you need for beautiful, lush ambiences.
Complete Control:
Morph between two samples and adjust their ADSR Envelopes and start positions at a whim. Then route effects to the Y axis and play around!
Automatic Movement:
The Chaos slider adds random movement to the XY Pad, allowing you to play with other controls while the sound morphs.
home page
https://bit.ly/3a1PVgs |
